Question 1: The Common Symbols palette referenced in the the section titled ... "Solution 2 - Use the Palettes" in Online Help HERE ...
Where is the Common Symbols palette in Maple Flow 2022 ... or is it missing?
Question 2: How can I add it if it  is missing as it looks very handy.
Question 3: Can you create custom Palettes and if so how?
Question 4: OT: Any chance of getting a spell checke for Forum Post ? :-)
Thanks for any help.
I have a student who then she uses tools/assistent/import data and then the file then Maple claims the Excel file is empty? She uses Maple 2021.2. File works on other my and other student computers.
To Maple support:
I was investigating this pde from a different forum.
I noticed that when using an expanded version of the pde, Maple hangs. Without expanding the PDE, Maple gives an answer in 2 seconds.
Why does expanding the PDE makes a difference? I do not have an earlier version of Maple on my new PC to check if this is a new issue or not.
`Standard Worksheet Interface, Maple 2022.0, Windows 10, March 8 2022 Build ID 1599809`
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1230 and is the same as the version installed in this computer, created 2022, April 21, 9:8 hours Pacific Time.`
pde1:=VectorCalculus:-Laplacian(u(r,theta),'polar'[r,theta]);
pde1_expanded:=expand(pde1);
bc  := u(1,theta)=sin(theta)^4,u(3,theta)=1;
pdsolve([pde1=0,bc],u(r,theta))
(diff(u(r, theta), r)+r*(diff(diff(u(r, theta), r), r))+(diff(diff(u(r, theta), theta), theta))/r)/r
(diff(u(r, theta), r))/r+diff(diff(u(r, theta), r), r)+(diff(diff(u(r, theta), theta), theta))/r^2
u(1, theta) = sin(theta)^4, u(3, theta) = 1
u(r, theta) = (1/52480)*((328*r^6-26568*r^2)*ln(3)*cos(2*theta)+(-r^8+6561)*ln(3)*cos(4*theta)+19680*(ln(3)+(5/3)*ln(r))*r^4)/(ln(3)*r^4)
pdsolve([pde1_expanded=0,bc],u(r,theta)); #HANGS, Waited more than 40 minutes.
Download hangs_pde.mw
Backspacing at the end of a few math containers on one row will shift them upwards beyond the top screen out of view and out of existence.  Your last chance of retrieval is when you can still see the bottom half portions of the letters/equations before you need to go to the first point and press enter to bring them down.  Once they're out of view, there's no chance to bring back what you wrote - the assignments are still valid.  Also note CRTL-Z will not bring them back.
Using the hide command after displaying a plot in MapleFlow2022 prevents that plot from being moved.
If you create another plot, then both plots are movable until you use the hide command again, at which point you need to create another plot to allow plots to be positioned.
Let
                              "a"
                              "b"
 be real numbers and
"A = Matrix(3, 3, [[a, a - 1, -b], [a - 1, a, -b], [b, b, 2*a -
   1]])"
                              "B="
 "Matrix(5, 5, [[0, a, 3, 0, a], [3, 0, 0, b, 0], [0, 1, b, 0,
    1], [b, 0, 0, 1, 0], [0, a, 1, 0, b]])"
(a) Show that if
                            "0 <= a"
                            "a <= 1"
                      "b^2 = 2*a*(1 - a)"
, then A is an orthogonal matrix with determinant equal to one.
(b) For what values of a and b is the matrix B singular? Determine the inverse of B (for those values of a and b for which B is invertible).
Find all rational function solutions to the Kadomtsev-Petviashvili equation
(&PartialD;)/(&PartialD;x);
diff(u, t) + 6*u*diff(u, x) + diff(u, x, x, x) - diff(u, y, y) = 0;
by u = 2
diff(ln, x, x)*f;
=(2 (((&PartialD;)^2)/(&PartialD;x^2) f) f-2 ((&PartialD;)/(&PartialD;x) f)^2)/(f^2);
 with
f;
(a[1 ]x+a[2] y+a[3] t+a[4])^2+(a[5] x+ a[6] y+a[7] t+a[8])^2+a[9], ;
where
a[i], i=1..9, ;
are real constants.
I am having a problem in evaluating a fluid flow problem at a boundary that includes infinity using a semi-analytic method Adomian Decomposition Method.
Find the attached code. Thanks in advance.
Just wondering how I do a loop over the contents of the table. I need both the index variable and the stored value associated with it.
This one apparently doesn't work.
F_vRk := table()
table( [ ] )
F_vRk["a"] := 1
F_vRk["b"] := 2
"for ind, val in F_vRk  do print(ind,val)  end do"
1, F_vRk
Download table_and_loop_1.mw
Hii!!
I need your help in state space system.... kindly guide me how to solve State Space system in maplesoft.....i excecute the command but i didn't find the answer....can you plz help me?I have been trying for two weeks now but it is not working.Thank you!!
Hello, we need to do an integral based on two numerically approximated functions given by a second degree coupled differential equation.
The integral:
Where xs and xu are functions of the variable t.
We wish to do a half-sums to approximate the integral, that is:
Define an N = number of points, such that we get a delta_x = L/N.
We then wish to get two vectors x_s = [x_s(0),x_s(1),...,x_s(N)] and x_u = [x_u(0),x_u(1),...,x_u(N)] by running some kind of for loop over our approximation procedure.
Is there any function for this already inside of Maple? We need to approximate the integral using Riemann sums and no other method.
When trying to print a Maple Document as a PDF on Mac, I am now getting an "Error while printing" message. A 1-page pdf is created that's empty.   This is a new error, one that I've never seen when printing as PDF for any other Maple Document I've created.
I'm running Mac OS 12.3.1, the latest version of Mac OS and using Maple 2020.
I am trying to develop a recursive code to the above equations.  Note, U,X&Y are multivariate functions (in this case bivariate functions of (x,y)) i.e. U=U(x,y), X=X(x,y) etc.
I have a nonlinear system of algebraic equations, I would like to solve it  without using fsolve and Newton's method.
Maybe one can use, fixed point method or Broyden's method
Fixed_Broyden_method.mw
Can we solve the system of 4 equations, using the proposed methods
thank you
Hello;
Hope you are fine. Can i apply numerical scheme on maple for the following problem. This in integro-differential equation i think. Waiting for kind response.
First 74 75 76 77 78 79 80 Last Page 76 of 371
