I have a time-fractional PDE as follows.  ( denotes Caputo fractional derivative with respect to t)
for alpha=1, this is a classical PDE and the exact solution is given as follows (in a book)
Question:
1) for alpha=1, I want to find the L2 errors and L∞ errors in a table.
2) for alpha=0.5, Can Maple find a solution (numeric or exact)?
MY TRY: (MAPLE 2020.2)
download the code.mw
PDE:=diff(y(x,t),t)=y(x,t)*diff(y(x,t),x$3)+y(x,t)*diff(y(x,t),x)+3*diff(y(x,t),x)*diff(y(x,t),x$2) ;
#c is an arbitratry constant
c:=4:
exact_sol:=(x,t)->-8*c/3*(cos ((x-c*t)/4))^2;
# I selected initial and boundary conditions as follows
IBC := { y(x,0)=exact_sol(x,0),y(0,t)=exact_sol(0,t),D[1](y)(0,t)=D[1](exact_sol)(0,t),y(1,t)=exact_sol(1,t)};
numeric_sol := pdsolve(PDE,IBC,numeric);
num3d:=numeric_sol:-plot3d(t=0..1,x=0..1,axes=boxed,
            color=[0,0,y]);
exact3d:=plot3d(exact_sol(x,t),t=0..1,x=0..1,axes=boxed);
display(exact3d,num3d);
pdetest(y(x,t)=exact_sol(x,t),PDE,IBC);
I have a system of pde that it is solved with pdsolve procedure.
This procedure takes a few time, but when I need to do plots, especially 3d plot the software takes a lot of time (several hours).
How can I make plots faster?
It's been about a year since I've been able to display any worksheet at all on MaplePrimes. In the example below, I took a very simple worksheet that had been displayed in an Answer to another recent Question and tried to upload it. So, we know that it's somehow possible to display this particular worksheet on MaplePrimes.
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/prove.mw .
Download prove.mw
I am facing difficulty to realize this double iterative process.
The equations in question are
The flow chart for the iterative process is given as
The different parameters are defined as
alphan:=1.72*10^(-4):
alphap:=2.037*10^(-4):
L:=1.3*10^(-3):
A:=2.08*10^(-6):
kp:=1.265:
kn:=1.011:
sigmap:=1.314e-5:
sigman:=1.119e-5:
alphapn:=alphap-alphan:
Rpn:=L/(A)*(sigmap+sigman):
RL:=1:
Kpn:=(A/L)*(kp+kn):
cf:=4205:
cc:=4153:
hf:=80:
hc:=1000:
Tfin:=773:
Tcin:=353:
mf:=20:
mc:=20:
Influence_of_different_cooling_methods_on_thermoelectric_performance_of_an_engine_exhaust_gas_waste_heat_recovery_system.pdf
Has anybody tried Maple 2020.2 on a new Macbook with Apple silicon? I believe native support is in development, i was curious if anyone had experience running Maple via Rosetta 2?
I have a problem when searching in a document. Namelly is there a way to search in the whole worksheet including all code editing regions?
In order to show a point, there is a worksheet. I determine a variable
x11:= 12;
This variable is used in the document and code edit regions. Then I want to change a variable name from x11 to x11data. In order to do that, I use Ctrl+F to find all the times when the variable is used. I have a problem while  searching 'x11'. Namelly, the cases outside a code edit region are displayed, and the ones that are situated in the code edit regions are not seen.
Best regards
I used dsolve to solve the Initial value problems numericaly.
When I set the parameter range=1..5*10^4 , it works and cost only about 200s cpu time.
But if I set range=1..2*10^5, it stop running ( cpu time stop) when the mserver memory reach about 1.5 G. (the memory record in the bottom-right of maple interface is about 700M .)
What is the reason please?
I need help for designing a procedure for Schubert Kronecker polynomial program in maple.
so i have a little school laptop and maple on it works just fine. Then i have my all powerful gaming desktop with an AM RTX 3700x ,RTX 2070S, SSD and 32GB ram.
I have never seen maple run so slow on any pc as i have on my desktop. It is completely impossible to use maple. Just writing normal input like 123 takes forever. One thing i have noticed is evertime i do some sort of action, then the icons to the left slowly go from being colored to grey and back to colored before i can do a new action.
The two images below show an example here you can see it is about to go from being colored to being grey, when i try to mark stuff. I have tried to install the x64 and x86 version, i have tried giving it 4096 ram in the ini file and i have tried removing splash. Nothing works....
I want to find fundamental matrix of the system: X(t).
Actually I need A=X(T) where T is 2*Pi.
So then I can find whether the solution is stable.
The problem is, I don't understand how to find X(t) in Maple.
Tried to solve numerically with dsolve at t=T but the next step is not obvious.
Eq=z"(t)+3z'(t)+2z(t)=24*(exp(-3t)-exp(-4t)) how to find the gereral solution of this equation. Thank you.
The last months Maple 2020 suffers from frozen interface behavior:
I simply wanted to save a file, but that resulted in a frozen window:
After 10 minutes the file explorer window appeared, but also this screen is unresponsive.
I reinstalled Maple last month, but that didn't help. Remarkably, the problem comes and goes. It seems to me that some java problem is making my life difficult.
Any ideas?
kind regards,
Harry
ps I ran the process monitor of Sysinternals, but I have no idea if this has any relevance to the problems:
11460 RegOpenKey HKCR\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\PackageRepository\Extensions\windows.protocol\Maple.cwmaple.2020 NAME NOT FOUND Desired Access: Read
11460 ReqQueryValue HKCR\Maple.cwmaple.2020\URL Protocol NAME NOT FOUND Length: 12
11460 RegOpenKey HKCU\Software\Classes\Maple.cwmaple.2020  NAME NOT FOUND Desired Access: Maximum Allowed
Would like to export a list into a text file
when I tried , it show ... 1234 items... , can not export a whole list into text file.
[[[0,0,0,0]], [[0,0,0,0]], .....]
thousands of [[...]] elements
Hi, I would like to parallelize the double for loop. I am computing pairwise SPolynomials like so
for i from 1 to n-1 do
for j from i+1 to ndo
spol:=Spol(poly[i],poly[j], tdeg(op(vars))):
I would like to parallelize this code, here is what I have done:
at_node:=proc(p1,p2,vars, polynomials)
spol:=SPolynomial(p1,p2,tdeg(op(vars))):
if NormalForm(spol, polynomials, tdeg(op(vars)))=0
return [1,0]:
fi:
Grid[Setup]("local", num_nodes=4):
Grid[Set](at_node): # below is the main loop that fails
for idx from 1 to n-1 do
out:=Grid[Seq](at_node(polynomials[idx], polynomials[j], vars, polynomials) j=idx+1, n):
The loop above fails due to the error when calling normal form. It seems that the at_node function accepts an incorrect input for p1, a list of polynomials instead of a single polynomial. Is there a way to parallelize double for-loop with Grid like that? I am not sure where my error is.
I think that I accidentely deleted a file from inside of a Maple workbook. Is there a way to restore it inside of that workbook?
First 95 96 97 98 99 100 101 Last Page 97 of 371
