I have this two expresions
e1 := (1/2)*P[psi]^2/(cos(`ϑ`)^2*Ix)
e2 := (1/2)*P[psi]^2/(cos(`ϑ`)^2*Ix)
simplify(e1-e2)=-(1/2)*(-P[psi]^2+P[psi]^2)/(cos(`ϑ`)^2*Ix)
but
simplify(-P[psi]^2+P[psi]^2)
is zero
why i dont obtain zero if i use simplify(e1-e2) ??
Download MHD1.mw
System of equations with boundary conditions are moving?
Also, find the values of unknown variables?
Dear Users!
Hope everyone fine here. I tried (as given bellow) to find the solution of nonlinear system of PDEs via FDM. To solve system of nonlinear equations I used newton raphson method and for higher value of like Mx > 8 the matrix G and G1 (mentioned as red) take alot of time. Can anyone help me to reduce the computational time? Becuase I have to evealuate the solution for Mx = 50.
restart; Digits := 30; with(LinearAlgebra);
T := 1; L := 3; N := 30; Mx := 5; `Δx` := L/(1.*Mx); `Δt` := T/(1.*N);
for i from 0 while i <= Mx do
u[i, 0] := 0.; u[i, -1] := u[i, 1]; tau[i, 0] := 0.; theta[i, 0] := 0.; theta[i, -1] := theta[i, 1]
for n from 0 while n <= N do u[0, n] := 0.; u[Mx, n] := 0.; theta[0, n] := 1.; theta[Mx, n] := 0.
for n from 0 while n <= N-1 do
print("Simulation in proccess at time-level n", n+1);
for i while i <= Mx-1 do
Ru[i, n] := simplify((u[i+1, n+1]-u[i+1, n])/`&Delta;t`+(u[i+1, n+1]-2*u[i+1, n]+u[i+1, n-1])/`&Delta;t`^2-(u[i+1, n+1]-2*u[i, n+1]+u[i-1, n+1])/`&Delta;x`^2+25.*(u[i+1, n+1]+(u[i+1, n+1]-u[i+1, n])/`&Delta;t`)-1.5*(theta[i, n]+(theta[i, n+1]-theta[i, n])/`&Delta;t`));
`R&theta;`[i, n] := simplify((theta[i+1, n+1]-theta[i+1, n])/`&Delta;t`+(theta[i+1, n+1]-2*theta[i+1, n]+theta[i+1, n-1])/`&Delta;t`^2-(theta[i+1, n+1]-2*theta[i, n+1]+theta[i-1, n+1])/((15.)*`&Delta;x`^2)-((u[i, n+1]-u[i-1, n+1])/`&Delta;x`)^2/(3.)) end do;
`R&tau;`[i, n] := simplify(tau[i+1, n+1]+(tau[i+1, n+1]-tau[i+1, n])/`&Delta;t`-1.5^(-1/4)*(u[i+1, n+1]-u[i, n+1])/`&Delta;x`)
Sys := `<,>`(seq(Ru[i, n], i = 1 .. Mx-1), seq(`R&tau;`[i, n], i = 1 .. Mx-1), seq(`R&theta;`[i, n], i = 1 .. Mx-1));
V := `<,>`(seq(u[i, n+1], i = 1 .. Mx-1), seq(theta[i, n+1], i = 1 .. Mx-1), seq(tau[i, n+1], i = 2 .. Mx));
G := Matrix(3*(Mx-1), proc (i, j) options operator, arrow; diff(Sys[i], V[j]) end proc); G1 := MatrixInverse(G);
X[n, 0] := Vector(1 .. 3*(Mx-1), 1);
for k1 from 0 to r do
X[n, k1+1] := eval(V-G1 . Sys, Equate(V, X[n, k1]))
Sol[n] := Equate(V, X[n, r+1]); assign(op(Sol[n]));
if n > 0 then
U := eval(`<,>`(seq(u[i1, n+1], i1 = 1 .. Mx)-seq(u[i1, n], i1 = 1 .. Mx))); Noru[n+1] := Norm(%, 2); print("L[&infin;] norm of &tau;(x,y,t) at time level = ", %);
Theta := eval(`<,>`(seq(theta[i1, n+1], i1 = 0 .. Mx)-seq(theta[i1, n], i1 = 0 .. Mx))); `Nor&theta;`[n+1] := Norm(%, 2); print("L[&infin;] norm of &theta;(x,y,t) at time level = ", %) else print("n < 0")
end if end do
Special request to:
@acer @Carl Love @Kitonum @Preben Alsholm
Hey, im new to maple and have a few questions.
1. Sometimes, when i type e.g. a:=10 the blue evaluate line shows "a = 10" and sometimes it just shows "10"
is there a way to get that straight?
I have created a set of help files using the example templates. After I create the .help file and install it with my package, I can view the help pages in the help viewer. However, when I click on any link within a help page, the target page opens as a worksheet in Maple. I understand this is because I created the hyperlink with a worksheet as the target. However, I don't know where to obtain the help topic name for a help page before it has been created.  I have searched help, but can't find any applicable guidance.  Can anyone tell me how to determine the help topic name when first creating the help pages.
I have attached one of my help file worksheets.     Hlpdiracmatrices.mw
Dear Maple community,
I would really appreciate it if you could tell me how I can solve numerically in Maple the following system of equations (the Maple file containing these equations can be found here: Mapleprime_Q.mw):
Thank you very much in advance for you help!
When I create a vector in spherical coordinates and map it to cartesian coordinates with Physics[Vectors] package as follows,
restart:with(Physics[Vectors]):
q_:=a _r + b _theta + c _phi
ChangeBasis(q_,cartesian)
I get the answer:
(a*cos(phi)*sin(theta)+b*cos(phi)*cos(theta)-c*sin(phi)) i + (a*sin(theta)*sin(phi)+b*cos(theta)*sin(phi)+c*cos(phi)) j + (-b*sin(theta)+a*cos(theta)) k
which is what I would expect.
But if I try to do that with VectorCalculus package as follows,
q := SetCoordinates(<a, b, c>, spherical)
MapToBasis(q, cartesian)
This gives
(a*sin(b)*cos(c)) ex + (a*sin(b)*sin(c)) ey + (a*cos(b)) ez
I am confused about this!
The SetCoordinates(<a, b, c>, spherical) command outputs
q:=(a) er  + (b) ephi + (c) etheta
here, a,b, and c are  depicted as the components of the vector q in spherical coordinates, but when I map to cartesian coordinates, a,b, and c are treated as if they were the coordinates in spherical coordinates rather than components-- unlike ChangeBasis in Physics[Vectors] package.
Why are these two different?
Hi, I hope this question is allowed
I wish to become well learned in maple but I find all the time, when I come across a new problem, the maple help function only takes me so far. In this community are some really helpful and bright characters which I would like to match in knowledge.
Is it possible to 'know it all' in the maple universe, or are there certain areas you're well versed in over others?
what are some of the ways you have learned to use maple effectively?
kind regards, Ben
As you can see in the code, I am trying to print the solution of the ODE using the Homotopy perturbation method for N = 10 ( f[0] till f[10]), but Maple is only printing f[0],f[1], and the rest of the terms are not printed out, what could cause this issue to take place?
N := 10:
  F(Y) :=  add(p^i*f[i](Y), i = 0..N);
  HPMEq := (1 - p)*diff(F(Y), Y $ 4) + p*(diff(F(Y), Y $ 4) + R*(diff(F(Y), Y $ 3)*F(Y)- diff(F(Y), Y $ 2)*diff(F(Y), Y $ 1))-G*diff(F(Y), Y $ 2));
    sol:=[]:
  for i from 0 to N do
      sol:= [ sol[],
              dsolve
              ( [ eval
                  ( coeff(HPMEq, p, i) = 0,
                    sol
                  f[i](0) = -a,
                  f[i](1) = -b,
                  D(f[i])(0) = B * D(D(f[i]))(0),
                  D(f[i])(1) = -B * D(D(f[i]))(1)
sol;
Please kindly try to run this code in your Maple version and tell me if all terms are printed.
How I can obtain system (21) in the following pdf file?
In the first step several changes of variables are done to obtain the system (20),
then changes the variables again repeated in the neighborhood (w1 *, w2 *) to gain Eq 21.
I have 3 questuin:
1-The change of variables performed in the neighborhood (w1 *, w2 *)
for system (20) or for system (7) ???
2-What does it mean in the neighborhood (w1 *, w2 *)?
3- How did obtaun Eq (21)?
[upload link replaced by moderator, as violation of Term of Use]
[paperhub.ir]10.1016@j.neucom.2010.06.023.pdf
I am using code edit region for parameters but getting this error, can someone help me to solve this issue.
Can anyone correct me, what's wrong with it.
Help_solution.mw
Here is a simple example which generates a loss of the connection to the kernel.
A few words to help you understand what this simplified code is aimed to do.
The inputs are:
  • a matrix (10 by 2 in the example given above),
  • a "slave" column p,
  • a "master" column q,
  • a list of rangesr.
Let nr the number of elements of r.
The goal is to separate the elements of M[.. ,p] in nr sorted lists L1, ..., Lnr according to the rule
  • M[n ,p] is in Lk  if M[n ,q] is in r[k]
A notional example is given in the snippet code below.
The variable num contains nr lists, the kth one contains the values of such that M[n ,q] is in r[k] .
As soon as one element of num is empty list the line S := ... generates the Connection to Kernel lost message.
I have made sure that this no longer happens by coding more carefully.
However, since some recent posts have mentioned this type of connection loss (usually difficult to trace), I thought it might be useful to publish this example (a census of connection loss situations might help make Maple more robust)
interface(version)
Standard Worksheet Interface, Maple 2015.2, Mac OS X, December 21 2015 Build ID 1097895
LTB := ListTools:-BinaryPlace:
M  := LinearAlgebra:-RandomMatrix(10, 2):
p  := 1:
q  := 2:
r  := [-100..-1, -1..1, 1..100]:
nr := numelems(r):
Y_x, Y_ix := sort(M[.., q] , output=[sorted, permutation]):
bounds    := map(u -> 1+LTB(Y_x, op(1, u))..LTB(Y_x, op(2, u)), r);
Y_nb      := map(u -> op(2, u)-op(1, u)+1, bounds);
            [2, 0, 8]
num       := [ seq(Y_ix[bounds[k]], k=1...nr) ];
            [[9, 1], [], [3, 2, 6, 7, 10, 4, 8, 5]]
S := [ seq(sort(convert(M[num[k], p], Vector)), k=1..nr) ];
KernelConnectionLost.mw
Hi there!
I have a procedure that compares the (2n+1)-point Gauß-Kronrod-Quadrature to the (2n+1)-point Patterson-Quadratures for a range of n. I have plotted the results (the absolute and relative error if they "exist", meaning they need to posess certain features) in a graph, however they do not look very insightful. For the lowest n, the reader gets an impression for the different accuracy of the quadrature rules, however, for higher n's, the resulting points are basically just on the x-axis with no difference to see. Is it possible to also print a math table with Maple? Something like:
      GKQ   PZ+   PZ-   PY
1     1,04   1,03  1,02  1,02
2     1,09   1,04     -       -
3     1,02   1,01  1,01  1,01
4     1,03   1,02  1,01  1,01
with - meaning no existance for that particular n? I havent found anything about that on the internet, it's all about plotting.
My (long) code is this:
with(ListTools):
with(PolynomialTools):
with(CurveFitting):
Plotting:=proc(Unten,Oben,f,g,nUnten,nOben)::plot;
local SpeicherlisteX, SpeichervektorX, #speichert die Stützstellen
SpeichervektorXGekürzt, #streicht nicht existierende Quaraturformeln.
SpeicherlisteYAbs, SpeichervektorYAbs,  #speichert die Stützwerte des späteren Splines aus dem absoluten Quadraturfehler
SpeicherlisteYRel, SpeichervektorYRel,  #speichert die Stützwerte des späteren Splines aus den relativen Quadraturfehler
î, #Laufvariable
InterpolationsfunktionAbs, #speichert den Spline aus dem absoluten Interpolationsfehler
InterpolationsfunktionRel, #speichert den Spline aus den relativen Fehlern von f
GraphAbsGK, GraphAbsPY, GraphAbsPZP, GraphAbsPZM, #speichert den Graphen aus dem Spline aus dem absoluten Interpolationsfehler          GraphRelGK, GraphRelPY, GraphRelPZP, GraphRelPZM, #speichert den Graphen aus dem Spline aus den relativen Fehlern  von f
PunkteAbsGK, PunkteAbsPY, PunkteAbsPZP, PunkteAbsPZM,#speichert den Punktgraphen aus dem absoluten Interpolationsfehler
PunkteRelGK, PunkteRelPY, PunkteRelPZP, PunkteRelPZM, #speichert den Punktgraphen aus dem absoluten Interpolationsfehler
NichtexistenzGK, NichtexistenzPY, NichtexistenzPZP, NichtexistenzPZM, #speichert die Häufigkeit der Nichtexistenz
p,i,c,d,e,Hn,Koeffizienten,s,j,M,V,S,K,nNeu,Em,Hnm,KnotenHnm,KoeffizientenHnm,h0,b,gxi,Gewichte,Delta,Ergebnis,
Endergebnis,Koeffizient,Rest,a,VorgegebeneKnoten,TatsächlicherWert, DoppelterKnoten, KomplexerKnoten,
Text:= proc() #Prozedur zum Schreiben der Ausgabe
uses T= Typesetting;
     T:-mrow(seq(`if`(e::string, T:-mn(e), T:-Typeset(T:-EV(e))), e= [args]))
end proc,
OrtPol:= proc(G,N)::list; #Prozedur zum Berechnen der benötigten orthogonalen Polynome
  local q,r,R;
  q[-1]:=0;
  q[0]:=1;
  for r from 1 to N do
  q[r]:=(x^r-add(evalf(Int(x^r*q[R]*G,x=(-1)..1))*q[R]/evalf(Int(q[R]^2*G,x=(-1)..1)),R=0..r-1));
  return(fsolve(q[N]));
end proc,
BasenwechselNormiert:=proc(Dividend, m)::list; #stellt ein gegebenes Polynom über eine Linearkombination der orthogonalen Polynome #dar.
   local BasenwechselNormiert;
  Koeffizient:=quo(Dividend, p[m],x);
  Rest:=rem(Dividend, p[m],x);
  if m=0 then
    BasenwechselNormiert:=[Koeffizient*evalf(Int(g*p[m]^2,x=Unten..Oben))];
    BasenwechselNormiert:=[Koeffizient*evalf(Int(g*p[m]^2,x=Unten..Oben)),op(procname(Rest,m-1))];
  end proc,
    Basenwechsel:=proc(Dividend, m)::list; #stellt ein gegebenes Polynom über eine Linearkombination der orthogonalen Polynome dar.
   local Basenwechsel;
  if m=0 then
    Basenwechsel:=[Koeffizient];
    Basenwechsel:=[Koeffizient,op(procname(Rest,m-1))];
  end proc,
Erweiterung:= proc(Unten, Oben, f,g,Liste,n)::real; #Prozedur zur Berechnung der optimalen Erweiterung nach Knotenvorgabe
  #Unten:= Untere Intervallgrenze; Oben:= Obere Intervallgrenze; f:= zu integrierende Funktion;
  #g:= Gewicht; Liste:= Liste der alten Knoten, n:= Anzahl hinzuzufügender Knoten;
Hn:=mul(x-Liste[i],i=1..numelems(Liste));
 Koeffizienten:=FromCoefficientList(BasenwechselNormiert(Hn,numelems(Liste)+1),x,termorder=reverse); #Die Koeffizienten der orthogonalen Polynome werden hier als Koeffizienten der Monome gespeichert.
M:=Matrix(n,n); #Beginn der Erstellung eines linearen Gleichungssystems, dessen Lösung die Koeffizienten der orthogonalen Polynome sind, deren Summe Em die hinzuzufügenden Knoten als Nullstellen hat.
V:=Vector(n);
  for s from 0 to n-1 do
    for j from 0 to s do
      M(s+1,j+1):=add(coeff(a[s][j],x,k)*coeff(Koeffizienten,x,k),k=0..n);
      if s<>j then
        M(j+1,s+1):=M(s+1,j+1);
    M(s+1,n+1):=add(coeff(a[n][s],x,k)*coeff(Koeffizienten,x,k),k=0..n);
S:=LinearSolve(M,V);
K:=evalindets(S,name,()->2);
Em:=add(p[i]*K[i+1],i=0..n); #Erstellen von Em, dessen Nullstellen die hinzuzufügenden Knoten sind
Hnm:=Hn*Em; #Erstellen von Hnm, welches alle Knoten als Nullstelle besitzt
KnotenHnm:=fsolve(Hnm,complex); #Knotenberechnung
if (KnotenHnm[1]<-1-10^(-10)) or (KnotenHnm[n+numelems(Liste)]>1+10^(-10)) then
  return(false)
KomplexerKnoten:=false;
for i from 1 to n+numelems(Liste) do
 if(Im(KnotenHnm[i])>10^(-10)) then
  KomplexerKnoten:=true
if KomplexerKnoten=true then
  return(false)
DoppelterKnoten:=false;
for i from 1 to n+numelems(Liste)-1 do
 if (KnotenHnm[i+1]-KnotenHnm[i]<10^(-10)) then
   DoppelterKnoten:=true
if DoppelterKnoten=true then
 return(false)
KoeffizientenHnm:=Reverse(Basenwechsel(Hnm,n+numelems(Liste)));  #Das Polynom Hnm wird über die orthogonalen Polynome dargestellt.
h0:=evalf(Int(g,x=Unten..Oben)); #Beginn der Berechnung der Gewichte
b[n+numelems(Liste)+2]:=0;
b[n+numelems(Liste)+1]:=0;
  for i from 1 to nops([KnotenHnm]) do
    for j from n+numelems(Liste) by -1 to 1 do
      b[j]:=KoeffizientenHnm[j+1]+(d[j]+KnotenHnm[i]*c[j])*b[j+1]+e[j+1]*b[j+2];
    gxi:=quo(Hnm,x-KnotenHnm[i],x);
    Gewichte[i]:=c[0]*b[1]*h0/eval(gxi,x=KnotenHnm[i]);
    Delta[i]:=c[0]*b[1];
Ergebnis:=add(eval(f,x=KnotenHnm[k])*Gewichte[k],k=1..nops([KnotenHnm]));
Endergebnis:=Re(evalf(Ergebnis))
p[-1]:=0;
p[0]:=1;
for i from 1 to (2*nOben+1)*2 do
  p[i]:=(x^i-add(evalf(Int(x^i*p[j]*g,x=Unten..Oben))*p[j]/evalf(Int(p[j]^2*g,x=Unten..Oben)),j=0..i-1)); #Berechnung einer Folge orthogonaler Polynome bezüglich der gegebenen Gewichtsfunktion und des gegebenes Intervalles
c[i-1]:=coeff(p[i],x,i)/coeff(p[i-1],x,i-1); #Berechnung der dreigliedrigen Rekursion der errechneten orthogonalen Polynome
d[i-1]:=(coeff(p[i],x,(i-1))-c[i-1]*coeff(p[i-1],x,(i-2)))/coeff(p[i-1],x,(i-1));
if i <> 1 then
  e[i-1]:=coeff(p[i]-(c[i-1]*x+d[i-1])*p[i-1],x,i-2)/coeff(p[i-2],x,i-2);
  e[i-1]:=0;
a[0][0]:=1; #Beginn der Berechnung der orthogonalen Produkterweiterungen, die Koeffizienten der orthogonalen Polynome werden wieder über die Monome gespeichert (2*x^2+2 bedeutet bspw. [2,0,2,0,0...] für die Koeffizienten)
a[1][0]:=x;
a[1][1]:=-e[1]*c[0]/c[1]+(d[0]-d[1]*c[0]/c[1])*x+c[0]/c[1]*x^2;
for s from 2 to 2*nOben+1 do
  a[s][0]:=x^s;
  a[s][1]:=-e[s]*c[0]/c[s]*x^(s-1)+(d[0]-d[s]*c[0]/c[s])*x^s+c[0]/c[s]*x^(s+1);
    pprint (coeff(a[s][1],x,s),as1s);
  for j from 2 to s do
     a[s][j]:=c[j-1]*add(coeff(a[s][j-1],x,k-1)/c[k-1]*x^k,k=abs(s-j)+2..s+j)+add((d[j-1]-c[j-1]*d[k]/c[k])*coeff(a[s][j-1],x,k)*x^k,k=abs(s-j)+1..s+j-1)-c[j-1]*add(e[k+1]*coeff(a[s][j-1],x,k+1)/c[k+1]*x^k,k=abs(s-j)..s+j-2)+e[j-1]*add(coeff(a[s][j-2],x,k)*x^k,k=abs(s-j)+2..s+j-2);
for î from nUnten to nOben do
  VorgegebeneKnoten[î]:=OrtPol(g,î);
TatsächlicherWert:=evalf(Int(f*g,x= Unten..Oben));
GraphAbsGK:=plot([]); PunkteAbsGK:=plot([]); GraphAbsPZP:=plot([]); PunkteAbsPZP:=plot([]); GraphAbsPZM:=plot([]); PunkteAbsPZM:=plot([]); GraphAbsPY:=plot([]); PunkteAbsPY:=plot([]);
GraphRelGK:=plot([]); PunkteRelGK:=plot([]); GraphRelPZP:=plot([]); PunkteRelPZP:=plot([]); GraphRelPZM:=plot([]); PunkteRelPZM:=plot([]); GraphRelPY:=plot([]); PunkteRelPY:=plot([]);
SpeicherlisteX:=[];
SpeicherlisteYAbs:=[];
SpeicherlisteYRel:=[];
  if Erweiterung(Unten,Oben,f,g,[VorgegebeneKnoten[î]],î+1) <> false then
    SpeicherlisteX:=[op(SpeicherlisteX),î]; #Stützstellen definieren
    SpeicherlisteYAbs:=[op(SpeicherlisteYAbs),Erweiterung(Unten,Oben,f,g,[VorgegebeneKnoten[î]],î+1)-evalf(Int(f*g,   x=Unten..Oben))]; #Bestimmen des absoluten Fehlers von f für n=î
      if abs(TatsächlicherWert) > 10^(-10) then #Bestimmen des relativen Fehlers von f1 falls                                                          #dieser definiert ist
      SpeicherlisteYRel:=[op(SpeicherlisteYRel),abs(SpeicherlisteYAbs[-1]/TatsächlicherWert)];
if numelems(SpeicherlisteX)>0 then
  SpeichervektorX:=Vector[row](numelems(SpeicherlisteX),SpeicherlisteX);
  SpeichervektorYAbs:=Vector[row](numelems(SpeicherlisteYAbs),SpeicherlisteYAbs);
  PunkteAbsGK:= plot(SpeichervektorX,SpeichervektorYAbs,style = point, color=red, legend = ["GK"]);
    #  Generierung des Punktgraphen, der sich aus den absoluten Fehlern von f ergibt
  if numelems(SpeicherlisteX)>1 then
    InterpolationsfunktionAbs:=Spline(SpeichervektorX,SpeichervektorYAbs,n);
      #  Splines aus Stützpunkten, die sich aus den absoluten Fehlern von f ergeben
    GraphAbsGK:= plot(InterpolationsfunktionAbs, n=nUnten..nOben, color=red);
      #  Generierung des Graphen, der sich aus dem Spline aus den absoluten Fehlern von f ergibt
  # falls der relative Fehler definiert ist analoges Vorgehen für die relativen Fehler
    SpeichervektorYRel:=Vector[row](numelems(SpeicherlisteYRel),SpeicherlisteYRel);
    PunkteRelGK:= plot(SpeichervektorX,SpeichervektorYRel,style = point, color=red, legend = ["GK"]);
    if numelems (SpeicherlisteX)>1 then
      InterpolationsfunktionRel:=Spline(SpeichervektorX,SpeichervektorYRel,n);
      GraphRelGK:= plot(InterpolationsfunktionRel, n=nUnten..nOben, color=red);
NichtexistenzGK:=nOben-nUnten+1-numelems(SpeicherlisteX);
SpeicherlisteX:=[]; # analoges Vorgehen für PZP
  if Erweiterung(Unten,Oben,f,g,[-1,VorgegebeneKnoten[î]],î) <> false then
    SpeicherlisteYAbs:=[op(SpeicherlisteYAbs),Erweiterung(Unten,Oben,f,g,[-1,VorgegebeneKnoten[î]],î)-TatsächlicherWert]; #Bestimmen des absoluten Fehlers von f für n=î
  PunkteAbsPZP:= plot(SpeichervektorX,SpeichervektorYAbs,style = point, color=orange);
    GraphAbsPZP:= plot(InterpolationsfunktionAbs, n=nUnten..nOben, color=orange);
    PunkteRelPZP:= plot(SpeichervektorX,SpeichervektorYRel,style = point, color=orange, legend = ["PZP"]);
      GraphRelPZP:= plot(InterpolationsfunktionRel, n=nUnten..nOben, color=orange);
NichtexistenzPZP:=nOben-nUnten+1-numelems(SpeicherlisteX);
SpeicherlisteX:=[];# analoges Vorgehen für PZM
  if Erweiterung(Unten,Oben,f,g,[VorgegebeneKnoten[î],1],î) <> false then
    SpeicherlisteYAbs:=[op(SpeicherlisteYAbs),Erweiterung(Unten,Oben,f,g,[VorgegebeneKnoten[î],1],î)-TatsächlicherWert]; #Bestimmen des absoluten Fehlers von f für n=î
  PunkteAbsPZM:= plot(SpeichervektorX,SpeichervektorYAbs,style = point, color=blue, legend = ["PZM"]);
    GraphAbsPZM:= plot(InterpolationsfunktionAbs, n=nUnten..nOben, color=blue);
    PunkteRelPZM:= plot(SpeichervektorX,SpeichervektorYRel,style = point, color=blue, legend = ["PZM"]);
      GraphRelPZM:= plot(InterpolationsfunktionRel, n=nUnten..nOben, color=blue);
NichtexistenzPZM:=nOben-nUnten+1-numelems(SpeicherlisteX);
SpeicherlisteX:=[]; #analoges Vorgehen für PY
  if Erweiterung(Unten,Oben,f,g,[-1,VorgegebeneKnoten[î],1],î-1) <> false then
    SpeicherlisteYAbs:=[op(SpeicherlisteYAbs),Erweiterung(Unten,Oben,f,g,[-1,VorgegebeneKnoten[î],1],î-1)-TatsächlicherWert]; #Bestimmen des absoluten Fehlers von f für n=î
  PunkteAbsPY:= plot(SpeichervektorX,SpeichervektorYAbs,style = point, color=purple, legend = ["PY"]);
    GraphAbsPY:= plot(InterpolationsfunktionAbs, n=nUnten..nOben, color=purple);
    PunkteRelPY:= plot(SpeichervektorX,SpeichervektorYRel,style = point, color=purple, legend = ["PY"]);
      GraphRelPY:= plot(InterpolationsfunktionRel, n=nUnten..nOben, color=purple);
NichtexistenzPY:=nOben-nUnten+1-numelems(SpeicherlisteX);
print(display({GraphAbsGK,PunkteAbsGK,GraphAbsPZP,PunkteAbsPZP, GraphAbsPZM,PunkteAbsPZM, GraphAbsPY,PunkteAbsPY}, title= "Absoluter Fehler", titlefont=["ROMAN",18]));
  print(display({GraphRelGK,PunkteRelGK,GraphRelPZP,PunkteRelPZP, GraphRelPZM,PunkteRelPZM, GraphRelPY,PunkteRelPY}, title= "Relativer Fehler", titlefont=["ROMAN",18]));
Text("Häufigkeit der Nichtexistenz: GK ",NichtexistenzGK, ", PZP ",NichtexistenzPZP, ", PZM ", NichtexistenzPZM, ", PY ", NichtexistenzPY);
An example of how it should not look like is this:
Plotting(-1,1,2*x^2+2,1,3,10)
On a side note, Maple's return is
Warning, `GraphRelGK` is implicitly declared local to procedure `Plotting`
Warning, `GraphRelPZP` is implicitly declared local to procedure `Plotting`
Warning, `GraphRelPZM` is implicitly declared local to procedure `Plotting`
Warning, `GraphRelPY` is implicitly declared local to procedure `Plotting`
even though I did declare them.
Any suggestions on that minor issue? And on how to construct a math table which allows for a symbol like - for nonexistence?
Thank you in advance!
First 93 94 95 96 97 98 99 Last Page 95 of 371
