Help, have no idea what to do.
Obtain a finite topological space from a dynamical system specified as a system of ODEs, by writing Maple code for following steps (use Maple packages DynamicSytems and GraphTheory, preferablly):
  1. Visualize the phase space of the system by plotting solution curves for different initial conditions.
  2. Consider a finite region of the phase space.
  3. Define a finite grid of points in the region.
  4. Define a topology on the grid points based on their connectivity.
  5. Give some useful information regarding the dynamical system in terms of topological properties.
Article https://mapleprimes.com/posts/208409-Downloading-Historical-Stock-Quotes has worked well for the last few years.
Somewhere in the last 6 months Yahoo has changed the method. Crumbstore no longer exists within the page source.
Does anyone have a method that currently works.
Problem is also verified at: https://www.solveforum.com/forums/threads/solved-yahoo-finance-cookie-and-crumb-not-working.2316600/ ,however they do not have a solution.
consider two lists of complex values :
list1 := [l1,l2,l3,l4,l5]
list2 := [s1,s2,s3,s4,s5].
There is a set of second order differential equation
d^2u(k)/dt^2+I*A*du/dt-B*u=0
where A is sum of elements of list1 and list2 and B is multiplication of their element. Therefore,
d^2u[1](k)/dt^2+I*(l1+s1)*du[1]/dt-(l1*s1)*u[1]=0
d^2u[2](k)/dt^2+I*(l2+s2)*du[2]/dt-(l2*s2)*u[2]=0
d^2u[3](k)/dt^2+I*(l3+s3)*du[3]/dt-(l3*s3)*u[3]=0
d^2u[4](k)/dt^2+I*(l4+s4)*du[4]/dt-(l4*s4)*u[4]=0
d^2u[5](k)/dt^2+I*(l5+s5)*du[5]/dt-(l5*s5)*u[5]=0
How can I create a set of differential equations and initial conditions based on nops(list1), then solve this system of differential equations numerically in Maple.
since u[i] are function of k, next step is to transforme them to real space by inverse fourier transform.
finally save the results and plot them.
Note that for simplisity I wrote a linear equation but it is not. so, because of nonlinear terms it is not possible to use superposition of the solution. I have to take them as coupled system of equations.
for example
list1 := [ [0., -5.496799068*10^(-15)-0.*I], [.1, 5.201897725*10^(-16)-1.188994754*I], [.2, 6.924043163*10^(-17)-4.747763855*I], [.3, 2.297497722*10^(-17)-10.66272177*I], [.4, 1.159126178*10^(-17)-18.96299588*I] ]
list2 :=[ [0., -8.634351786*10^(-7)-67.81404036*I], [.1, -0.7387644021e-5-67.76491234*I], [.2, -0.1433025271e-4-67.59922295*I], [.3, -0.2231598645e-4-67.25152449*I], [.4, -0.3280855430e-4-66.56357035*I] ]
where first element is k and the second value is l_i and s_i
the differential equation is
ode_u[i]:= diff(u[i](t),t$2)+I*(list1[i][2]+list2[i][2])*diff(u[i](t),t)-list1[1][2]*list2[2][2]*u[i](t)=0;
eta is in fourier space where k values are in list1[i][1].
We laso know that f(-k)= - f*(k) where f=list[i][2]
and u[i] as function of k, initially has a Gaussian shape at t=0 in fourier space..
Thanks in advance for your help
Anyone out there converted the  nyqlog at MATLAB/nyqlog.m at master · nielsSkov/MATLAB · GitHub  to Maple or Maple Flow? For Nyquist plots...
Bonjour, petite question simple que je me pose la MapleSim permet de tout réaliser ?
I want to import a numeric 2800*1 matrix from matlab to maple by following command, but faced error as bellow:
X := ImportMatrix("E:/.../Omega.mat", source = MATLAB);
 ImportMatrix:-ModuleApply called with arguments: E:/.../Omega.mat, datatype = auto, delimiter = (), format = (), mode = (), output = all, ragged = true, skiplines = 0, source = MATLAB, sourceid = all, transpose = false
 #(ImportMatrix:-ModuleApply,36): error
Error, (in ImportMatrix) Array index out of range
 locals defined as: file = E:/.../Omega.mat, src = Matlab, ext = ext, res = res, x = x, isv7 = isv7, del = false
Where is the problem?
How to import?
Hello guys
I'm having trouble solving a PDE using pdsolve-numerical. Here's a notebook attached.
I'm grateful if anyone can help.
Oliveira
                   PDE1.mw
I would appreciate any help to solve the following Partial Differential Equation, which is a mix of partial and regular derivatives as coefficients.
How to solve it with/without initial conditions?
Let us begin with few simulations:
CodeTools:-Usage(plots['pointplot3d'](Matrix((proc (_) options operator, arrow; [_[() .. (), 1]-_[() .. (), 3], _[() .. (), 2]-_[() .. (), 4], _[() .. (), 5]] end proc)(convert(ssystem("wolframscript -code \"RandomPoint[Simplex[IdentityMatrix[5]], 2*^4]\"")[-1], FromMma)), scan = [rectangular, columns], datatype = float[4]), scaling = constrained))
memory used=0.57TiB, alloc change=91.51MiB, cpu time=18.77m, real time=15.86m, gc time=4.91m
CodeTools:-Usage(plots['pointplot3d'](Matrix((proc (_) options operator, arrow; [_[() .. (), 1]-_[() .. (), 3], _[() .. (), 2]-_[() .. (), 4], _[() .. (), 5]] end proc)(convert(ssystem("wolframscript -code \"RandomPoint[Sphere[5], 2*^4, ConstantArray[List[0, 1], 5]]\"")[-1], FromMma)), scan = columns, datatype = float[4]), scaling = constrained))
memory used=0.56TiB, alloc change=-12.08MiB, cpu time=18.70m, real time=15.11m, gc time=5.69m
Download iDistributionVector.mws
Well, I'd like to prove (through the use of Maple):
transform((x1, x2, x3, x4, x5) -> [x1 - x3, x2 - x4, x5])(inequal(And((x || (1 .. 5)) >=~ 0, norm([x || (1 .. 5)], 1) = 1))) # not Maple syntax
is equivalent to a filled pyramid
ImplicitRegion((X, Y, Z), 0 <= Z <= 1 - abs(X) - abs(Y)) # not SymPy syntax
transform((x1, x2, x3, x4, x5) -> [x1 - x3, x2 - x4, x5])(inequal(And((x || (1 .. 5)) >=~ 0, norm([x || (1 .. 5)], 2) = 1))) # not Maple syntax
is equivalent to a hemi-ball
ImplicitRegion((X, Y, Z), 0 <= Z <= sqrt(1 - X**2 - Y**2)) # not SymPy syntax
, and
transform((x1, x2, x3, x4, x5) -> [x1 - x3, x2 - x4, x5])(inequal(And((x || (1 .. 5)) >=~ 0, norm([x || (1 .. 5)], 'infinity') = 1))) # not Maple syntax
is equivalent to a solid cuboid
ImplicitRegion((X, Y, Z), -1 <= X <= 1 & -1 <= Y <= 1 & 0 <= Z <= 1) # not SymPy syntax
. (Here, for the convenience of the descriptions, I utilize some non-standard notation from .)
Note that ”two regions are equal" is a two-way property, which means the following proof
is(Z >= 0) and is(Z <= 1 - abs(X) - abs(Y)) assuming (X, Y, Z) =~ (x1 - x3, x2 - x4, x5), x || (1 .. 5) >=~ 0, add(x || (1 .. 5)) = 1;
(*Accordingly, the latter region is a subset of the former one.*)
is incomplete (because it's hard to determine whether the is routine always performs equivalent transformations in internal evaluation).
So, can I execute such eliminations in Maple?
As the code:
poly := x^4 + 8*x + 12:
galois(poly, x)
"4T4", {"A(4)"}, "+", 12, {"(1 2 4)", "(2 3 4)"}
 Then I know it's Galois group has to be (isomorphic to) A4. And I can draw its Subgroup Lattice:
DrawSubgroupLattice(GaloisGroup(poly, x), 'indices')
But according to Galois's theory, each subgroup represents an intermediate field. As far as I know, ⑤⑥⑦⑧ are Q(r1),Q(r2),Q(r3) and Q(r4), respectively, where ri is the root of equation x^4+8x+12. But I have no idea what fields ②③④⑨ means. How do you calculate out those intermediate fields with maple?
Dear researchers,
Greetings, I have unable to apply Nonlinear Least-Squares Methods  for an SIR parameter estimation. May you share me your Maple code model as a  sample parameter estimation ?
Thank you in advance!!!
Dear people,
I have resolved the primitives of the equation of the odometric model.
I have plotted them to the Maple interface and I was thinking that it can have been done by the solver.
Nevertheless it has not been possible to do it.
Can you tell me if a package of Maple can resolve it ?
Best regards,
Edern Ollivier.
May  I please get a Maple code to solve the below Perturbation Iteration Solutions for Volterra Integral Equations?
I shall be very much grateful if I can get the Maple Code.
And possible plotting
What does the following message imply?
"Error, (in Engine:-Dispatch) invalid boolean expression: 0"
I was introduced to DataFrame by some kind people here the other day and I thought I understood.  Then I tried this
M := DataFrame(<0,0,0;0,1,a;0,a,1>,rows=[0,1,a],columns=[0,1,a])
Now M[1, a] returns 0.  What's going on here?
First 62 63 64 65 66 67 68 Last Page 64 of 371
