We want to find a curve fit for an integer sequence.
We have n such that n^2+n+17 is a prime number.
See oeis.org/A007635 and comments.
Use the Maple CurveFitting package.
I tried with(CurveFitting).
We do not know if this is best represented by a polynomial or exponential curve fit.
n2_and_n_and_17_in_OEIS_007635.mw
n2_and_n_and_17_in_OEIS_007635.pdf
Matt
Since I am a mathematician, I am wondering how Maple goes about solving an identity for 3 functions.
Let's say we have af1(t)+bf_2(t)+cf_3(t) = 0 for all t. How does maple actually find a triplet a,b,c that works for all real t?
It does with solve(identity( ),[a,b,c]). But what is the theory behind it?
We know, of course, a priori, that such a triplet exists.
Thank you!
mapleatha
Dear Colleagues,
Apologies for the generic question below.
I am trying to obtain the Nash equilibrium solutions for a two-person game. I am not sure of any in-built packages that can help me in obtaining the solutions computationally. The algorithms that I created do not seem to give good solutions that are meaningful in my application. Any suggestion would be much appreciated.
Omkar
I've been studying the  drawing  of graph lately .    One of the themes is  1-planar graph .
A 1-planar graph is a graph that can be drawn in the Euclidean plane in such a way that each edge has at most one crossing point,  where it crosses a single additional edge. If a 1-planar graph, one of the most natural generalizations of planar graphs, is drawn that way, the drawing is called a 1-plane graph or 1-planar embedding of the graph.
I know it is NP hard to determine whether a graph is a 1-planar . My idea is to take advantage of some mathematical software to provide some roughly and  intuitive understanding before determining .
Now,  the layout of vertices or edges becomes important.  The drawing of a plane graph is a good example.
G1:=AddEdge( CycleGraph([v__1,v__2,v__3,v__4]),{{v__2,v__4},{v__1,v__3}}):
DrawGraph(G1)
DrawGraph(G1,style=planar)
K5 := CompleteGraph(5);
DrawGraph(K5);
vp:=[[-1,0],[1,0],[-0.2,0.5],[0.2,0.5],[0,1]];
SetVertexPositions(K5,vp);  #modified the vertex position
DrawGraph(K5);
My problem is that I see that  Maple2020 has updated a lot of layouts about DrawGraph  graph theory backpack , and I don’t know which ones are working towards the least possible number of crossing of  each edges of graph .
Some links that may be useful:
https://de.maplesoft.com/products/maple/new_features/Maple2020/graphtheory.aspx
https://de.maplesoft.com/support/help/Maple/view.aspx?path=GraphTheory/SetVertexPositions
I think the software can improve some calculations related to topological graph theory, such as crossing number of graph, etc.
How to find sgn on maple?
signum.mw
When I select "oldest first", the first post shown is the newest.  Vice-versa when selecting "newest first".  Am I misunderstanding the meaning of the term?  I suppose it doesn't matter as both options are available but it's weird.
Maple Apps-Venn Diagrams does not work.  In box on the right there is an error message.
#include<iostream>
#include<vector>
#include<cmath>
#define NODE 8
using namespace std;
int graph[NODE][NODE] = {
   {0,1,1,0,0,0,0,0},
   {1,0,1,1,1,0,0,0},
   {1,1,0,1,0,1,0,0},
   {0,1,1,0,0,0,0,0},
   {0,1,0,0,0,1,1,1},
   {0,0,1,0,1,0,1,1},
   {0,0,0,0,1,1,0,0},
   {0,0,0,0,1,1,0,0}
int tempGraph[NODE][NODE];
int findStartVert() {
   for(int i = 0; i<NODE; i++) {
      int deg = 0;
      for(int j = 0; j<NODE; j++) {
         if(tempGraph[i][j])
            deg++; //increase degree, when connected edge found
      if(deg % 2 != 0) //when degree of vertices are odd
      return i; //i is node with odd degree
   return 0; //when all vertices have even degree, start from 0
int dfs(int prev, int start, bool visited[]){
   int count = 1;
   visited[start] = true;
   for(int u = 0; u<NODE; u++){
      if(prev != u){
         if(!visited[u]){
            if(tempGraph[start][u]){
               count += dfs(start, u, visited);
   return count;
bool isBridge(int u, int v) {
   int deg = 0;
      if(tempGraph[v][i])
   deg++;
   if(deg>1) {
      return false; //the edge is not forming bridge
   return true; //edge forming a bridge
int edgeCount() {
   int count = 0;
      for(int j = i; j<NODE; j++)
         if(tempGraph[i][j])
   count++;
   return count;
void fleuryAlgorithm(int start) {
   static int edge = edgeCount();
   static int v_count = NODE;
   for(int v = 0; v<NODE; v++) {
      if(tempGraph[start][v]) {
         bool visited[NODE] = {false};
         if(isBridge(start, v)){
            v_count--;
         int cnt = dfs(start, v, visited);
         if(abs(v_count-cnt) <= 2){
            cout << start << "--" << v << " ";
            if(isBridge(v, start)){
               v_count--;
            tempGraph[start][v] = tempGraph[v][start] = 0; //remove edge from graph
            edge--;
            fleuryAlgorithm(v);
int main() {
   for(int i = 0; i<NODE; i++) //copy main graph to tempGraph
      tempGraph[i][j] = graph[i][j];
   cout << "Euler Path Or Circuit: ";
   fleuryAlgorithm(findStartVert());
Kind help
Hi, I generated latex formate of an equation by using a command of maple but when I paste it into MathType, could not get the required equation, can anyone help me
${\frac {1}{51200\, \left( {x}^{2}+2 \right) ^{6}} \left( -187110\,
 \left( {x}^{2}+2 \right) ^{6}\sqrt {2} \left( {Q}^{3}+ \left( {\frac
{18\,k}{11}}-{\frac{18}{11}} \right) {Q}^{2}+ \left( {\frac {320\,{k}^
{2}}{297}}-{\frac {40\,k}{27}}+{\frac{320}{297}} \right) Q+{\frac {80
\,{k}^{3}}{297}}-{\frac {80\,{k}^{2}}{189}}+{\frac {80\,k}{189}}+{
\frac {640\,\lambda}{2079}}-{\frac{80}{297}} \right) \arctan \left( 1/
2\,x\sqrt {2} \right) -93555\, \left( {x}^{2}+2 \right) ^{6}\pi\,
 \left( {Q}^{3}+ \left( {\frac {18\,k}{11}}-{\frac{18}{11}} \right) {Q
}^{2}+ \left( {\frac {320\,{k}^{2}}{297}}-{\frac {40\,k}{27}}+{\frac{
320}{297}} \right) Q+{\frac {80\,{k}^{3}}{297}}-{\frac {80\,{k}^{2}}{
189}}+{\frac {80\,k}{189}}+{\frac {640\,\lambda}{2079}}-{\frac{80}{297
}} \right) \sqrt {2}-374220\, \left(  \left( {Q}^{3}+ \left( {\frac {
18\,k}{11}}-{\frac{18}{11}} \right) {Q}^{2}+ \left( {\frac {320\,{k}^{
2}}{297}}-{\frac {40\,k}{27}}+{\frac{320}{297}} \right) Q+{\frac {80\,
{k}^{3}}{297}}-{\frac {80\,{k}^{2}}{189}}+{\frac {80\,k}{189}}+{\frac
{640\,\lambda}{2079}}-{\frac{80}{297}} \right) {x}^{10}+ \left( {
\frac {34\,{Q}^{3}}{3}}+ \left( {\frac {204\,k}{11}}-{\frac{204}{11}}
 \right) {Q}^{2}+ \left( {\frac {10880\,{k}^{2}}{891}}-{\frac {1360\,k
}{81}}+{\frac{10880}{891}} \right) Q+{\frac {2720\,{k}^{3}}{891}}-{
\frac {2720\,{k}^{2}}{567}}+{\frac {2720\,k}{567}}+{\frac {21760\,
\lambda}{6237}}-{\frac{2720}{891}} \right) {x}^{8}+ \left( {\frac {264
\,{Q}^{3}}{5}}+ \left( {\frac {432\,k}{5}}-{\frac{432}{5}} \right) {Q}
^{2}+ \left( {\frac {512\,{k}^{2}}{9}}-{\frac {704\,k}{9}}+{\frac{512}
{9}} \right) Q+{\frac {128\,{k}^{3}}{9}}-{\frac {1408\,{k}^{2}}{63}}+{
\frac {1408\,k}{63}}+{\frac {97280\,\lambda}{6237}}-{\frac{128}{9}}
 \right) {x}^{6}+ \left( {\frac {4496\,{Q}^{3}}{35}}+ \left( {\frac {
80928\,k}{385}}-{\frac{80928}{385}} \right) {Q}^{2}+ \left( {\frac {
287744\,{k}^{2}}{2079}}-{\frac {35968\,k}{189}}+{\frac{287744}{2079}}
 \right) Q+{\frac {3328\,{k}^{3}}{99}}-{\frac {3328\,{k}^{2}}{63}}+{
\frac {3328\,k}{63}}+{\frac {10240\,\lambda}{297}}-{\frac{3328}{99}}
 \right) {x}^{4}+ \left( {\frac {10672\,{Q}^{3}}{63}}+ \left( {\frac {
21344\,k}{77}}-{\frac{21344}{77}} \right) {Q}^{2}+ \left( {\frac {
1094656\,{k}^{2}}{6237}}-{\frac {136832\,k}{567}}+{\frac{1094656}{6237
}} \right) Q+{\frac {35584\,{k}^{3}}{891}}-{\frac {35584\,{k}^{2}}{567
}}+{\frac {35584\,k}{567}}+{\frac {235520\,\lambda}{6237}}-{\frac{
35584}{891}} \right) {x}^{2}+{\frac {25376\,{Q}^{3}}{231}}+ \left( {
\frac {12352\,k}{77}}-{\frac{12352}{77}} \right) {Q}^{2}+ \left( -{
\frac {7936\,k}{63}}+{\frac {63488\,{k}^{2}}{693}}+{\frac{63488}{693}}
 \right) Q-{\frac{512}{27}}+{\frac {512\,{k}^{3}}{27}}-{\frac {5632\,{
k}^{2}}{189}}+{\frac {102400\,\lambda}{6237}}+{\frac {5632\,k}{189}}
 \right) x \right) }$
How to obtain the multiple solution and graph given in the paper.
Stefan Blowing and Slip Effects on Unsteady Nanofluid Transport Past a Shrinking Sheet: Multiple Solutions
https://doi.org/10.1002/htj.21470
Can anyone help to get solutions.
I would like to instal Maple 9.5 in my laptop, once I already have some few programs for his version. I don't know how much cost Maple 9.5, and how do download it.
I live in Brazil.
Carrijo.
jose.carrijo@gmail.com
Hi.
in the ThermophysicalData[Chemicals] package that compute the coefficients for different species how I can find that coefficients for seven coefficients not nine of them
in other words, I am seeking to find Databases for the NASA Seven-Coefficient Polynomial Fits for Calculating Thermodynamic Properties of Individual Species.
Best
How do I use to compute d(logS(t)) and use this to find the closed form solution of S(t)
I have the following of fractional of ode system.
.How to solve it by maple.
Professor Robert J. Lopez is a Maple Fellow and the author of many Maple webinars and applications. He is also co-author of a book entitled Discovering Calculus With Maple, which I have recently acquired, and which turns out to be keyed to Maple V Release 3 on a Mac. Well, I have Maple 2020 on a Mac. What is the best way to get this book to work for me?  Thanks very much.
First 99 100 101 102 103 104 105 Last Page 101 of 371
