Hello guys,
I created a palette, but when I click on an entry, the following occurs:
If the entry line, where the mouse cursor is, is empty, insertion takes place on this line.
If the input line has any expression and the mouse cursor is to the left of the expression, insertion takes place on the line above.
If the input line has any expression and the mouse cursor is to the right of the expression, insertion takes place on the line below.
Does anyone know how to fix this?
Sincerely,
Oliveira
Before answering, Please Note,
Do not suggest I use
maple <filename.maple>
The conversion in maple to convert an ".mw" file in xmaple for a text file to be executed with
maple command
does not work and I therefore need a way to execute and operate a ".mw" workksheet straight in terminal without the need for X.
This is a Linux based question.
I have batches of about 50 maple processes that I run in parallel accross several 32-core and 64-core servers.
I am not using the built in spawning process commands, but rather run a new instance of maple.
Some of these batches need to be developed in xmaple it is just not feasable to do it in a text editor to be executed by "maple"
QUESTION:
Is there any switches in maple that I can run a ".mw" maple file as a terminal operation without starting the interface ?
e.g. how can I run
xmaple <mystery switches> maplefile.mw   such that the interface doesnt load but the file is executed completely in terminal without the need for X.
So I have a problem when copying multiple output from Maple to Word. I am using a simple example here.
When I copy each part of the output as an image SEPERATELY, it comes out much cleaner than if I highlight everything together and then copy. Is there a reason this is the case and is there a way to fix this problem?
Here is the Maple Code:
with(plottools);
with(plots);
ttt1 := textplot([0, 1, "3  +  5  =  __", color = "black", font = ["Arial", "bold", 120]]);
display(ttt1, size = [1000, 200], axes = none);
ttt1 := textplot([0, 1, "1  +  3  =  __", color = "black", font = ["Arial", "bold", 120]]);
I also uploaded the Maple Worksheet
Here is the output:
There are TWO imges in the output in this example. I tried copying both together and pasting them, and then I tried copying them individually. The output is very different in quality.
The one copied alot is much cleaner once copied and pasted in Word. Does anyone why this is happening? I don't want to have to copy images individally for obvoius reasons. I know this example is only two images but what if there was alot more, etc.
with(plottools); with(plots); ttt1 := textplot([0, 1, "3  +  5  =  __", color = "black", font = ["Arial", "bold", 120]]); display(ttt1, size = [1000, 200], axes = none); ttt1 := textplot([0, 1, "1  +  3  =  __", color = "black", font = ["Arial", "bold", 120]]); display(ttt1, size = [1000, 200], axes = none)
Download Copy_Images.mw
    I am manually re-creating the TS diagram for phase plot of fluid=air for use in a report as a pretty plot.   The TemperatureEntropyChart function is colored in grayscale.  I really need to change to colorized for additional data being added.
   The code to generate the various isobars color gradient is shadebetween two curves.
    Using the code method to plot leaves white gaps in the discontinutiy of the plot curves returned from the Property function at the liquid and vapor lines.   I have manually connected the horizontal "under the dome" in a matrix of X,Y for each of two isobar curves.
   However, the shadebetween doesn't seem to like the two X,Y matrices for the curves as inputs to shadebetween.
    So,...   Q:   1.)  Can the color be changed using the TempertureEntropyChart function,..or
                      2.)  Can matrices of unequal X,Y values (scatterplot type data sets) be used for the curves in shadebetween command?  The help infers the Y (v, of (u,v))  values need to match.
Bill
Ref:    worksheet contained at:  https://www.mapleprimes.com/maplesoftblog/203462-Computing-With-Thermophysical-Data
Hello guys
Could someone help me create a simple palette to contain, for example, three functions that I use constantly?
           conve1(a), conve2(a) and conve3(a).
I tried through the help documentation, but I couldn't.
Sincerely,
Oliveira
I was having this problem with Maple Flow 2021, and just purchased Maple Flow 2022 but am still having this problem.
I define a variable, using := and an equation (that itself uses other variables that have been assigned a numeric value) and end it with an = and it is clear that the variable has a numeric value successfully assigned to it.
Lower down in the document, I use this variable, but it isn't recognized as having any numeric value or having been previously definied at all and when evaluated it stays in symbolic form.
I have tried deleting variables, renaming them without subscripts, retyping equations, etc. and nothing seems to work. Oddly most of the variables work, but some won't even though there doesn't seem to be anything special about them.
Any thoughts or advice would be greatly appreciated.
I have just installed the Google Maps package but when I run the commands I only get empty results and some errors
Any thoughts of what can be wrong. Have latest Montery OSX
/Anders
Mathematica's Dimensions returns a list of the allowed levels, which has been implemented in Maple as . But
MmaTranslator:-Mma:-Dimensions(<<1 | 2>, <1 | 0>>);
returns [6], and
MmaTranslator:-Mma:-Dimensions([[1, 2], [1, 0]]);
returns [2, 2, 4]. What happened here?
It should be [2, 2].
MmaTranslator:-Mma:-Dimensions(linalg[matrix]([[1, 2], [1, 0]]));
[0]
MmaTranslator:-Mma:-Dimensions(< 1 , 2 ; 1 , 0 >);
[6]
MmaTranslator:-Mma:-Dimensions(convert(`{{1, 2}, {1, 0}}`, FromMma));
[2, 2, 4]
MmaTranslator:-FromMma(`Dimensions[{{1, 2}, {1, 0}}]`, evaluate);
[2, 2]
Download Mma[Dimensions].mws
Hi Everyone,
I intend to find the invariants of a 2nd-order Tensor using the representation of the rotational group as an Infinitesimal generator. However, maple does not seem to find the correct invariants $\tr \mathbf{a}$, $\tr \mathbf{a}^2$, $\tr \mathbf{a}^3$. Maple only returns an empty set. I can't seem to figure out why that is the case.
Here is my code
with(PDETools)
assume(r >= 0)
interface(showassumed = 0)
X_z2 := (-a__21-a__12)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__11))+(a__11-a__22)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__12))-a__23*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__13))+(a__11-a__22)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__21))+(a__12+a__21)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__22))+a__13*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__23))-a__32*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__31))+a__31*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__32)) = 0
X_y2 := (-a__31-a__13)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__11))-a__32*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__12))+(a__11-a__33)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__13))-a__23*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__21))+a__21*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__23))+(a__11-a__33)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__31))+a__12*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__32))+(a__13+a__31)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__33)) = 0
X_x2 := -a__13*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__12))+a__12*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__13))-a__31*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__21))+(-a__32-a__23)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__22))+(a__22-a__33)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__23))+a__21*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__31))+(a__22-a__33)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__32))+(a__23+a__32)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__33)) = 0
sys := [X_z2, X_y2, X_x2]
sol := pdsolve(sys)
Download SO(3)_spherical_2.mw
Any input would be appreciated!
I just wrote up a bug report (aka "Software Change Request") but got a "We are currently experiencing technical difficulties" error so the report is not being sent.
I will just post here about the bug in case anyone knows what it is.
I am going through the Multivariate Calculus Study Guide. I went to section 1.1, and was going through the examples. At the end of an example is a link "Next Example", but when I click this I get an error and have to go back to section 1.1 Table of Contents. Kind of annoying. Also, I notice that Maple simply crashes seemingly randomly when going through this study guide. Very annoying.
Here is a screenshot of the write-up to the bug report service that isn't working, for the record
I was wondering if this is something wrong with my Maple installation or if other people experience it too.
I embed Maple code in Mobius for test questions. A simple 2-step CRR tree gives significantly different answer from the calculated by hand or by R's fOptions. Here is the piece of Mobius/Maple:
$ct = maple("
    with(Finance):
    S0:=50; X:=50; Ty:=6./12; r:=0.07; sig:=0.3156; n:=1;
    dt := Ty/n;
    u  := exp(sig*sqrt(dt));
    d  := 1/u;
    pu := (exp(r*dt) - d)/(u - d);
    pd := 1 - pu;
    BT := BinomialTree(Ty,n,S0,u,pu,d,pd);
    cT := ST -> max(ST - $X,0);
    Ec := EuropeanOption(cT, $Ty):
    LatticePrice(Ec,BT,$r);
The answer is: 6.545478168.  Exactly the same with BlackScholesBinomialTree
The correct answer should be 6.32
In this case the solution by hand is simply e^(-0.07*05)*0.5236*$12.50
R confirms 6.32:
CRRBinomialTreeOption(TypeFlag = "ce", S=S, X=X, Time=T, r=r, b=b, sigma=sig, n=n)@price
The error decreases with the increase of number of steps. All quantities before LatticePrice are calculated corectly. Any idea of what the reason might be?
Dear,
I would like to do equation of motion calculations using spin matrices.
I would like to do calculations using the  coupling.
Thanks for listening.
I'm trying to use Maple to take the following integral for positive values of a, b, c and non-negative integers i and j.
I know that for fixed values of j and k this doable — for example, for j=k=0 Mathematica gives
I'm trying the following code in Maple:
int(exp(-(x + y)/2)/(a*x + b*y + c), [x = 0 .. infinity, y = 0 .. infinity]) assuming (a::real, 0 < a, b::real, 0 < b, c::real, 0 < c)
Am I doing anything wrong?
Hi dears
I have a pde system and want to get the solution of this system step by step. is there any command or bunch of commands that could help me?
(pde = partial differential equations)
simplify(sqrt((x^2 + y^2)/x)/sqrt(x^2 + y^2)) assuming x>0, y>0
is not sqrt(1/x), why?
First 63 64 65 66 67 68 69 Last Page 65 of 371
