I have constructed a model of an UR5e in maplesim with the hop to be able to test my controller writen in python on it.
I hope to be able from the model to
  • Enter a tourqvalue for the joints.
  • Extract joint angles, joint velocitys as well as the forces and tourqes that affects the end effector.
  • (If posible) visualize the sumulated robot arm so I can se that the motion reflects that of the real robot arm.
the simulated robot arm
The question is how to best do this in a semi realtime way?
I have been looking into generating a FMU but if there are other ways to do this, then I am open to ides.
The contorller is based on a haptic algoritm for connecting two robot arms and I will only get one robot arm due to prise and space constraints.
This means that I will reseave realtime information from the real robot arm into my python controller that then i supose to take inforamtion from the simulated arm and with information from both arms calculate the tourqe values for both arms joints.
Thanks in advance for all youre help
Eric Ragnarsson
I am wondering if there are examples of agent-based models in economics domain that have been implemented in Maple.
Any infomration/source is more than welcome!
I actually want to numerically solve Karhunen-Loeve Decomposition, which is reduced to homogenous Fredholm integral equation second kind when the kernel is the function of correlation of variables, by using any procedures (Galerkin is better if it is availabe). FYI, with "intsolve" I just got f(x)=0.
I am a newbie in Maple! I tried both ThermophysicalData and its CoolProp package to find saturation pressure of vapor for given air-water mixture temperature.
I want to calculate water vapor density in air or simply Absolute humidity (kg/m3)
But i can not see any meaningful function or combination of functions/properties in CoolProp to give such output.
P_w in CoolProp, HApropSI takes this as input only that is not usefule either way inpoutput
The rationale is to work from RH and then calculate P_w as output: P_w=RH x P_g where P_g is vapor saturation pressure at the given ambient condition.
From there all world is yours!
You can use ideal gas rules to do everything. But i cant use CoolProp to calculate the ABsolute humidty for given RH and ambient condition.
Note that clearly i can calculate all these from hand calculation as well as approximation formuale of Clausius-Clapeyron equation. But i wanted to do in Maple with its packages.
Any help is appreciated!?
Sina
I have the following fractional  system of differential equation. How to plot it for alpha=0.5, beta=0.5?
eq1:=diff(y1(t),t$alpha)=0.04-(0.09*y1(t)*y2(t))-(0.00250*y1(t)*y2(t))/((0.03500+y2(t)))-0.04*y1(t);
eq2:=diff(y2(t),t$beta)=(0.09*y1(t)*y2(t))+(0.00250*y1(t)*y2(t))/((0.035+y2(t)))-(0.02+0.04)*y2(t);
Whenever I open Maple 2020 and type one single letter or number (doesn't matter) Maple 2020 will "freeze" and load forever (i have had it open for a long time, just watching that f**king blue circle spin...
I have tried reinstalling, repairing, running as admin, and changing the compatibility mode, still, nothing works:(
I run Maple 2020 as a Student with WithGym
Pc specs:
Intel i5-10300h 2.6 ghz
Geforce 1660 ti 6gb
Windows 10 x64
Is it possible in one worksheet of a workbooks to access variables or embedded components in another worksheet programmatically?
As far as I can see it is possible to save and restore variables through the variable browser, so it is also possible to get them from one worksheet to another. This is however done by the user.
Now the question is, if it is somehow possible to e.g. access the contents of a embedded component like a Combobox in a different worksheet of the workbook - without opening the worksheet first?
[[1,1,["ab","xy"]], [0,1,["xy"]]]
how to sort by first number , second number , and list of string ?
how to count and group by third list of strings having first two number 0,0 or 0,1 or 1,0 or 1,1
for example
["xy"] at most count 4  , at least count 1
would like to find which is [1,1,... ] and only count 1
Suppose we have a 200-litre tank. Suppose 10 litres per minute of salt water (brine) flows into the tank at the top, it mixes perfectly with the contents of the tank, and 10 litres per minute of the mixture flows out of the tank at the bottom. Assume for simplicity that the salt water in the tank is stirred so that its concentration is uniform in the tank. Let S(t) be the amount of salt, in grams, in the tank at t time minutes. Suppose the salt water flowing into the tank has concentration 80 grams per litre.
Find the differential equation to model the change in S(t).
Assuming that at t = 0 time the concentration of salt in the tank is 10 grams per litre, solve the differential equation using Maple.
What is S(infinite)? That is, how much salt is in the tank after a long time?
Now graph S(t) for a suitable domain so we can see the function approaching the value S(infinite)
Have some difficulty to understand the problem. I mean, such modelling problem rather than pure math computation.
Thank you so much!
Let's say you make a tabulate of plots (using tabulate, because you don't want equal space for your plots as in array-plot etc). Then how should one save or export the final result as one eps or pdf file? When I right click and choose export, it only save one cell of the tabulate alone.
Does it exist a command in the LieAlgebras package to find the list of normal subalgbras of a given finite dimensional Lie algebra?
Thank.
I used the command "Decompose" for the following trivial 2 dimensional abelian Lie algebra:
This command returns an error:
Alg:=[D_x,D_y]:
Alg_L:=LieAlgebraData(Alg):
DGsetup(Alg_L):
Decompose();
Error, (in print/_DG) final value in for loop must be numeric or character
Why this issue?
Hello, I have a sipmle wave PDE with dirichlet BC,I am trying to plot the solution , so I us the following code try to solve it at first,
pde := diff(u(x, t), t $ 2) - diff(u(x, t), x $ 2) = 0:
h := piecewise(2 < x and x <= 3, 6 - 2*x, 0):
ic := u(x, 0) = h, D[2](u)(x, 0) = 0:
bc := u(0, t) = 0:
solution := pdsolve([pde, ic, bc])
The problem is the following code give me a zero solution, but it should't be according to the d'Alembert formula.
I am not sure where is problem in my code, could someone help me on this? thanks.
I have the first and second fundamental forms of a surface. The Bonnet theorem tells me that this is enough to determine a surface in Euclidean space. Has this theorem been implemented in Maple?
1. Write a procedure that enables to compute the volume of a cone. Remember that a cone volume can be calculated using the following equation:
𝑉𝑜𝑙𝑐𝑜𝑛𝑒 =1/3𝜋𝑟2ℎ
with r and h generated randomly, both in the range from -100 to 100.
If Maple returns negative figures for r and h, ask it to replace these values with their absolute values.
If Maple returns 0 for r and h, Maple asks directly the user to input desired values.
2) With reference to point 2, you have the following matrix:
−65 1 32
1 −12 3
12 −2 2
Write a procedure that chooses randomly two numbers from the above matrix and assigns them to r and h. Then, it compares the two cone volumes and returns the largest value.
First 97 98 99 100 101 102 103 Last Page 99 of 371
