So I recently bought a new desktop with Windows 10 installed. The problem is hard to describe so I put a picture. This problem occurs randomly (Mostly occurs after I click the right button, when browsing the option in the pop-up toolbar).
When this problem happens, if I move my mouse to any toolbar which suppose to pop-up a toolbar, the pop-up toolbar wont disspear. And ultmately leads to the picture I showned above.
Sorry for the bad explaintion but it is just like I said, it is hard to describe the problem. This PC arrives around Christmas and I downloaded Maple last week. And it never have been normal. This issue also happens to NetLogo (A model simulation software).
I asked DELL's technique services and they did a remote control to help me fix the issue. However, the problem doesn't solved (They worked on this for about 3 hours). It seems the only choice I have is to reinstall the Windows.
Does anyone have met this problem or know who met it before? Please let me know and I'm really appreciate it.
I would like to define two vectors in spherical coordinates (preferably using Physics[Vectors] package) such that these two vectors have the magnitudes of r1 and r2, resepctively, but pointing in different directions.
In Physics[Vectors] package, basis vectors _r,_theta,_phi are predefined. So, I cannot define the vectors as r1_:=r1*_r1 and r2_:=r2*_r2 and use all the cool features of physics package.
I will eventually be needing the norm of the difference of these vectors at a later calculation, but this representation turned out to be a problem.
I am avoiding to define these vectors  in cartesian basis with spherical coordinates such as r1_=r1*(sin(theta1)*cos(phi1) i + sin(theta1)*sin(phi1) j + cos(theta1) k), etc. which is a work around.
How can I do this in Maple?
Im new to Maple. My instructor asked us to use it, but I can't find a student free version, please help.
I was trying to use the idea explained in this post (), using `densityplot` to create a barplot. But there are several difficultes specially using new Maple that has problem with exporting plots in pdf format the same as displayed inside Maple.
The example code:
zmin := 0;
zmax := 1;
verthuebar := plots:-densityplot(z, dummy = 0 .. 1, z = zmin .. zmax, grid = [2, 10], style = patchnogrid, size = [90, 260], colorscheme = [ColorTools[Color]([0, 0, 1]), ColorTools[Color]([1, 0, 0])], style = surface, axes = frame, labels = [``, ``], axis[1] = [tickmarks = []], axis[2] = [tickmarks = [aList[1] = "0   ", 0.5 = typeset(alpha*` `), 1 = "1    "]]);
Problems:
1- When I export the bar-plot as `.eps`, it shows white lines as a grid, while I don't want it and it is not the same way it is displayed at Maple!
test-1.pdf
I tried adding `gridlines=false` and other similar things, but had no effect. I changed `10` to `3` in `grid = [2, 10]`, but it increases the distance of 0 and 1 from the borderies and therefore wrong numbers will be read from the color bar. Exporting the picture as `.pdf` doesn't have that gridlines problem, but destroys the proportions of the image, so I want to stick on the `.eps` one, but without those white lines.
2- How can I have 0 and 1 exactly on the start and end of the color bar and with no distance from the edges? I can use `view=[0..1,0..1]` at the end of the above code, but depending on the number in the `grid=[2,n]` that I choose, the colors may not start and end exactly at the specified colors.
There is the following differential equation:
where l(t)=2+t,  g=10 and the goal is to find φ(t). I wrote the following code:
M := diff(phi(t), t);
M1 := diff(M, t);
g := 10;
M2 := diff(l(t), t);
ode := M1 + 2*M2*M/l(t) + g*sin(phi(t))/l(t) = 0;
ics := phi(0) = 1, D(phi)(0) = 1;
l := t -> 2 + t;
ode;
dsovle([ode, ics]);
But I don't get any result. How can I solve this differential equation?
I just got a "new" graphics card, NVIDIA GT630, and was wondering whether the CUDA capabilities are accessible. But no luck:
CUDA:-Enable();
Error, (in CUDA:-Enable) CUDA not supported on the current system (see CUDA,supported_hardware for more information)
The CUDA help page with the example, when run, just shows a host of error messages.
I have OS X 10.11.6, the above mentioned GT630 card with claimed 384 CUDA cores and 2 GB of VRAM; NVIDIA WebDriver 346.03.15f16 for the card (i.e. latest for this OS) and NVIDIA CUDA driver 8.0.90 (again, latest for this OS as far as I can tell). My Maple is 2015.2. All this running on a MacPro 4,1.
I am not having great illusions about the performance I should get (this is not a state-of-the-art card today), but it seems to me this combination should be working with Maple 2015 and not throw an error, shouldn't it? Checking the system extensions: CUDA.kext is loaded and its dependencies are satisfied, so I don't see any problem there.
Am I missing something?
M.D.
I'm having an issue with Maple 2020.2 classic interface being *very* slow on a new MacBook pro with Big Sur. It takes about 1 second between each keystroke and it appearing on the screen.
Is this a known bug?
I want to read file dates (for data files) from inside Maple.  Specifically, I want to automate the comparison of access dates.
I thought I'd done this in the past, but my attempt to recreate it has led me to think that I am remembering incorrectly.
Is there a way of doing this?
I don't deeply care about portability (I'm working on Windows 10 and that would be good enough), but since I'm asking the question please comment on the easiest way to make this portable.
I am aware that by default Windows 10 doesn't update the access date.  On the machines I care about, I have changed the configuration so Windows is updating the access date (often enough for my purposes).  I have PowerShell scripts that work correctly.
I have several questions about Grid Toolbox. I am getting into distributed computing for a very large problem I have been working on for a long time; I am working on the simple examples that come with the Grid package, and I am not having much success. I am fairly experienced in Maple but I need help with this. My e-mail is harrisjtster@gmail.com.
I would be really grateful if someone can help me in solving the below attached problem in maple.
Plot the wedge cut from the cylinder x²+y²=1 by the planes z=-y and z=0.
Hey everyone,
f_1 and f_2  are satisfying the set of non-linear integral equations I have attached to this message.
I know that I need to solve them numerically by iterations. Probably, the first guest of the function f_1 and f_2  is the driving term. a is just a parameter which can be fixed (I guess smaller than \pi/4). * is the convolution product and k is the momentum space parameter. I learnt that in order to solve them I should solve them in the Fourier space. I know also that I need to discretize these function in the “real ” space between {-L,+L} before applying the FFT or one of its relatives. Thank you for any suggestions or leads.
I noticed that, in Maple 2020.2, the caracters seem smaller. As if the zoom had somewhat been reduced (a bit).
However, in the preferences, the default zoom level I would like is between 100 and 125% (something like 110%) (since the default zoom level is adjusted by steps of +/- 25%). I wondered if there was a way to set the default zoom level to an arbitrary value. In fact I thought it would be great to have a field instead of a list of choices, so we can choose a custom value.
Here is my try to integrate the expression L with trapozoid or simpson
numerical_int.mw
I have  Lie commutations for vectors e1, e2, e3, e4, e5, e6 as follow:
[e1, e3] = e3, [e1, e4] = e4, [e1, e5] = e5, [e1, e6] = e6, [e2, e3] = -e5, [e2, e4] = e6, [e3, e5] = e6
for which the command
Query("Jacobi")
returns the false result, which means, the vectors are not closed under Jacobi's identity. How can I find vector triplets for which Jacobi's identity does not hold?
Please find Maple file.Jacobi_identity.mw
First 94 95 96 97 98 99 100 Last Page 96 of 371
