I discovered the MRB constant (CMRB) while using Maple. Since then, I've found many formulas related to it, including its integrated analog the MKB constant (MKB). They're both found in Google scholar!
However, I am stuck on proving the following.
Also prove the above equation, ReMKB+NoMKB-CMRB=0.
All my similar proofs are found at
https://www.mapleprimes.com/posts/214522-Formulas-For-The-MRB-Constant?sp=214522
Dear Users!
Hope everything going find with you. I want to generate sequence of Spline[i,p], p=1…M as given bellow
restart; M := 3;
for p while p <= M do
(x-x[i])*B[i, p-1]/(x[i+p]-x[i])+(x[i+p+1]-x)*B[i+1, p-1]/(x[i+p+1]-x[i+1]);
B[i, p] := collect(%, [`$`(B[i+s, 0], s = 0 .. M)]);
B[i+1, p] := eval(%, i = i+1)
Spline[i, p] := B[i, p]
end do
The expression for Spline[i,1] and Spline[i,2] are fine but the expressions of Spline [i,p] p>2 is not in simplified form I got the its simplification like given bellow for Spline[i,3]
Spline[i, 3]:=(x-x[i])^3*B[i, 0]/((x[i+3]-x[i])*(x[i+2]-x[i])*(x[i+1]-x[i]))+(((x-x[i])*(x-x[i]))*(x[i+2]-x)/((x[i+3]-x[i])*(x[i+2]-x[i])*(x[i+2]-x[i+1]))+(x-x[i])*(x[i+3]-x)*(x-x[i+1])/((x[i+3]-x[i])*(x[i+3]-x[i+1])*(x[i+2]-x[i+1]))+(x[i+4]-x)*(x-x[i+1])^2/((x[i+4]-x[i+1])*(x[i+3]-x[i+1])*(x[i+2]-x[i+1])))*B[i+1, 0]+((x-x[i])*(x[i+3]-x)^2/((x[i+3]-x[i])*(x[i+3]-x[i+1])*(x[i+3]-x[i+2]))+(x[i+4]-x)*(x-x[i+1])*(x[i+3]-x)/((x[i+4]-x[i+1])*(x[i+3]-x[i+1])*(x[i+3]-x[i+2]))+((x[i+4]-x)*(x[i+4]-x))*(x-x[i+2])/((x[i+4]-x[i+1])*(x[i+4]-x[i+2])*(x[i+3]-x[i+2])))*B[i+2, 0]+(x[i+4]-x)^3*B[i+3, 0]/((x[i+4]-x[i+1])*(x[i+4]-x[i+2])*(x[i+4]-x[i+3]));
I am waiting for positive respone. Please take care and thanks in advance
Please help to find the exact solution of any ODE by the >sinh or cosh method. I have attached arbitrary ODE here:
>ode:=U""+c^2*U"+k*c*U"-(3U^2+a)*U''=0
Send my matrix to word as matrix either via maple or phython
Say we have
A:=Matrix([[0, 1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 1, 0, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0], [1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 1, 0, 0, 1, 0, 1, 1, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 1, 0], [0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 0, 1], [0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 1, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0]])
How to write this matrix to a word file in a matrix form
In general If I have a n cross n matrix  How to write this matrix to a word file in a matrix form
This a Adjacency matrix
If I have several n cross n matricies I want them to be fprintf in the same file one after other giving paragraph space with some name of the matrix at the top.
Hi, when I tried the simple example of Java OpenMaple on Mac, I can compile the code but couldn't run it. It complained about not finding libjopenmaple.jnilib. I checked that library directory, there was /libjopenmaple.jnilib but not libmaplec.dylib. Any suggestions?
> java -Djava.library.path=/Library/Frameworks/Maple.framework/Versions/2021/bin.APPLE_UNIVERSAL_OSX -classpath "$MAPLE/java/externalcall.jar:$MAPLE/java/Maple.jar:." test
Error loading libraries: java.lang.UnsatisfiedLinkError: /Library/Frameworks/Maple.framework/Versions/2021/bin.APPLE_UNIVERSAL_OSX/libjopenmaple.jnilib: dlopen(/Library/Frameworks/Maple.framework/Versions/2021/bin.APPLE_UNIVERSAL_OSX/libjopenmaple.jnilib, 1): Library not loaded: @rpath/libmaplec.dylib
  Referenced from: /Library/Frameworks/Maple.framework/Versions/2021/bin.APPLE_UNIVERSAL_OSX/libjopenmaple.jnilib
  Reason: image not found
    at java.base/jdk.internal.loader.NativeLibraries.load(Native Method)
    at java.base/jdk.internal.loader.NativeLibraries$NativeLibraryImpl.open(NativeLibraries.java:383)
    at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:227)
    at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:169)
    at java.base/jdk.internal.loader.NativeLibraries.findFromPaths(NativeLibraries.java:316)
    at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:282)
    at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2440)
    at java.base/java.lang.Runtime.loadLibrary0(Runtime.java:809)
    at java.base/java.lang.System.loadLibrary(System.java:1893)
    at com.maplesoft.openmaple.Engine.<clinit>(Engine.java:23)
    at test.main(test.java:22)
Exception in thread "main" java.lang.UnsatisfiedLinkError: 'long com.maplesoft.openmaple.Engine.getKernel(java.lang.String[], com.maplesoft.openmaple.EngineCallBacks, java.lang.Object, java.lang.Object)'
    at com.maplesoft.openmaple.Engine.getKernel(Native Method)
    at com.maplesoft.openmaple.Engine.<init>(Engine.java:44)
Since I installed Maple 2021 I have noticed a problem with the left corner of the menu and toolbar.  See the screenshot attached. I don't know if this is a general problem in Win10 or is this a problem with my installation.
I've noticed after a creating a few documents that when save such documents as PDFs on my Mac, the drawing elements in my drawings are misalgined. Is this just a bug or is there a way to prevent this?  I've attached screenshots of the correct drawign in a document and what the result is in a pdf.
help.mw
How to solve Linear first-order PDE by the Lagrange method?
dx/(x) =dy/0=dt/0=du/3=dv/v=dw/w, where x,y,t are independent variables and u,v,w are dependent variables.
I have used Maple almost daily for the last four years, but a few days ago two students approached me with an issue I had never encountered before. However, it had happened to both of them within a few weeks.
They described the issue as follows: When they opened a random Maple document and they tried to type in simple operators (like +, - or *), Maple would instead write an odd symbol, which none of them recognised as a mathematical symbol.
As they could not find a way to solve the problem within Maple, they tried restarting their computers. When they afterwards reopened Maple, the problem was gone and the operators worked as expected again. Neither of the students has experienced the issue since.
During the last few days, I have been trying to replicate the issue myself without success. Therefore, I also don't have any screenshots to share, so hopefully my simple explanation is enough.
My questions are: Has anyone heard about this issue before? Does anyone know what might have caused it? Is there a way to replicate it and/or prevent it from happening again in the future?
I hope someone is able to clarify it a bit for me! :)
Frederik
How can I use symbols from the Emoji and Symbols collection on a Mac in a document or worksheet in Maple? I want to create documents but I find symbols not included in Maple that I require. I have found that some symbols will stay in the document if I insert them when in TEXT mode, but that does not work when entering a fraction for example and needing a symbol. When reloading a previously saved document, I find that the symbol has not saved.
A related question: how can I expand on the default symbols in the toolboxes?
For debbugging big programs, i have been told that one good solution is to use the mint application.
I'm trying to do so that is to say to use the mint application with windows. But, i encounter some difficulties.
The program on which i would like to apply the mint is composed of several parts like in the package Shapes and the different parts of the module are called thanks to the $include syntax.
To test mint, i have launched a command window with the command cmd in windows.
After, i apply cd PathRepertoryContainingMint
On i am located in this repertory, i test the following syntax :
mint -I PathRepertoryContainingTheDifferentFiles PathRepertoryContainingTheMainProgram\program.mpl
In my case these two paths are the same.
I test also the following syntax:
mint -o PathRepertoryContainingTheOuput\mintoutput.mpl PathRepertoryContainingTheMainProgram\program.mpl
It may run but i don't know where i can recover the output of mint
I have been told also to set the Windows PATH variable to include the Maple bin directory (thank you @Joe Riel for this tip). I think that it should be a good idea but I never do this type of manipulation.
On the net, I find that the process to do so is the following : setx path "%path%;c:\directoryPath"
Questions:
1) If you have some experience in using mint with windows, may you give some tips (precise the right syntax) to use it ?
2) In case the option -o is not used, where the output of mint is coming ?
I thank you in advance for your help.
Using a Cyrillic font in the Combo Box component gives an runtime error when saving workbook file (*.maple file extension).
cyr_wb_save_error.zip
Select the second item in Combo Box component and press save button.
Dear maple users,
Greetings.
In this code, the problem has executed. But I unable to get the graph.
Kindly do the needful to plot the figure at time t=0.45.
Also, please explain how to import the computed values into an excel file.
Waiting for your reply.JVB.mw
with(PDEtools):
ra:=1:b1:=4:na:=0.7:we:=0.5:eta[1]:=4*0.1:beta:=0.5/1:xi:=tan(0):m:=na:ea:=0.5:
R:=z->piecewise(beta<=z,(1+xi*z)*(1-(64/10)*eta[1]*((11/32)*(z-beta)-(47/48)*(z-beta)^2+(z-beta)^3-(1/3)*(z-beta)^4)),z<=beta+(3/2),(1+xi*z)*(1-(64/10)*eta[1]*((11/32)*(z-beta)-(47/48)*(z-beta)^2+(z-beta)^3-(1/3)*(z-beta)^4)),(1+xi*z));
proc (z) options operator, arrow; piecewise(beta <= z, (1+xi*z)*(1-(32/5)*eta[1]*((11/32)*z-(11/32)*beta-(47/48)*(z-beta)^2+(z-beta)^3-(1/3)*(z-beta)^4)), z <= beta+3/2, (1+xi*z)*(1-(32/5)*eta[1]*((11/32)*z-(11/32)*beta-(47/48)*(z-beta)^2+(z-beta)^3-(1/3)*(z-beta)^4)), 1+xi*z) end proc
PDE :=ra*(diff(f(x,t),t))=+b1*(1+ea*cos(t))+(1/(x*R(z)^2))*diff((x*(m+(1-m)*(1+(we*we*((diff(f(x,t),x)))^((na-1)/2)))^(-1))*(diff(f(x,t),x))),x);
PDE := diff(f(x, t), t) = 4+2.0*cos(t)+((.7+.3/(1+.25/(diff(f(x, t), x))^.1500000000))*(diff(f(x, t), x))+0.1125000000e-1*x*(diff(f(x, t), x, x))/((1+.25/(diff(f(x, t), x))^.1500000000)^2*(diff(f(x, t), x))^.150000000)+x*(.7+.3/(1+.25/(diff(f(x, t), x))^.1500000000))*(diff(f(x, t), x, x)))/(x*piecewise(.5 <= z, 1.440000000-.8800000000*z+2.506666667*(z-.5)^2-2.560000000*(z-.5)^3+.8533333331*(z-.5)^4, z <= 2.000000000, 1.440000000-.8800000000*z+2.506666667*(z-.5)^2-2.560000000*(z-.5)^3+.8533333331*(z-.5)^4, 1)^2)
IBC := {D[1](f)(0,t)=0,f(1,t)=0,f(x,0)=0};
{f(1, t) = 0, f(x, 0) = 0, (D[1](f))(0, t) = 0}
z:=0.77:
sol := pdsolve(PDE, IBC, numeric, spacestep = 0.1e-1);
module () local INFO; export plot, plot3d, animate, value, settings; option `Copyright (c) 2001 by Waterloo Maple Inc. All rights reserved.`; end module
Download JVB.mw
Does anyone use maple calculator?
I am trying to use it on my iPad for matrix functions.
I tried standard maple %T for transpose, get an error.  I've tried -1.  No joy.
I can't seem to find how to assign to a variable, or use indexing to a matrix element.
Any suggestions welcomed for iPad maple functionality.
I am having trouble with a Lie algebra cohomology computation. Suppose I have a poset on {1,2,3,4} where 1 < 3, 1 < 4, 2 < 3, and 2 < 4. I can express this as a matrix:
* 0 * *
0 * * *
0 0 * 0
0 0 0 *
where *'s mean "any entry in my ground field," say R or C, and 0s are 0s. Basically, if there is a relation between row i and column j, there is a *. This is why there is a * in row-1 and column 3, as 1<3, but a 0 in row-1 and column 2. I can make the collection of all of these matrices into a Lie algebra using the commutator, as it is closed, and can further suppose it is of trace 0 - that is, it is Type A.
My question is this: I know this algebra has non-trivial cohology, and deforms. However, I want to make Maple do this for me, so I can try it on bigger algebras - however it always tells me that the cohomology is dead zero. What am I doing wrong? My approach is this:
Let P equal the following collection of matrices - these form my basis:
 [Matrix(4, 4, [[1, 0, 0, 0], [0, -1, 0, 0], [0, 0, 0, 0], [0, 0, 0, 0]]), Matrix(4, 4, [[0, 0, 1, 0], [0, 0, 0, 0], [0, 0, 0, 0], [0, 0, 0, 0]]), Matrix(4, 4, [[0, 0, 0, 1], [0, 0, 0, 0], [0, 0, 0, 0], [0, 0, 0, 0]]), Matrix(4, 4, [[0, 0, 0, 0], [0, 1, 0, 0], [0, 0, -1, 0], [0, 0, 0, 0]]), Matrix(4, 4, [[0, 0, 0, 0], [0, 0, 1, 0], [0, 0, 0, 0], [0, 0, 0, 0]]), Matrix(4, 4, [[0, 0, 0, 0], [0, 0, 0, 1], [0, 0, 0, 0], [0, 0, 0, 0]]), Matrix(4, 4, [[0, 0, 0, 0], [0, 0, 0, 0], [0, 0, 1, 0], [0, 0, 0, -1]])]
Now I can run the basic commands to get started:
L := LieAlgebraData(P, Ex1);
DGsetup(L);
I can now go straight to cohomology. If my algebra is named L, then I want to build my cochain complex C^*(L, L):
c := RelativeChains([e1,e2,e3,e4,e5,e6,e7]);
However, the answer is always that there are no non-trivial cochains: the answer is [[], []]. This will make it very difficult to have non-trivial cohomology.
I know this isn't true (see https://arxiv.org/pdf/1407.0428.pdf). I also tried the approach in the Maple documentation, where I work in the adjoint representation. This gave me non-trivial cochains, but the cohomolgy was 0.
Does anyone know what I'm doing wrong?
First 86 87 88 89 90 91 92 Last Page 88 of 371
