Who deleted my post - "How to factor out specific parts from expression"
I want to solve system of  PDE equations by maple and i dont know how can i write it codes that can solve them for me. Can anyone help me please??!!
So I just noticed that if you want to animate something in real time, the best you can achieve is something close but not exact.
For example lets say we have a ball travelling 22 m/s over 1000 m and I want to animate that in real time.
ball := proc(x, y) plots[pointplot]([[x, y]], color = blue, symbol = solidcircle, symbolsize = 40); end proc:
animate(ball, [22*t, 0], t = 0 .. 1000/22, frames = floor(1000/22));
frames has to be an integer value so determining how long it will take and adjusting the frames to 1 frame per second.  It requires a bit of manipulation to get it right.  Is there a better way?  I suppose boosting the frame rate and increasing the number of frames would work but then it becomes cumbersome and any large period of times would use a high number of frames and consume enormous amounts of memory.
Every time I open Maple it has the invitation to Login in the top right-hand corner.  I would like to sign in but have had quite a bit of trouble doing that.  I have a user name and password with Maplesoft web store and the same for MaplePrimes.  Should either of these work to log in?
with(plots); with(LinearAlgebra)
couples := [5, 0], [6, 0], [6, 3], [10, 3], [7, 5], [9, 5], [7, 7], [8, 7], [5.5, 9], [3, 7], [4, 7], [2, 5], [4, 5], [1, 3], [5, 3]
Points := Matrix([[5, 6, 6, 10, 7, 9, 7, 8, 5.5, 3, 4, 2, 4, 1, 5], [0, 0, 3, 3, 5, 5, 7, 7, 9, 7, 7, 5, 5, 3, 3]])
Homothety
W := Matrix(2, 2, {(1, 1) = (1/60)*k, (1, 2) = 0, (2, 1) = 0, (2, 2) = (1/60)*k})NULLNULL``NULLNULL
Rotation on x axis
X := Matrix(2, 2, {(1, 1) = cos((1/90)*Pi*k), (1, 2) = sin((1/90)*Pi*k), (2, 1) = sin((1/90)*Pi*k), (2, 2) = -cos((1/90)*Pi*k)})````NULLNULL
Rotation of angle k
Y := Matrix(2, 2, {(1, 1) = cos((1/180)*Pi*k), (1, 2) = -sin((1/180)*Pi*k), (2, 1) = sin((1/180)*Pi*k), (2, 2) = cos((1/180)*Pi*k)})NULLNULLNULL
n := Multiply(Y, Multiply(X, Multiply(W, Points)))
_rtable[18446746437110297774]
(3.1)
NouvCouples := seq([n[1, i], n[2, i]], i = 1 .. 15)
Sapin := animate(polygonplot, [[NouvCouples], color = "ForestGreen"], k = 0 .. 180)
Neige
PointsNeige := seq([-30+i, 30-(1/2)*j*sin(i+j)], i = 0 .. 60); neige := animate(pointplot, [[PointsNeige], color = black], j = 0 .. 60, view = [-30 .. 30, 0 .. 30])
display([Sapin, neige], scaling = constrained)
Download Homework.mw
Hi, i need some help for a homework.
Here is the statement
You must first animate a series of linear transformations on the polygon formed by the following couples: [5, 0], [6., 0], [6, 3], [10, 3], [7, 5], [9, 5], [7, 7], [8, 7], [5.5, 9], [3, 7], [4, 7], [2, 5], [4, 5], [1, 3], [5, 3] It will be necessary to make, at the same time, a rotation around a line making an angle k with the axis of x, a rotation of an angle k and a scaling of variable ratio (but equal to 3 at the end animation). The k animation parameter should range from 0 to 180. I suggest you use the color green for your polygon. Then you will need to create a second animation by entering these command lines: SnowPoints: = seq ([- 30 + i, 30 - j / 2 * sin (i + j)], i = 0 .. 60): snow: = animate (pointplot, [[PointsNeige], color = black], j = 0 .. 60, view = [-30 .. 30, 0 .. 30]) : Finally, you will have to roll both animations at the same time.
The GIF shows the results that I should get according to my teacher
Thanks for the help !
In the obselote book programming examples it is using array's as data type
Is het easier to use A Vector or Matrix as datatype?
Error occurred running sample test.java (at new EngineCallBackDefault()):
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffd66e7345a, pid=1740, tid=7716
# JRE version: Java(TM) SE Runtime Environment (11.0.1+13) (build 11.0.1+13-LTS)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (11.0.1+13-LTS, mixed mode, tiered, compressed oops, g1 gc, windows-amd64)
# Problematic frame:
# C  [maplec.dll+0x345a]
# No core dump will be written. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
I compute the solution of first order nonlinear ode, supplied to initial condition.
The code is written, the exact solution is derived.
 plot the solution in a small interval like (0,1/5) I see that there is no difference between exact and semi-analytical soluton.
But, If I plot the solution in other interval like (0,1) or (0,2), It is noticed that the semi-analytical solution is different to the exact solution.
Thansk you in advance for your help
test3.mw
Apparently a colon within a string causes some issues when generating a XMLElement.
Didn't find anything in Maple Help about that though.
with(XMLTools)
dummy := "NS-EN 1995-1-1, part 1-1, Section 6"
XMLElement(dummy)
_XML_Element(_XML_ElementType("NS-EN 1995-1-1, part 1-1, Section 6"), [], [])
dummy1 := "NS-EN 1995-1-1, part 1-1, Section 6: Ultimate"
XMLElement(dummy1)
Error, (in XMLTools:-XMLElement) element tag name `NS-EN 1995-1-1, part 1-1, Section 6: Ultimate' contains the namespace prefix `NS-EN 1995-1-1, part 1-1, Section 6', but there is no `xmlns' attribute
Download xmlns.mw
Good day everyone,
I have problem-solving this system of equations using Iterative Projection Theorem. Anyone with a better explanations please.
The equation is as stated below.
Solve this set of equations using the iterative projection theorem.
(x1 - 2)2 + (2x22 - 6)2 - 5 = 0
(x12 - 4)2 + (x2 - 10)2 - 39 = 0
Take the provisional values of  x1 and x2 as x01 = 5, x02 = 4,
Thank you in anticipation
Good day everyone, please I'm soliciting help on how to solve PDE in Maple. I know how to solve ODE but I don't know how to go about PDE. The problem I want to solve is attached as an attachment. If epsilon is zero, then the problem reduces to ODE which can easily be solved, but epsilon is not supposed to be zero. please I need your help, thank you in anticipation.
PDE.pdf
How to change the distance (spacing) between 2D Input cells and 2D Output cells so that this procedure can be inserted into a style sheet and thus applied to multiple documents?
Oliveira
Hi Maple Users,
Microsoft is enticing me to upgrade to Windows 11 from 10 for free. I am a bit hesitant because I don't know if Maple 2021 will continue working as well as in Windows 10. Does anyone have any thoughts or wisdom to share.
How do i get to the 2nd line for a multiple problem?
I am generating several random weighted graphs using the following code:
with(GraphTheory):
with(RandomGraphs):
G:=RandomGraph(10,20,connected):
G1:=AssignEdgeWeights(G,5..25):
DrawGraph(G1,showlabels=true,stylesheet=[edgecolor=blue,weightfont = [times,bold,11]])
By default weight labels appear to be positioned at the midpoint of each edge. Is there a way to change that positioning?
First 81 82 83 84 85 86 87 Last Page 83 of 371
