The last several times that I've tried to use the Delete As Spam feature I've gotten an error message Error Generating Page, and the spam was not deleted. Anyone know what's happening?
We give a line (D) and a point A located at a distance AH=h from D. A constant angle of magnitude alpha pivots to its apex A and we call B and C the points where its sides cut the line D. Let O be the center of the circle circumscribed to the triangle ABC.
Demonstrate that the B and C tangents to the O circle keep a fixed direction.
Here is my code which don't work for slopes are not equal.
restart; with(plots): with(geometry):unprotect(D):
_EnvHorizontalName := 'x':_EnvVerticalName := 'y':
line(D, y = (1/2)*x-1); point(A, 5, 5); PerpendicularLine(lp, A, D); h := distance(A, D); intersection(H, D, lp);
alpha := (1/16)*Pi;
rotation(lp1, lp, (1/6)*Pi, 'clockwise', A); rotation(lp2, lp1, (1/6)*Pi-alpha, 'clockwise', A); FindAngle(lp1, lp2); evalf(%);
intersection(B, D, lp1); intersection(C, D, lp2);
triangle(T, [A, B, C]);
circumcircle(Elc, T, 'centername' = OO);
TangentLine(tgB, B, Elc); TangentLine(tgC, C, Elc);
evalf(slope(tgB)); evalf(slope(tgC));
dr := draw([D(color = blue), lp(color = red), Elc(color = green), A, B, C, T(color = black), H, tgB, tgC], printtext = true);
display([dr], axes = none, scaling = constrained);
Fig := proc (k) local dr, Elc, B, C, lp1, lp2; global D, A, lp, H, alpha; geometry:-rotation(lp1, lp, (1/6)*Pi+k, 'clockwise', A); geometry:-rotation(lp2, lp1, (1/6)*Pi-alpha+k, 'clockwise', A); geometry:-intersection(B, D, lp1); geometry:-intersection(C, D, lp2); geometry:-triangle(T, [A, B, C]); geometry:-circumcircle(Elc, T, 'centername' = OO); geometry:-TangentLine(tgB, B, Elc); geometry:-TangentLine(tgC, C, Elc); dr := geometry:-draw([D(color = blue), lp(color = red), Elc(color = green), A, B, C, T(color = black), H, tgB, tgC], printtext = true); plots:-display([dr], axes = none, scaling = constrained) end proc;
iframes := 10;
display([seq(Fig((1/12)*Pi+i/(10*iframes)), i = 1 .. iframes)], insequence, scaling = constrained);
How to improve this code ? Thank you.
In an answer to an earlier question
https://mapleprimes.com/questions/232067-Error-Invalid-Neutral-Operator
I inadvertently used the "Insert Contents" link - AND IT WORKED
Anybody know how long this has been fixed?
Hi everyone, i want to draw 3d graphics of fractional solution with given by Mittag Leffler function in cantor sets. I want to see like this graphic. I added maple file. Thanks in advance.
3D_graphic.mw3D_graphic.mw
I tried to used insert code edit region, to write many subcodes
but no return varibales names.
example, x:=3;
when I run the code, I get only the number affected to x, I would like to get
x:=3
No_return_variable.mw
Why is Maple 2020 in "abcapps.cloud.com" different from Maple 2020 in apps.abc.edu? I am connecting to maple 2020 in two different ways to the school where I work. The schools name is, say, "abc". The first version of Maple 2020 has two arrows at the top. The second arrow is the "upload" arrow and allows me to upload a file from my home computer the my folder at school.
The second version of Maple 2020 has no such arrows. Both versions allow me to get my Maple cloud working for local loading and saving Maple files. How can I upload a Maple file to my Maple cloud from my home computer in the second Maple 2020 version in apps.abc.edu? Or, how can I upload a file to my Maple cloud in any way from my home computer?
By the way, the second Maple 2020 version is coming from Microsoft's Remore Desktop Web Client. It look like it has its own navigation bar at the top.
Thank you!
mapleatha
I defined x(t) and y(t) with units; motion in gravity, motion in y-direction with constant velocity, motion in x-direction as motion with constant acceleration.
x := t -> 10*Unit(('m')/'s'^2)*t^2;
y := t -> 50*Unit(('m')/('s'))*t;
plot([x(t), y(t), t = 0*Unit('s') .. 5*Unit('s')]);
Error, (in plot) invalid terms in product: 0 .. 5*Units:-Unit(s)
It works fine if I remove the units.
Also I can plot graph for x(t) and for y(t) with units, but not graph for [x(t), y(t)]
How to solve the Linear first-order partial differential equation by the Lagrange method. Suppose u and v are dependent variables and x,y,z are independent variables of a partial differential equation of the form:
dx/f(x,y,z)=dy/g(x,y,z)=dz/h(x,y,z)=du/k(x,y,z)=dv/s(x,y,z). I need its solution in the form of u and v . How to find it ?
I'm trying out the simple Java example for accessing OpenMaple.  I'm doing it in IntelliJ using JDK15.  I've included the two jar files in the project, externalcall.jar and Maple.jar.  When compiling I run into this error, as IntelliJ doesn't seem to be able to find jopenmaple.jar
Error loading libraries: java.lang.UnsatisfiedLinkError: no jopenmaple in java.library.path: /Users/jasmith/Library/Java/Extensions:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java:.
Now, I'd like to add its location to the library path, but I can't seem to find its location.  My understanding is that is should be in $MAPLE/java/jopenmaple.jar
which, on Mac OS is "/Library/Frameworks/Maple.framework/Versions/2021"
But when I look in there there is no jopenmaple.jar.
Does anyone have a suggestion as to where I could find it?  (Maple 2021, IntelliJ 2020 with JDK 15 on macOS 10.14)
thanks!
James
When I open up Maple the toolbar which says insert: 'Math, Text etc' has disappeared. However sometimes when I restart the program the tool bar re-appears again. I have attached a screenshot have a look. I want to know is anyone else experiencing this in Maple 2021?
Some special graphs are temporarily difficult to be generated by maple's function NonIsomorphicGraphsSo I want to read some such data from the following URL.
http://users.cecs.anu.edu.au/~bdm/data/graphs.html
But recently I found out that the data on this website has been changed. Different graphs are not on a single line, so I can’t read them by maple effectively. The previous method fails.
https://www.mapleprimes.com/questions/228819-How-To-Import-All-Graphs-In-A-Graph6-File
restart: with(GraphTheory):
L:=ImportGraph("yourpath/graph5c.g6", graph6, output=list):
 DrawGraph(L);
For example: all 41 Strongly regular graphs(19,14,6,7).The g6 file is converted into text format, as shown below
\}rE^yceKLtLlGeduRQhMYLLKZZapjTSLUKw[kQXIyLbHtkCzStI`{y@}FOWzcBzHozFg
\}rEnYSbLSTVeek[ulB`YUiH[QrWqzLKhbRHU\EGRVzCfT]@vLMKdZgfGsigmUclBxQq[
\}rFMqidTgvDbYbdu]BHsULThIykJzwW@jPPTwaP`frcg{zEaxyB\Kx@vDiXEyXhCzcks
\}rFMyoiLcqseVblTlBG{TI\YsBoMqUqxiam\[D?JlzDKmYFEZcCyq\@puexMeDuKrHrc
\}rFUihddgvDbYbdu]BPsTLTeIyqJzwW@f`HUscP`frcg{zEaxyBlJT@nE[XEydhCzbKs
\}rMNeceLDqtedmQtmAbwYIt[pRTKZcpLsExRuE@Qldb`lMC{itHep]?{^cWUZmXLXPfo
\}rMNeockxsqayjHvIbHwSdtiaywbRRadXMX\i@_TlNcZXYMBZLHRknAk^oGnIBtBuLPk
\}rNEmSeLXUMifkiPyJ_rQlLipIfSrIkh[bF^BE?Q^vCstUDc{\@zRUcnEw`qJHxEu`c{
\}rNEmo`k\uQmBe\TkQhhYK\iRIwkjbSTJLX\iD?FtnAjXiJJO{EbmLCg}fovBKuHtIps
\}rNMqobdRqYdhhZVEQXFST\ctYVSrcppycE\Q`OF{mdBtuFBs\DmQwcw\Qgz`HrIp[Yk
\}rNUio`{rt`hkehUGycyYJd`pywdylE`jGd\XAOXjN_ZvNBYrWLBkwbW\QpMigfMm?m[
\}rNUmBhKpUMkijErbb_NXN@WyJT`ijQthL[Tcn?Frf`szIBXlhLSpofPdWhMTPvEtPNW
\}rNUmBiKhULkkjFRbR_NXN@WyJJ`qtQliK{TSv?Frf`szIBXlhMTPoepTWhMUHvEtINW
\}rNUmBiKhULkkjFRbR_NYN@SyJLQir`tdS{Uav?Frf`susBXuTLSpofPdWhMTPvEtPNW
\}rNUmBiKhUMkijErbb_NYN@SyJJQqt`leK{USv?Frf`sykBXmdMaioeigwhMdHvErQNW
\}rUNUgdLFrdhke`vIJ`qQetYkJaMrWdXLsR\gL@DNNd`nIE[jc@vInaZMl?^E`lLR`pk
\}rVE]gclhTRc{bVVcRPbUBtpUY\gAloteBy]Y@_JulbPtVGyq[LDXk`ktwWubamHrLRK
\}rVE]gdLWuda|c{VPIpbWjTdqYssRckdLLX^GH_Kv\dNG]Bhk]KPx^BHvoGnISlHuLPk
\}rVE]oakxsqmDczTkRPJP\TiwJcUarctUQm^BD?W^|AueMHVasKWzK`ZMUwuMIyHyHrc
\}reMuHkK\VBdmjHUYIpRWmLhqI[iYskdsbX\RD?c^{c[wnJElSD^Ak?}MYwyFLUIrIXs
\}reMuWglFrdbdlKVGZOtTLdikAeeY\BxwTU\YE?dVm`hyVI[jcHRZpaZfKHkLHtB{O\k
\}reMuoiDLrcefb\U]BPhSjd[YRgiREetM`{]Y@_dfN_|ijIYq[AvMdAjLsX[LDuLPlPk
\}ree]`eLhrakkazTorDiYG|YWzWkajgpUJJ]Y@_LZlf@lMA{g~DXjU@jXsHeMcjHuLPk
\}rmeU`clPrJfIlcs{ahhYFTJqJFQqi[dqIl^KD?JfzEKwyEikkHfH\@o~ow]qEuMPYNc
\}vENMahLWrUeUkXrtAhsRLTRURgbZTWhiJJ]WM?FVxeRcvI[hsDg{w`hlxO]kPmLRST[
\}vevMgiKaolcjlEpub`XTG|K]AKryFk\wTTYYf?UZdcY\NL`lHFUJDbkhLH\EKtK}Co{
\}zEmYWglgo}kRa{vdAbbYdLqeIq[rKqdTwSZGpWH^}civEEeqlI^@w@xLdW|HEmKo|P[
\}zUvMckCTpJ`\fJUUR`iYIhSXiSliFU|[eYXVF?NXLaW~IJSpoFeaLfGldp\Bc}K}CYw
\}zUvMgkChpQ_~fLSlaXXST\QiiLMjA{tkXF]Kf?YNXc]LsLdKdLWoufPclW]s`{EyUP[
\}zVMq``lPqRb[fBu[aoxXJPEbyb[yUqhbUJ^KE@`fj`ivEAxZTM`oma~?YXiRRXJal`[
\}zVUmobCoqV_zjKsnB`RQUtEsyKmjA\t[iK]L?wZFFc]TeLTQTLashdpclWupcyExVAk
\}~EMmPhCXtNkchirURHdUItQ]JhQjFgxiDeRUMGF\laixeBh]XK[W|BrCwXUUQrNPcbk
\}~VEMQbDBtQeZdlSnA@}\@lX`rLQqYwliosSueHINx@[twDlI\MEZd@yWVheYIuNI_yk
\~rEM]WhLTS^d[ecv`ITqRD\hqRciYxSTpMX\gL?L\]crYMD\MKIPzNAX]tOvIEmJUHpk
\~rE~YWdKKsJaZjLUTR_ZRK\gjQdkIIt|i[MTXe`KNT`\fEL]@LFatEfITLXNBM[EtSp[
\~rE~YceKSsL`jlMRIqpLTD\EqiRqjA{\kJX[jD_iVddPleJ[HNMkcWaz`JW^IsJKoxrS
\~rF]ySiCXqTglhUrMb`bQ]dE[yJMqSNls[E]IaXQZFai[mFiSTJkKieXj`PNDWzEtahw
\~rU^QccSTqiblgzVFA@}Y`lL`qrcjJWpqXYTeLPoNwaslsBVJXG{itCyWfWuYEyNI_yk
\~veMUSiCFpqejk\SnA@}[`lLarWwjFQtXWwTkTHINxBKlwBlI\KejdAxgVhUeIuNI_yk
\~zE]mcdKcpHa^lJTUaW]WilDsrBMYcr|w[EVKeG[jFa\deLP]FJiTHFIUgWvEEzHuaiw
\~zUUMPhCTuKilbVQvA@}R`lwPrIwqxQpbguS{dOkNxDKlkB[jdKfItCyWNguYKuNI_yk
I don’t know how to select some graphs from them , so helpless.
I'm using the command
Matlab(AA,resultname="A",optimize=tryhard)
to generate Matlab code for a quite big matrix. The first problem is, that I get a lot of the following warnings
Warning, cannot resolve types, reassigning t33's type
for a bunch of different t** variables. When I copy the generated code to Matlab I get the error: 'Dimensions of arrays being concatenated are not consistent.'
I found that some entries are obviously transposed like
t50 = [0 0 0 0 0 0 t34 0 0 0 0 -t33 t37 0 0 0 0 0 -t44 0 0 0 0 0 t49 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0];
should be a column vector. Here is a snippet of how the resulting matrix A is constructed (I can't show the full code because it consists of some 100 lines):
A = [t50 t97 t143 t190 t237 t261 ... ]
I tried to manually transpose the entries. The matrix can be generated but the dimension is wrong, hence, it must be a wrong matrix then. Does anyone know what could be the reason for this? I generate the matrix via the Hessian-command
I'm trying to use an older package but the results of the author's own example returns the error:
"Error, (in SumTools:-DefiniteSum:-ClosedForm) summand is singular in the interval of summation"
I don't have access to the source coude, but by looking at other similar issues it seems to be happening when "sum" function is used. Is there a way to force Maple use "add" instead?
Hi, dear community,
I have a Maple package "rath" for finding the traveling wave solution of differential equations. But I am not able to loading in Maple 18. Please see this attached zip folder and need help in this regard.
Kind regard
inform.txt,
PaperExp.mws
rath.txt
First 88 89 90 91 92 93 94 Last Page 90 of 371
