 Can you tell me how I can create the variation tab of a function with Maple 2022?
Thanking you,
,DAVID CRESPIL
When exporting a maple file containing
pH = 1/2*(pKa - log[10](c)),
I could see that the minus was transformed into a K
Any idea for solving this problem ?
Cheers for Maple anyway
There are two issues I am having with images in Maple Flow 2022.
1. When I need to move an image up or down in the document it instantly flies to the top or off in to the vast corner of the document with the tiniest motion of the mouse. It's utterly ridiculous. Is there a setting to change this behaviour in Maple Flow? I have changed settings on my desktop with no change, so I believe it is Maple Flow's behavior.
2. When I do put an image somewhere and save the document and open it some time later, the images are moved in position on top of text. No amount of moving them and saving them ever changes this and I can't export a document that I need to submit for calculations on a report because of this.
Any help would be appreciated.
OdeSys := diff(U(Y), Y, Y)+Theta(Y)+N*(Theta(Y)*Theta(Y))-(M*M)*U(Y) = 0, diff(Theta(Y), Y, Y)+E*(diff(U(Y), Y))^2 = 0;
Cond := U(0) = lambda*(D(U))(0), Theta(0) = A+g*(D(Theta))(0), U(1) = 0, Theta(1) = B; sys := [OdeSys, Cond];
Ans := dsolve(sys);
in my program, I keep assumptions in a set. Sometimes this is empty if no assumptions are used. This never caused a problem before (at least I do not think so, else I would have seen it) when using empty {} in assuming, except for now.
Here is one example below. Is this a known problem? I noticed when changing {} to [] the error goes away. I am not sure why, and if this is known issue. But will change from a set to a list to avoid this.
Maple 2022.2 on windows 10
`Standard Worksheet Interface, Maple 2022.2, Windows 10, October 23 2022 Build ID 1657361`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1392 and is the same as the version installed in this computer, created 2023, February 13, 12:58 hours Pacific Time.`
ode:=diff(diff(y(x),x),x)+diff(y(x),x)^2+diff(y(x),x) = 0;
ic:=y(0) = 0;
sol:=y(x) = -ln(exp(x))+ln(-1+_C1*exp(x))-ln(-1+_C1);
diff(diff(y(x), x), x)+(diff(y(x), x))^2+diff(y(x), x) = 0
y(0) = 0
odetest(sol,[ode,ic]) assuming {};
Error, (in convert/multiset) too many levels of recursion
odetest(sol,[ode,ic]) assuming [];
[0, 0]
odetest(sol,[ode, ic]);
[0, 0]
Download feb_14_2023.mw
My question is can the last step be equal to 1/6.
I want to output to 1/6. it outputs to sqrt(9)/18 - (See Below).
NULL"5)Square root: undefined - DNE (Limit does not exist):"
limit((sqrt(x+1)-3)/(x-8), x = 8)"(=)"1/6
limit((sqrt(x+1)-3)/(x-8), x = 8)Limit(((x+1)^(1/2)-3)/(x-8), x = 8) = (1/18)*9^(1/2)"(=)"Limit(((x+1)^(1/2)-3)/(x-8), x = 8) = 1/6
Download limit-sqrt-5.mw
My Maple Program run perfectly  with Window 10.  My new Laptop has Window 11 and I get system  crash wenn I applied
plot3d(...) .
So I think It is somethink with the Grapics Redering ?
Can somebody help ?
Betriebsystemname    Microsoft Windows 11 Home
Version    10.0.22621 Build 22621
Weitere Betriebsystembeschreibung     Nicht verfügbar
Betriebsystemhersteller    Microsoft Corporation
Systemname    ELIPAN
Systemhersteller    SAMSUNG ELECTRONICS CO., LTD.
Systemmodell    750XED
Systemtyp    x64-basierter PC
System-SKU    SCAI-A5A5-A5A5-ADLP-PCFG
Prozessor    12th Gen Intel(R) Core(TM) i5-1235U, 1300 MHz, 10 Kern(e), 12 logische(r) Prozessor(en)
BIOS-Version/-Datum    American Megatrends International, LLC. P08CFG.033.220913.HQ, 13.09.2022
SMBIOS-Version    3.4
Version des eingebetteten Controllers    255.255
BIOS-Modus    UEFI
BaseBoard-Hersteller    SAMSUNG ELECTRONICS CO., LTD.
BaseBoard-Produkt    NP750XED-KC5DE
BaseBoard-Version    SAMSUNG_SW_REVISION_12345+10.0.22000
Plattformrolle    Mobil
Sicherer Startzustand    Ein
PCR7-Konfiguration    Erweiterung zum Anzeigen erforderlich
Windows-Verzeichnis    C:\WINDOWS
Systemverzeichnis    C:\WINDOWS\system32
Startgerät    \Device\HarddiskVolume1
Gebietsschema    Deutschland
Hardwareabstraktionsebene    Version = "10.0.22621.819"
Benutzername    ELIPAN\Pan
Zeitzone    Mitteleuropäische Zeit
Installierter physischer Speicher (RAM)    16,0 GB
Gesamter physischer Speicher    15,7 GB
Verfügbarer physischer Speicher    8,28 GB
Gesamter virtueller Speicher    16,7 GB
Verfügbarer virtueller Speicher    6,98 GB
Größe der Auslagerungsdatei    1,00 GB
Auslagerungsdatei    C:\pagefile.sys
Kernel-DMA-Schutz    Ein
Virtualisierungsbasierte Sicherheit    Wird ausgeführt...
Virtualisierungsbasierte Sicherheit – erforderliche Sicherheitseigenschaften
Virtualisierungsbasierte Sicherheit – verfügbare Sicherheitseigenschaften    Allgemeine Virtualisierungsunterstützung, Sicherer Start, DMA-Schutz, UEFI-Code Readonly, SMM Security Mitigations 1.0, Modusbasierte Ausführungssteuerung, APIC-Virtualisierung
Virtualisierungsbasierte Sicherheit – konfigurierte Dienste    Durch Hypervisor erzwungene Codeintegrität
Virtualisierungsbasierte Sicherheit – ausgeführte Dienste    Durch Hypervisor erzwungene Codeintegrität
Windows Defender-Anwendungssteuerungsrichtlinie    Erzwungen
Windows Defender-Anwendungssteuerungs-Richtlinie für den Benutzermodus    Aus
Unterstützung der Geräteverschlüsselung    Erweiterung zum Anzeigen erforderlich
Es wurde ein Hypervisor erkannt. Features, die für Hyper-V erforderlich sind, werden nicht angezeigt.
IndependencePolynomial returns the independence polynomial for the graph G in the variable x.
For the following example, its calculation took over 20 minutes and still hasn't produced a result, and what's fatal is that it  has consumed 4G  memory.
with(GraphTheory):
G:=ConvertGraph("W|tNHEpCKoh`@@Po_WHB@CKC?WGO{G?KKCB`?OMG?_y_?Sn");
G1:=LineGraph(G);
IndependencePolynomial(G1, x) # be careful
I use  codes in  the link https://github.com/pernici/hobj.
It produced results quickly (It takes approximately 5 seconds.). So I think the built-in function " IndependencePolynomial " should be able to be improved. (Of course we are usually very concerned about their coefficients)
Their coefficients of the independent polynomial of G1 are as follows.
[340649, 12329124, 68797662, 140606548, 139481127, 77027880, 25546428, 5303544, 700911, 58580, 2982, 84, 1]
It tells me the total number of independence sets with size 12 is 340649.
I want to solve system of PDE equations by maple and i dont know how can i write it codes that can solve them for me. Can you create the code for the equation
Good day,
1. Please I need your greatest help. Can anyone please help me to run the examples on the attached papers on Maple software?
 2. Also help me to plot the graphs along with the exact solution
 3. If possible with tables
 I tried but did not get the results as expected. I shall be very grateful if I can get assistance from you
I have a workflow in which I edit files from a package I develop. These are usually mpl files, and I edit them in an editor (VS Code).
Then I have a worksheet called readFile.mw open in Maple that has two commands:
read("path/to/an/entry/file/that/includes/all/the/other/files")
and another worksheet actual.mw which is the actual worksheet I am working on, which starts with restart: with(MyPackage): and then contains calls to procedures from the package.
With this workflow, I make a change in the editor, execute readFile.mw and then go to my actual worksheet and restart and then use with(MyPackage), and the updates are available.
This works.
However, in actual.mw I may have a bunch of data that I don't want to wipe out with a restart.
On the other hand, if I don't restart, a new call to with(MyPackage) does not update the import of the package (because it has already been imported.
Is there an idiomatic or preferred way to accomplish reimporting the package without having to call restart?
PS I don't remember now the exact reason why I don't have the call to read the file in actual.mw but it had something to do with this issue of not getting the package updated correctly.
I think my question can be answered without necessrily providing any code.
I have a procedure that takes in many arguments and performs heavy calculations (solves multiple sets of differential equations in parallel using Grid:-Map and then does matrix manipulations with results, etc).
It runs fine in a Maple worksheet.
Until about half an hour ago, I hadn't used the Maple CLI. I would like to run my procedure from the CLI. I did exactly the steps as I do them in a worksheet.
with(MyPackage):
myProcedure(argsList);
But Maple just echoes the second command back to me. myProcedure is in myPackage. There is a much simpler procedure in that package called myProcedure2 and I can call that just fine from the CLI.
What could be happening?
queryequal(expr1, expr2)
queryequal(Int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0) = 2^(1/2)*EllipticK((1/2)*(2+2*x__0)^(1/2))-2^(1/2)*EllipticF(1/(1+x__0)^(1/2), (1/2)*(2+2*x__0)^(1/2)), 2^(1/2)*EllipticF((1-1/(1+x__0))^(1/2)*2^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2)))
(This question has its origin here).
Plotting the difference of rhs - lhs seems to indicate equality over the range [0..1)
difference := rhs(op(queryequal(Int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0) = 2^(1/2)*EllipticK((1/2)*(2+2*x__0)^(1/2))-2^(1/2)*EllipticF(1/(1+x__0)^(1/2), (1/2)*(2+2*x__0)^(1/2)), 2^(1/2)*EllipticF((1-1/(1+x__0))^(1/2)*2^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2))))[1])-op(queryequal(Int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0) = 2^(1/2)*EllipticK((1/2)*(2+2*x__0)^(1/2))-2^(1/2)*EllipticF(1/(1+x__0)^(1/2), (1/2)*(2+2*x__0)^(1/2)), 2^(1/2)*EllipticF((1-1/(1+x__0))^(1/2)*2^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2))))[2]; plot(difference, x__0 = 0 .. 1, title = 'difference', color = RED)
Try simplify
`assuming`([simplify(difference)], [0 < x__0 and x__0 < 1])
(EllipticK((1/2)*(2+2*x__0)^(1/2))-EllipticF(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2))-EllipticF(1/(1+x__0)^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2)))*2^(1/2)
Try combine
`assuming`([combine(difference)], [0 < x__0 and x__0 < 1])
-2^(1/2)*EllipticF((x__0/(1+x__0))^(1/2)*2^(1/2), (1/2)*(2+2*x__0)^(1/2))-2^(1/2)*EllipticF(1/(1+x__0)^(1/2), (1/2)*(2+2*x__0)^(1/2))+2^(1/2)*EllipticK((1/2)*(2+2*x__0)^(1/2))
Try conversion to integral form
convert(difference, Int)
2^(1/2)*(Int(2/((-_alpha1^2+1)^(1/2)*(-2*_alpha1^2*x__0-2*_alpha1^2+4)^(1/2)), _alpha1 = 0 .. 1))-2^(1/2)*(Int(2/((-_alpha1^2+1)^(1/2)*(-2*_alpha1^2*x__0-2*_alpha1^2+4)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2)))-2^(1/2)*(Int(2/((-_alpha1^2+1)^(1/2)*(-2*_alpha1^2*x__0-2*_alpha1^2+4)^(1/2)), _alpha1 = 0 .. (1-1/(1+x__0))^(1/2)*2^(1/2)))
`assuming`([simplify(%)], [0 < x__0 and x__0 < 1])
-2*2^(1/2)*(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2))-(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2) .. 1)))
plot(-2*2^(1/2)*(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2))-(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2) .. 1))), x__0 = .999 .. 1, color = RED)
evalf(eval(-2*2^(1/2)*(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2))-(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2) .. 1))), x__0 = 1), 40); evalf(eval(-2*2^(1/2)*(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2))-(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2) .. 1))), x__0 = .9999999999), 40)
-0.8716953127866940896552122384831392143938e-30
There seems to be a finite difference at x__0 = 1
Try an addition theorem from DLMF
Since all elliptic expression have the same modulus k, the following addition theorem could be applied under the condition that the corresponding case is fulfilled https://dlmf.nist.gov/19.11#E7
Check if the following case applies (i.e. is ψ=π/2?)
theta = 1/sqrt(1+x__0), `&varphi;` = sqrt(1-1/(1+x__0))*sqrt(2)
theta = 1/(x__0+1)^(1/2), varphi = (1-1/(x__0+1))^(1/2)*2^(1/2)
k = (1/2)*sqrt(1+x__0)*sqrt(2)
k = (1/2)*(x__0+1)^(1/2)*2^(1/2)
tan((1/2)*psi) = (sin(theta)*Delta(`&varphi;`)+sin(`&varphi;`)*Delta(theta))/(cos(theta)+cos(`&varphi;`))
tan((1/2)*psi) = (sin(theta)*Delta(varphi)+sin(varphi)*Delta(theta))/(cos(theta)+cos(varphi))
Delta(theta) = sqrt(1-k^2*sin(theta)^2)
Delta(theta) = (1-k^2*sin(theta)^2)^(1/2)
subs(theta = `&varphi;`, Delta(theta) = (1-k^2*sin(theta)^2)^(1/2))
Delta(varphi) = (1-k^2*sin(varphi)^2)^(1/2)
subs(Delta(theta) = (1-k^2*sin(theta)^2)^(1/2), Delta(varphi) = (1-k^2*sin(varphi)^2)^(1/2), k = (1/2)*(1+x__0)^(1/2)*2^(1/2), theta = 1/(1+x__0)^(1/2), varphi = (1-1/(1+x__0))^(1/2)*2^(1/2), tan((1/2)*psi) = (sin(theta)*Delta(varphi)+sin(varphi)*Delta(theta))/(cos(theta)+cos(varphi)))
tan((1/2)*psi) = (sin(1/(x__0+1)^(1/2))*(1-(1/2)*(x__0+1)*sin((1-1/(x__0+1))^(1/2)*2^(1/2))^2)^(1/2)+sin((1-1/(x__0+1))^(1/2)*2^(1/2))*(1-(1/2)*(x__0+1)*sin(1/(x__0+1)^(1/2))^2)^(1/2))/(cos(1/(x__0+1)^(1/2))+cos((1-1/(x__0+1))^(1/2)*2^(1/2)))
`assuming`([simplify(subs(psi = (1/2)*Pi, tan((1/2)*psi) = (sin(1/(1+x__0)^(1/2))*(1-(1/2)*(1+x__0)*sin((1-1/(1+x__0))^(1/2)*2^(1/2))^2)^(1/2)+sin((1-1/(1+x__0))^(1/2)*2^(1/2))*(1-(1/2)*(1+x__0)*sin(1/(1+x__0)^(1/2))^2)^(1/2))/(cos(1/(1+x__0)^(1/2))+cos((1-1/(1+x__0))^(1/2)*2^(1/2)))))], [0 < x__0 and x__0 < 1])
1 = (sin(1/(x__0+1)^(1/2))*((2+2*x__0)*cos(x__0^(1/2)*2^(1/2)/(x__0+1)^(1/2))^2+2-2*x__0)^(1/2)+sin(x__0^(1/2)*2^(1/2)/(x__0+1)^(1/2))*((2+2*x__0)*cos(1/(x__0+1)^(1/2))^2+2-2*x__0)^(1/2))/(2*cos(1/(x__0+1)^(1/2))+2*cos(x__0^(1/2)*2^(1/2)/(x__0+1)^(1/2)))
plot([lhs(1 = (sin(1/(1+x__0)^(1/2))*((2+2*x__0)*cos(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))^2+2-2*x__0)^(1/2)+sin(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))*((2+2*x__0)*cos(1/(1+x__0)^(1/2))^2+2-2*x__0)^(1/2))/(2*cos(1/(1+x__0)^(1/2))+2*cos(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2)))), rhs(1 = (sin(1/(1+x__0)^(1/2))*((2+2*x__0)*cos(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))^2+2-2*x__0)^(1/2)+sin(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))*((2+2*x__0)*cos(1/(1+x__0)^(1/2))^2+2-2*x__0)^(1/2))/(2*cos(1/(1+x__0)^(1/2))+2*cos(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))))], x__0 = 0 .. 1, legend = [lhs, rhs])
lhs and rhs are not equal -> Case psi = (1/2)*Pi does not apply (provided that the formulas have been applied correctly).
Perhaps this is why Maple does not simply the difference to zero.  NULL
Anything else that could be tried in Maple (maybe with other formulas)?
Download Equality_of_Elliptic_expressions.mw
I have been bothered lately by the number format for axis labels in Maple. My problem existed before, but it apparently didn't bother me before. I have spent many hours trying to find an answer in the program help, in MaplePrimes, and in general online searches. I am not having any luck at all (good luck, that is).
I want to change the format of the axis numbering. Maple seems to default to 2 decimal places in my graph, and I really need more. Oddly, when I export the graph to PDF, I get another decimal place (even though I didn't explicitly ask for one).
How do I change the axis-label format? Any idea what I might get when I export the graph?
Thanks for your help,
Jno.
Hi MaplePrimes,
I am interested in obtaining some gravitational field equations from an action using the FunDiff command. I have been able to write what I think is a pretty short and quick worksheet(with an arbitrary metric) and I am easily able to obtain the Einstein Field Equations. However, when I introduce some new more complicated terms into the action and apply the Simplify command maple does not appear to be able to evaluate and I end up halting the computation. When I specify a metric Maple, for example Schwarzschild, Maple will easily be able to Simplify my expression but it will use metric components during the process. Where what I am interested in is just the Tensor expression with respective indices.
I was wondering if anyone had any thoughts on how I could resolve this.
I have attached the worksheet that I am working with. I look forward to your thoughts/comments.
ActionFieldEquations.mw
First 61 62 63 64 65 66 67 Last Page 63 of 371
