Problem with pdsolve/numeric
Contextualizing:
I created a routine for solving a thermo-mechanical problem. The size of the spatial domain is a function of time and the thermo-mechanical behavior of the structure.
The solution is obtained by discretizing the time domain in n intervals. The thermo-mechanical responses are obtained at each time t[i] =t[i-1]+dt.
The material exhibits elastic and elastoplastic mechanical behavior and thus the problem was divided into two consecutive phases (phase 1 and 2).
The heat problem is nonlinear because the thermal properties are variable (termal conductivity, specific heat, and density).
The problem:
In phase 2, the pdsolve/numeric command returns an error for the solution of the heat conduction equation (equation called pde1). I believe this error is related to the derivative of thermal conductivity k(x1) (piecewise function).
I tested many alternatives (I wrote the pde1 equation in two different ways), I checked the routine many times and I don't understand the reason for the error. With each attempt, the command returns a different error.
Thanks for your attention and help.
Problem.mw
Hi everyone.
I have a 2D function and I wanna after Differentiating from it with respect to tau (at any amount of sigma value) and equaling this derivative to zero solve the infinite system of equations.
P[n](tau)==LegendreP(n - 1/2, cosh(tau)) , Q[n](tau)==LegendreQ(n - 1/2, cosh(tau))
are Legendre function.
Thanks in advanced
FUNCTION_f.mw
"restart;:N:=3: f(sigma,tau):=(sqrt(cosh(tau)-cos(sigma)))*(∑)(A[n]*P[n]((tau)) -n*Q[n]((tau)) )*sin(n*sigma)"
proc (sigma, tau) options operator, arrow, function_assign; sqrt(cosh(tau)-cos(sigma))*(sum((A[n]*P[n](tau)-n*Q[n](tau))*sin(n*sigma), n = 1 .. N)) end proc
W := simplify(diff(f(sigma, tau), tau))
(1/2)*((2*A[2]*(cosh(tau)-cos(sigma))*(diff(P[2](tau), tau))+(-4*cosh(tau)+4*cos(sigma))*(diff(Q[2](tau), tau))+sinh(tau)*(A[2]*P[2](tau)-2*Q[2](tau)))*sin(2*sigma)+(2*A[3]*(cosh(tau)-cos(sigma))*(diff(P[3](tau), tau))+(-6*cosh(tau)+6*cos(sigma))*(diff(Q[3](tau), tau))+sinh(tau)*(A[3]*P[3](tau)-3*Q[3](tau)))*sin(3*sigma)+sin(sigma)*(2*A[1]*(cosh(tau)-cos(sigma))*(diff(P[1](tau), tau))+(-2*cosh(tau)+2*cos(sigma))*(diff(Q[1](tau), tau))+sinh(tau)*(A[1]*P[1](tau)-Q[1](tau))))/(cosh(tau)-cos(sigma))^(1/2)
Download FUNCTION_f.mw
P1 := x^2+y^2-4:
P2 := y^2-2*x+2:
Original question is find CAD of (some y)[P1 <0 and P2 <0]
how to use maple 12 and maple 2015 to find Q1,Q2,Q3 which are projection of P1 and P2
my book show sample points are [-4,-1-sqrt(7),-3,-2,0,1,3/2,-1+sqrt(7),9/5,2,3]
but FindSamples result is not the same with my book, is it my book wrong or FindSamples function wrong?
I find result of my script is the same as book's quantifier position at 7,8,9 though sample points has little different
how to generalize my following script to multiple variables x, y, z, and more ?
I compare with maple 2015 result are different from my book solution, is maple 2015 more advanced version CAD?
with(ListTools):
P1 := x^2+y^2-4:
P2 := y^2-2*x+2:
Q1 := x^2 + 2*x - 6;
Q2 := x^2 - 4;
Q3 := x - 1;
sourcesamples := sort(evalf([solve(Q1), solve(Q2), solve(Q3)]),`<`);
FindSamples:=proc(sourcesamples)
local N, P;
N:=nops(sourcesamples);
P:=proc(a,b)
local a1, b1, m1, n, m;
if a=b then error "Should be a<>b" fi;
a1,b1:=op(convert(sort([a,b],(x,y)->evalf(x)<evalf(y)),rational));
count := 0:
for n from 1 do
m1:=a1*n;
m:=`if`(type(m1,integer),m1+1,ceil(m1));
count := count + 1:
if is(m/n>a1) and is(m/n<b1) then return m/n fi;
od;
print("count=",count);
[ceil(sourcesamples[1])-1, seq(op([sourcesamples[i],P(sourcesamples[i],sourcesamples[i+1])]), i=1..N-1),sourcesamples[N],floor(sourcesamples[N])+1];
RemoveComplex := proc(yy)
local result, k:
result := []:
for k in yy do
if Im(k) = 0 then
result := [op(result), k]:
if result = [] then
result := []:
return result:
Joinsolution := proc(param1, param2group)
local result, k:
result := []:
for k in param2group do
result := [op(result), [param1, k]]:
return result:
CADsamples := FindSamples(sourcesamples):
CADresult1 := []:
for mm in CADsamples do
#print(mm):
if MakeUnique(RemoveComplex([solve(subs(x=mm, P1)), solve(subs(x=mm, P2))])) = [] then
CADresult1 := [op(CADresult1), op(Joinsolution(mm,[0]))];
CADresult1 := [op(CADresult1), op(Joinsolution(mm,FindSamples(sort(evalf(MakeUnique(RemoveComplex([solve(subs(x=mm, P1)), solve(subs(x=mm, P2))]))),`<`))))];
CADresult1;
for mm in CADresult1 do
if subs(x=mm[1],subs(y=mm[2], P1)) < 0 and subs(x=mm[1],subs(y=mm[2], P2)) < 0 then
print("solution ", mm, SearchAll(mm[1],CADsamples), evalf(mm)):
Compare with
with(RegularChains):
with(ChainTools):
with(MatrixTools):
with(ConstructibleSetTools):
with(ParametricSystemTools):
with(SemiAlgebraicSetTools):
with(FastArithmeticTools):
R := PolynomialRing([x,y]):
sys := [x^2+y^2-4,y^2-2*x+2]:
N := []:
P := []:
H := [x]:
dec := RealTriangularize(sys,N,P,H,R):
proj := Projection(sys, N, P, H, 1, R);
Display(dec, R);
P := SamplePoints(sys, R);
Display(P, R);
cad := CylindricalAlgebraicDecompose(sys, R);
Hello everyone, my computer installed Maple 2016, 2020 and set Maple 2016 as default opening files .mw, .mws. How to change default to Maple 2020 . I tried searching on Google but not found.
Thank you very much.
How I can prove the following equation in red box.
Also, Pn(v) and qn(v) are the real combinations of half-integer Legendre functions.
For more details please see
https://math.stackexchange.com/questions/2746660/potential-flow-around-a-torus-laplace-equation-in-toroidal-coordinates/3809487#3809487
Determine how many transitive relations there are on a set with n elements for all positive integers n with n<=7.
Custom Palettes and Palette Entries on windows Pro 7
Read a tutorial from a user @les 185
https://www.mapleprimes.com/posts/207781-Custom-Palettes-And-Palette-Entries
Is this still valid this tutorial from 2015  in the current version of Maple ?
This seems to be userunfriendly.
This is strange.  It is true that this function (a modular form) goes to infinity as t -> 0 from the right.
But should plotting it it do this?
    |\^/|     Maple 2019 (APPLE UNIVERSAL OSX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2019
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
> version();
 User Interface: 1435526
         Kernel: 1435526
        Library: 1435526
                                    1435526
> exp(-Pi*t/3)^8*JacobiTheta3(Pi*(4*I*t+1)/2,
> exp(-12*Pi*t))^8/(exp(-Pi*t/6)^4*
> JacobiTheta3(Pi*(2*I*t + 1)/2, exp(-6*Pi*t))^4);
                 Pi t 8              Pi (4 I t + 1)                8
           exp(- ----)  JacobiTheta3(--------------, exp(-12 Pi t))
                  3                        2
                 Pi t 4              Pi (2 I t + 1)               4
           exp(- ----)  JacobiTheta3(--------------, exp(-6 Pi t))
                  6                        2
> plot(%,t=0..4);
memory used=48.4MB, alloc=45.3MB, time=0.45
Execution stopped: Stack limit reached.
Thank you all for participating to my questions before.
I was wondering if we can change an equation into quartic form or quadratic form in maple.
I have succesfully got an equation like the following:
`S__2 ` = sin(alpha - phi)*sin(-beta + alpha)*(gamma*H^2*sin(beta - varepsilon)*sin(alpha) - h^2*sin(beta)*sin(alpha - varepsilon)*gamma + h^2*sin(beta)*sin(alpha - varepsilon)*psi)/(2*sin(-beta - delta - phi + alpha)*sin(beta)^2*sin(alpha - varepsilon)*sin(alpha)) - S__1
From the paper I studied, they change it to form an equation like this
`S__2 ` = 1/2*gamma*H^2*sin(beta - alpha)*(M__3(X)^3 + M__2(X)^2 + M__1*X)/(sin(beta)^2*(D__3(X)^3 + D__2(X)^2 + D__1*X + D__0)) - S__1
Where value of M, D and X is sets of long equation. Can someone teach me how to assign maple to change this kind of equation to another form of equation. It's good enough if I can learn how to learn the basic.
Faiz Farhan
I want to apply the ‘simplify’ command, in parallel, for the simplification of some parameters. Both Grid:-Map and Grid:-Run commands are tested. There is no error in both, whereas no simplification is implemented. It seems that the ‘simplify’ command correctly works on only ‘Master’ node, namely anywhere we are typing.
Can anyone help me to simplify in parallel. I examined two following codes.
1)
with (Grid);
for i from 1 to nops(dummy_UU1) do
freenode:=WaitForFirst():
Run(freenode,simplify,[dummy_UU1[i]],assignto='dummy_UU2'[i]):
Wait();
2)
dummy_UU2:=Map[tasksize=1](simplify,[seq(dummy_UU1[i],i=1..nops(dummy_UU1))]):
The following code is correctly executed and resulted in the simplification of dummy_UU1 components in serial.
dummy_UU2[i]:=simplify(dummy_UU1[i]):
Could anyone help me out to convert the equation into differential transform method
Hello Everyone, can anyone explain how to import a mathematical equation from maple to word directly?
Just wonder about the status of the public folder in Maple Cloud.
I've tried to upload a file there, but got the reply that the uploaded file is going to be reviewed first. That was end of july.
Sorting files after date shows that the last upload was done in october 2019. Content unknown as it that was in chinese (probably).
It's not really important to me, as I can always find another site to upload stuff, just wondering.
I want to to solve the system of partial differential equation using maple. I tried it but I am not able to solve it ... please help.
the equations are as follows
Finding transformation eqn between zero and harmonic with conformal1
with(PDEtools)
sys := {(diff(Phi(r1, r2, r4), r1))^2-(diff(R(r1, r2, r4), r1))^2 = cos(T(r1, r2, r4))^2, (diff(Phi(r1, r2, r4), r2))^2-(diff(R(r1, r2, r4), r2))^2 = -cos(T(r1, r2, r4))^2, -(diff(R(r1, r2, r4), r2))*(diff(R(r1, r2, r4), r1))+(diff(Phi(r1, r2, r4), r2))*(diff(Phi(r1, r2, r4), r1)) = 0, -(diff(R(r1, r2, r4), r4))*(diff(R(r1, r2, r4), r1))+(diff(Theta(r1, r2, r4), r1))*(diff(T(r1, r2, r4), r4))+(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r1)) = 0, -(diff(R(r1, r2, r4), r4))*(diff(R(r1, r2, r4), r2))+(diff(Theta(r1, r2, r4), r2))*(diff(T(r1, r2, r4), r4))+(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r2)) = 0, (R(r1, r2, r4)^2-Phi(r1, r2, r4)^2)*(diff(T(r1, r2, r4), r4))^2+2*(diff(Theta(r1, r2, r4), r4))*(diff(T(r1, r2, r4), r4))+(diff(Phi(r1, r2, r4), r4))^2-(diff(R(r1, r2, r4), r4))^2 = 0, diff(T(r1, r2, r4), r1) = 0, diff(T(r1, r2, r4), r2) = 0, diff(T(r1, r2, r4), r4) = cos(T(r1, r2, r4))^2}
declare(Phi(r1, r2, r4), R(r1, r2, r4), T(r1, r2, r4), Theta(r1, r2, r4))
` Phi`(r1, r2, r4)*`will now be displayed as`*Phi
` R`(r1, r2, r4)*`will now be displayed as`*R
` T`(r1, r2, r4)*`will now be displayed as`*T
` Theta`(r1, r2, r4)*`will now be displayed as`*Theta
cases := [PDEtools:-casesplit({(diff(Phi(r1, r2, r4), r1))^2-(diff(R(r1, r2, r4), r1))^2 = cos(T(r1, r2, r4))^2, (diff(Phi(r1, r2, r4), r2))^2-(diff(R(r1, r2, r4), r2))^2 = -cos(T(r1, r2, r4))^2, -(diff(R(r1, r2, r4), r2))*(diff(R(r1, r2, r4), r1))+(diff(Phi(r1, r2, r4), r2))*(diff(Phi(r1, r2, r4), r1)) = 0, -(diff(R(r1, r2, r4), r4))*(diff(R(r1, r2, r4), r1))+(diff(Theta(r1, r2, r4), r1))*(diff(T(r1, r2, r4), r4))+(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r1)) = 0, -(diff(R(r1, r2, r4), r4))*(diff(R(r1, r2, r4), r2))+(diff(Theta(r1, r2, r4), r2))*(diff(T(r1, r2, r4), r4))+(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r2)) = 0, (R(r1, r2, r4)^2-Phi(r1, r2, r4)^2)*(diff(T(r1, r2, r4), r4))^2+2*(diff(Theta(r1, r2, r4), r4))*(diff(T(r1, r2, r4), r4))+(diff(Phi(r1, r2, r4), r4))^2-(diff(R(r1, r2, r4), r4))^2 = 0, diff(T(r1, r2, r4), r1) = 0, diff(T(r1, r2, r4), r2) = 0, diff(T(r1, r2, r4), r4) = cos(T(r1, r2, r4))^2}, caseplot)]
`========= Pivots Legend =========`
p1 = diff(R(r1, r2, r4), r2)
p2 = diff(Phi(r1, r2, r4), r1)
p3 = (diff(Phi(r1, r2, r4), r2))^2+cos(T(r1, r2, r4))^2
p4 = diff(Phi(r1, r2, r4), r2)
p5 = diff(R(r1, r2, r4), r1)
[`casesplit/ans`([diff(Theta(r1, r2, r4), r4) = (1/2)*(Phi(r1, r2, r4)^2*cos(T(r1, r2, r4))^4-R(r1, r2, r4)^2*cos(T(r1, r2, r4))^4-(diff(Phi(r1, r2, r4), r4))^2+(diff(R(r1, r2, r4), r4))^2)/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r1) = (-(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r1))*(diff(Phi(r1, r2, r4), r2))^2-(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r1))*cos(T(r1, r2, r4))^2+(diff(Phi(r1, r2, r4), r1))*(diff(Phi(r1, r2, r4), r2))*(diff(R(r1, r2, r4), r4))*(diff(R(r1, r2, r4), r2)))/(cos(T(r1, r2, r4))^2*(diff(Phi(r1, r2, r4), r2))^2+cos(T(r1, r2, r4))^4), diff(Theta(r1, r2, r4), r2) = (-(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r2))+(diff(R(r1, r2, r4), r4))*(diff(R(r1, r2, r4), r2)))/cos(T(r1, r2, r4))^2, diff(diff(R(r1, r2, r4), r4), r4) = -R(r1, r2, r4)*cos(T(r1, r2, r4))^4-2*cos(T(r1, r2, r4))*sin(T(r1, r2, r4))*(diff(R(r1, r2, r4), r4)), diff(R(r1, r2, r4), r1) = (diff(Phi(r1, r2, r4), r2))*(diff(Phi(r1, r2, r4), r1))/(diff(R(r1, r2, r4), r2)), (diff(R(r1, r2, r4), r2))^2 = (diff(Phi(r1, r2, r4), r2))^2+cos(T(r1, r2, r4))^2, diff(diff(Phi(r1, r2, r4), r4), r4) = -Phi(r1, r2, r4)*cos(T(r1, r2, r4))^4-2*(diff(Phi(r1, r2, r4), r4))*cos(T(r1, r2, r4))*sin(T(r1, r2, r4)), diff(diff(Phi(r1, r2, r4), r2), r4) = -(diff(Phi(r1, r2, r4), r2))*cos(T(r1, r2, r4))*sin(T(r1, r2, r4)), diff(diff(Phi(r1, r2, r4), r2), r2) = 0, (diff(Phi(r1, r2, r4), r1))^2 = (diff(Phi(r1, r2, r4), r2))^2+cos(T(r1, r2, r4))^2, sin(T(r1, r2, r4))^2 = -cos(T(r1, r2, r4))^2+1, diff(T(r1, r2, r4), r4) = cos(T(r1, r2, r4))^2, (diff(T(r1, r2, r4), r1))*sin(T(r1, r2, r4)) = 0, (diff(T(r1, r2, r4), r2))*sin(T(r1, r2, r4)) = 0, diff(T(r1, r2, r4), r1) = 0, diff(T(r1, r2, r4), r2) = 0], [diff(R(r1, r2, r4), r2) <> 0, diff(Phi(r1, r2, r4), r1) <> 0]), `casesplit/ans`([diff(Theta(r1, r2, r4), r4) = (1/2)*(Phi(r1, r2, r4)^2*cos(T(r1, r2, r4))^4-R(r1, r2, r4)^2*cos(T(r1, r2, r4))^4-(diff(Phi(r1, r2, r4), r4))^2+(diff(R(r1, r2, r4), r4))^2)/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r1) = (diff(R(r1, r2, r4), r4))*(diff(R(r1, r2, r4), r1))/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r2) = -(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r2))/cos(T(r1, r2, r4))^2, diff(diff(R(r1, r2, r4), r4), r4) = -R(r1, r2, r4)*cos(T(r1, r2, r4))^4-2*cos(T(r1, r2, r4))*sin(T(r1, r2, r4))*(diff(R(r1, r2, r4), r4)), diff(R(r1, r2, r4), r2) = 0, (diff(R(r1, r2, r4), r1))^2 = -cos(T(r1, r2, r4))^2, diff(diff(Phi(r1, r2, r4), r4), r4) = -Phi(r1, r2, r4)*cos(T(r1, r2, r4))^4-2*(diff(Phi(r1, r2, r4), r4))*cos(T(r1, r2, r4))*sin(T(r1, r2, r4)), diff(Phi(r1, r2, r4), r1) = 0, (diff(Phi(r1, r2, r4), r2))^2 = -cos(T(r1, r2, r4))^2, sin(T(r1, r2, r4))^2 = -cos(T(r1, r2, r4))^2+1, diff(T(r1, r2, r4), r4) = cos(T(r1, r2, r4))^2, (diff(T(r1, r2, r4), r1))*sin(T(r1, r2, r4)) = 0, (diff(T(r1, r2, r4), r2))*sin(T(r1, r2, r4)) = 0, diff(T(r1, r2, r4), r1) = 0, diff(T(r1, r2, r4), r2) = 0], [diff(R(r1, r2, r4), r1) <> 0, diff(Phi(r1, r2, r4), r2) <> 0])]
map(length, cases)
[2101, 1405]
sys1 := op(1, cases[2])
sys2 := op(1, cases[1])
sys3 := op(2, cases[1])
sys4 := op(2, cases[2])
sol1 := dsolve(sys1, explicit)
constraint, subsystem := selectremove(has, sys1, T)
[diff(Theta(r1, r2, r4), r4) = (1/2)*(Phi(r1, r2, r4)^2*cos(T(r1, r2, r4))^4-R(r1, r2, r4)^2*cos(T(r1, r2, r4))^4-(diff(Phi(r1, r2, r4), r4))^2+(diff(R(r1, r2, r4), r4))^2)/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r1) = (diff(R(r1, r2, r4), r4))*(diff(R(r1, r2, r4), r1))/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r2) = -(diff(Phi(r1, r2, r4), r4))*(diff(Phi(r1, r2, r4), r2))/cos(T(r1, r2, r4))^2, diff(diff(R(r1, r2, r4), r4), r4) = -R(r1, r2, r4)*cos(T(r1, r2, r4))^4-2*cos(T(r1, r2, r4))*sin(T(r1, r2, r4))*(diff(R(r1, r2, r4), r4)), (diff(R(r1, r2, r4), r1))^2 = -cos(T(r1, r2, r4))^2, diff(diff(Phi(r1, r2, r4), r4), r4) = -Phi(r1, r2, r4)*cos(T(r1, r2, r4))^4-2*(diff(Phi(r1, r2, r4), r4))*cos(T(r1, r2, r4))*sin(T(r1, r2, r4)), (diff(Phi(r1, r2, r4), r2))^2 = -cos(T(r1, r2, r4))^2, sin(T(r1, r2, r4))^2 = -cos(T(r1, r2, r4))^2+1, diff(T(r1, r2, r4), r4) = cos(T(r1, r2, r4))^2, (diff(T(r1, r2, r4), r1))*sin(T(r1, r2, r4)) = 0, (diff(T(r1, r2, r4), r2))*sin(T(r1, r2, r4)) = 0, diff(T(r1, r2, r4), r1) = 0, diff(T(r1, r2, r4), r2) = 0], [diff(R(r1, r2, r4), r2) = 0, diff(Phi(r1, r2, r4), r1) = 0]
sol__subsystem := dsolve(subsystem)
{Phi(r1, r2, r4) = _F1(r2, r4), R(r1, r2, r4) = _F2(r1, r4)}
eval(constraint, sol__subsystem)
[diff(Theta(r1, r2, r4), r4) = (1/2)*(_F1(r2, r4)^2*cos(T(r1, r2, r4))^4-_F2(r1, r4)^2*cos(T(r1, r2, r4))^4-(diff(_F1(r2, r4), r4))^2+(diff(_F2(r1, r4), r4))^2)/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r1) = (diff(_F2(r1, r4), r4))*(diff(_F2(r1, r4), r1))/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r2) = -(diff(_F1(r2, r4), r4))*(diff(_F1(r2, r4), r2))/cos(T(r1, r2, r4))^2, diff(diff(_F2(r1, r4), r4), r4) = -_F2(r1, r4)*cos(T(r1, r2, r4))^4-2*cos(T(r1, r2, r4))*sin(T(r1, r2, r4))*(diff(_F2(r1, r4), r4)), (diff(_F2(r1, r4), r1))^2 = -cos(T(r1, r2, r4))^2, diff(diff(_F1(r2, r4), r4), r4) = -_F1(r2, r4)*cos(T(r1, r2, r4))^4-2*(diff(_F1(r2, r4), r4))*cos(T(r1, r2, r4))*sin(T(r1, r2, r4)), (diff(_F1(r2, r4), r2))^2 = -cos(T(r1, r2, r4))^2, sin(T(r1, r2, r4))^2 = -cos(T(r1, r2, r4))^2+1, diff(T(r1, r2, r4), r4) = cos(T(r1, r2, r4))^2, (diff(T(r1, r2, r4), r1))*sin(T(r1, r2, r4)) = 0, (diff(T(r1, r2, r4), r2))*sin(T(r1, r2, r4)) = 0, diff(T(r1, r2, r4), r1) = 0, diff(T(r1, r2, r4), r2) = 0]
map(simplify, [diff(Theta(r1, r2, r4), r4) = (1/2)*(_F1(r2, r4)^2*cos(T(r1, r2, r4))^4-_F2(r1, r4)^2*cos(T(r1, r2, r4))^4-(diff(_F1(r2, r4), r4))^2+(diff(_F2(r1, r4), r4))^2)/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r1) = (diff(_F2(r1, r4), r4))*(diff(_F2(r1, r4), r1))/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r2) = -(diff(_F1(r2, r4), r4))*(diff(_F1(r2, r4), r2))/cos(T(r1, r2, r4))^2, diff(diff(_F2(r1, r4), r4), r4) = -_F2(r1, r4)*cos(T(r1, r2, r4))^4-2*cos(T(r1, r2, r4))*sin(T(r1, r2, r4))*(diff(_F2(r1, r4), r4)), (diff(_F2(r1, r4), r1))^2 = -cos(T(r1, r2, r4))^2, diff(diff(_F1(r2, r4), r4), r4) = -_F1(r2, r4)*cos(T(r1, r2, r4))^4-2*(diff(_F1(r2, r4), r4))*cos(T(r1, r2, r4))*sin(T(r1, r2, r4)), (diff(_F1(r2, r4), r2))^2 = -cos(T(r1, r2, r4))^2, sin(T(r1, r2, r4))^2 = -cos(T(r1, r2, r4))^2+1, diff(T(r1, r2, r4), r4) = cos(T(r1, r2, r4))^2, (diff(T(r1, r2, r4), r1))*sin(T(r1, r2, r4)) = 0, (diff(T(r1, r2, r4), r2))*sin(T(r1, r2, r4)) = 0, diff(T(r1, r2, r4), r1) = 0, diff(T(r1, r2, r4), r2) = 0])
[diff(Theta(r1, r2, r4), r4) = (1/2)*((_F1(r2, r4)^2-_F2(r1, r4)^2)*cos(T(r1, r2, r4))^4-(diff(_F1(r2, r4), r4))^2+(diff(_F2(r1, r4), r4))^2)/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r1) = (diff(_F2(r1, r4), r4))*(diff(_F2(r1, r4), r1))/cos(T(r1, r2, r4))^2, diff(Theta(r1, r2, r4), r2) = -(diff(_F1(r2, r4), r4))*(diff(_F1(r2, r4), r2))/cos(T(r1, r2, r4))^2, diff(diff(_F2(r1, r4), r4), r4) = -cos(T(r1, r2, r4))*(_F2(r1, r4)*cos(T(r1, r2, r4))^3+2*(diff(_F2(r1, r4), r4))*sin(T(r1, r2, r4))), (diff(_F2(r1, r4), r1))^2 = -cos(T(r1, r2, r4))^2, diff(diff(_F1(r2, r4), r4), r4) = -cos(T(r1, r2, r4))*(_F1(r2, r4)*cos(T(r1, r2, r4))^3+2*(diff(_F1(r2, r4), r4))*sin(T(r1, r2, r4))), (diff(_F1(r2, r4), r2))^2 = -cos(T(r1, r2, r4))^2, sin(T(r1, r2, r4))^2 = sin(T(r1, r2, r4))^2, diff(T(r1, r2, r4), r4) = cos(T(r1, r2, r4))^2, (diff(T(r1, r2, r4), r1))*sin(T(r1, r2, r4)) = 0, (diff(T(r1, r2, r4), r2))*sin(T(r1, r2, r4)) = 0, diff(T(r1, r2, r4), r1) = 0, diff(T(r1, r2, r4), r2) = 0]
Download Finding_transformation_eqn_between_zero_and_harmonic_with_conformal1.mw
First 102 103 104 105 106 107 108 Last Page 104 of 371
