In this example, i have a top module A. Inside it, I have module named my_RECORD (which happened to be option object) that I want to return back to caller when they call a proc.
Maple allows me to declare the proc to return my_RECORD. No problem., But when making a local variable inside the proc and using o::my_RECORD it complains  that my_RECORD does not exist.
The solution is to change o::my_RECORD to o::A:-my_RECORD
My question why it did not complain the same way on the return value on the proc?   for me, they are both semantically the same. One says the proc returns this type, and the other says the local variable is this type. So why had to do A:-my_RECORD on one but not the other?
Here is an example. Maple 2021.2 on windows 10.
interface(warnlevel=4);
kernelopts('assertlevel'=2):
A:=module()
 #this is the RECORD to return
  local module my_RECORD()
   option object;
   export data::string:="";
  end module;
  export do_analysis:=proc()::my_RECORD;
    local o::my_RECORD; #error here. But this is the same above line above?
    o:=Object(my_RECORD);
    o:-data:="test";
    return o;
end module;
_m2642451182336
A:-do_analysis()
Error, (in do_analysis) type `my_RECORD` does not exist
#FIXED BELOW
A:=module()
        option object;
    end module;
          local o::A:-my_RECORD;
          o:-data:="test";
          return o;
end module;
_m2642339719872
A:-do_analysis()
module my_RECORD () export data::string; option object; end module
Download A_no_lib.mw
hi,
I looked at the file mapleflowrc and saw that it lists several palettes that are not visible in the workshheet dock.
Does anyone know if these palettes are available in mapleflow? And if so, how to make them visible in the worksheet dock?
thanks very much in advance.
I often create diagrams in Maple and export them so I can embed them in a Word Doc.  Lately, when I right-click on the picture so I can select "export," the entire program closes.   It seems to happen more when the picture is in 3D.   Am I doing something wrong?     Thanks.
           David
Hi, I am trying to enter into the Mini-Course Computer Algebra for Physicists from the help, but instead of going to the page I get the help page of Physics[FeynmanIntegral]. Can anyone confirm that this happens to them on Maple 2021.2?
Kevin
Sorry to bother moderators again but a question from @panke has just disappeared.
I browsed its old questions but found none in a recent past related to the one removed.
Can you please tell me where it has been moved ?
TIA
PS: I understand perfectly the need to avoid multiple occurrences of a same thread, but in case of the displacement of a question, couldn't a systematic message be sent?
But ODEsteps supports simliar ODEs (see attached).
Is the ODESteps command not generic enough to cover the pendulum or have I missed something?
ODESteps.mw
I can't move files in the navigator window anymore in Maple 2021.2.
Anyone else with the same problems?
Other than saving few bytes of memory, why would one use ::static for methods of Object?
I found that if I use ::static, then I have to add prefix _self:- each time an object data member is referenced anywhere, making the code very hard to read.
Imagine having to write  _self:-x + 3* _self:-x^2 + 2* _self:-y^3 and so on all the time, instead of just x+3*x^2+2*y^3. (where it is assumed here that x,y happened to be object private data members and not local variables for a proc inside the module).
But then I found if I remove  ::static now _self:- no longer needed and can still get the benefit of using the object and the code works as before, but the code is now much more readable.
I know that by not using static, then a copy of each method is made for each new object.
I am OK with that. As I do not use that many objects any way (few at a time before GC cleans the ones I used).
But the benefit of much more readable code far outweights the little extra memory needed, and memory is cheap these days anyway. I got lots of RAM. An extra few MB's is not a big deal.
What Am I missing here? Why does all the Maple help and documenation say that one should use static for object methods then? But do not mention that by not using static:: then the code will become more readable since _self:- is not needed to be appeneded to each variable or method name.
Here is an example below to compare.
First example uses ::static methods, and the second does not.
One can see the difference The code is more clear in the second.   Is there something else I am overlooking by not using ::static . I am still learning OOP in Maple, and could be overlooking something else. I definitly do not want to code using _self:-variable_name all the time if I have to use OOP in Maple as it makes the code hard to read.
Notice that in both examples, and for the exported methods, I used _self as first argument. This is OK. This is meant to allow client of the object to call it using object:-method() syntax which is what I prefer instead of method(object,....). syntax.
I am talking about the execssive use of _self internal to the module/object code when having to use ::static. methods.
person_class_STATIC:=module()
   option object;
   local age:=5;
   export set_age::static:=proc(_self,age,$)
     _self:-age:=age:
   export update_age::static:=proc(_self,age,$)
      do_the_update(_self)
   local do_the_update::static:=proc(_self,$)
      _self:-age:=_self:-age+1;
      _self:-age:=sqrt(_self:-age^2+3);
   export get_age::static:=proc(_self,$)
     return _self:-age;
end module:
o:=Object(person_class_STATIC);
o:-set_age(100);
o:-get_age();
o:-update_age();
o2:=Object(person_class_STATIC);
o2:-get_age();
_m1982588380672
100
100
2*2551^(1/2)
_m1982698669216
person_class_NO_STATIC:=module()
   option object;
   local age:=5;
   export set_age:=proc(_self,_age,$)
     age:=_age:
   export update_age:=proc(_self,$)
      do_the_update()
   local do_the_update:=proc()
      age:=age+1;
      age:=sqrt(age^2+3);
   export get_age:=proc(_self,$)
     return age;
end module:
o:=Object(person_class_NO_STATIC);
o:-set_age(100);
o:-get_age();
o:-update_age();
o2:=Object(person_class_NO_STATIC);
o2:-get_age();
_m1982698652256
100
100
2*2551^(1/2)
_m1982698629312
Download OOP.mw
Hi, I'm trying to solve auxilary equation to find its familes but I don't know what I'm doing wrong as I'm using following code:
famtemp := (diff(z(xi), xi))^2-a*z(xi)^2-b*z(xi)^3-c*z(xi)^4;
fam1 := simplify(`assuming`([dsolve(famtemp)], [b::real, a::real, c::real, -4*a*c+b^2 > 0, a > 0]))
I want to get the following family:
fam1 := 2*a*sech(sqrt(a)*xi)/(sqrt(-4*a*c+b^2)-b*sech(sqrt(a)*xi));
I hope someone will help me to solve it.
HOW TO DECIDE THE TRIPLE INTEGRAL IS POSITIVE, NEGATIVE OR ZERO WITHOUT CALCULATING IT?
Hey guys,
How can I create a bar chart or a column chart, with specific x values under the bars.
Would be great If someone could help me.
Thank you;)
Is there some basis containing polynomials of the form x[1]^p*x[2]^q+x[2]^p*x[3]^q+x[3]^p*x[1]^q, (p,q posint)?
Are there known relationships between these?
Note: these are not the symmetric polynomials.
I want to arrange this equation in term of powers of x and then plot the  real and imagenery part of x vs y. How can I do this with Maple?
1-alpha*((1/x^2)+(1/(x-y)^2)+(1/(x+ay)^2))=0;
1.mw     (alpha and a are constant, for example alpha=1 and a=0.3)
Does anyone by any chance know why I might be getting this error?
I'm working with polynomials that have coefficients with many digits (16).
Thank you in advance,
First 80 81 82 83 84 85 86 Last Page 82 of 371
