Hi there.
It seems like a bug in modp1(('Rem')(...)) with large polynomials with large coefficients.
Please look at the file:
bug_rem.mw
It needs the file polys.m there:
https://dropmefiles.com/9fATR
File polys.m too big for this forum so I used dropmefiles.
Polys.m contain two polynomials x and f_t with large degrees: degree(f_t) = m = 50021, degree(x) = 2*m - 2 = 100040 and large coefficients up to 2^N, where N = ceil(m / 2)+2 = 25013.
I just compute rem(x,f_t) mod 2^N.
As you can see in the first part of doc bug_rem.mw I decreased coefficients of polynomials by additional mod 2^N (with Embed function), where N = floor(N / 2) = 12506. WIth these decreased polynomials and decreased N modp1(('Rem')(...)) function works well and use maximum about 2.5 Gb of RAM.
But in the second part of doc bug_rem.mw with original polynomials and N = 25013 modp1(('Rem')(...)) use maximum about 3.5 Gb of RAM and crash with error:
Error, Maple was unable to allocate enough memory to complete this computation.  Please see ?alloc
This is strange and looks like a bug considering that the test server has 48 Gb of RAM.
Is it a bug or modp1(('Rem')(...)) just need more than 48 Gb of RAM?
How many RAM it needs for this computation?
Hello, I am trying to fix the problem reported below.
I am using the 64 bit version of Maple 2020.1. I am experiencing similar problems with other java applications. So I believe it must be something related to Java.
Moreover, it looks like the local refreshing problem is following the cursor of the mouse, therefore it must be something related to the interaction of the mouse with the GUI.
I am using a I7 CPU, 32 GB of Ram and a Nvidia Geforce RTX 2070.
Is anyone experiencing something like this? How can I fix this?
My personal edition of Maple 2020 throws java-lang-thread for every plot3d. No further output is provided by Maple. How can I further troubleshoot this?
Dave
Why do I get an error when using this:/// during readin of a xml attachment in Maple workbook?
Exceltools Import works without problems.
ReadXML.zip
Is there any programming or package to solve my problem. I am poor in programming.
Thanks sincerely!
Any idea why the result of the FirstChild function of the attached file is
_XML_Text("\n  ")
Test.zip
I also miss a more complete example on Maple Help for writing, reading and processing xml files.
Hello! Sorry if this question was already asked, I just can't find my answer and I don't really know how to form the question since I'm new to using Maple. My question is: How can I find a point on a plot I did in Maple? When I use the cursor position(from when I click Probe info) I can never align it right enough for me to not get a decimal answer. For instance, I can't figure out the y-value for when x=2 because the closest I can get to 2 is like 2.1 which isn't exact enough for me.
To practice more in documentmode
Given  f := x^2 + y^2 + z^2 = 1
Asked:
surfacelevel on level 1  and surfacelevel upon wich the point (sqrt(3), 3, -2) is located.
1) x^2 + y^2 + z^2 = 1   : what solid ( a sphere with radius 1)  and  plot
2) surfacelevel (solid sphere)   for point  (sqrt(3), 3, -2) and plot
3) Plot together
Doing this calculation solely with contextpanel..no that's not always possible as it seems by trying to plot a sphere.
I'm new to Maplesim and Maple. I've modeled a planar slider-crank mechanism in Maplesim and it works.
Now I want to extract the equations of motion (DAE) for further analysis. From 'Template' --> 'Worksheet', I used A:-GetEquations() to try to get the DAE. However, the equations are too long and not shown. Moreover, I don't know what coordinates Maplesim used to generated those 'unseen' equations. Here are the equations that can be hand-derived:
where I and m represent inertia and mass respectively. Theta, beta and s are the chosen generalized coordiantes, s_theta is sin(theta), c_theta is cos(theta)s_beta is sin(beta), c_beta is cos(beta). Rx and Ry are lagrange multipliers representing the reaction force in the pin between the crank and the connecting rod.
How can I generate such DAEs using Maplesim? Thank you very much.
How can this alteration occur by itself and what is the point of doing so? How do I change it back to $\cup$ and $\cap$?
I'm trying to put image in my maplet interface.
I use this following code
Label(Image(cat(currentdir(),"\\Image Folder\File name.png")))
The code work as well when i run the code in worksheet. But it doesn't work since i export the worksheet to .maplet file.
Please help. Thank you
interface(prettyprint=2):
with(ListTools):
with(StringTools):
for xx from 1 to 2 do
xx := 1:
Source := FileTools[Text][ReadFile](cat("C:\\hello\\probability1-200-26042020\\home\\probability",xx,"\\probability",xx,".txt")):
openindex := [SearchAll("[",Source)]:
endindex := [SearchAll("]",Source)]:
beforefiltered := []:
for mm from 1 to nops(openindex) do
if mm > 27 then
beforefiltered := [op(beforefiltered), Chop(substring(Source, openindex[mm]..endindex[mm]))]:
afterfiltered := []:
for mm in beforefiltered do
if Has(mm,"--") or Has(mm,"|") or Has(mm,"{") or Has(mm,"}") then
dummy := 0:
elif Has(mm,"Root") then
dummy := 0:
afterfiltered := [op(afterfiltered),mm]:
afterfiltered[1];
however after chop still has new line, can not make a beautiful csv format,
"[b(t,k)+ a
(t,k)*
x(t,k)]"
# I try to export to text first and then use Excel to use "|" as delimiter instead comma as delimiter,
#because b(t,k) has comma "," will separate to open a new column
appendto("C:\\Users\\Student\\Documents\\IQ1-200csv.txt"):
for mm in afterfiltered do
AA := parse(mm):
lprint(xx,"|","hello := [","|",AA[1],"|",AA[2],"|","]:");
Expect csv in format
1,b(t,k)+a(t,k)*x(t,k)
2,a(t,k)+s(t,k)*z(t,k)
Hello, I found this very strange behavior in Maple and I can't explain why this is not working
A little bit of context first:
1. I placed a polygon as a boundary for a section and then two polygons that correspond to inner holes to the first one.
2. Then I proceed to create a regular mesh that places N x M points spread across the region (OK here)
3. A procedure checks weather or not a Point is inside the region, on the borders or in the inner holes (OK here)
4. Then I want to select the closest (but exterior) ones so I can create a path using the mesh points.
Here is where I find the issue. I start at a vertex called V[1,1] and I want to arrive at V[1,2] (in the document they are blue solid points marked they are near-vertices near the original polygons). The procedure that I apply finds a path towards the V[1,2] as I was expecting but when the procedure hits the V[1,2] coordinates the while loop does not stop
The condition I wrote was:    while point<>V[1,2] do  where 'point' is correctly generated by another procedure.
This happens in a 40 by 50 mesh but with other configurations it works properly (there are also another kind of errors but it's inherent to lack of optimization in my procedures).
What baffles me is why doesn't it stop the cycle, if I test the condition outside the loop it DOES recognize the points are indeed equal. Is it something in Maple or is it something in my PC?
Thanks to anyone who can see the error or the problem because I don't understand the nature of the problem.
Not_Working.mw
First 101 102 103 104 105 106 107 Last Page 103 of 371
