have table like table(symmetric, [() = x]) from other code not mine, strange syntax
how to extract x from table thanks
I want to calculate the Noether Symmetries from the Lagrangian. Is there any built-in Maple cammad to  where i just put the lagrangian and get the determining PDEs and calculate the Noether Symmetries?
The timelimit command of Maple can be used to do a computation if it uses less than a given amount of time, otherwise generating an error message that can be cought by try ... catch. Now my question is that there exists any similar command, but with a limitation on memory usage, not the time usage. I don't mean what datalimit in kernelopts can does, because I am not going to limit the memory usage of the whole Maple session, but just a command which may be used inside a larger procedure etc.
I need help on maple code for solving both linear and non linear boudary condition for fractional order partial differential equation
I cannot solve the equation. The problem is:
we have the integrals (1) and variable (2)
(1) F := (a1, b1) -> int(1/sqrt(1 + (-1)*b1^2*sin(teta)*sin(teta)), teta = 0 .. a1)
(2) Phi(Pi/2, teta) = 2*(F((Pi/2 - teta_l)/2, sqrt(2/(1 - sin(teta_l)))) - F1(Pi/4, sqrt(2/(1 - sin(teta_L)))))/sqrt(sin(teta_l) - 1)
After the solution for variable (2) I received:
(-InverseJacobiAM(-Pi/4 + teta_l/2, 1/abs(cos(Pi/4 + teta_l/2))) - InverseJacobiAM(Pi/4, 1/abs(cos(Pi/4 + teta_l/2))))^2/(2*(sin(teta_l) - 1))
Next, I have the equation and (by the followed paper) should solve the equation respect to teta_l
M*B*(L/C)^2/G = 1/8*Phi(Pi/2, teta_l)^2
But I received just empty solution. The reference paper 10.1016/j.jmps.2020.104045
Can somebody recommend the way to solve the problem?
I need to declare a whole set of variables as local. The variable names are generates algorithmically using assign. Like so:
seq(seq(assign(cat(S,i,j)=Vector(datatype=float)),i=1..9),j=1..9);
Stand-alone, this works and creates all these Vectors for later use. But this:
local seq(seq(assign(cat(S,i,j)=Vector(datatype=float)),i=1..9),j=1..9);
does not work; I get an "error; '(' unexpected".
I really do not want to type all these by hand... on the other hand, if I do not declare these as local I get 99 warnings about implicit local declaration; not nice.
Is there a way to do this?
M.D.
PS: I do not upload as the one line really is all that is needed. At the lowest level one does not get the implicit-declaration warning, but with "local" it still fails.
My forced spring mass system is 4x"+4x'+3x=sin(wt). I calculated my w=w* value that maximizes the amplitude (0.5) and my initial conditions are x(0)=x'(0)=0. I need to graph x(t) when w= w* and when w=w*/2. How am I supposed to input this information into maple to create a graph?
i'm working with the confluent Heun function (Maple 2019).
Since for the case of an integer coefficient delta or gamma there are two integer Frobenius roots at the regular singularities 0 or 1, there is a logarithmic term in the Frobenius solution at these singularities. So, my question is the following:
When moving around this singularity in the complex plane, the value of the logarithmic term might depend on the choice of the complex logarithm's branch cuts. So, does anybody know just about how HeunC is implemented? Is there sth like a power series solution, which value would in my oppinion depend on this choice of a branch cut?
Or is there another implementation that preserves us from this ambiguity in the case of logarithmic singularities (i.e. integer coefficients in the confluent Heun equation)?
Many thanks,
This worksheet creates geodesics in the Poincare disk by transformation of a series of circles of diminishing radii in the complex plane.
The intersections of the geodesics are meant to create the first few pentagonal uniform tilings in the Poincare disk.
I do not know the mathematically correct way to create such a display, so the radii of the circles are only a trial and error approximation.
What Maple code will provide the radii of the complex circles which produce an accurate uniform pentagonal tiling?
Is there a better overall strategy for producing uniform tilings of the Poincare disk?
HyperbolicTiling.mw
When I use Solve for a PDE with the option singsol=all, is Maple guaranteeing that I am getting all the solutions, and in partidcular , is it returning the *general* solution(s)?
One of our users asks how they can find the Re ( sqrt(a+I*b)) where a, b are real.
They had tried entering the latter as "assume", without any luck.
We told them that it may not be very intuitive, but such expressions can be evaluated by wrapping into evalc which implicitly assumes that free parameters are real-valued:
evalc(Re(sqrt(a+I*b)));
How is the matrix of the affinity of base the plan of equation x+2*y-z=1, of direction u <1,0,-1>and of ratio 2 determined? Thank you.
I am trying to learn how to apply initial conditions to pdes with maple.  I have figured out how to do it with odes, but when assigning initial values to derivatives, I get weird results.  I have attached my Maple file, with the error, and a link to the document I am using as motivation for my analysis.
Test_1D_Wave_Equation.mw
https://personal.math.ubc.ca/~ward/teaching/m316/lecture21.pdf
I used to have this kind of code without problem:
myModule := module()
    option package;
    export myFunc;
    # local i;
    myFunc := proc()
        [seq(i, i in 1..10)]
end module;
But after upgrading to the latest version of Maple 2021, I get a warning
Warning, (in myModule:-myFunc) `i` is implicitly declared local |myModule.mpl:5|
I have to uncomment the local i declaration for the warning to go away. Has the behavior of seq changed in Maple 2021?
Maple returns to me an algebraic expression that involves many RootOf expressions and I have found it hard to get all solutions behind this expression (by using "allvalues") - this keeps on running without terminating. Is there a way to get the number of solutions without asking Maple to return all solutions explicitaly?
First 82 83 84 85 86 87 88 Last Page 84 of 371
