Can someone confirm, that autosave is not implemented for workbooks?
The only thing I can restore form a workbook session are specific worksheets of the workbook that I was working on.
None of the Maple codes are saved for example.
This is a major issue, folks. If you haven't implemented it, you need to tell us about it in the help document.
IN CAPITAL LETTERS!
I following a example of products multiplication like this one
u:=n->Product(2*k-1,k=1..n)/Product(3*k-1,k=1..n)*x^n;
Calculating with  this with maple 1d input is correct, but when i convert a maple 1d input  to 2D input ( i did somewhere) and use this then there is difference with the maple 1d calculation
Seems to be not a advisable to use converted maple 1d to 2 D input for calculation : ( for a mixed calculation(maple input/2D input)  or solely 2d input) , but only for purpose of seeing what the expression in maple input is standing for.
Note: i did the calculation again with mixed input and now the correct sequenze of answers shows up ?
Just wanted to post that I had some data loss because I opened two different workbooks with the same name from different locations.
This could lead to loss of data.
I had code attachments from the "old" workbook implemented in the "new" workbook, while the new code was gone.
Thought always that the round d is reserved for function of two variables x,y , but  that seems to be not the case here ?
Comparing Different Answers
Een antwoord ergens gegeven is
Int(sqrt(x^2+1), x) = (1/2)*x*sqrt(x^2+1)+(1/2)*ln(x+sqrt(x^2+1)) + C                                                             (vb)
Mple geeft
Int(sqrt(x^2+1),x)=int(sqrt(x^2+1),x)+C[1];
Int((x^2+1)^(1/2), x) = (1/2)*x*(x^2+1)^(1/2)+(1/2)*arcsinh(x)+C[1]
De twee antwoorden lijken nog niet opelkaar !
In het gegeven antwoord staat er een ln en in Maple kan een expressie omgezet worden in ln termen
convert(%,ln);
Int((x^2+1)^(1/2), x) = (1/2)*x*(x^2+1)^(1/2)+(1/2)*ln(x+(x^2+1)^(1/2))+C[1]
(2)  is hetzelfde (vb)
Dezelfde integraal i sook gegeven als
Int(sqrt(x^2+1),x)=((x+sqrt(x^2+1))^2+4*ln(x+sqrt(x^2+1))-(x+sqrt(x^2+1))^(-2))/8+C[2];
Int((x^2+1)^(1/2), x) = (1/8)*(x+(x^2+1)^(1/2))^2+(1/2)*ln(x+(x^2+1)^(1/2))-(1/8)/(x+(x^2+1)^(1/2))^2+C[2]
Controle
een effectieve manier om twe antwoorden t evergelijken voor hetzelfde probleem is het verschil te berekenen van een vergelijking met de twee integralen
#lhs(%);
#rhs(%%);
#diff(lhs(%)-rhs(%)=0,x);
#diff(f,x);
(x^2+1)^(1/2)-(1/4)*(x+(x^2+1)^(1/2))*(1+x/(x^2+1)^(1/2))-(1/2)*(1+x/(x^2+1)^(1/2))/(x+(x^2+1)^(1/2))-(1/4)*(1+x/(x^2+1)^(1/2))/(x+(x^2+1)^(1/2))^3 = 0
simplify(%);
0 = 0
Strange that  diff(lhs(%)-rhs(%)=0,x);  is translated by 2 d input with round d notation for functions with two variables ?
The two integrals are functions of one variable
diff(f, x)
Download Controleren_dezelfde_antwoord_voo_expressies.mw
I have defined a function II1norm of one variable. The variable has units "microns". It plots perfecting using a range defined in microns, but gives an error when I try to find the root using NextZero. If I just leave off the "microns" in the second argument, NextRoot just reports "FAIL". If I rewite the worksheet without units, then the NextZero executes fine. Why? How to I use units when finding roots?
This is so useful to see geometrical mapping diagram to visualize Complex analysis
Something that also can be made for Maple
Mapping Diagram for Cauchy Integral Formula – GeoGebra
Using GeoGebra for visualizing complex variable. (google.com)
I highly encourage everyone interested in complex variable to read Tristan Needham „Visual Complex Analysis” and try to solve problems with or without aid of GeoGebra. I hope that in this workshop we will manage to get a feeling of complex functions and as a final point understand how complex integration works. It is a common misconception that complex integration can't be visualized, and using Tristan Needham's ideas we will try to explore this idea. It's a pity that we don't have a lot of time, thus we will skip a lot of important information and construct only some graphs.
There is so much experimenting with Geogebra software and doing too this in Maple ?
Hello there,
Would you allow me to ask one question?
Is there any way to get a saturated water vapor pressure value with a temperature outside of the range?
The range here means [273.06 K, 647.096 K]. The pressure value certainly exists (T<273.06 K), but the API only comes up with an error.
Here is the Maple worksheet where I got into this issue:
with(ThermophysicalData):
with(CoolProp):
with(Units[Standard]):
with(ScientificConstants):
T2 := (-40.0 + 273.15) * Unit('K');
233.15*Units:-Unit(K)
xbb := 1: # 100% steam, saturated.
Pg2 := PropsSI("P", "T", T2, "Q", xbb, "water");
Error, (in ThermophysicalData:-CoolProp:-PropsSI) Temperature to QT_flash [233.15 K] must be in range [273.06 K, 647.096 K] : PropsSI("P","T",233.15,"Q",1,"water")
Download Q20220111.mw
I must feed the not trivial zeros numbers into this aproximation formula ?
Riemann hypothese and staircase of primes
with(NumberTheory)
PrimeCounting(1)
pi(Pi)
PrimeCounting(10000)
1229
numelems(select(isprime, [seq(1 .. 10000)]))
1229
The prime counting function is approximated by Li(x) and x/ln(x).
plot([PrimeCounting(x), Li(x), x/ln(x)], x = 1 .. 500, legend = [pi(x), Li(x), x/ln(x)])
The staircase of primes approximated by two functions
Interesting is the video: How i learned to love and fear the Riemann Hypothesis
https://www.quantamagazine.org/how-i-learned-to-love-and-fear-the-riemann-hypothesis-20210104/
ps:=Array(1..30):
y:=0:
for n from 1 to 30 do
 if is(n,prime)
     then ps[n]:=plot([[n,y],[n,y+1],[n+1,y+1]]):
     y:=y+1;
     else ps[n]:=plot([[n,y],[n+1,y]]):
 end if ;
od;
display({seq(ps[n],n=1..30)}):
plot([PrimeCounting(x)] ,x = 1 .. 35, legend = [pi(x)]):
plot([PrimeCounting(x), Li(x), x/ln(x)], x = 1 .. 35, legend = [pi(x), Li(x), x/ln(x)])
Prime counting function
What found RIEMANN for the prime counting function in relation to the zeta function after he defined the zeta function?
He found further a function what follows exactly the shape of the prime counting function
Final discovery v. Riemann.
- step in the omhoog in de priemtelfunctie = log(p) (zie video)
Using the logarithmic primecount function( from Chebyshev) (approximation)
Further  analyse with this Chebyshev approximation formula in relation to the not trivial zero points from Riemann zeta function ( zeros) gives another real function for approximating the primecounting function what uses the non trivial zeros from Riemanns zeta function  in this function:
"(not trivial zeros ) u[k ] = "i*w[k]+v[k]
Number now all nottrivial zeros in the upperhalfplane from down to bottom,  as u[1], u[2], u[3, () .. ()]
"`&varphi;`(x)  := x-ln(2Pi)-1/(2 )ln(1-1/(x^(2))) - (&sum;)2/(|u[k]|) x^(v[k]) cos(w[k] ln(x)-alpha[k])"
Its only alpha[k] that must be calculated out of the not trivial zeros and i must have a list of  serie of not trivial zeroes from the zeta function. => see Hardy's Z(t) ? from this ..... alpha[k]  can be calculated ?
All not trivial zeros are complex numbers laying on a line ,but  orginating from (0,0) in the complex plane as  vectors to the points
varphi(x):= x - ln(2*Pi) - 1/2*ln(1 - 1/x^2) - sum(2*x^v[k]*cos(w[k]*ln(x) - alpha[k])/abs(u[k]), k = 1 .. infinity);
x-ln(2*Pi)-(1/2)*ln(1-1/x^2)-(sum(2*x^v[k]*cos(-w[k]*ln(x)+alpha[k])/abs(u[k]), k = 1 .. infinity))
This formula seems to be correct .
Now how to make a plot ?
Hardy's Z(t) function shows the not trivial zeros in the upperhalfplane of the critical strip of the Riemann zeta function  as zeros in this Z(t) real function : derived from a alternating serie ?
Download priem_staircase_en_riemann_functie.mw
Hello everyone . I wish you all a happy new year and a great 2022.
i have a project in Maplesim and i just began working with it .
my project is about the creation of an umbrella using maple sim . I tried my best to create one of the mechanic system of the revolute system . But in an umbrella there are 8 system of a revolute , and it depends of the orientation . I don't knew how to create the other 7 system
Can you please help me ?
Oussama
It's sad when a bug is found for such a simple problem!
sys := [x*y*z = 0, x*y*z + x*z + z = 0, x*y*z + x*y + x = 0]:
solve(sys, {x,y,z});    # OK
#         {x = 0, y = y, z = 0}, {x = x, y = -1, z = 0}
solve(sys, [x,y,z]);    # ???
Happy New Years All
Can anyone explain two document formating features I am trying to implement?
1.)  Sections.  I select numbering with follow previous selected and I get three sections with a 1. in front of them vs 1, 2, 3.
I would expect Technical to become 3.1 when properly following Section 3. header.   Also, I have seen how to manually type the section number, but that seems to defeat the document layout and formatting if it gets "jumbled up".
2.)  Headers.   Can you suppress headers on pages 2 through X to have a unique cover page header?   This would be similar to word (headers and footers linked to previous section, or not(?) with section breaks as new pages)
Bill
hello
i have a long proc i am defining in a loop inside the proc for some reason it calculates the value of a1[j+1] and a2[j+1] and assigns it(in the case of the picture j=1 and in j=2 it doesnt sub) but when it is called again in the next iteration  it doesnt sub the value it just calcluated !
i would be so thankful for any help ive been stuck on this for a while now
I installed the cloud version of Syrup with xmaple, by clicking the cloud icon, etc. It is loaded with xmaple and cmaple. But, not in maple running in emacs.
with(Syrup);
(**) Error, invalid input: with expects its 1st argument, pname, to be of type
{module, package}, but received Syrup
Tom Dean
It has been a decade or more since I have seen an option for lifetime enrollment for anything. Does maple calculator even have such an option available? If not, why not?
When the new Beta application center becomes active and the old one is obsoleted (sigh) many links to the applications centers from here (mapleprimes) will be broken.  Or will the links be directed to the proper location?
First 79 80 81 82 83 84 85 Last Page 81 of 371
