The IsSubgraphIsomorphic command accepts either two undirected graphs or two directed graphs as input.  It returns true if G1 is isomorphic to some subgraph of G2. The GraphTheory [IsSubgraphIsomorphic] command was introduced in Maple 2021.
If a graph T is isomorphic to some subgraph T' of  a graph GIsSubgraphIsomorphic(T,G)  will  return true. But there is no option to return T'. That makes it hard to check manually.
I've seen  IsSubgraphIsomorphic behaving strangely lately. I want to check whether K8-P6 contains K7-K3 as its subgraph.
T:=DeleteEdge(CompleteGraph(7),{{1,2},{2,3},{3,1}},inplace= false):
G:=DeleteEdge(CompleteGraph(8),{{1,2},{2,3},{3,4},{4,5},{5,6}},inplace= false):
I think theoretically, the result of IsSubgraphIsomorphic is not correct. I also tested it from Mathematica, and it worked as I expected.
h = EdgeDelete[ CompleteGraph[7], {1 <-> 2, 2 <-> 3, 3 <-> 1}];
g = EdgeDelete[ CompleteGraph[8], {1 <-> 2, 2 <-> 3, 3 <-> 4, 4 <-> 5, 5 <-> 6}];
IsomorphicSubgraphQ[h, g]
False
I wonder what went wrong.
PS: Subgraph isomorphism is a question I've asked before, and we can refer to the following links and code. https://www.mapleprimes.com/questions/226937-How-To--Test--A--Graph--Whether-Contains
with(GraphTheory):
with(combinat):
G:=DeleteEdge(CompleteGraph(8),{{1,2},{2,3},{3,4},{4,5},{5,6}},inplace=false):
nE,nV := NumberOfEdges(T), NumberOfVertices(T):
# Produce all subgraphs of G which have the same number of edges and vertices as the "test" sub-graph T
U:=choose(Edges(G),nE): nops(%):
U1:=select(t -> (nops(`union`(t[]))=nV), U): nops(%):
gL:= Graph~(U1): nops(%):
ans:= [ seq
          ( `if`
            ( IsIsomorphic( T, gL[j] ),
              j,
            j=1..numelems(gL)
if   numelems(ans)>0
then HighlightSubgraph( G, gL[ans[1]], edgestylesheet=[thickness=4, color="Red"]);
     DrawGraph(G, style=spring);
fi;
These codes are due to tomleslie  and  vv. According to above codes, it seems that there is something wrong with IsSubgraphIsomorphic too.
Hi there!
Do you know when the new version of Maple will be released?
Do you think it might come with a "Dark Theme"?
Kevin
The question https://www.mapleprimes.com/questions/233780-Plot-Absolute-Advantage-Of-Option-A disappeared (I know since I answered today).
Why?
A have som problems when i Will save a project. It Will take 2-5 Minutes where my other freinds never Experince this? Also i have some problems when i pauses writing, when i take notes in class, it Will give me the loading circle on mac( iam using a MacBook Air 2018)
i hope you Can help:)
thx
The two points on the sphere has radius r=1/2. So, the distance is 1.
The three points on the sphere has radius r=1/sqrt(3). So, all distances are 1.
The four points on the sphere has radius r=sqrt(6)/4. So, all distances are 1.
What is the smallest sphere radius for 5 points and above numbers?
Find the smallest sphere radius and 3D position of each point.
Answer of smaller radius is better.
Tokoro.
All distances of point to point on the sphere to be integer.
What is the smallest sphere radius for 5 points and above numbers?  Find the smallest sphere radius and 3D position of each point.
with(plots)with(GraphTheory); with(LinearAlgebra); with(SpecialGraphs)
with(plottools)
The answer of 4 points. r=sqrt(6)/4
plots[display]([c, nodes, plotlinesx], scaling = constrained, style = wireframe, axes = boxed)
Download 3D-4points.mw
I know how can I use gauss seidel to solve a linear system.
But, how can we add chebychev acceleration.
hi
hiiiiiiiiiii
i am working and modling on brushless motor for my project but when i run that i get this error and i can not fix that could you please help me. error is :
equation generation
(}),At offset 4370 in `:-2108.m`, unexpected DAG type: 0,125
every project  i run  has the same error
@acer,
In the past, you had shown how to use take a given sparse A matrix and store the LU components and use the same factorization for multiple backsolves at https://www.mapleprimes.com/posts/41191-Solving-Sparse-Linear-Systems-In-Maple#comment200817
When PDEs are solved, we are calling the A matrix at every time step (with some discretizations in x) and the factorization is done and stored at every time step (this is time-consuming and memory-consuming). Is it possible to call UMFPACK using only the sparse storage and entries? The main routine seems to provide the option
https://people.sc.fsu.edu/~jburkardt/f77_src/umfpack/umfpack.html
This would mean that the pattern is found only once for the Jacobian at t= 0, then only the non-zero sparse entries (vector/row, not a matrix) are updated at every time step.
To be clear, what I am asking for is create a random sparse matrix (say 4x4 or 10x10)
create a b Vector.
Solve AZ =b with method = SparseDirect. (This should internally create and store R, CC, X as at https://people.sc.fsu.edu/~jburkardt/f77_src/umfpack/umfpack.html)
Store R, CC, X and update only X for a different A matrix with the same sparsity pattern and solve for Z using stored (R, CC), and updated X.
which kind of input is DeepLearning:-Optimizer(GradientDescent()) suppose to take? Nummeric value or function?
I have an assignment for my class but I don't know how to get the answer without getting an error. Maple_2.mw
Vector Valued Functions
Level Sets of Scalar Valued Functions
This worksheet is meant to give you some tools that you can use to
explore vector valued functions and scalar valued functions of several variables.
We will use the Student[VectorCalculus]  and the plots  packages.
First we load the packages with a restart at the beginning.  That is
meant to make it easier to check what happens when you run your
solutions.
with(Student:-VectorCalculus);
BasisFormat(false):
with(plottools):
Deivatives and integrals for vector valued functions
Plotting velocity and acceleration along a curve
Plotting functions of two variables and contours.
Exercises
Download Maple_2.mw
with(Physics)
Setup(spacetime)
[spacetimeindices = greek]
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1142 and is the same as the version installed in this computer, created 2022, February 12, 11:16 hours Pacific Time.`
Define(t[mu])
{Physics:-Dgamma[mu], Physics:-Psigma[mu], Physics:-d_[mu], Physics:-g_[mu, nu], t[mu], Physics:-LeviCivita[alpha, beta, mu, nu]}
SumOverRepeatedIndices(t[mu]*t[`~mu`])
t[1]*t[`~1`]+t[2]*t[`~2`]+t[3]*t[`~3`]+t[4]*t[`~4`]
SumOverRepeatedIndices(t[mu]*t[`~&mu;`])
t[mu]*t[`~&mu;`]
Download greek-index.mw
windows 11 maple 2020 I can load other packages but cannot load the student packages
Session Save doesnt work:
DeepLearning:-Save("model.ckpt");
Error, (in DeepLearning:-Save) format not supported
DeepLearning:-Save("model.h5");
DeepLearning:-Save("model.keras");
Which format is supported?
Why int gives this error? Is this a known problem?
Update
fyi, This is reported to Maplesoft.
Here is updated worksheet. The int() command does not generate the error the second time it used, but generates the error the very first time used. Hopefully will be fixed in 2022 Maple.
`Standard Worksheet Interface, Maple 2021.2, Windows 10, November 23 2021 Build ID 1576349`
Example 1
expr:=(7*x - 3 + sqrt(x^2 + (x^3*(x - 1)^2)^(1/3) - x) + sqrt(-2*((-x^2 + x + (x^3*(x - 1)^2)^(1/3)/2)*sqrt(x^2 + (x^3*(x - 1)^2)^(1/3) - x) + x^2*(x - 1))/sqrt(x^2 + (x^3*(x - 1)^2)^(1/3) - x)))/(12*x*(x - 1));
(1/12)*(7*x-3+(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2)+(-2*((-x^2+x+(1/2)*(x^3*(x-1)^2)^(1/3))*(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2)+x^2*(x-1))/(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2))^(1/2))/(x*(x-1))
int(expr,x)
Error, (in IntegrationTools:-Indefinite:-AlgebraicFunction) invalid argument for sign, lcoeff or tcoeff
int(expr,x)
int((1/12)*(7*x-3+(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2)+(-2*((-x^2+x+(1/2)*(x^3*(x-1)^2)^(1/3))*(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2)+x^2*(x-1))/(x^2+(x^3*(x-1)^2)^(1/3)-x)^(1/2))^(1/2))/(x*(x-1)), x)
Download int_problem_feb_13_2022.mw
First 77 78 79 80 81 82 83 Last Page 79 of 371
