Hi.
What wrong could be there with the color line?
equ1 := BesselJ(sqrt(17)/2, 10*sqrt(t)*sqrt(2))/t^(1/4) + BesselY(sqrt(17)/2, 10*sqrt(t)*sqrt(2))/t^(1/4):
equ2 := BesselJ(sqrt(17)/2, 10*sqrt(t)*sqrt(2))/t^(1/4) + 5*BesselY(sqrt(17)/2, 10*sqrt(t)*sqrt(2))/t^(1/4):
equ3 := BesselJ(sqrt(17)/2, 10*sqrt(t))/t^(1/4) + 5*BesselY(sqrt(17)/2, 10*sqrt(t))/t^(1/4):
tmax   := 30:
colors := ["Red", "Violet", "Blue"]:
p1 := plot([equ1, equ2, equ3], t = 0 .. tmax, labels = [t, T[2](t)], tickmarks = [0, 0], labelfont = [TIMES, ITALIC, 12], axes = boxed, color = colors):
ymin := min(op~(1, op~(2, op~(2, [plottools:-getdata(p1)])))):
ymax := max(op~(2, op~(2, op~(2, [plottools:-getdata(p1)])))):
dy   := 2*ymax:
legend1 := typeset(C[3] = 1, ` , `, C[4] = 1, ` , `, Omega^2 = 50):
legend2 := typeset(C[3] = 1, ` , `, C[4] = 5, ` , `, Omega^2 = 50):
legend3 := typeset(C[3] = 1, ` , `, C[4] = 5, ` , `, Omega^2 = 25):
p2 := seq(textplot([tmax-2, ymax-k*dy/20, legend||k], align=left), k=1..3):
p3 := seq(plot([[tmax-2, ymax-k*dy/20], [tmax-1, ymax-k*dy/20]], color=colors[k]), k=1..3):
display(p1, p2, p3, view=[default, -ymax..ymax], size=[800, 500])
Error, (in plot) invalid color specification: colors[1]
display(p1, p2, p3, view = [default, -ymax .. ymax], size = [800, 500])
Download Legend_Inside.mw
I want to calculate the double integral of the following expression which includes sum of several Legendre polynomial terms, but the speed is so low. Any suggestion to speed up the calculation?
Restart:
II := 9:
JJ := 9:
M := 9:
`ΔP1` := add(add(add(add(add(add(add(-(LegendreP(i, zeta__1)*LegendreP(j, eta__1)*(diff(diff(tau[r](t), t), t))+LegendreP(m, zeta__1)*LegendreP(j, eta__1)*(diff(tau[r](t), t))+LegendreP(m, zeta__1)*LegendreP(j, eta__1)*tau[r](t))/sqrt(LegendreP(m, zeta__1)*LegendreP(j, eta__1)+LegendreP(i, zeta__1)*LegendreP(l, eta__1)), i = 1 .. II), j = 1 .. JJ), k = 1 .. II), m = 1 .. II), l = 1 .. JJ), n = 1 .. JJ), r = 1 .. M):
A := int(int(`ΔP1`, zeta__1 = -1 .. 1), eta__1 = -1 .. 1):
A
Download Soal.mw
When I run this code, I will get a error information:
CompositionSeries(SmallGroup(336, 209))
It's mean this function just work in transitive group? But IsTransitive(SmallGroup(336, 209)) will get true. Is it a bug of maple? Or do I have any misunderstandings?
I am using the following (dummy) code to generate a density plot.
densityplot(x-y^2, x=-5..5, y=-5..5, axes=boxed, style=patchnogrid, numpoints=1000, legendstyle=[location=bottom], labels=[x, y]);
While this command does generate x vs y plots with varying color shared, I cannot figure out where the function (x-y^2) value by looking at the color shades. Is there a way to produce a legend along with the plot that will demonstrate how the function is taking different values with parameters?
I found a similar post, dated 2005, that suggests using the "s_tyle=" command. However, it does not work for some reasons. I would appreciate help in this regard.
Thank you,
Omkar
HI, I have numerically solved the given problem using the dsolve command But I want to solve the same problem using the Differential transformation method.
Can anyone help me to get the series solution for the given problem using DTM.
I want to compare the numerical results with DTM results when lambda =0.5.
eqn1 := diff(f(eta), `$`(eta, 3))+f(eta)*(diff(f(eta), `$`(eta, 2)))-(diff(f(eta), eta))^2-lambda*(diff(f(eta), eta)) = 0.
eqn2 := diff(theta(eta), `$`(eta, 2))+f(eta)*(diff(theta(eta), eta))*Pr = 0
Bcs := (D(f))(0) = 1, f(0) = 0, (D(f))(infinity) = 0, theta(0) = 1, theta(infinity) = 0;
[lambda = .5, Pr = 6.3]
read "C:/Program Files/Maple 2020/lib/ASP v4.6.3.txt";
    DESOLVII_V5R5 (March 2011)(c), by Dr. K. T. Vu, Dr. J.
       Carminati and Miss G. Jefferson
The authors kindly request that this software be referenced, if
   it is used in work eventuating in a publication, by citing
   the article:
  K.T. Vu, G.F. Jefferson, J. Carminati, Finding generalised
     symmetries of differential equations
  using the MAPLE package DESOLVII,Comput. Phys. Commun. 183
     (2012) 1044-1054.
 ASP (November 2011), by Miss G. Jefferson and Dr. J. Carminati
   the article:
     G.F. Jefferson, J. Carminati, ASP: Automated Symbolic
        Computation of Approximate Symmetries
   of Differential Equations, Comput. Phys. Comm. 184 (2013)
      1045-1063.
 [classify, comtab, defeqn, deteq_split, extgenerator, gendef,
   genvec, icde_cons, liesolve, mod_eq, originalVar, pdesolv,
   reduceVar, reduceVargen, symmetry, varchange]
                     ASP := _m2229977204928
with(ASP);
       [ApproximateSymmetry, applygenerator, commutator]
with(desolv);
read "C:/Program Files/Maple 2020/lib/FracSym.v1.16.txt";
FracSym (April 2013), by Miss G. Jefferson and Dr. J. Carminati
   it is used in work eventuating in a publication, by citing:
   G.F. Jefferson, J. Carminati, FracSym: Automated symbolic
      computation of Lie symmetries
   of fractional differential equations, Comput. Phys. Comm.
      Submitted May 2013.
with(FracSym);
[Rfracdiff, TotalD, applyFracgen, evalTotalD, expandsum, fracDet,
  fracGen, split]
Rfracdiff(u(x, t), t, alpha);
                          alpha
                       D[t     ](u(x, t))
Rfracdiff(u(x, t) &* v(x, t), t, alpha);
infinity
   )                          (alpha - n)              n
  /     binomial(alpha, n) D[t           ](u(x, t)) D[t ](v(x, t))
 n = 0
Rfracdiff(v(x, t) &* u(x, t), t, alpha);
infinity
   )                          (alpha - n)              n
  /     binomial(alpha, n) D[t           ](v(x, t)) D[t ](u(x, t))
 n = 0
Rfracdiff(u(x, t) &* v(x, t), t, 2);
     /  2         \
     | d          |             / d         \ / d         \
     |---- u(x, t)| v(x, t) + 2 |--- u(x, t)| |--- v(x, t)|
     |   2        |             \ dt        / \ dt        /
     \ dt         /
                  /  2         \
                  | d          |
        + u(x, t) |---- v(x, t)|
                  |   2        |
                  \ dt         /
TotalD(xi[x](x, y), x, 2);
                       D[x ](xi[x](x, y))
evalTotalD([%], [y], [x]);
     [     /  2             \     /   2              \
     [   2 | d              |     |  d               |
     [y_x  |---- xi[x](x, y)| + 2 |------ xi[x](x, y)| y_x
     [     |   2            |     \ dy dx            /
     [     \ dy             /
                                   /  2             \]
               / d             \   | d              |]
        + y_xx |--- xi[x](x, y)| + |---- xi[x](x, y)|]
               \ dy            /   |   2            |]
                                   \ dx             /]
fde1 := Rfracdiff(u(x, t), t, alpha) = -u(x, t)*diff(u(x, t), x) - diff(u(x, t), x, x) - diff(u(x, t), x, x, x) - diff(u(x, t), x, x, x, x);
                alpha                      / d         \
     fde1 := D[t     ](u(x, t)) = -u(x, t) |--- u(x, t)|
                                           \ dx        /
          /  2         \   /  3         \   /  4         \
          | d          |   | d          |   | d          |
        - |---- u(x, t)| - |---- u(x, t)| - |---- u(x, t)|
          |   2        |   |   3        |   |   4        |
          \ dx         /   \ dx         /   \ dx         /
deteqs := fracDet([fde1], [u], [x, t], 2);
  Intervals/values considered for the fractional derivative/s:
                     {0 < alpha, alpha < 1}
          [[  2
          [[ d                     d
deteqs := [[---- eta[u](x, t, u), --- xi[t](x, t, u),
          [[   2                   du
          [[ du
   d                   d                   d
  --- xi[t](x, t, u), --- xi[t](x, t, u), --- xi[x](x, t, u),
   du                  dx                  du
                        2                    2
   d                   d                    d
  --- xi[x](x, t, u), ---- xi[t](x, t, u), ---- xi[t](x, t, u),
   du                    2                    2
                       du                   du
   d                         / d                \
  ---- xi[t](x, t, u), alpha |--- xi[x](x, t, u)|,
     2                       \ dt               /
   du
        / d                \   d
  alpha |--- xi[x](x, t, u)|, ---- xi[t](x, t, u),
        \ du               /     2
                               du
    2                    2                    3
   d                    d                    d
  ---- xi[x](x, t, u), ---- xi[x](x, t, u), ---- xi[t](x, t, u),
     2                    2                    3
   du                   du                   du
    3                    3                    4
   d                    d                    d
  ---- xi[t](x, t, u), ---- xi[x](x, t, u), ---- xi[t](x, t, u),
     3                    3                    4
   du                   du                   du
    4
   d
     4
   du
     /  2                \
     | d                 |     / d                \
  -6 |---- xi[t](x, t, u)| - 3 |--- xi[t](x, t, u)|,
     |   2               |     \ dx               /
     \ dx                /
        / d                \     / d                \
  alpha |--- xi[t](x, t, u)| - 4 |--- xi[x](x, t, u)|,
        \ dt               /     \ dx               /
  / d                \
  |--- xi[t](x, t, u)| (alpha - 1),
  \ du               /
                               /   2                 \
     / d                \      |  d                  |
  -3 |--- xi[t](x, t, u)| - 12 |------ xi[t](x, t, u)|,
     \ du               /      \ dx du               /
        / d                \
  alpha |--- xi[t](x, t, u)| (alpha - 1),
        \ du               /
        / d                \
  alpha |--- xi[x](x, t, u)| (alpha - 1),
        \ du               /
     /  2                \      /   3                  \
     | d                 |      |  d                   |
  -3 |---- xi[t](x, t, u)| - 12 |------- xi[t](x, t, u)|,
     |   2               |      |      2               |
     \ du                /      \ dx du                /
        /   2                 \
        |  d                  |
  alpha |------ xi[t](x, t, u)| (alpha - 1),
        \ du dt               /
        /   2                 \
        |  d                  |
  alpha |------ xi[x](x, t, u)| (alpha - 1),
        \ du dt               /
        /  2                \
        | d                 |
  alpha |---- xi[t](x, t, u)| (alpha - 1),
        |   2               |
        \ du                /
        /  2                \
        | d                 |
  alpha |---- xi[x](x, t, u)| (alpha - 1),
        |   2               |
        \ dt                /
        /  2                \
        | d                 |
        |   2               |
        \ du                /
   /  3                \     /   4                  \
   | d                 |     |  d                   |
  -|---- xi[t](x, t, u)| - 4 |------- xi[t](x, t, u)|,
   |   3               |     |      3               |
   \ du                /     \ dx du                /
                          /   2                 \
 / d                \     |  d                  |
-|--- xi[t](x, t, u)| - 4 |------ xi[t](x, t, u)|
 \ du               /     \ dx du               /
           / d                \     / d                \
   + alpha |--- xi[t](x, t, u)|, -4 |--- xi[x](x, t, u)|
           \ du               /     \ du               /
       /  2                 \      /   2                 \
       | d                  |      |  d                  |
   + 4 |---- eta[u](x, t, u)| - 16 |------ xi[x](x, t, u)|,
       |   2                |      \ dx du               /
       \ du                 /
                            /  2                 \
   / d                \     | d                  |
-3 |--- xi[x](x, t, u)| + 3 |---- eta[u](x, t, u)|
   \ du               /     |   2                |
                            \ du                 /
        /   2                 \     /  3                \
        |  d                  |     | d                 |
   - 12 |------ xi[x](x, t, u)|, -4 |---- xi[t](x, t, u)|
        \ dx du               /     |   3               |
                                    \ dx                /
                                /  2                \
       / d                \     | d                 |
   - 2 |--- xi[t](x, t, u)| - 3 |---- xi[t](x, t, u)|,
       \ dx               /     |   2               |
                                \ dx                /
   /   2                 \      /   3                  \
   |  d                  |      |  d                   |
-6 |------ xi[t](x, t, u)| - 12 |------- xi[t](x, t, u)|
   \ dx du               /      |   2                  |
                                \ dx  du               /
       / d                \
   - 2 |--- xi[t](x, t, u)|,
       \ du               /
        / d                \
  alpha |--- xi[t](x, t, u)| (alpha - 1) (alpha - 2),
        \ du               /
   /  2                \     /  3                 \
   | d                 |     | d                  |
-6 |---- xi[x](x, t, u)| + 6 |---- eta[u](x, t, u)|
   |   2               |     |   3                |
   \ du                /     \ du                 /
        /   3                  \     /   3                  \
        |  d                   |     |  d                   |
   - 24 |------- xi[x](x, t, u)|, -3 |------- xi[t](x, t, u)|
        |      2               |     |      2               |
        \ dx du                /     \ dx du                /
       /    4                  \   /  2                \
       |   d                   |   | d                 |        /
   - 6 |-------- xi[t](x, t, u)| - |---- xi[t](x, t, u)|, alpha |
       |   2   2               |   |   2               |        \
       \ dx  du                /   \ du                /
   d                \     / d                \
  --- xi[t](x, t, u)| - 3 |--- xi[x](x, t, u)|
   dt               /     \ dx               /
       /   2                  \     /  2                \
       |  d                   |     | d                 |
   + 4 |------ eta[u](x, t, u)| - 6 |---- xi[x](x, t, u)|,
       \ dx du                /     |   2               |
                                    \ dx                /
        /   2                 \
        |  d                  |
  alpha |------ xi[t](x, t, u)| (alpha - 1) (alpha - 2),
        \ du dt               /
        /  2                \
        | d                 |
  alpha |---- xi[t](x, t, u)| (alpha - 1) (alpha - 2),
        |   2               |
        \ du                /
   /   2                 \     /   3                  \
   |  d                  |     |  d                   |
-3 |------ xi[t](x, t, u)| - 6 |------- xi[t](x, t, u)|
   \ dx du               /     |   2                  |
                               \ dx  du               /
     / d                \         / d                \        |
   - |--- xi[t](x, t, u)| + alpha |--- xi[t](x, t, u)|, alpha |
     \ du               /         \ du               /        |
       /  2                \     /   2                  \
       | d                 |     |  d                   |
-alpha |---- xi[t](x, t, u)| + 2 |------ eta[u](x, t, u)|
       |   2               |     \ du dt                /
       \ dt                /
     /  2                \\   /  3                \
     | d                 ||   | d                 |
   + |---- xi[t](x, t, u)||, -|---- xi[x](x, t, u)|
     |   2               ||   |   3               |
     \ dt                //   \ du                /
       /   4                  \   /  4                 \
       |  d                   |   | d                  |
   - 4 |------- xi[x](x, t, u)| + |---- eta[u](x, t, u)|,
       |      3               |   |   4                |
       \ dx du                /   \ du                 /
                          /  2                \
   / d                \   | d                 |
-u |--- xi[t](x, t, u)| - |---- xi[t](x, t, u)|
   \ dx               /   |   2               |
                          \ dx                /
     /  3                \   /  4                \
     | d                 |   | d                 |
   - |---- xi[t](x, t, u)| - |---- xi[t](x, t, u)|,
     |   3               |   |   4               |
     \ dx                /   \ dx                /
        /   3                  \
        |  d                   |
  alpha |------- xi[t](x, t, u)| (alpha - 1) (alpha - 2),
        |      2               |
        \ du dt                /
        /   3                  \
        |  d                   |
        |   2                  |
        \ du  dt               /
        /  3                \
        | d                 |
        |   3               |
        \ du                /
                            /  2                 \
   / d                \     | d                  |
   \ du               /     |   2                |
                            \ du                 /
       /   2                 \      /   3                   \
       |  d                  |      |  d                    |
   - 9 |------ xi[x](x, t, u)| + 12 |------- eta[u](x, t, u)|
       \ dx du               /      |      2                |
                                    \ dx du                 /
        /   3                  \
        |  d                   |        / d                \
   - 18 |------- xi[x](x, t, u)|, alpha |--- xi[t](x, t, u)| u
        |   2                  |        \ du               /
        \ dx  du               /
       /   3                  \     /   4                  \
       |  d                   |     |  d                   |
   - 3 |------- xi[t](x, t, u)| - 4 |------- xi[t](x, t, u)|
       |   2                  |     |   3                  |
       \ dx  du               /     \ dx  du               /
       /   2                 \
       |  d                  |   / d                \          /
   - 2 |------ xi[t](x, t, u)| - |--- xi[t](x, t, u)| u, alpha |
       \ dx du               /   \ du               /          \
                          /  3                \
   d                \     | d                 |
  --- xi[t](x, t, u)| - 4 |---- xi[x](x, t, u)|
   dt               /     |   3               |
                          \ dx                /
       /  2                \
       | d                 |     / d                \
   - 3 |---- xi[x](x, t, u)| - 2 |--- xi[x](x, t, u)|
       |   2               |     \ dx               /
       \ dx                /
       /   3                   \     /   2                  \
       |  d                    |     |  d                   |
   + 6 |------- eta[u](x, t, u)| + 3 |------ eta[u](x, t, u)|,
       |   2                   |     \ dx du                /
       \ dx  du                /
 /  2                \   /  3                 \
 | d                 |   | d                  |
-|---- xi[x](x, t, u)| + |---- eta[u](x, t, u)|
 |   2               |   |   3                |
 \ du                /   \ du                 /
       /   3                  \     /   4                   \
       |  d                   |     |  d                    |
   - 3 |------- xi[x](x, t, u)| + 4 |------- eta[u](x, t, u)|
       |      2               |     |      3                |
       \ dx du                /     \ dx du                 /
       /    4                  \              /
       |   d                   |              |
   - 6 |-------- xi[x](x, t, u)|, (alpha - 1) |
       |   2   2               |              |
       \ dx  du                /              \
       /  3                \     /   3                   \
       | d                 |     |  d                    |
-alpha |---- xi[t](x, t, u)| + 3 |------- eta[u](x, t, u)|
       |   3               |     |      2                |
       \ dt                /     \ du dt                 /
       /  3                \\
       | d                 ||           / d                \
   + 2 |---- xi[t](x, t, u)|| alpha, -u |--- xi[x](x, t, u)|
       |   3               ||           \ du               /
       \ dt                //
     /  2                 \     /   2                 \
     | d                  |     |  d                  |
   + |---- eta[u](x, t, u)| - 2 |------ xi[x](x, t, u)|
     |   2                |     \ dx du               /
     \ du                 /
       /   3                   \     /   3                  \
       |  d                    |     |  d                   |
   + 3 |------- eta[u](x, t, u)| - 3 |------- xi[x](x, t, u)|
       |      2                |     |   2                  |
       \ dx du                 /     \ dx  du               /
       /   4                  \     /    4                   \
       |  d                   |     |   d                    |
   - 4 |------- xi[x](x, t, u)| + 6 |-------- eta[u](x, t, u)|,
       |   3                  |     |   2   2                |
       \ dx  du               /     \ dx  du                 /
   / d                \
-u |--- xi[x](x, t, u)| + eta[u](x, t, u)
   \ dx               /
                                      /   2                  \
           / d                \       |  d                   |
   + alpha |--- xi[t](x, t, u)| u + 2 |------ eta[u](x, t, u)|
           \ dt               /       \ dx du                /
     /  2                \     /   3                   \
     | d                 |     |  d                    |
   - |---- xi[x](x, t, u)| + 3 |------- eta[u](x, t, u)|
     |   2               |     |   2                   |
     \ dx                /     \ dx  du                /
     /  3                \     /   4                   \
     | d                 |     |  d                    |
   - |---- xi[x](x, t, u)| + 4 |------- eta[u](x, t, u)|
     |   3               |     |   3                   |
     \ dx                /     \ dx  du                /
     /  4                \]  [
     | d                 |]  [
   - |---- xi[x](x, t, u)|], [xi[t](x, 0, u) = 0, (Diff(
     |   4               |]  [
     \ dx                /]  [
                                   / d                 \
  eta[u](x, t, u), t $ alpha)) + u |--- eta[u](x, t, u)|
                                   \ dx                /
       /    / d                            \\
   - u |Diff|--- eta[u](x, t, u), t $ alpha||
       \    \ du                           //
     /  3                 \   /  4                 \
     | d                  |   | d                  |
   + |---- eta[u](x, t, u)| + |---- eta[u](x, t, u)|
     |   3                |   |   4                |
     \ dx                 /   \ dx                 /
                             /infinity
     /  2                 \  |  \
     | d                  |  |   )    /    1   /
   + |---- eta[u](x, t, u)|, |  /     |- ----- |binomial(alpha, n)
     |   2                |  | -----  \  n + 1 \
     \ dx                 /  \ n = 3
  /   (alpha - n)              (n + 1)
  |D[t           ](u(x, t)) D[t       ](xi[t](x, t, u)) alpha
        (alpha - n)              (n + 1)
   - D[t           ](u(x, t)) D[t       ](xi[t](x, t, u)) n
        (alpha - n) / d         \    n
   + D[t           ]|--- u(x, t)| D[t ](xi[x](x, t, u)) n
                    \ dx        /
                                                          \   /Sum(
        (alpha - n) / d         \    n                 \\\|   |
   + D[t           ]|--- u(x, t)| D[t ](xi[x](x, t, u))|||| + |
                    \ dx        /                      ///|   |
                     /    / d                        \\
  binomial(alpha, n) |Diff|--- eta[u](x, t, u), t $ n||
                     \    \ du                       //
     (alpha - n) (u(x, t)), n = 3 .. infinity)\]
  D[t           ]                             |]
  [xi[x](x, t, u), xi[t](x, t, u), eta[u](x, t, u)], [x, t, u]]
sol1 := pdesolv(expand(deteqs[1]), deteqs[3], deteqs[4]);
Error, (in desolv/lderivx) cannot determine if this expression is true or false: 1 < x |C:/Program Files/Maple 2020/lib/ASP v4.6.3.txt:4312|
  1. I use both Maple and Matlab
  2. I also install (a stripped down version of) Maple as the "symbolic toolbox" for Matlab using the executable MapleToolbox2022.0WindowsX64Installer.exe, which lives in C:\Program Files\Maple 2022. This gives me acces to (some) symbolic computation capability from within Matlab.
  3. This installation process has been working for as long as I remember, certainly more than 10 years
  4. With Maple 2022 and Matlab R2022a, this installation process ran with no problems and I can perform symbolic computation within Matlab
  5. However, although the Matlab help lists the Maple toolbox as supplemental software (as in all previous releases), I can no longer acces help for Maple from within Matlab - I just get a "Page not found" message
  6. The relevant Maple "help" is at the same place within the Matlab folder structure which is C:\Program Files\MATLAB\R2022a\toolbox\maple\html
  7. I have just spoken to support at Matlab and they claim tha this must be a Maple (or Maple toolbox installer issue) - so nothing to do with them!
  8. Has anyone else had a similar problem andd found a workaround?
Switching font to Arial apparently makes the sign disappear in MathContainers.
Vorzeichen.mw
If i want to do mathematical modelling for planetary motion, how can maple help me with it?
Anyone experience a delay in typing as the screen fills with text/math etc.?
I'm using Maple 2021 and as the space is filled typing slows. I can finish typing and watch the last 4 keys enter on the screen.
Hi !
Looks like there is a bug in the inert "Diff" command.
I have Maple 2018 on Windows 10 ,64 bits.
Does Maple consider Diff(f(x),x) to be equal to Diff(f(x),[x]) ?
It should be the same.
Maple displays  that it is equal but keeps in memory something else.
In the attached file, I give a very simple example.
I don't like to say this but my old version of Maple V Release V (1997) is more consistent i.e.
this version shows it's different and  keeps in memory that difference.
diff-problem.mw
I wonder if newer versions have this problem ?
Best regards !
When using the built-in fsolve function to find the roots of a polynomial, how does exponentiation occur? For example, x3 is found​​​​​​first, and then to find x4, will he start again from the beginning, that is, x*x*x*x, or will he take the value of x3​​​​​​ and multiply by x? The teacher is interested in finding out this, but I don't know how to find out myself.
Hello Everyone;
Hope you are fine. I am solving system of odes using rk-4 method. For this purpose I formulate the "residual" (on maple file) which is further function of "x" and "y". With the help of discritization point further I convert "residual" into system of ode's. Then i used "sys111 := solve(odes_Combine, `~`[diff](var, t))" to simplify the system. Finnally i applied RK-1. Code is pasted and attached. This all process is for "N=4". When i increase the value of "N", number of Odes increase accordingly. With increasing value of "N" the comand "sys111 := solve(odes_Combine, `~`[diff](var, t))" taking a lot of time due to heavy computation. Is that any way to proceed without this comand for rk-1?
Question1.mw
restart; with(PDEtools, Solve); with(LinearAlgebra); with(plots); DD := 30; Digits := DD; N := 4; nu := 1.0; t0, tf := 0, 1; Ntt := 10; h := evalf((tf-t0)/(Ntt-1)); xmin := 0; xmax := Pi; `&Delta;xx` := 1.0*xmax/N; ymin := 0; ymax := xmax; `&Delta;yy` := 1.0*ymax/N
0, 1
.111111111111111111111111111111
.785398163397448309615660845820
residual := 1.000000000*(diff(A[0, 0](t), t))-32.00000000*A[2, 0](t)-32.00000002*A[0, 2](t)+(diff(A[1, 1](t), t))*(4.000000001-8.000000003*y-8.000000003*x+16.00000000*x*y)+(diff(A[1, 0](t), t))*(-2.000000000+4.000000000*x)+(diff(A[0, 3](t), t))*(-4.000000000+40.00000000*y-95.99999994*y^2+64.00000001*y^3)+(diff(A[0, 2](t), t))*(3.000000000-16.00000001*y+16.00000001*y^2)+(diff(A[0, 1](t), t))*(-2.000000001+4.000000000*y)-A[3, 3](t)*(768.0000000-7680.000000*y+18432.00000*y^2-12288.00000*y^3-1536.000000*x+15360.00000*x*y-36863.99998*x*y^2+24576.00000*x*y^3)-A[3, 2](t)*(-576.0000002+3072.000000*y-3072.000000*y^2+1152.000000*x-6144.000000*x*y+6144.000000*x*y^2)-A[3, 1](t)*(384.0000000-768.0000000*y-768.0000006*x+1536.000000*x*y)-A[3, 0](t)*(-192.0000000+384.0000000*x)-A[2, 3](t)*(-128.0000000+1280.000000*y-3072.000000*y^2+2048.000000*y^3)-A[2, 2](t)*(96.00000000-512.0000002*y+512.0000002*y^2)-A[2, 1](t)*(-64.00000002+128.0000000*y)-A[3, 3](t)*(767.9999998-1536.000000*y-7679.999998*x+15360.00000*x*y+18432.00000*x^2-36864.00000*x^2*y-12288.00000*x^3+24576.00000*x^3*y)-A[2, 3](t)*(-575.9999998+1152.000000*y+3072.000000*x-6144.000000*x*y-3072.000000*x^2+6144.000000*x^2*y)-A[3, 2](t)*(-128.0000000+1280.000000*x-3072.000000*x^2+2048.000000*x^3)-A[1, 2](t)*(-64.00000002+128.0000000*x)-A[1, 3](t)*(384.0000000-768.0000000*y-767.9999998*x+1536.000000*x*y)-A[2, 2](t)*(96.00000004-512.0000002*x+512.0000002*x^2)+(diff(A[3, 3](t), t))*(16.00000000-160.0000000*y+383.9999999*y^2-256.0000000*y^3-160.0000000*x+1600.000000*x*y-3839.999999*x*y^2+2560.000000*x*y^3+384.0000000*x^2-3840.000000*x^2*y+9215.999998*x^2*y^2-6144.000001*x^2*y^3-256.0000000*x^3+2560.000000*x^3*y-6143.999998*x^3*y^2+4096.000000*x^3*y^3)+(diff(A[3, 2](t), t))*(-12.00000000+64.00000002*y-64.00000002*y^2+120.0000000*x-640.0000002*x*y+640.0000002*x*y^2-288.0000001*x^2+1536.000000*x^2*y-1536.000000*x^2*y^2+192.0000000*x^3-1024.000000*x^3*y+1024.000000*x^3*y^2)+(diff(A[3, 1](t), t))*(8.000000003-16.00000000*y-80.00000003*x+160.0000000*x*y+192.0000000*x^2-384.0000000*x^2*y-128.0000001*x^3+256.0000000*x^3*y)-A[0, 3](t)*(-191.9999999+384.0000000*y)+(diff(A[3, 0](t), t))*(-4.000000000+40.00000000*x-96.00000002*x^2+64.00000001*x^3)+(diff(A[2, 3](t), t))*(-12.00000000+120.0000000*y-287.9999999*y^2+192.0000000*y^3+64.00000000*x-640.0000000*x*y+1536.000000*x*y^2-1024.000000*x*y^3-64.00000000*x^2+640.0000000*x^2*y-1536.000000*x^2*y^2+1024.000000*x^2*y^3)+(diff(A[2, 2](t), t))*(8.999999999-48.00000002*y+48.00000002*y^2-48.00000000*x+256.0000001*x*y-256.0000001*x*y^2+48.00000000*x^2-256.0000001*x^2*y+256.0000001*x^2*y^2)+(diff(A[2, 1](t), t))*(-6.000000002+12.00000000*y+32.00000001*x-64.00000000*x*y-32.00000001*x^2+64.00000000*x^2*y)+(diff(A[2, 0](t), t))*(3.000000000-16.00000000*x+16.00000000*x^2)+(diff(A[1, 3](t), t))*(8.000000003-80.00000003*y+192.0000000*y^2-128.0000000*y^3-16.00000000*x+160.0000000*x*y-383.9999999*x*y^2+256.0000000*x*y^3)+(diff(A[1, 2](t), t))*(-6.000000000+32.00000001*y-32.00000001*y^2+12.00000000*x-64.00000002*x*y+64.00000002*x*y^2):
for i2 from 0 while i2 <= N-1 do odes11[0, i2] := simplify(eval(residual, [x = 0, y = i2*ymax/(N-1)])) = 0; odes11[N-1, i2] := simplify(eval(residual, [x = xmax, y = i2*ymax/(N-1)])) = 0 end do:
8
odes_Combine := {seq(seq(odes11[i, j], i = 0 .. N-1), j = 0 .. N-1)}:
sys111 := solve(odes_Combine, `~`[diff](var, t)):
ICS1 := {A[0, 0](0) = .444104979341173495851499233536, A[0, 1](0) = .198590961107083475045046921568, A[0, 2](0) = -0.167999146492673347540059075790e-1, A[0, 3](0) = -0.869171705198864625153083083786e-3, A[1, 0](0) = .198590961107083475045046921567, A[1, 1](0) = 0.888041604305848495880917177172e-1, A[1, 2](0) = -0.751243816645416714455046298805e-2, A[1, 3](0) = -0.388668563362181391196975707953e-3, A[2, 0](0) = -0.167999146492673347540059075793e-1, A[2, 1](0) = -0.751243816645416714455046298835e-2, A[2, 2](0) = 0.635518954643030408055028178047e-3, A[2, 3](0) = 0.328796368925226898150257328603e-4, A[3, 0](0) = -0.869171705198864625153083083734e-3, A[3, 1](0) = -0.388668563362181391196975707910e-3, A[3, 2](0) = 0.328796368925226898150257328592e-4, A[3, 3](0) = 0.170108305076655667148638268230e-5}:
f, diffs := eval(GenerateMatrix(`~`[`-`](`~`[rhs](sys222), `~`[lhs](sys222)), var1))
f, diffs := Matrix(16, 16, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 32., (1, 4) = 0.494812294492356575865153049102e-27, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0.120000000000000000001649374315e-7, (1, 8) = -0.107999999927999999998854228220e-6, (1, 9) = 32.0000000200000000000000000000, (1, 10) = -0.199999999999999999998350625685e-7, (1, 11) = 0.249999999859375000081951230025e-7, (1, 12) = -0.700000000203125000132933066388e-7, (1, 13) = 0.196000000000000000000494812294e-6, (1, 14) = 0.292000000072000000001204420404e-6, (1, 15) = -0.458000000726562499721923065316e-6, (1, 16) = 0.682900000453875000014432471170e-5, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = -0.377561971763063776372092766396e-27, (2, 5) = 0, (2, 6) = 0, (2, 7) = 32.0000000000000000000000000000, (2, 8) = 0.719999999999999999998878327317e-7, (2, 9) = 0, (2, 10) = -0.125853990587687925457364255465e-27, (2, 11) = 0.906355783222184042180194163758e-27, (2, 12) = 0.135077431625990682476379737660e-25, (2, 13) = 96.0000000000000000000000000001, (2, 14) = 0.719999999999999999989394464730e-7, (2, 15) = -0.549999999914062500010607576813e-6, (2, 16) = 0.202000000048749999997617654955e-5, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0.855583965847405137008732798371e-28, (3, 5) = 0, (3, 6) = 0, (3, 7) = -0.257808598553160159742093659020e-28, (3, 8) = -0.377264825438544618607975742790e-27, (3, 9) = 0, (3, 10) = 0.285194655282468379002910932790e-28, (3, 11) = 31.9999999925000000046874999970, (3, 12) = 0.326865301360930805043812804544e-26, (3, 13) = -0.773425795659480479226280977060e-28, (3, 14) = -0.313579545661510489918366218529e-27, (3, 15) = -0.149999999882812500075601322065e-6, (3, 16) = 0.324999999796875000093151106353e-6, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = -0.384112032581666751703476763000e-29, (4, 5) = 0, (4, 6) = 0, (4, 7) = 0.265935771387910529598689301718e-29, (4, 8) = 0.399754551928273029196600976861e-28, (4, 9) = 0, (4, 10) = -0.128037344193888917234492254333e-29, (4, 11) = 0.173718566046259004921454811253e-28, (4, 12) = -0.553232882345597286403223410199e-27, (4, 13) = 0.797807314163731588796067905154e-29, (4, 14) = 0.427742792008362106477653509643e-28, (4, 15) = 31.9999999950000000007812499996, (4, 16) = 0.583137134641934297089284679036e-26, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 96.0000000000000000000000000001, (5, 5) = 0, (5, 6) = 0, (5, 7) = -0.125853990576278889372664086359e-27, (5, 8) = -0.780000000000000000003341913398e-7, (5, 9) = 0, (5, 10) = 32.0000000000000000000000000000, (5, 11) = 0.155215894719877680168982772333e-28, (5, 12) = 0.179999999957812500011610427218e-6, (5, 13) = -0.377561971728836668117992259076e-27, (5, 14) = 0.121999999999999999999928850210e-6, (5, 15) = 0.957742348838601502120463181878e-26, (5, 16) = 0.413250000106171874986265224797e-5, (6, 1) = 0, (6, 2) = 0, (6, 3) = 0, (6, 4) = -0.821348457439978150891092618719e-28, (6, 5) = 0, (6, 6) = 0, (6, 7) = -0.273782819058452669879599110853e-28, (6, 8) = 95.9999999999999999999999999997, (6, 9) = 0, (6, 10) = -0.273782819146659383630364206240e-28, (6, 11) = 0.294057068291966163490658104104e-27, (6, 12) = -0.253498333196688505804635565222e-27, (6, 13) = -0.821348457175358009638797332558e-28, (6, 14) = 95.9999999999999999999999999997, (6, 15) = 0.212121033252676198558579131631e-28, (6, 16) = 0.649999999999999999980740836208e-6, (7, 1) = 0, (7, 2) = 0, (7, 3) = 0, (7, 4) = 0.186123768597305842557431955743e-28, (7, 5) = 0, (7, 6) = 0, (7, 7) = 0.214460223691860703703477959545e-28, (7, 8) = 0.317673924810187018756335641686e-28, (7, 9) = 0, (7, 10) = 0.620412561991019475191439852476e-29, (7, 11) = 0.753895620987131323747484439705e-28, (7, 12) = 95.9999999700000000093749999970, (7, 13) = 0.643380671075582111110433878635e-28, (7, 14) = 0.348244413167432788858088750543e-30, (7, 15) = -0.195081345734130085456007896310e-26, (7, 16) = 0.162499999949218750020914346448e-6, (8, 1) = 0, (8, 2) = 0, (8, 3) = 0, (8, 4) = -0.835597462589282450911924283887e-30, (8, 5) = 0, (8, 6) = 0, (8, 7) = -0.168983990754200234313642237958e-29, (8, 8) = 0.255518912827614707211229660888e-30, (8, 9) = 0, (8, 10) = -0.278532487529760816970641427962e-30, (8, 11) = -0.912041057783558505972445866734e-29, (8, 12) = 0.152862192823148604497047654434e-28, (8, 13) = -0.506951972262600702940926713875e-29, (8, 14) = 0.212025424265299406832408057357e-29, (8, 15) = 0.158222957859551043617221056103e-27, (8, 16) = 96.0000000000000000000000000002, (9, 1) = 0, (9, 2) = 0, (9, 3) = 0, (9, 4) = -0.773425795970180636575593526265e-28, (9, 5) = 0, (9, 6) = 0, (9, 7) = 0.285194655390087477280223771532e-28, (9, 8) = -0.241100887243597349107036806234e-27, (9, 9) = 0, (9, 10) = -0.257808598656726878858531175422e-28, (9, 11) = 32.0000000125000000000000000004, (9, 12) = 0.999999999843750000174507862823e-8, (9, 13) = 0.855583966170262431840671314596e-28, (9, 14) = -0.104420360226003256663758222866e-27, (9, 15) = 0.600000000000000000027497059897e-7, (9, 16) = 0.900000000046874999977170328969e-6, (10, 1) = 0, (10, 2) = 0, (10, 3) = 0, (10, 4) = 0.643380671224932994877201196193e-28, (10, 5) = 0, (10, 6) = 0, (10, 7) = 0.620412562284547562356437593923e-29, (10, 8) = -0.782971264706294608812923943602e-28, (10, 9) = 0, (10, 10) = 0.214460223741644331625733732064e-28, (10, 11) = -0.117716452160171050903010422567e-27, (10, 12) = -0.324249553007268016939337229307e-26, (10, 13) = 0.186123768685364268706931278177e-28, (10, 14) = 0.210791990319339808396292213890e-27, (10, 15) = 95.9999999999999999999999999990, (10, 16) = 0.601289924118833452883693495332e-26, (11, 1) = 0, (11, 2) = 0, (11, 3) = 0, (11, 4) = -0.145794923079456919867181504653e-28, (11, 5) = 0, (11, 6) = 0, (11, 7) = -0.485983076931523066223938348837e-29, (11, 8) = 0.703045314344404024740114826873e-28, (11, 9) = 0, (11, 10) = -0.485983076931523066223938348844e-29, (11, 11) = 0.154061910958820937154327251969e-28, (11, 12) = 0.586431085917646726477197552134e-27, (11, 13) = -0.145794923079456919867181504651e-28, (11, 14) = 0.327116591013740734656854347967e-28, (11, 15) = 0.186427448215109472676159333906e-27, (11, 16) = 0.727156843809743343593213639608e-26, (12, 1) = 0, (12, 2) = 0, (12, 3) = 0, (12, 4) = 0.654542236344866764687318521378e-30, (12, 5) = 0, (12, 6) = 0, (12, 7) = 0.382930495785563772474113758933e-30, (12, 8) = -0.765771840140216030924576968705e-29, (12, 9) = 0, (12, 10) = 0.218180745448288921562439507126e-30, (12, 11) = -0.591357855581324858104400230586e-30, (12, 12) = 0.164090126078907967224367765176e-28, (12, 13) = 0.114879148735669131742234127680e-29, (12, 14) = -0.733606589050003370341598338138e-29, (12, 15) = 0.279365514914751130455040418258e-28, (12, 16) = -0.138821502091830040436688448298e-26, (13, 1) = 0, (13, 2) = 0, (13, 3) = 0, (13, 4) = 0.797807313447167969819086050522e-29, (13, 5) = 0, (13, 6) = 0, (13, 7) = -0.128037344212226672551029214969e-29, (13, 8) = 0.262885403001488132812902903311e-28, (13, 9) = 0, (13, 10) = 0.265935771149055989939695350174e-29, (13, 11) = -0.349411324204567081081722661297e-28, (13, 12) = 31.9999999950000000007812499995, (13, 13) = -0.384112032636680017653087644907e-29, (13, 14) = 0.119403167752948354510697994999e-28, (13, 15) = -0.452504513537780686847551220204e-27, (13, 16) = 0.149999999976562500006592455374e-6, (14, 1) = 0, (14, 2) = 0, (14, 3) = 0, (14, 4) = -0.506951972202161632959380608780e-29, (14, 5) = 0, (14, 6) = 0, (14, 7) = -0.278532487328297250365487744273e-30, (14, 8) = 0.100313589069551339782957918087e-28, (14, 9) = 0, (14, 10) = -0.168983990734053877653126869593e-29, (14, 11) = 0.876003797684675659527198447426e-29, (14, 12) = 0.309396538522635365039103628797e-27, (14, 13) = -0.835597461984891751096463232820e-30, (14, 14) = -0.169500948608311509445295032991e-28, (14, 15) = 0.104005614175784513152332127959e-27, (14, 16) = 95.9999999999999999999999999996, (15, 1) = 0, (15, 2) = 0, (15, 3) = 0, (15, 4) = 0.114879148750778899237620653952e-29, (15, 5) = 0, (15, 6) = 0, (15, 7) = 0.218180745498654813213727928025e-30, (15, 8) = -0.867251219227502985269662069579e-29, (15, 9) = 0, (15, 10) = 0.382930495835929664125402179841e-30, (15, 11) = -0.267864188359583543656192185112e-29, (15, 12) = -0.387791753042961333529856694716e-28, (15, 13) = 0.654542236495964439641183784074e-30, (15, 14) = -0.523627245808308931882255033583e-29, (15, 15) = 0.369199231034048272468531636165e-28, (15, 16) = -0.123439611085554953594747603640e-26, (16, 1) = 0, (16, 2) = 0, (16, 3) = 0, (16, 4) = -0.515746730509193430144544493936e-31, (16, 5) = 0, (16, 6) = 0, (16, 7) = -0.171915576836397810048181497977e-31, (16, 8) = 0.857347676859656256220355661580e-30, (16, 9) = 0, (16, 10) = -0.171915576836397810048181497979e-31, (16, 11) = 0.182597096197097886514765184582e-30, (16, 12) = -0.370616214664321329971866697584e-29, (16, 13) = -0.515746730509193430144544493932e-31, (16, 14) = 0.865925397235117524875431212196e-30, (16, 15) = -0.750058451906403875595888288641e-29, (16, 16) = 0.183460376006651920829411996611e-27}), Vector(16, {(1) = diff(A[0, 0](t), t), (2) = diff(A[0, 1](t), t), (3) = diff(A[0, 2](t), t), (4) = diff(A[0, 3](t), t), (5) = diff(A[1, 0](t), t), (6) = diff(A[1, 1](t), t), (7) = diff(A[1, 2](t), t), (8) = diff(A[1, 3](t), t), (9) = diff(A[2, 0](t), t), (10) = diff(A[2, 1](t), t), (11) = diff(A[2, 2](t), t), (12) = diff(A[2, 3](t), t), (13) = diff(A[3, 0](t), t), (14) = diff(A[3, 1](t), t), (15) = diff(A[3, 2](t), t), (16) = diff(A[3, 3](t), t)})
npts := Ntt:
Download Question1.mw
I'm running Maple Flow 2022 on a Win10 Pro PC...
When looking at a Maple Flow worksheet I press Ctl-F to search for something on the worksheet ...
The search seems to work but the "found text" turns white ... so it is hard to see ... any fix for this?
Also, Is Dark Mode available for Maple Flow?
Thanks for any help.
Let say,
A= A1+A2+.....................+An
B=B1+B2+.....................+Bn,
C=C1+C2+.....................+Cn
And all the values of A1 to Cn may be both positive or Negative.
Then, how to program to find the Maximum Value of  (A^2+B^2+C^2+A.B+B.C+C.A)^(1/2).
First 73 74 75 76 77 78 79 Last Page 75 of 371
