every time we past with windows button + v
it has the form of one liner math input i want to force all pasting to have normal math input !
example
i copy two items and past them (the last one with the windows button)
   a/b,  and x/y
and i get
x/y and a/b
or another example
i want to have a script that ones ran, makes all pasting that contains one liner into normal math
this is not a scrip we need to run at the end or periodically but a package ones loaded changes the way it pastes with the windows button (something like for every past "check IF it is a oneliner IF True, then make it into normal math, else stop)
or change a setting in maple via " := " that forces all math inputs to only be able to exist in normal math, ie. disable one liner math input.
the reason i know this is a setting problem and can be fixed (easily) is this
when we look at the clipboard folder both of them are actually formed by one liner math input. and only the older copyed item has the wrong form when pasting. just take a look at the clipboard folder
when i just use CTRL + V i get the first one (with the correct form), when i use windows button + v and select the second one (i get the second one but in the wrong form)
they dont look the samme (not the letters inside but the form)
so pls help this is a major problem in order to work effectively.
Given a graph G say and a positive integer k
I am in look out how to remove
 edge-disjoint copies of G in G^k
That is edge disjoint copies of G into its power graph all possible ways
Again it is the maximum number of copies I means
Keeping this particular way can someone help kind help please
I will surely acknowledge it
G into to GraphPower(G,k)
the quick brown fox jumps over the lazy dog
Download the_quick_brown_fox_jumps_over_the_lazy_dog.mw
Problem 1)   Give graph G1 and a graph G2  the problem is to extract maximum isomorphic copies of G1 from G2 such that it has no edge intersection maximum number is floor((number of edges of G2)/(number of edges of G1)) and display the Edge sets of those isomorphic graphs and the graph formed by the remaining edges sometimes their may be no remaing edges too.  Need all possible such copies.
Problem 2) Give graph G1 and a graph G2  the problem is to extract maximum isomorphic copies of G1 from G2 such that each copy has  exactly one edge intersection with each of the copies and that one edge intersection occurs only between those two copies and  display the Edge sets of those isomorphic graphs . Need all possible such copies.
If any more examples or explation will give kind help please I can give more examples or more kind please help.
I had written this c++ code years back for problem 2 which i have forgotten kind help if possible to make it better with maplesoft.
Please take your time. Kind help help plese it will be very helpful it is of real help.
orthogonal.txt
I had written this c++ code years back for problem 1 which i have forgotten kind help if possible to make it better with maplesoft.
decom.txt
Need to maintain memory space as graph size is a little big may be
would usage of database or any other be useful dont know I had done those code in c++ long back which i forgotten logic too.
Please please help based on latest technology please take your time and kind help I apologize disturb you kind help.
I would surely acknowledge for this great work as much as I can much more than I can acknowlege too
I am using Maple 2020
Consider the following code:
van_der_Waals := (p + a / V[m]^2) * (V[m] - b) = R * T:
expand(van_der_Waals);
The objective of the exercise is express the equation in a cubic form. Obvious solution is to take the output of the code above and multiplie both sides by V[m]^2. However, I would like to know if there exists a different aproach to get the same result.
simplify is a procedure in Maple that have as parameter an assumption ¿Have the assumption a default value? For example, if we consider the following code:
f:= (x^3 - 27) / (x^2 - 3 * x):
print(f = simplify(f));
The output of that code assume that denominator is not zero, so I think the procedure have a default value for assume parameter.
eval.mw This is the maple worksheet The regions are u<=-1, -1<=u<=1,u>=1
Good day everyone,
Please, I need help on how to optimize the function above. I actually wanted to plot the function with respect to "eta", but, I need the optimum value(s) for "alpha". Anyone with useful information should please help.
Thanking you in anticipation for your help.                                                             f=((-0.111000111e-1*alpha^4+.109890109900000*alpha^3+0.110726700000000e-1*alpha^2+0.133899904900000e-3*alpha+0.136700000000000e-4)*exp(-alpha*eta)+(-0.683733733e-5+0.683733733e-5*alpha^2-0.676896396e-4*alpha)*exp(-2*alpha*eta)+0.111000111e-1*alpha^4-.109890109900000*alpha^3-0.110794990900000e-1*alpha^2-0.663221721200000e-4*alpha-0.683733733200000e-5)/(.1*alpha^5-.99*alpha^4-.1*alpha^3)
About a half hour ago, there was a Post titled "Read binary file" from a new user. I converted it to a Question. Now that I want to Answer the Question, I can't find it. If you are the author of that Question, and you still want an answer, please post it again, but put it in the Questions area.
(I think that there may be a bug in MaplePrimes that makes this happen. I've had it happen several times before.)
Anyway, please respond to this regardless of what you want regarding the Question. That'll help me figure out what went wrong.
When trying to construct objects like SU(3)xSU(2)xU(1), one needs parameters to satisfy SU(n,q)xSU(n,q)xU(n,q).  What are the values of 'q' for these group constructions using the group theory package?
D^γ S(t)=(b-ev)S-α_1 (1-ev)SI_1-α_2 (1-ev)SI_2-dS,
D^γ I_1 (t)=α_1 (1-ev)SI_1-(β_1+d_1+d)I_1,
D^γ I_2 (t)=α_2 (1-ev)SI_2-(β_2+d_2+d) I_2                  ,
D^γ R(t)=β_1 I_1+β_2 I_2+evS-dR
I have maplesim installed and I get the error "Error, `MapleSim` does not evaluate to a module" when I run A:=MapleSim:-LinkModel(); in a Maple worksheet.
Does anyone know how to solve this error?
Hello everybody.
I wrote the attached code. this code gives a good result when "H" parameter is equal to 0.5. Even in this condition if I change other parameters, I can get a true result as well. But when I change "H" parameter to 0.6,0.7,0.8 or 0.9 the code can't be executed anymore and I can't get a result.
based on the paper, for H=0.6,0.7,0.8 or 0.9. we have a result.
what's the problem?
can anyone please help me to solve this problem?
thank you for your help in advance.
1.mw
I have two plots that I want to overlay.  I can do that, but I want the units to be in english units ("lbf" instead of "N" for force).  Individually each plot will switch the units, but the "display" command throws an error!  Help, please.
plot_issue_Flow.zip
Can pacemaker and corosync work with maple?
How to setup pacemaker and Corosync to maple work in Amazon EC2?
i had only one installed License in linux
how to make it work in clusters ?
what is the difference with supercomputing in Amazon ?
which consulting company in Hong Kong can help to use supercomputing in Amazon in my case ? I would like to run batch of batch total 100 script running maple in one instance , but total numbers need to run around 60 years. Any consultant to calculate and setup this supercomputing or pacemaker to make calculations into one day or a few days ?
First 70 71 72 73 74 75 76 Last Page 72 of 371
