Is it possible to generate a XMLElement by using part of the code to be generated with a string, or are the only methods a strict use of AddAttribute and AddChild?
Hope the code below explains what I mean. The first line is a strict copy of a declaration in the help file.
The question is if I could use some part of the definition which is saved in the str variable and combine it into the first declaration?
with(XMLTools)
x := XMLElement("a", ["colour" = "red", "style" = "italic"], ["some content", XMLElement("b", ["colour" = "blue"], "more text"), "still more text"])
_XML_Element(_XML_ElementType("a"), [_XML_Attribute(_XML_AttrName("colour"), _XML_AttrValue("red")), _XML_Attribute(_XML_AttrName("style"), _XML_AttrValue("italic"))], [_XML_Text("some content"), _XML_Element(_XML_ElementType("b"), [_XML_Attribute(_XML_AttrName("colour"), _XML_AttrValue("blue"))], [_XML_Text("more text")]), _XML_Text("still more text")])
str := "["colour"="red","style"="italic"],["some content",XMLElement("b",["colour"="blue"],"more text"),"still more text"]"
Download xml_string.mw
I am trying to plot generator reactive output (Q) over a range of generator power output (P) with field current (Ifldc) and terminal voltage (Et) constant using “solve”. The system of equations includes an interpolating fiction Ifld(el).
I’m looking for some help as to how to configure a solution. Attached are a few of my failed attempts.
The upload of my file deleats the "solve" fo my first try it is:
MvaGen := 1354; PfGen := .935; KvGen := 24
           Xd__u := 1.89 - Synchronous reactance of d-axis, Unsatuarted
              Xq__u := 1.80 - Synchronous reactance of q-axis, Unsatuarted
              X__l := .26   - leakage reactance d or q-axis``
            Ifld__base := 3114
Open Ckt Sat Curve DS807-1a
     First col=Ifld amps
     Second col= el voltage behind leakage reactance
OC_SatDat := Matrix(16, 2, {(1, 1) = 0, (1, 2) = 0., (2, 1) = 655.6456, (2, 2) = .3422578, (3, 1) = 1009.961, (3, 2) = .5331404, (4, 1) = 1253.12, (4, 2) = .6492209, (5, 1) = 1562.724, (5, 2) = .8014143, (6, 1) = 1893.545, (6, 2) = .9329786, (7, 1) = 2201.68, (7, 2) = 1.033593, (8, 1) = 2487.276, (8, 2) = 1.108416, (9, 1) = 2793.943, (9, 2) = 1.157452, (10, 1) = 3122.338, (10, 2) = 1.203911, (11, 1) = 3690.959, (11, 2) = 1.263294, (12, 1) = 4259.141, (12, 2) = 1.307202, (13, 1) = 4827.028, (13, 2) = 1.340795, (14, 1) = 5351.085, (14, 2) = 1.366646, (15, 1) = 5787.775, (15, 2) = 1.387329, (16, 1) = 6224.391, (16, 2) = 1.405433})
  ido := It*sin(theta+delta)
Plot OC saturation with field current in pu
with(LinearAlgebra)
with(ArrayTools)
with(plots)
      OC_Sat_Ifld_pu := Column(OC_SatDat, [1])/Ifld__base
         OC_Sat := Concatenate(2, Column(OC_SatDat, [2]), OC_Sat_Ifld_pu)
iterpolate values of field current vs el from OC sat curve
                                    pts_el := Column(OC_Sat, [1]); pts_Ifldpu := Column(OC_Sat, [2])
                         Ifield as a function of el  ->  Ifld := LinearInterpolation(pts_el, pts_Ifldpu)
Solve for Q with
P = .935; Iflc := 1.88; Et := 1.0
TRY1
 Eq1 := Ir = P/Et; Eq2 := Ix = Q/Et    Eq3 := It*sqrt(Ir^2+Ix^2)     Eq4:=theta = arctan(Q, P)
    Eq5 := el = abs(Et+X__l*(Ix+I*Ir))      Eq6 := `ΨAG__d` = Xad__u*Ifld(el)   Eq7:=K__ds = el/`ΨAG__d`
NULL Eq8 := Xd__s = K__ds*Xad__u+X__l   Eq9 := `ΨAG__q` = Xaq__u*Ifld(el)    Eq10 := K__qs = el/`ΨAG__q`
   Eq11 := Xq__s = X__l+K__qs(el)*Xaq__u      Eq12 := Eq = Et+Xq__s(el)*(Q/Et+I*P/Et)
NULLNULL
Eq13 := delta = argument(Eq)        Eq14 := eqo = Et*cos(delta)    Eq15 := ido = It*sin(theta+delta)
Eq16 := EI = Xd__s*Iflec; Eq17 := EI = Ido*Xd__s+eqo
syst := {E15, Eq1, Eq10, Eq11, Eq12, Eq13, Eq14, Eq16, Eq17, Eq2, Eq3, Eq4, Eq5, Eq6, Eq7, Eq8, Eq9}
solve(sys, {Eq, Ir, It, Ix, K__ds, K__qs, Q, Xd__s, Xq__s, el, eqo, ido, theta, `ΨAG__d`, `ΨAG__q`})
Warning, solving for expressions other than names or functions is not recommended.
TRY 2
`` Ix := proc (Q) options operator, arrow; Q/Et end proc   It := proc (Q) options operator, arrow; sqrt(Ir^2+Ix^2) end proc     theta := proc (Q) options operator, arrow; arctan(Q, P) end proc
 el := proc (Q) options operator, arrow; abs(Et+X__l*(Ix(Q)+I*Ir)) end proc      `ΨAG__d` := proc (Q) options operator, arrow; Xad__u*Ifld(el(Q)) end proc   K__ds := proc (Q) options operator, arrow; el(Q)/`ΨAG__d`(el(Q)) end proc``
NULL Xd__s := proc (Q) options operator, arrow; X__l+K__ds(el(Q))*Xad__u end proc   `ΨAG__q` := proc (Q) options operator, arrow; Xaq__u*Ifld(el(Q)) end proc    K__qs := proc (Q) options operator, arrow; el(Q)/`ΨAG__q`(el(Q)) end proc
Xq__s := proc (Q) options operator, arrow; X__l+K__qs(Q)*Xaq__u end proc      Eq := proc (Q) options operator, arrow; Et+Xq__s(Q)*(Q/Et+I*P/Et) end proc
delta := proc (Q) options operator, arrow; argument(Eq(Q)) end proc        eqo := proc (Q) options operator, arrow; Et*cos(delta(Q)) end proc    ido := proc (Q) options operator, arrow; It*sin(theta(Q)+delta(Q)) end proc``
EI := proc (Q) options operator, arrow; Xd__s(Q)*Iflec end proc    EI := proc (Q) options operator, arrow; eqo(Q)+Xd__s(Q)*Ido(Q) end proc
solve(EI(Q) = eqo(Q)+Xd__s(Q)*Ido(Q), {Eq, Ir, It, Ix, K__ds, K__qs, Q, Xd__s, Xq__s, el, eqo, ido, theta, `ΨAG__d`, `ΨAG__q`})
{Eq = Eq, Ir = Ir, It = It, Ix = Ix, K__ds = K__ds, K__qs = K__qs, Q = Q, Xd__s = Xd__s, Xq__s = Xq__s, el = el, eqo = eqo, ido = ido, theta = theta, `ΨAG__d` = `ΨAG__d`, `ΨAG__q` = `ΨAG__q`}
TRY3
     "Eq20:=Ir=P/(Et):     Eq21:=Ix=Q->Q/(Et):"
Error, invalid operator parameter name
"Eq20:=Ir=P/Et: Eq21:=Ix=Q->Q/Et:"
Download Qcalc1.mw
why setting interface(warnlevel=0); makes dsolve change the form of the final solution to an ODE?
Is this to be expected? Help on warnlevel 0 says to just suppress all warnings
In this example, both solutions are equivalent. One is just simpler than the other.
But now I am worried if this setting could affect dsolve in other ways not yet anticipated.
`Standard Worksheet Interface, Maple 2020.2, Windows 10, November 11 2020 Build ID 1502365`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 884 and is the same as the version installed in this computer, created 2020, November 25, 16:49 hours Pacific Time.`
ic:=y(0)=3:
ode := diff(y(x),x)*y(x)/(1+1/2*sqrt(1+diff(y(x),x)^2))=-x:
sol_1:=dsolve([ode,ic],y(x),singsol=all);
y(x) = -3+(1/3)*(-9*x^2+324)^(1/2), y(x) = 1+(1/3)*(-9*x^2+36)^(1/2)
ic:=y(0)=3:
sol_2:=dsolve([ode,ic],y(x),singsol=all);
y(x) = -3+(-x^2+36)^(1/2), y(x) = 1+(-x^2+4)^(1/2)
Download warnlevel_difference.mw
btw, the same thing happens with warnlevel 2. i.e. answers look different.
But with warnlevel 3 and 4, now dsolve gives the same answer.
SInce it seems default is warnlevel 3, it seems internally, dsolve takes different path depending on warnlevel setting?
Edit
Here is a movie. I am using windows 10.
Edit: Here is another video. Tried now with fresh start of Maple. i.e. closed Maple and started it again.  Using worksheet. No other worksheet was open. This is what I found. Initially it gives the longer solution. After couple of tries, it then changed to the simpler one
Please I have an issue with the attached plot code. Can you kindly help to correct it?
interface(rtablesize=infinity):
B:=<<0,0.05,0.1,0.15,0.2,0.25,0.3,0.35,0.4,0.45,0.49,"0","0.05","0.1","0.15","0.2","0.25","0.3","0.35","0.4","0.45","0.49">|
	<14.73,14.4,14,13.4,12.67,11.67,10.4,8.67,6,3,0,"14.73","14.4","14","13.4","12.67","11.67","10.4","8.67","6","3","0">|
     <-0.007072,0.013309,0.033707,0.054125,0.074571,0.095056,0.115597,0.136218,0.156956,0.177867,0.199036,0.22059,0.242719,0.265702,0.289932,0.31592,0.344214,0.375124,0.408175,0.441761,0.473484,0.501857>|
	<1.34E+01,1.33E+01,1.33E+01,1.32E+01,1.31E+01,1.31E+01,1.30E+01,1.29E+01,1.28E+01,1.26E+01,1.25E+01,1.22E+01,1.19E+01,1.14E+01,1.08E+01,9.86E+00,8.58E+00,6.90E+00,4.90E+00,2.81E+00,1.00E+00,-2.86E-01>>:
B:
 plot([B[..,[1, 2]],B[1..1,[1, 2]], B[.., [3, 4]],B[1..1,[3, 4]], B[..,[5, 6]],B[1..1,[5, 6]],B[.., [7, 8]],B[1..1,[7, 8]],
 	  B[..,[9, 10]],B[1..1,[9, 10]], B[.., [11, 12]],B[1..1,[11, 12]],B[..,[13, 14]],B[1..1,[13, 14]],B[.., [15, 16]],B[1..1,[15, 16]],
 	  B[..,[17, 18]],B[1..1,[17, 18]], B[.., [19, 20]],B[1..1,[19, 20]],B[..,[21, 22]],B[1..1,[21, 22]]],
 	  legend = ["","Experimental","","Simulation"],
 	  style = ["line","line","line","line","line","line","line","line","line","line","line","line","line","line","line","line",
 	 		"line","line","line","line","line","line"],
 	  color=[blue,red], labels=[`V (V)`, `Jsc (mA/cm^2)`]);
Download Graph_Example.mw
I found a condition for p, q that N=pq can be factored in plynominal time using Maple 2020.
Is fllowing Hypothesis and Proof is right?
Hypothesis
       N=pq  p and q are large prime respectively.
         R=q/p  q > p  R is very close to an small integer or a simple rational number.
        N=pq can be factorized in time polynomial
Proof
        point[p, q] is on y=N/x
        y=N/x  and y=Rx cross at point[p, q]
        N is n digit
        upper  2 digits N2  round off the 3rd digit
        upper  3 digits N3  round off the 4th digit
        upper  4 digits N4  round off the 5th digit
        y=N2/x and y=Rx cross at point[p2,q2]
        y=N3/x and y=Rx cross at point[p3,q3]
        y=N4/x and y=Rx cross at point[p4, p4]
        But we only know N.
        Let line up candidates point[p2,q2] , point[p3,q3] and point[p4, p4]
       N2 < 99  i=1..10 j=1..10
       R2=i/j
       f2=N2/R2 - j^2
       dn2=abs(N2-R2*j^2)
      N4 < 9999  i=1..99 j=1.. sqrt(N4)
      R4=i/j
      f4=N4/R4 - j^2
      dn4=abs(N4-R4*j^2)
     Point[j, i] that have  small f2 and dn2 can be nominated as candidate for point[p2, q2]
     Point[j, i] that have  small f3 and dn3 can be nominated as candidate for point[p3, q3]
     Point[j, i] that have  small f4 and dn4 can be nominated as candidate for point[p4, q4]
    Find cross point[px, qx] of y=R2x and y=N/x , y=R3x, y=N/x and y=R4x, y=N/x
    Find the nearest prime pn for px and the nearest prime qn for qx
   pn*qn=N  bingo!
   Number of candidates are finit.
   You can factorized N=pq in time polynomial.
        Q.E.D. ?
In addition, using "https://www.mapleprimes.com/questions/228532-Strange-Factorization"
Rang from p - half digits of p to p + half degits of p and /or range q - half digits of q to q + half degits of q  N=pq can be factored in plynominal time.
Hi, everyone!
I'm trying to do some computations with (truncated) multivariable power series, which I'd like to put into Hironaka standard basis form.  This is almost the same as a Groebner basis, except that the "leading" terms have smallest degree instead of largest.  This requires slight changes to the algorithms in order to make sure they terminate.  Does anyone know if this has been implemented in Maple or have a good way to fake it?  Here's what I've thought of:
  • Using the Groebner package with grlex_min instead of grlex.  The documentation warns that this may not terminate, and sure enough, it doesn't.  (At least not before my computer runs out of memory.)
  • Replacing the truncated power series with their palindromes, using the Groebner package, and then switching back, making sure all the degrees are correctly accounted for.  This should work, but it's going to be a major pain.
  • Reimplementing the Groebner routines.  I'd really rather not, but I'd love to know if anyone else has.
Anybody have any other ideas or suggestions?
----Josh
I tried to find the set of real parameters a1, a2, a3, a4 and u1, u2, u3 which make a subalgebra L an ideal of a finite real Lie algebra LieAlg. Unfortunately, the "Query" command with the "Ideal" argument returns an error message that I can't get around. What should I change in this command?
with(DifferentialGeometry):
with(LieAlgebras):
DGsetup([x1,x2,x3],R3):
Lie_Generators := [D_x1*x1+D_x2*x2+D_x3*x3, D_x3*k^2*x1+D_x1*x3, -D_x1*x2+D_x2*x1, D_x3*k^2*x2+D_x2*x3, D_x1, D_x2, D_x3]:
LieAlg:=LieAlgebraData(Lie_Generators):
DGsetup(LieAlg):
L:= evalDG([e3+u2*e5-u1*e6,e2-u3*e5-k^2*u1*e7,e4-u3*e6-k^2*u2*e7,e1-u1*e5-u2*e6-u3*e7]);
Sub_Alg_L:=LieAlgebraData(L);
TrueFalse,Equations,Solutions,IdealList:=Query(L,{u1,u2,u3},"Ideal");
TrueFalse,Equations,Solutions,IdealList:=Query([DGzip([a1,a2,a3,a4], L, "plus")],{a1,a2,a3,a4,u1,u2,u3},"Ideal");
Thanks for your help.
Jaqr
converts a Maple polynomial into a list of its coefficients.
Hey
Can anyone help me with this file?
I don't know how it happend, but the file somehow got corrupted. Is there anything i can do?
Videregående_beton_Gang_9.mw
I have a parametric polynomial which is defined based on the multiplication of different variables and I want to rearrange the polynomial based on specific variables. For example, suppose the polynomial is defined as follows:
a:= (1+x+y)(2x-yx+z)(y^2-zy)
and I want to have a based on first, and second orders of x, or even other variables. Thanks
Hi, my problem is the next differential equation:
In maple. I used this code to solved it, but throws this error:
dsolve({diff(y(x), x, x) = -P*x/(I*E), eval(y(x), x = L) = 0, eval((D(y))(x), x = L) = 0});
Error, (in dsolve) found differentiated functions with same name but depending on different arguments in the given DE system: {y(L), y(x)}
What is the problem with my code? How can solve my ODE with tis boundary conditions?
How to write down the differential equation for this practical question?
I can use dsolve to solve the system equation.
Thank you!
EDIT TIME: 14:30 CET
where P(1) and P(2) are NxN matrix functions.
My trial code for STEP 0
 alpha times integral w.r.t. x
 Int_x__alpha:=proc(term,alpha):
 return
select(has,term,x).P(alpha)^T.remove(has,term,x)
 alpha times integral w.r.t. t
Int_t__alpha:=proc(term,alpha):   #alpha times integral w.r.t. t
 return
remove(has,term,t).P(alpha).select(has,term,t)
when I run the last procedure for the testing
 Int_t__alpha(Psi(x)^T.C. Psi(t),2);
I get
But it must be
Because the multiplication is not commutative in Matrices. So, the last procedure must be corrected.
DETAILS for the procedures:
MAIN QUESTION:
Suppose that we have a PDE as follows
                                             ...(3)
subject to appropriate Initial and Boundary conditions.
STEP 1
  • Find the highest derivative w.r.t. x and w.r.t. t. Then, Let the trial function be the summation derivative of these highest derivatives. I mean
Trial Function:                                           ...(4)
where Psi(x), Psi(t) are Nx1 vectors and C is a NxN matrix.
I can't write a maple code for selecting the trial function.  May be you can.
trial_function:=diff(u(x,t),x,t)=Psi(x)^T.C. Psi(t);
# I deliberately used ^T instead of ^+ for Transpose.
# If I use ^+, the transpose sign doesn't appear in 2d output. May be you have an other idea.
STEP 2
  • Integrate the Eq.4  w.r.t. t from 0 to t, we have
STEP2:=int(  lhs(trial_function) ,t=0..t)=Int_t__alpha(rhs(trial_function),1);
The code must be improved. Firstly, substitute t=s in lhs(trial_function) and then integrate s=0..t
STEP 3
int(lhs(STEP2),x=0..x)= Int_x__alpha(rhs(STEP2),1);
STEP 4
  • Integrate Eq.4 w.r.t x
STEP 5
  • Substitute Eq. (5), Eq. (6), Eq. (7) to Eq. (3),
  • I mean substituting  u_x(x,t), u_t(x,t), u(x,t) to PDE.
STEP 6
DOWNLOAD ALL MAPLE CODE: all_code.mw
How can I get Maple to simplify expressions into more meaningful forms?
For example,
xc1 := -(2*Q*R1 + sqrt(4*Q^2*R1*RL - R1^2 + 2*R1*RL - RL^2))*R1/(4*Q^2*R1 + R1 - RL)
The numerator, under the radical, is more meaningful as sqrt(4 Q^2 R1 RL-(R1-RL)^2).
Similarly, the denominator can be simplified to Rs(4 Q^2+1)-RL.
How do I get Maple to get me there?
First 96 97 98 99 100 101 102 Last Page 98 of 371
