Hello;
Hope you are fine. I need to learn how can I call my code in the other file of maple, define new value for A and can get results. For this purpose, I just take an simple example as
questionmaple.mw
restart; A := 5; B := 10; AAA[0] := 10; for i from 0 while i <= A do AAA[i+1] := B*i*AAA[0] end do
10
10
100
200
300
400
500
Download questionmaple.mw
I would like to read data from a google sheet document. I can download a local copy to excel format, but then I'm no longer tied to the origional file.
MyPackageTools := module()
    option package;
    export addPackageDirectoryToLibname, savePackageToMla;
    addPackageDirectoryToLibname := proc(packageDir)
        local mapleInitFile, newLibname:
        mapleInitFile := "/Library/Frameworks/Maple.framework/Versions/2022/lib/init":
        try
            FileTools:-Text:-Open(mapleInitFile, 'append'):
        catch:
            return "Failed to open file":
        end:
        try
            newLibname := cat("libname := \"", packageDir, "\", libname:" ):
            FileTools:-Text:-WriteLine(mapleInitFile, newLibname):
        catch:
            FileTools:-Text:-Close(mapleInitFile):
            return "Failed to write to file.":
        end:
        try
            return "Added to libname successfully. Restart worksheet for changes to come into effect.":
        catch:
            return "Failed to close file":
        end:
    end:
    savePackageToMla := proc(mlaPath, mplPath, packageName)
        read(mplPath);
        LibraryTools:-Save(packageName, mlaPath);
    end:
end:
I'd like to automate my workflow a bit. I having a hard time making savePackageToMla work. The commands inside it are the ones I would run in a Maple worksheet to save a package to an .mla file.
The error I get when I try to use this is
Error, (in LibraryTools:-Save) 1st variable is not a name or equation |/Users/marcusegues/maple/Packages/MyPackageTools/MyPackageTools.mpl:38|
Note that the goal is to pass in an mla path and an mpl path. The mpl file is read. The package that is read is the same as the argument packageName.
I invoke this procedure with something like
savePackageToMla(mlaPath, mplPath, 'MyPackage')
where
mplPath := '/somePath/MyPackage.mpl';
mlaPath := 'somePath/MyPackage.mla';
and MyPackage.mpl contains something like
MyPackage := module()
  option package;
end;
Please help me consider the convergence of this improper integral without using Maple. Thank you so much.
Note: It seems in the course of writing this question I found the answer, but I am still interested in any tips on the best workflow to update a library. Here is the original post (annotated ex post in bold):
I have successully created my own package in Maple. I basically used LibraryTools:-Create to create an .mla file and then I used LibraryTools:-Save, passing in the name of my package and the path to the .mla file. I did this in a worksheet.
I can import it with the command with(MyPackage).
I'd like to add code to the package.
I have a package defined in as
module MyPackage()
  option package;
  export MyModule;
  module MyModule()
  end;
 end;
I would like to add a procedure to be exported inside the package.
I tried to add the procedure, save the file, and then use LibraryTools:-Save again, but the error I get is
Error (in MyPackage) attempting to assign to 'MyPackage' which is protected. Try declaring local 'MyPackage'; see ?protect for details.
I tried to unprotect the name 'MyPackage' but this gives another error
Error, on line %1, unexpected end of input. Error while reading '%1' (this turned out to be a missing semicolon on the Save command, which was the last command in the mpl file. The error messags are quite unhelpful)
Note: As I mentioned before, I did the initial saving of the package from a worksheet (the package code was in a code editing region in the worksheet). In the current attempt to add the new procedure, I copied the code to an .mpl file so I could edit it in a code editor (VSCode). At the end of this file I added the commands to LibraryTools:-Save the package again to the same .mla file as before.
My attempt to unprotect the name "MyPackage" involved simply adding unprotect('MyPackage') as the first line in this .mpl file.
I then used the command read to execute the mpl file from within a worksheet.
What am I doing wrong, and what is the recommended workflow to be able to work on a package?
If I try to update a simple variable in the .mla file it seems to work.
EDIT: The problem seems to be the use of the named module initially, ie module MyPackage().
If I try the whole process again (write a simple package and save it to the mla file) but this time I use the syntax
MyTestPackage = module()
then I can update it no problem (at least for a simple package that I just wrote; for the actual package with my real code I still get even though Maple is able to read the mpl file without a problem, apparently there is still some issue while trying to save.
Error, on line %1, unexpected end of input. Error while reading '%1'   (turns out it was the missing semicolon)
In summary: don't used named module syntax.
Hello guys.
I want to solve Laplace's equation for a triangle plate, subject to the following boundary conditions:
For the contour y = x, u(x,y) =20
For the contour y = -x+2, u(x,y) =100
diff(u(x,y),x,x)+diff(u(x,y),y,y)=0
Oliveira
Hi maple users
I am working with the PDE solver.
i am receiving a following error
"unable to compute solution for t>HFloat(0.0):"
Kindly do the needful how to rectify this error.
dumm.mw
HHow do i correct "error, illegal use of an object as a name"
Dear maple user i am facing difficulty to plot the graph   for different values  of parameter M=2,4  and fixing t=j=0 to 2 and   y=i=0 to 4 on x axis and U on y axis. I am unable to plot 2D . I am enclosing the codes and sample graphs.
# Parameter values:
 Pr:=0.71:E:=1:A:=0:Sc:=0.02: K:=1:
a := 0: b := 1: N := 9:
h := (b-a)/(N+1): k := (b-a)/(N+1):
 lambda:= 1/h^2:  lambda1:= 1/k^2:
# Initial conditions
for i from 0 to N do
  U[i, 0] := h*i+1:
  T[i, 0] := h*i+1:
  C[i, 0] := h*i+1:
# Boundary conditions
for j from 0 to N+1 do
  U[0, j] := exp(A*j*lambda);
  U[N+1, j] := 0;
  T[0, j] := j*lambda1;
  T[N+1, j] := 0;
  C[0, j] := j*lambda1;
  C[N+1, j] := 0
#Discretization Scheme
for i to N do
  for j from 0 to N do
    eq1[i, j]:= lambda1*(U[i, j+1]-U[i, j]) = (Gr/2)*(T[i, j+1]+T[i,j])+(Gr/2)*(C[i, j+1]+C[i,j])+(lambda^2/2)*(U[i-1,j+1]-2*U[i,j+1]+U[i+1,j+1]+U[i-1,j]-2*U[i,j]+U[i+1,j])-(M/2)*(U[i,j+1]+U[i,j]) ;
    eq2[i, j]:= lambda1*(T[i, j+1]-T[i, j]) = (1/Pr)*(lambda^2/2)*(T[i,j+1]-2*T[i,j+1]+T[i+1,j+1]+T[i-1,j]-2*T[i,j]+T[i+1,j])+(E*lambda^2)*((U[i+1,j]-U[i,j])^2);
    eq3[i, j]:= lambda1*(C[i, j+1]-C[i, j]) = (1/Sc)*(lambda^2/2)*(C[i,j+1]-2*C[i,j+1]+C[i+1,j+1]+C[i-1,j]-2*C[i,j]+C[i+1,j])+(K/2)*((C[i,j+1]+C[i,j]))
  end do
# Determine the unknowns in the system
  `union`(  seq(seq( indets( eq1[i,j], name), i=1..N), j=0..N),
            seq(seq( indets( eq2[i,j], name), i=1..N), j=0..N),
            seq(seq( indets( eq3[i,j], name), i=1..N), j=0..N)
# And how many unknowns
   numelems(%);
# And the number of equations
  numelems(eq1)+numelems(eq2)+numelems(eq3);
# So if one supplies values for 'Gr' and 'M', and
# (assuming the equations are consistent), one ought
# to be able to get values for C[1..9, 1..10],
# T[1..9,1..10], and U[1..9,1..10]
# As an example below, choos Gr=1.0 and M=2, then the
# following obtains a 'solution` afer a minute or so
  fsolve( eval( [ seq(seq(eq1[i,j], i=1..N),j=0..N),
                  seq(seq(eq2[i,j], i=1..N),j=0..N),
                  seq(seq(eq3[i,j], i=1..N),j=0..N)
                [Gr=1.0, M=2]
Hi got this set of error using the Plot package. Anyone here know what they mean?
Maple offers the dimension “lenght” whereas MapleSim offers two types.
What is the difference between the two types length and distance?
Can they always be used interchangeably?
Hello community. I'm trying to use Maple for some study.
My goal is to get the Wiener-Hopf equation in matrix form like in the book (eq 3.56).
So at first i need the gradient of eq 3.53, the result is eq 3.55 (nabla is not printed) .
Could you please provide an example of this operation, if it is possible, thanks.
During my reaserch on diffusion I am arrived at the integral with argument
exp(-1/sqrt(x^2 + 1)) which Maple is not able to solve.
If some experts in solving integrals is able to solve it please keep me informed.
The file in Maple 2022 is below
primes_integral_diffusion.mw
Hello everyone!
I use this procedure to open my inbox:
>restart;
ShellExecute := define_external('ShellExecuteA', hwnd::(integer[4]), lpOperation::string, lpFile::string, lpParameters::string, lpDirectory::string, nShowCmd::integer[4], 'RETURN'::integer[4], LIB = "C:\\WINDOWS\\SYSTEM32\\shell32.dll"):
OpenBrowser := proc(someURL::string := "http://")
ShellExecute(0, " ", someURL, " ", " ", 1); NULL;
Case 1:  I entered the correct email address of my friend who sent me the mail
>OpenBrowser("https://mail.google.com/mail/u/0/?tab=rm&ogbl#inbox/xxxxxxGqRZXPKXGzrrSrfHscdNWspRJF");
As a result, the content of the message I received was opened with full information.
Case 2:  When I enter an arbitrary email address that is not my friend, the result is that no content is displayed.
>OpenBrowser("https://mail.google.com/mail/u/0/?tab=rm&ogbl#inbox/yyyyyyGqRZXPKXGzrrSrfHscdNWspRJf");
On the email there is only the message: The conversation you requested could not be loaded.
May I ask:  Is there any Maple command to return true in case 1 and to return false in case 2 ?
Thank you very much for your help !
When I try to change the number format (decimal places) of a sequence in Maple Flow using the right hand slide out context panel all numbers in the sequence are replaced by only the first number in the sequence.  I'm not sure if it has been fixed in 2022.1
Before the adjustment ...
Selecting fixed prompts the result to stop after the first number in the series.
Can anyone else confirm this issue?
First 66 67 68 69 70 71 72 Last Page 68 of 371
