I asked before how to determine whether a graph is  outerplanar graph.  vv  and  Carl Love  provided very good guidance.
https://www.mapleprimes.com/questions/229128--How-To-Determine-If-A-Graph-Is-Outerplanar
 Today I tried to use the previous code to further determine whether a plane graph is maximal outerplanar graph.
maximal outerplanar graph is an outerplanar graph that cannot have any additional edges added to it while preserving outerplanarity.
IsOuterplanar:= proc(G::Graph)
uses GT= GraphTheory;
    GT:-IsPlanar(GT:-GraphJoin(G, GT:-PathGraph(1)))
IsmaximalOuterplanar:= proc(G::Graph)
uses GT= GraphTheory:
local glist, Outerplanartest:
      glist:= map[2](GT:-AddEdge,G,GT:-Edges(GT:-GraphComplement(G)),inplace = false ):
       Outerplanartest:=IsOuterplanar~(glist):
      if evalb(true in Outerplanartest) then
         return false:
         return true:
      fi:
I feel that the  above adding edges in programs is a bit inefficient.
So I wonder if there is a better way.  Then I want to start from property of this graph class.
Some Properties:
  1. Every maximal outerplanar graph with n vertices has exactly 2n − 3 edges.
  2. A graph on  n (>=3) vertices  is  maximal outerplanar graph  if and if  every bounded face of a maximal outerplanar graph is a triangle and boundary of  unbounded face  is  Hamiltonian cycle.
I noticed the second one. I don’t know if it can be achieved through programming
I want to get some information about the degree sequence of the face with the help of the dual graph . But I know  dual graph not unique   since  there are different plane embeddings  for not 3 connected  planar graphs.
Or is there a more efficient way?
Is it possible to auto close brackets in Maple? Like when I type "sin(pi" it would automatically create a closing bracket and I could just press enter to calculate
Any good online training for maple soft to purchase
How to solve this differential equation numerically
eq:=diff(f(tau), tau) =Af(tau) +Lf(tau) +C+Bf(tau)
Comparing the following 2 outputs, all done using worksheet mode. They are same expression. But one is generated using assignment and one using function definition (with arrow).
expr:=sinh(Pi)/Pi*(1+  Sum( (-1)^n/(1+n^2)*(cos(n*x)+n*sin(n*x)),n=1..m)):
f1:=expr;
f2:=unapply(expr,x);
Why Maple 2D display shows small dot for multiplication in the second case, but not in the first? Is there a way to remove this dot? I do not like it and find it distracting.  I looked at options->display and see nothing there to affect this.
Maple 2021 on windows 10
I run Maple on two different computers each with 2 4k monitors running Windows 10 Pro.  Everything appears to work fine on one computer but on the other one, the display gets corrupted when moving the mouse under certain conditions.  I have eliminated the mouse and the video card as the problem because the same problem occurs after replacing them with other manufacturers components.  I have a document that generates a few plots that I can run from both computers.  At first all seems fine and the mouse can be moved across the display and plots without corruption.  But as soon as I try to enable any "Probe Info" via right clicking a plot or from the side pane when the plot is selected, moving the mouse over the plot will cause a continuous corruption that continuous to change as I move the mouse.  The only way I have found to recover from this is to close Maple and resart it.
It appears the problem has to do with redrawing the display after the mouse moves.  Below is an example:
Has anyone experienced this?
Thank you, David
I am using Maple 13, 16 and 17 on 64 bit ubuntu 14.04LTS without
any problems.
I tried to start the above Maple versions after upgrading to ubuntu 18.04LTS. Unfortunately, Maple does not start and transmits an incorrect hostid error message. The error message for Maple 16 is pasted below.
The command ifconfig -a produces an ethernet address 00:21:70:a6:a4:4b that is identical to the hostid given in the license.dat file.
I believe that the license manager flexnet is 32 bit. I used the synaptic
manager to install lsb-base and ia32-libs (synaptic package manager refused to install lsb-core and transmitted some error messages). However, this did not help and I obtained the same hostid error message.
I do not know what is causing the hostid error message. Maybe some script file/s in the Maple installation can be modified such that Maple starts correctly?
Any assistance in getting Maple 13, 16, 17 to start on ubuntu 18.04LTS
would be much appreciated.
Thank you very much for your support.
CF
> ...:~/maple> maple16
> Maple initialization error, Invalid host.
> The hostid of this system does not match the hostid
> specified in the license file.
> Feature: Maple16
> Hostid: 002170a6a44b
> License path:
> /home/apps/maple16/toolbox/MapleSim/license/MapleSim.dat:/home/apps/maple16/license/license.dat:
> FLEXnet Licensing error:-9,57
> For further information, refer to the FLEXnet Licensing documentation,
> available at
> "https://linkprotect.cudasvc.com/url?a=https%3a%2f%2fwww.acresso.com&c=E,1,5ci9cywR8uvrXaVJ4IkoXH0TFBBbJwSK_TulrfrUDs5AyVQ4TXsHOVm5KWKAIhp4OZb9C4OAnmgylY1JC6fpbdZK9SjQLVrW012Uzxq18iDYC56NG2eDyHS8RPA,&typo=1".
> root@<mailto:root@>...:~# ifconfig -a
> enp0s25: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
> ether 00:21:70:a6:a4:4b txqueuelen 1000 (Ethernet)
> RX packets 0 bytes 0 (0.0 B)
> RX errors 0 dropped 0 overruns 0 frame 0
> TX packets 0 bytes 0 (0.0 B)
> TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
> device interrupt 22 memory 0xf6ae0000-f6b00000
> lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
> inet 127.0.0.1 netmask 255.0.0.0
> inet6 ::1 prefixlen 128 scopeid 0x10<host>
> loop txqueuelen 1000 (Local Loopback)
> RX packets 454 bytes 35138 (35.1 KB)
> TX packets 454 bytes 35138 (35.1 KB)
Would be nice if someone could add Maple 2021 to Software Change Requests list.
Right now Maple 2021 is unusable for us due to a big problem related to saving workbooks.
From old memory, I recall some boolean algebra.  We have zeros and ones.
Some of us are familiar with logic gates.
The simplest is the simple inverter.  It inverts.
Very interesting.
https://en.wikipedia.org/wiki/Boolean_algebra
I've experienced problems a couple of times when trying to save a workbook in Maple 2021.
At first I thought it was due to a unstable VPN connection, but this also happens on a local drive.
This is just an obervation. May be due to me missing some clarification.
My understanding is that in Maple 2021, one can now export a complete Maple worksheet/document to Latex successfuly.
According to https://www.maplesoft.com/products/maple/new_features/  it says under "Latex export"
  Export is available for individual expressions or the entire document, though the latex command
So I would have expected that now all the online PDF documents for the new features in Maple 2021 to be generated from Latex for better formatting.
But when going over number of documents, they do not appear to have converted to Latex before generating the PDF.
Even the PDF document about the new latex command does not appear to have been generated from Latex. I can quickly recognize a PDF that was generated from Latex, and these PDF files are clearly not.
Looking at sample PDF from Maple website, it says the generator is "iText" and not latex compiler.
It looks like these documents were just a direct export of the Maple worksheet to PDF, instead of being exporting to Latex first, and then compiled to PDF.
Am I missing something? Why not take advantage of the Maple Latex export, and convert all the documents to Latex first and then generate the PDF from Latex? This would make them look much better in terms of formatting and math rendering.
Here are some examples
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/AdvancedMath.pdf
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/ODEsandPDEs.pdf
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/GraphTheory.pdf
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/Physics.pdf
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/LaTeX.pdf
Why did not Maple documentation take advantage of the new export command of Maple's latex command? This would also have been a good way and an opportunity to show case the effectiveness of the new latex export command.
May be it was not done due to time constraint before the release date of maple 2021? Or are there other technical reasons?
How to draw a streamlines by using stream function provided in pdf. In the presence and absence of lambda parameter.
please help me to obtain graphs
1.pdf
Download 1.mw
Show that x-2 is a factor of p(x)=x^3+3x^2-4x-12
I)determine all the linear factors of p(x)
ii)what are the zeros of y=p(x)
iii)sketch function y=p(x)
I read the code in the link below and have some thoughts on drawing the graph.
https://www.mapleprimes.com/questions/216092-Options-For-Graph-Drawing-In-The-GraphTheory
with(GraphTheory):
with(SpecialGraphs):
G     := PetersenGraph();:
POS := GetVertexPositions(G);
EG   := Edges(G);
PLOT(
   seq( CURVES([POS[EG[i][1]], POS[EG[i][2]]], LINESTYLE(3) ), i=1..numelems(Edges(G))),
   POINTS(POS, SYMBOL(_SOLIDBOX, 35), COLOR(RGB, 1, 1, 0)),
   seq(TEXT(POS[i], i), i=1..numelems(Vertices(G))),
   AXESSTYLE(NONE)
But if we want to change the edge to a curvilinear style, it seems very difficult. We know  PetersenGraph is 1-planar graph.  The following picture is one of  its 1-plane drawing.  That is  also what I want to draw .
PS: 1-planar graph is a graph that can be drawn in the Euclidean plane in such a way that each edge has at most one crossing point, where it crosses a single additional edge
Although I asked a similar question, but it uses too many special curve functions and the method is relatively isolated. Because the cycle graph is too special.  https://www.mapleprimes.com/questions/228987--Can-We-Draw-Curved-Edges-In-The-Graph
I also noticed the optional items of the edge style.  But there are no curves, such as arcs, parabola, etc.
The plot style must be one of line, point, pointline, polygon (patchnogrid), or polygonoutline (patch).
I am trying to draw a parabola, it seems to be quite difficult. And it completely deviated from the use of graph theory package.
drawarc :=proc(A,B,C,ecolor);
local  c,ax,cx ,ay,cy,ox,oy,oo,x,y,b,a,an_end,an_start,r,yuanhu:
ax :=evalf(geometry)[HorizontalCoord](A):
cx :=evalf(geometry)[HorizontalCoord](C):
ay :=evalf(geometry)[VerticalCoord](A):
cy :=evalf(geometry)[VerticalCoord](C):
geometry[circle](c,[ A ,B ,C], [x,y],'centername' =o):
ox :=evalf(geometry[HorizontalCoord] (o)):
oy :=evalf(geometry[ VerticalCoord] (o)):
if(cx -ox)>0 then
b :=arctan((cy -oy) /(cx -ox)):
elif(cx -ox)=0 and (cy -oy)>0 then
b :=Pi/2 :
elif(cx -ox)=0 and (cy -oy)<0 then
b :=-Pi/ 2 :
b :=Pi +arctan((cy -oy) /(cx -ox)):
fi :
if(ax -ox)>0 then
a :=arctan((ay -oy) /(ax -ox)):
elif(ax -ox)=0 and (ay -oy)>0 then
a :=Pi /2 :
elif(ax -ox)=0 and (ay -oy)<0 then
a :=-Pi/ 2 ;
a :=Pi +arctan((ay -oy)/ (ax -ox)):
fi ;
if(evalf(b)<evalf(a))then
an_start :=a :
an_start :=a +2*Pi :
fi :
an_end :=b :
r :=geometry[ radius] (c);
yuanhu :=plottools[ arc] ([ ox , oy] , r , an_start..an_end):
plots[ display] (yuanhu , scaling =constrained, color =ecolor,axes=none);
end :
geometry[point] (a , -3 .00 , 1 .70);
geometry[point] (b , 0 .35 , -0 .45);
geometry[point] (c , 3 .13 , 1 .86);
l :=[a , b , c] ;
drawarc(a,b,c,blue);
I would like to ask maple if there is a more versatile and simpler way to draw a curve of  graph drawing.
drawarcs:=proc(VL ::list , ecolor , scope);
local i , num , arcs , arc_text , vl , display_set ;
vl :=VL ;
num:=nops(vl);
arcs :={};
i:=1;
if num <3 then
"There isn' t enough points in the point list." ;
return ;
elif irem(num-1 , 2)<>0 then
"The number of the list must be multiple of 2 when it minus 1 .";
fi :
while i <num do
arcs :={drawarc(vl[i] ,vl[i +1] , vl[i +2],ecolor),op(arcs)};
i:=i +2 ;
od ;
arc_text :=geometry[ draw] ({vl[1] , vl[num] }, printtext =true , color =ecolor);
display_set:={op(arcs),arc_text};
plots[ display] (display_set , view =[ -abs(scope)..abs(scope), -abs(scope)..abs(scope)] , scaling =constrained,axes=none);
geometry[ point] (v1 , 0 ,0):
geometry[ point] (a , 3, 9):
geometry[ point] (b , 7, 9):
geometry[ point] (c, 6,8):
geometry[ point] (d , 12,9):
geometry[ point] (e , 7 ,2):
geometry[ point] (v3 , 9 ,0):
vl:=[ v1,a,b,c,d,e,v3] :
drawarcs(vl,red,20);
try.mwtry.mw
The above program is too cumbersome and not robust
macro(GS=GetVertexPositions):
with(GraphTheory):
G     := PetersenGraph():
POS := GetVertexPositions(G):
EG   := Edges(G) minus {{6,10},{6,7}}:
s1:=PLOT(
   seq( CURVES([POS[EG[i][1]], POS[EG[i][2]]], LINESTYLE(3) ), i=1..numelems(Edges(G))-2),
   AXESSTYLE(NONE)
geometry[ point] (a,op(GS(G)[6])):
geometry[ point] (b , op(GS(G)[7])):
geometry[ point] (c , op(GS(G)[10])):
geometry[ point] (d ,op(GS(G)[8])[1]+0.3,op(GS(G)[8])[2]-0.5):
geometry[ point] (d2 ,op(GS(G)[9])[1]-0.3,op(GS(G)[9])[2]-0.5):
s2:=drawarc(a,d,b,red):
s3:=drawarc(c,d2,a,red):
plots:-display({s1,s2,s3});
So in multivariate calculus there is a function called Lagrange Multipliers that searches for maxima, minima and saddle points on a 3d surface with an algebraic as a constraint. I was wondering if there was a way to do something similar on a polygon constraint by feeding the corner points to a procedure and returning all extrema and saddle points? Ideas I've had so far is using the directional derivative on the corners in the direction towards the next corner and looking if it is bigger or equal than 0 if multiplied with the directional derivative towards the previous corner (if yes, extrema or saddle point, if no not) however this adresses only corners and there may be extrema on the lines between the corners too. What should I do for that?
First 90 91 92 93 94 95 96 Last Page 92 of 371
