could you please help me ,the maple code for this given series.
U[0](x) := x;
x
"U[k+1](x):=solve((k+1)*U[k+1](x)+(x*(-1)^((k-1)/(2)))/(k!)-x^(2)*((e)^(x))/(10){6/(k!)-sum((2^(k[1]))/(k[1!])(5*delta[k[]-k[1]](x)+(2^(k-k[1])*(-1)^((k-k[1])/(2)))/((k-k[1])!)+(2^(k-k[1]+1)*(-1)^((k-k[1]-1)/(2)))/((k-k[1])!)),k[1]=0..k)}-(cos^(2)(x)+sin^()(x))*((∂)^2)/((∂)^( )x^2) [U[k](x)]-(e)^(x)[sum(1/(k[1]!){1/(k-k[1])(sum(sum(1/(k[3]!)*U[k[2]-k[3]](x)*U[k-k[1]-k[2]-1](x)},k[1]=0..k),k[2]=0..k-k[1]-1),k[3]=0..k[2])),U[k+1](x)];  od;"
Error, unable to match delimiters
"U[k+1](x):=solve((k+1)*U[k+1](x)+(x*(-1)^((k-1)/2))/(k!)-x^2*((e)^x)/10{6/(k!)-sum((2^(k[1]))/(k[1!])(5*delta[k-k[1]](x)+(2^(k-k[1])*(-1)^((k-k[1])/2))/((k-k[1])!)+(2^(k-k[1]+1)*(-1)^((k-k[1]-1)/2))/((k-k[1])!)),k[1]=0..k)}-(cos^2(x)+sin(x))*((∂)^2)/(∂x^2) [U[k](x)]-(e)^x[sum(1/(k[1]!){1/(k-k[1])(sum(sum(1/(k[3]!)*U[k[2]-k[3]](x)*U[k-k[1]-k[2]-1](x)},k[1]=0..k),k[2]=0..k-k[1]-1),k[3]=0..k[2])),U[k+1](x)];  od;"
Download Chapter_6-Example-6.5.4.mw
Hi! Do you know maybe how to solve equation with Laplace operator in Maple like BZ equation?
a := 0.75;
rho := u(t) + v(t) + w(t);
ode := diff(u(t), t) = 10*Delta(u(t)) + u*(-a*v - rho + 1);
ode1 := diff(v(t), t) = 10*Delta(v(t)) + v*(-a*w - rho + 1);
ode2 := diff(w(t), t) = 10*Delta(w(t)) + w*(-a*u - rho + 1);
Edit: Sorry I guess it should be function of three variables so u,v,w depends on (x,y,z) not strictle from time
I am wondering how to animate something like this from BZ equation:
Let the curves y=2x^3-x^2-5x   and 𝑦=−𝑥^2+3𝑥be given.
a) Plot both curves on the same 𝑥y −axis.
b) Shade the region (between the curves).
c) Calculate the area of the region enclosed by the curves given.
I get this error when typing a sigma symbol with some subscripts.
Is there anyway to get rid of it?
If mapleflow doesn't allow typing in this way, how can I type it in an unexcutable Math format like document mode in Maple?
Hi everyone! I'd really appreciate if I could get pointed in the right direction as I am a brand new maple user.
So im trying to solve this constrainted optimization problem (See picture) using Maple symbollically. I believe I should have a closed form solution given I can substitute the one constraint into the objective function. Specifically closed form solutions for the three phi variables.
Can someone point me in the right direction as to how I should go about this? I've already taken first order conditions and tried to using the solve() function to no avail, realizing my sytem of equations weren't linear );.
How to plot this equation with explore or animation
E[1]:=Sum((GAMMA(((beta+1)n-gamma(nu-1))+k))/(GAMMA(((beta+1)n-gamma(nu-1)))*GAMMA(rho*k + (nu(1-mu)+mu(2 n+1))))*((omega*t^(p))^(k))/(k!),k=0..5);  E[2] :=Sum((GAMMA((gamma(n+1)-beta *n)+k))/(GAMMA((gamma(n+1)-beta *n))*GAMMA(rho*k + (mu(2 n+1))))*((omega*t^(p))^(k))/(k!),k=0..5);    y(p):=Sum(c*gamma^(n)*t^(nu*(1-mu)+mu+2*mu*n-1)*E[1]+gamma^(n)t^(mu(2 n+1)-1)*E[2]*g, n=0..5);
with the conditions
mu, nu \in (0, 1); omega \in R; rho > 0; gamma, beta > or = 0; c & g are constant
I got a solution to use D as a symbol that prints well in italic. For convienience I like to have it in my favorite palette.
When I drag `&D;` from a Maple Input line to the favorites palette, the ampersand and the statement operator are removed. Copy and paste have the same effect on the pasted selection. If  these characters are removed, `&D;` becomes the differential operator D. That's not what I want.
Is it possible at all to get `&D;` or simliar expressions using special characters within left single quotes into the favorite palette?
How to solve the following system of ode analytically in maple?
diff(s(t), t) = gamma*s(t) + eta*s(t) + sigma*m(t)*s(t) - kappa*s(t) - phi*s(t), diff(g(t), t) = -alpha*g(t)*m(t) + mu*g(t) + delta*s(t)*g(t), diff(m(t), t) = beta*s(t) - alpha_1*g(t)*m(t)
Hi there.
There is some floating bug in Thread-Seq.
Maple is crashing sometimes (not always, 50/50) after running the script below:
thread-seq_error.mw
What's going on?
Hi,all
I am new in Maple,when I execute the "InversePlot" command ,all functions were correct except for exp(x), error occurs as follows, can anyone tell me what mistake I took?
Tks in advance!
with(Student[Calculus1]);
InversePlot(exp(x), -1 .. 1);
Error, (in Student:-Calculus1:-InversePlot) module does not export `IsTrigProc`
Tks for all you guys.
I have uninstall Maple and deleted the installed directory ,clear the register,reinstall Maple 2022, now all works well.
I think the problem is I installed Maple 2022 in the old directory of 2021for keeping my configuration,this caused much unexpected problem
primes_integrale_exp.mwThe integral in x of
exp(-sqrt(x^2 + c))
was done by Maple 11 but return unevaluated in Maple 2021,
see attached worksheet
Please help me solve the following problem about complex numbers with Maple: w= (3+zi)/(2+z) whose geometric representation in the "oxy" plane is a straight line. Calculate module of z. Thank you so much.
This worksheet animates part of the motion of the classic ladder sliding down a wall.
Please answer the two questions posed in the opening text.
Respondents will need to establish their own link to the DirectSearch package
Slide_Ladder.mw
u := (H(x, t, z)+sqrt(R))*exp(I*R*x);
                /              (1/2)\
                \H(x, t, z) + R     / exp(I R x)
I*(Diff(u, z))+Diff(u, `$`(x, 2))+Diff(u, `$`(t, 2))+(abs(u)*abs(u))*u-((abs(u)*abs(u))*abs(u)*abs(u))*u;
  / d  //              (1/2)\           \\
I |--- \\H(x, t, z) + R     / exp(I R x)/|
  \ dz                                   /
     / 2                                   \
     |d  //              (1/2)\           \|
   + |-- \\H(x, t, z) + R     / exp(I R x)/|
     / 2                                   \
     |d  //              (1/2)\           \|                  2
   + |-- \\H(x, t, z) + R     / exp(I R x)/| + (exp(-Im(R x)))
  |              (1/2)|  /              (1/2)\
  |H(x, t, z) + R     |  \H(x, t, z) + R     / exp(I R x) -
                                        4
                 4 |              (1/2)|  /              (1/2)\
  (exp(-Im(R x)))  |H(x, t, z) + R     |  \H(x, t, z) + R     /
  exp(I R x)
value(%);
  / d            \              / d  / d            \\
I |--- H(x, t, z)| exp(I R x) + |--- |--- H(x, t, z)|| exp(I R x)
  \ dz           /              \ dx \ dx           //
         / d            \
   + 2 I |--- H(x, t, z)| R exp(I R x)
         \ dx           /
     /              (1/2)\  2
   - \H(x, t, z) + R     / R  exp(I R x)
     / d  / d            \\                             2
   + |--- |--- H(x, t, z)|| exp(I R x) + (exp(-Im(R x)))
     \ dt \ dt           //
  |              (1/2)|  /              (1/2)\
                                        4
                 4 |              (1/2)|  /              (1/2)\
  exp(I R x)
simplify(%);
  / d            \              / d  / d            \\
  \ dz           /              \ dx \ dx           //
         / d            \                 2
   + 2 I |--- H(x, t, z)| R exp(I R x) - R  exp(I R x) H(x, t, z)
         \ dx           /
      (5/2)              / d  / d            \\
   - R      exp(I R x) + |--- |--- H(x, t, z)|| exp(I R x)
                         \ dt \ dt           //
                             |              (1/2)|
   + exp(-2 Im(R x) + I R x) |H(x, t, z) + R     |  H(x, t, z)
                             |              (1/2)|   (1/2)
   + exp(-2 Im(R x) + I R x) |H(x, t, z) + R     |  R
                                                  4
                             |              (1/2)|
   - exp(-4 Im(R x) + I R x) |H(x, t, z) + R     |  H(x, t, z)
                                                  4
                             |              (1/2)|   (1/2)
   - exp(-4 Im(R x) + I R x) |H(x, t, z) + R     |  R
collect(%, exp(I*R*x));
 /  (5/2)       / d            \      2
 |-R      + 2 I |--- H(x, t, z)| R - R  H(x, t, z)
 \              \ dx           /
        / d            \   / d  / d            \\
    + I |--- H(x, t, z)| + |--- |--- H(x, t, z)||
        \ dz           /   \ dx \ dx           //
      / d  / d            \\\
    + |--- |--- H(x, t, z)||| exp(I R x)
      \ dt \ dt           ///
                              |              (1/2)|
                              |              (1/2)|   (1/2)
                                                   4
                              |              (1/2)|
                                                   4
                              |              (1/2)|   (1/2)
I run Maple 2021 under Ubuntu 20.04 on a new Lenovo laptop with 32Gb of Ram. Every time I start Maple, it runs for a few minutes and then loses the "kernel connection". I have to save the worksheet and re-start Maple. In dmesg, I find:
[ 1436.724570] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@1000.service,task=mserver,pid=8037,uid=1000
[ 1436.724589] Out of memory: Killed process 8037 (mserver) total-vm:31723552kB, anon-rss:31289772kB, file-rss:60kB, shmem-rss:0kB, UID:1000 pgtables:61656kB oom_score_adj:0
[ 1437.151441] oom_reaper: reaped process 8037 (mserver), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
indicating that Maple's virtual memory exceeded 30 Gb! This happens even if the only command I execute is, for instance, "resrart" or "A:=1" and nothing else. It also happens when no other applications are running and the "top" command indicates that around 30Gb of RAM is available.
In this state, Maple is utterly useless to me. This was a new install of Maple and a fresh install of Ubuntu on a new laptop, surely I am not the only one seeing this?
I have tried setting a 30Gb limit in "kerneloptions" for "stacklimit" but that di not make a difference.
If you have seen any behaviour like this, please respond. Is there some bug in Maple that leads to oncontrolled and unprovoked memory grabbing?
First 75 76 77 78 79 80 81 Last Page 77 of 371
