Is there a way to make all computations in Maple to run modulo specified prime p? If, for example, I want to use a function such as DifferentialAlgebra:-RosenfeldGroebner and force it to run its internal computations modulo p, can this be done?
So far I have tried to use GF(p, k), but there seem to be issues where `+` and other operations require defining all symbold via :-ConvertIn().
Dear administration, I hope you all are good,why my question have been deleted? My question is a little similar to the one before, but there are still a lot of differences.I didn't do a backup which was bad.Once deleted, there is no chance of modification.
Is there a possibility of aligning choices in a horizontal manner?
QuizzTest1.mw
Hello!
I have a difficulty with a function used in procedure. The procedure uses a multivariable function and if the specific choice of the function is not made the procedure seems to give proper result, but In case I make a specific choice of the function and then try use this procedure gives me incorrect result.
To be more exact I use Physics package (there is a need to calcute combinations of covariant derivates ). The calculations are performed in a curved space with a defined metric.
So here is the procedure:
SD2 := proc (psi) SumOverRepeatedIndices(g_[`~kappa`, `~lambda`]*(d_[kappa](d_[lambda](psi(X)))-Christoffel[`~sigma`, kappa, lambda]*d_[sigma](psi(X))))^2-SumOverRepeatedIndices(g_[`~kappa`, `~rho`]*(d_[kappa](d_[lambda](psi(X)))-Christoffel[`~sigma`, kappa, lambda]*d_[sigma](psi(X)))*g_[`~lambda`, `~tau`]*(d_[rho](d_[tau](psi(X)))-Christoffel[`~gamma`, rho, tau]*d_[gamma](psi(X)))) end proc;
If I turn to the procedure :
SD2(psi);
the result is  correct.
But  then I specify a psi function:
psi:=(t,r,x,y,z)->chi(r)+q*t;(here q is supposed to be a constant)
and turn to the procedure once again:
SD2(psi);
It gives me a wrong result.
I don't know what is the reason.
Hello, I'm a student in high-school, and i was wondering if it is possible to have multiple people writing in the same document at the same time. It would make groupwork a lot easier if I could do the writing like e.g.: google docs.
-Max
Here's another possible bug related to special characters (like ø, æ, å).
SubString considers each of the characters to be consisting of 2 different other ones.
Related to https://www.mapleprimes.com/questions/231765-Special-Characters-In-Maple-Workbook-Code.
with(StringTools)
a := "Øyeblikk"
"Øyeblikk"
SubString(a, 2 .. ())
"�yeblikk"
SubString(a, 1 .. ())
"Øyeblikk"
SubString(a, 3 .. ())
"yeblikk"
Download SubString.mw
I'm using Maple on a linux partition and for some time now I can't really use it anymore. For example, when I open a help window, I can't scroll through the content, and scrolling gets stuck if an image needs to be displayed. I think my partition is too full and does not have enough free space left. Doesn't Maple create a temporary file that is too big for the space available?  But I have another partition that is not in the same format as the linux partition but is nevertheless readable and writable. Is it possible, if the problem is a temporary file, that this file is written to this other partition to avoid this storage problem?
Or could it be due to a memory problem (RAM?) that did not occur before?
I want to solve this system of PDEs. Please let me know how I can solve it.
Kindly find both my code written in Maple and the image of the problem.
Best,
PDE.mw
Two days ago I have answered a question about using numapprox:-infnorm for functions of several variables. The question is now deleted. Is it possible to find whether it was deleted by the author (even if she/he has used the "best answer" tag)?
PDE:
(a+b)*(uxx+vxy)+c*laplacian(u)=0
(a+b)*(vxy+vyy)+c*laplacian(v)=0
a,b,c=const.  Initial:u=1/2*sin(2*theta),v=cos(theta)
Text book says: Solve by complex variable method
I'm french and I'm working on an Imac.
The path for the desktop is  /Users/myname/Desktop.
If cur := "/Users/myname", one can easily verify this:
IsDirectory(cat(cur, "/Desktop"))
In some application I'm developping, I use a  FileDialog Maplet to select a directory where to write a file.
For an unknown reason this maplet doesn't display the desktop with the name Desktop, but with it's french counterpart Bureau.
# Observe thet the desktop (8th line above) is named "Desktop"
# Now run
 maplet := Maplet(
      FileDialog['FD1'](
        'title' = "Output Directory",
        'directory' = cur,
        'fileselectionmode' = directoriesonly,
        'onapprove' = Shutdown(['FD1']),
        'oncancel' = Shutdown()
res := Maplets[Display](maplet):
StringTools:-StringSplit(res[], cur);
                        ["", "/Bureau"]
As a result, saving a file in cur/Bureau generates an error.
Here is a more detailed worksheet:
English_French_confusion.mw
Of course I have adjusted my code in an ad hoc way by french translating  what the maplet returns, but it is just a band-aid on a larger wound. For instance "Downloads" appears as "Téléchargements", and so on, and many names potentially need to be translated.
I do not understand why FileTools seems to "work in english" while  FileDialog seems to "work in french".
I suspect this is due to the fact that my Imac, although natively "English speaking", uses a French overlay.
For instance the  Unix command pwd run in a terminal window indicates Users or Desktop, while  < command + i > executed on a given file displays Utilisateurs and Bureau.
Could it be that FileTools relies upon English, while FileDialog  relies upon the regionalized language?
What do you advice me:
  • to intervene at the Apple level by changing the "user" language my Imac uses,
  • to intervene at the FileDialog  level (if possible),
  • or to keep translating undesired outcomes from FileDialog?
I have two functions u(x,y,t) and p(x,y,t).
I want to find the total derivative of D_x( p*u) (where * is the multiplication)
where D_x is as given in the attached file formula_of_D_x.pdf
Also, it is given in the following link but it's not clear to me. I think it somehow resembles my query, but not clear about the syntax so that I should implement it on mine.
https://www.maplesoft.com/support/help/Maple/view.aspx?path=DifferentialGeometry/JetCalculus/TotalDiff
Any idea of how to import necessary libraries for use in Maple Player?
Dear administration, I hope you all are good, why my question have been deleted? Even my important question on legends was deleted.
Two questions posted by AHSAN have just been deleted.
They were somewhat redundant with a previous one, which probably justifies their deletion.
Nevertheless, some had given AHSAN answers or replies: in this case, could the answers not be kept in some place? Perhaps in the question that the "eraser" thought was the original question?
First 91 92 93 94 95 96 97 Last Page 93 of 371
