As you can see in the figure below,
it shows a very strange "font",
you can obviously see very weird spacing even inside one word...
Who knows what's wrong???
Thanks a lot.
B/R
Jankel
Good day,
I am looking for some guidance with the Syrup toolbox
I have a netlist that was generated with the Altium designer Spice simulator (XSpice based), I was able to import it into LTSpice and verrify the results.
I want to move it into maple to make use of the modellica code generation.
I then began modifying the netlist in order to meet the netlist syntax of Syrup. One of the most prominant change I needed to make was the arbitrary input nodes for my Voltage dependant Voltage sources.
Therefore, for any line that implies arbitrary sources such as:
E_U8_E1 U8_N208620 LO
+ VALUE { IF(V(U8_N208706, 0) > 0.5, 5, -5) }
was changed to:
V1    16   17 1vdc
E_U8_E1 U8_N208620 LO 16 17
This, of course, is a non ideal workaround which brings me to question 1,
Is there a way to define a arbitrary source with the Spice parser in Syrup?
Once these changes were made, it seems the Solve function in Syrup can parse the netlist without issue, however when it gets to the Solve portion it throws the following error:
Solve("file://C:/Users/msavoy/Documents/Spice_cct/inverter_newfet_nonot.cir", 'tran');
Solve: Analyzing SPICE deck "The Apple" (ignoring this line)
Error, (in Syrup:-Solve) invalid input: rcopy uses a 1st argument, A (of type anything), which is missing
Attached is a copy of the netlist, inverter_newfet_nonot.txtI am honestly at a lost as to what could be throwing the rcopy error
Furthermore, I wanted to test out the Modellica code generation in Syurp, it appears that it does not like having subcircuits, as running the test:
V 1 0 1
L1 1 2 L
C1 2 0 C
L2 2 3 L
C2 3 0 C
L3 3 4 L
C3 4 0 C
Vshort 4 5 0
Rt 5 0 1
.SUBCKT TEST A B C Y
V1 14 15 1
EINT YINT 0 14 15
+ VALUE {IF(V(A) > 0.5 && V(B) > 0.5 && V(C) > 0.5, 1, 0)}
RINT YINT Y 1
CINT Y 0 1n
.ENDS TEST
.end
provides the error of:
test_c := ToModelica("file://C:/Users/msavoy/Documents/Spice_cct/test_cct_RCL.txt", 'probes' = ["Rt.v"], 'parameters' = {C = 2, L = 1});
Error, (in Syrup:-ToModelica) invalid input: nodeToModelica expects its 1st argument, node, to be of type nonnegint, but received Y
Is it possible to define a sub circuit in a netlist that is to be converted to Modellica, or do all subcircuits need to be defined in their own file?
in the context of solving an ode, sometimes the constant of integration that will satisfy an initial condition is +infinity or -infinity.
But Maple's solve does not find such solutions to the constant of integration. It only can solve for finite value if it can.
When this happens, I manually try taking the limit as the constant of integration goes to +- infinity, until I get an equation where both sides are the same or fail, and then give up.
I was wondering if there is a way or different command/package which will find solution such as infinity (which is valid solution to constant of integration).
Here are two examples
ode:=diff(y(x),x)=1/(LambertW(-exp(-1+_C1+x))+1);
ic:=[diff(y(x),x)=1,x=0];
eq2:=eval(ode,ic);
solution_for_constant := solve(eq2,_C1,'allsolutions'=true,'tryhard'=true);
Maple can not solve for _C1. It gives
But when trying manually few values, I find that _C1=-infinity satisfies the equation
limit(rhs(eq2),_C1=0);
limit(rhs(eq2),_C1=1);
limit(rhs(eq2),_C1=-1);
limit(rhs(eq2),_C1=infinity);
limit(rhs(eq2),_C1=-infinity);
The above shows that _C1 = -infinity is the constant of integration. Another simpler example
eq:=exp(-1 + _C1) = 0;
solution_for_constant:=solve(eq,_C1) assuming real;
limit(lhs(eq),_C1=-infinity)
The above shows that _C1=-infinity is solution for exp(-1+C_1)=0.  which one can see by just looking at it as exp(-infinity)=0.  Adding assumptions did not help.I also tried symbolic option.
I am not familar with SolveTools package, may there is something there.
So for now, my code just try the limit until it finds solution or gives up.
Any suggestions if Maple itself can find such solutions?
Maple 2022.2
if isolate fail, then it returns back the input equation. But if solve failed to solve for the variable in question, it returns either NULL or empty list, or empty set (depending on the input). So it is easy to check if it failed or not.
How does one check that isolate failed? Should I check the left side of what isolate returns is the variable I am solving for? For an example,
sol:=isolate(-2*y-cos(y)+x+sin(x)-_C1 = 0,y)
returns back -2*y-cos(y)+x+sin(x)-_C1 = 0
Is the following the correct way to check if isolate solved the equation or not:
sol:=isolate(-2*y-cos(y)+x+sin(x)-_C1 = 0,y);
if lhs(sol)=y then
   print("it solved it. Soltion is ",sol);
   print("Failed to solve it. Try solve command now ");
fi;
Just wanted to make sure as help for isolate does not mention anything about what happens if isolate can't solve the equation.
Maple 2022.1
I am trying to solve a system of 4 ODEs that describe a physical system, however, I get the message:
Error, (in dsolve/numeric/bvp) matrix is singular
Any help is much appreciated. The initial conditions are such that to find solution in steady state, that means, v(0)=v(period) and so on with all variables.
Download LLCcircuit_SteadyState_numerical.mw
Good day.
I have been looking into the time series features in Maple and was eager to apply the models to one specific example containing 47 data points (attached).
When I run the ESM routine, Maple provides a forecast based on a (A,N,N) configuration. You will notice that the forecast for the following 12 data points is a constant value. I have also noticed this for several other data set examples and I would have expected the predictions to vary across the next 12 data points.
Does the (A,N,N) configuration in Maple automatically provide an optimal forecast and can anyone advise me on how to specify all possible combinations of (error, trend, season) models?
Thanks you for reading.
MaplePrimes_TS_Example.mw
solve((∂(-    ∇(f) ))/(∂ t)+((DotProduct(v[0],∇f))*(1-e(DotProduct(B,Omega)))+(c[s0]^(2)*rho[1])/(rho[0])(1-e(DotProduct(B,Omega)))+e(CrossProduct(∇ f,B))*Omega-e((DotProduct(-∇f,Omega))*(DotProduct(B,∇)))*(-∇f)+e(E)*(1-(DotProduct(B,Omega)))+e^(2)(DotProduct(E,B))*Omega-e*((CrossProduct(E,Omega))*(∇(-∇f)),rho[1]);
Since a couple of years ago,  SQLite has been enriched with a bunch of new math functions not existing in previous versions: acos, asin, atan, atn2, atan2, acosh, asinh, atanh, difference, degrees, radians, cos, sin, tan, cot, cosh, sinh, tanh, coth, exp, log, log10, power, sign, sqrt, square, ceil, floor, pi.
Examples: In SQLite version 3.39.4 2022-09-29 15:55:41 we can invoke:
sqlite> select pi();
3.14159265358979
sqlite> select power(2, 3);
8.0
sqlite> select floor(2.35);
2.0
Package Database[SQLite] in Maple 2022.2 does not recognize these functions.
In oldest versions of Sqlite3 we were able to add these functions after loading an external extension with sqlite3 api function load_extension() (see  https://sqlite.org/contrib/download/extension-functions.c), but his option is blocked in Maple:
dbName := "d:/sq3_maple/etc.db":
sq3Extension := "d:/sq3_maple/extensions.sq3":
with(Database[SQLite]);
[Attach, Bind, ClearBindings, Close, ColumnCount, ColumnNames,
  Execute, Fetch, FetchAll, FetchRow, Finalize, Open, Opened,
  Prepare, RESULT_BUSY, RESULT_DONE, RESULT_ROW, Reset, Step]
conn := Open(dbName):
Execute(conn, sprintf("SELECT load_extension('%s')", sq3Extension));
Error, (in Database:-SQLite:-Execute) not authorized
Am I missing something? Any way to add these functions to SQLite in current version of Maple?
César Lozada
PS: SQLite is updated in Mathematica 13.1
I construct by hand the two matrices L and U so that A= LU ( LU-factorization)
I would like to find the number of arithmetic operations required to obtain the matrices 𝐿 and 𝑈
Number_arithmetic_operation.mw
does the update of MapleSim 2022.2 have a bug when loading the own libraries?
After installing the MapleSim 2022.2 update, my libraries have disappeared. I am unable to load them again. The libraries are still in the same folder as before, but when I try to load them, I get the error message
However, the library NoiseX is not listed in the left bar. Even when I try to create a new library, it is not shown in the left bar. On the other hand, there are no problems with the imported libraries. Many thanks in advance for any advice.
Best wishes,
Clemens
Anybody find Import CAD closes MapleSim 2022.2 when just opening file chooser when attempting to import CAD file?
Bill
Hi.  I am using the linux version of Maple.  I seem to experience more bombs in Maple/Linux vs MathCad/Windows.  The program just froze as I was entering text.  Just text.  It is not a disaster since I make very frequent saves.  But it is very annoying.  I was a heavy user of MathCad from about 2005 to 2019.  In the early days, it bombed a lot.  But I do not recall that it ever bombed when I was entering text.  Any suggestions?  Would there be a limition on the number of text characters?  Is it Linux?  Other than this problem, it is a great program.
Hi! This is probably simple, but
I would like to know if there's an specific algorithm to do this:
let B = {x[i], i=1..n} in such a way that:
f( B ) = Sum(a[i]*b[i], i=1..N); a_i in R; b_i in B; N>n.
so Linearcomb: f->V(R).
Linearcomb( f ) =
 (Sum(a[j],j in J))*x[1]+(Sum(a[k],k in K))*x[2] + ... +(Sum(a[z],z in Z))*x[n].
with V(R) a vector space; R the Real numbers, and B the base. Neither the "factorize", nor the "simplify" are proving useful to this. Is there something i'm missng?
Does Maple Flow support the Maple Physics[Vectors] package? If so, how are vectors entered?
Let the square matrix A satisfy A^2023 = 0.
a. Prove: I-A is invertible.
b. If B is invertible, is B - A invertible?
This is not a Maple problem but it has something to do with math, specifically linear algebra, and I need help. Sorry if I bothered you. If possible please help me!
First 67 68 69 70 71 72 73 Last Page 69 of 371
