Trying to use the following question dialog
with(Maplets[Elements]);
maplet := Maplet(QuestionDialog("Is x > 0?"));
result := parse(Maplets[Display](maplet));
Displays question with Yes and No buttons but whichever button is clicked the result is always false.  This was based closely on an example from the documentation.
So, how can I tell which button was clicked.  Also, the close button could have been clicked - how should that be dealt with?
Hello guys.
Is there any way to convert a worksheet to a document and vice versa?
Oliveira.
xwhat is the fenchel conjugate transform of f(x)=x*x2*x3 over xi in R?  the general question is what is the fenchel transform of a polynomial that is not a quadratic?
I am having problems printing Maple Flow documents. I have set up both a header and a footer. In the Print Preview mode, everything is fine. When I try to print to a PDF file, the header loses its format and the footer does not print at all. Printing to a printer looks the same. What settings must be selected so that the printout can be passed on as a well-formatted document?
Many thanks in advance.
I have been using Maple Calculator on my phone and found that the "Steps" to solutions option was useful, particularly for integration. However, I spend more time on my computer than phone and thought that Maple Learn would be even better. When I tried the free version of Maple Learn the "Steps" button never appeared. I thought this might be because it is only available with a subscription, so I have subscribed for one month to evaluate. However, after doing that the "Steps" button still did not appear. After a bit of digging, I found the Steps documentation and found you must open specific documents from the Maple Gallery for different problems to get the Steps button which seems a bit odd when the Maple Calculator does this automatically. Worse still there does not seem to be an option for integration!
Although I can see a lot of benefits with Maple Learn this seems to be a backward step (pardon the pun). Also, even though I have subscribed to Maple Learn, I still do not appear to have Premium on my phone in the same account. Again, a little disappointing.
Have I misunderstood something or is this the way it is?
Will
please, help me..this is my model
I have a fairly simple worksheet with a 56x2 matrix M1 which I am trying to export to Excel with the following
ExcelTools:-Export( M1, "C:/Temp/M1.xlsx", 1, "B2")
This causes the following message to appear
After that the program is frozen and totally unresponsive.  The only way to proceed is end the task in Task Manager..
I am trying to upload the worksheet but am not sure if I have succeeded
Download Calculation_of_pH_from_known_values_of_Vb.mwCalculation_of_pH_from_known_values_of_Vb.mw
I created a Github repository with files to reproduce the example that my question is based on.
I am using Grid:-Run to compute a 10000x3 matrix in each of 100 parallel runs. I then average the 100 matrices to obtain a final 10000x3 matrix, which I saved to an .m file.
It contains a variable called with the matrix.
Each row of the matrix is a 3d point, and the entire matrix represents a trajectory on a sphere. I'd like to display an animation of this trajectory. Now, my question is not about how to do this, but rather about the memory requirements necessary to do so.
I can plot trajectories with, say, 1000 points, but apparently 10000 requires too much memory.
The Github repository I linked to contains an example of all of this.
The worksheet matrixTest.mw reads the matrix from the .m file and reads some procedures defined in the .mpl file that are used for creating the animation data.
Then, a call to the procedure animateMatrices basically calls plots:-display to display the matrix as an animation.
I've been able to display the first 5000 rows of the matrix.
What type of memory is running out when I try to display the animation of the full 10000 rows?
Here is a screenshot of my Activity Monitor right before I get the
Error, out of memory error while processing result
Hi! I need to simplify a polynomial over an arbitrary field F on a radical variable ν, such that for some power j, ν is in F.
the polynomial takes the form:
k0+a1ν1/j+...+anνn/j
but, since νj is in F, this divides every element νi/j into a cotient group of order j, so this can be rewritten as a radical extension of F, in the form:
k1+(a1+...)ν1/j+...+(ak+...)ν(j-1)/j
where ki, ai are in F. I feel like this is a very straightforward technique for handwritten algebra, but i can't see a command for this on Maple 18. Nor the simplify(..., radicals) Or the combine(...,radicals) seems to help here. Maybe there's an special command for this? Must i do it myself? Please, any help is aprecciated.
This question is based on the following worksheet I created specifically to show my question: Animation_Test.mw
Unfortunately, MaplePrimes gives me an error when I try to insert the contents here directly.
Basically my question is about the syntax of plots:-display.
I have a sphere
sphereDisplay := plottools:-sphere([0, 0, 0], 1, transparency = 0.9);
and something which is the result of calling plots:display on a sequence of two other other plots:-display.
arrowAndTrailDisplay := plots:-display(seq(plots:-display(computeArrowPlotFrame(m, t, red), computeTrailPlotFrame(m, t, windowSize, red)), t = times), insequence = true)
You can see in the attached worksheet what computeArrowPlotFrame and computeTrailPlotFrame are, but they are basically lists of plot structures. arrowAndTrailDisplay is thus an animation containing two different sequences of frames.
I wish to have Maple plot the sphere and the animation together. This works as expected (a static sphere and the animation of an arrow and a trail of the path of the tip of the arrow)
plots:-display([sphereDisplay, arrowAndTrailDisplay]):
but the following does not work as expected (instead it plots each frame separately)
plots:-display([arrowAndTrailDisplay])
adding insequence=true to the latter makes it work. But my question is why do I have to add that? I can't understand, from syntax standpoint why the former plots arrowAndTrailDisplay as an animation but the latter does not.
I am trying to solve a system of six equations through a matrix and a vector. The matrix is 6x6, so the function "LinearSolve" should find a solution
The matrix is
Matrix(6, 6, [[1., -1., 1., -1., 1., -1.], [1., 1., 1., 1., 1., 1.], [-2., 1.618033989, 30.94427190, -153.8246851, 371.1559479, -572.9674774], [-2., 0.6180339876, 22.94427191, -41.15905356, -37.04759741, 149.3606798], [-2., -0.6180339876, 13.05572810, 22.82468509, -20.15594802, -81.03252254], [-2., -1.618033989, 5.055728096, 28.15905368, 68.04759752, 104.6393203]])
and the vector associated with the system is
Vector[column](6, [-1/3, -1, 0, 0, 0, 0])
I am trying to solve this system with
a := LinearSolve(M3, v);
but it stays evaluating.
I have solved a similar system (5x5) with this function (LinearSolve) and it took less than a second, so I dont understand why it takes so long in this case.
Thank you in advance.
Consider the following code in an .mpl file
$define MACRO1 "1"
$define MACRO2 "2"
$ifdef __FILE__
$define MACRO3 "3"
$endif
$ifdef MACRO1
$define MACRO4 "4"
$endif
f := proc()
print(MACRO1, MACRO2, MACRO3, MACRO4, __FILE__):
end:
If we run this from a worksheet and call the procedure f, the printed output is
"1", "2", MACRO3, "4", "/Users/zenterix/..."
Why does $ifdef __FILE__ evaluate to false? Ie, why doesn't MACRO3 get defined? I thought __FILE__ was a predefined macro.
I have been unable to re-size and imported image into a Maple Flow 2022.2 document. I just used my old Maple Flow 2021 and I had no problem. When I use Maple Flow 2022.2 I cannot re-size an imported image. I was able to re-size an imported image in Maple Flow 2022.1. Is it just me or has anybody else experienced the same problem? I also imported the image into Maple 2022.2 and had no problem re-sizing the image.
I formatted all the input math expressions with a different style and then exported them to create a style set called Mystyle1. However, when I load Mystyle1 and apply it to a document, the functions that were typed partially obey the style, but the expressions that were inserted through the palette do not; font and size are different and bold is not applied.
Does anyone know why this happens?
If anyone wants to test it, Mystyle1 and a simple document are attached.
Oliveira
Example.mw
Mystyle1.mw
@ASHAN's question was about a linestyle which wasn't displayed as expected.
Maybe a handling error on my part?
To ASHAN:
First 65 66 67 68 69 70 71 Last Page 67 of 371
