I require the condition for equations  C1<C2<C4​, with all parameters strictly positive and subject to the constraint t > t1​.
I want to solve for the variables t and s. Specifically, what are the analytical conditions on t that ensure C2>C1​, and what are the analytical conditions on s that ensure C4 > C2 >C1​ ?
I attempted to solve this , but I keep encountering errors.
Q_solving_t_and_s.mw
Why when going to user pages and clicking to see the next page, Mapleprimes gives
https://mapleprimes.com/users/?page=2
This happens for each page after the first one which shows OK.
Do others see this also?
Hello all,
I just need a hint how to enter "matrices" in Maple which are lists of lists and so on.
Since I gave up on "math"ematica I would like to be able to enter what is just
below (with the dimension).
Is it doable in Maple...I guess yes :)
M = {{a, {1, a, -0.5}}
, {{b, {1}}}, c + d}
Out[5]= {a, {1, a, -0.5}, {{b, {1}}}, c + d}
In[8]:= MatrixForm[M]
Out[8]//MatrixForm=
a
{1, a, -0.5}
{{b, {1}}}
c + d
In[9]:= Dimensions[M]
Out[9]= {4}
PS: Is a moderator ready to make me with a reputation of 100 in order I can enter tags.
Thank you for everything.
JM
I am not able to find place in help which lists which changes interface(typesetting = extended); makes compared to interface(typesetting = standard);
Reason  I am asking, is that in interface(typesetting = extended); Maple adds a small annoying "dot"  between each term for multiplication, which is not there in standard.
Is there a place in documentation that mentions this as part of extended? Where to find it?
What does Error, (in dsolve/numeric/bvp) bad index into Matrix mean?
Also, I'm trying to run it, it is slow, any suggestions?
with(Student[VectorCalculus]);
with(DynamicSystems);
with(DEtools);
with(PDEtools, ReducedForm, declare, diff_table, dsubs);
NULL;
 #Digits:= trunc(evalhf(Digits)); #generally a very efficient setting
# Here we solve a 1D problem in 3 regions. In each region, we have concentration and potential (c,phi) distributions,
# We first solve the unperturbed steady-state problem and then the linearized perturbation problem (which rely on the steady state).
# Each region is defined in x = 0..1, and the regions are connected by interface conditions that
# connect (c1(1),phi1(1)) to (c2(0),phi2(0)) and (c2(1),phi2(1)) to (c3(0),phi3(0))
Q:=10;   omega:=100;     J0:= 0.01;   # parameters
                            Q := 10
                          omega := 100
                           J0 := 0.01
# The unperturbed steady-state
c1:=1-J0/2*x:
c3:=1-J0/2*(x-1):
c12:= eval(c1,x=1);
c32 := eval(c3,x=0);
S1:=sqrt(Q^2+4*c12^2):
S3:=sqrt(Q^2+4*c32^2):
c21:=eval((S1-Q)/2);
c23:=eval((S3-Q)/2);
I0:=fsolve(Q*i0/2/J0*ln((J0*S1-Q*i0)/(J0*S3-Q*i0))=(J0-S1+S3)/2,i0);
V:=(I0/J0+1)*ln(c32/c12)+ln((c21+Q)/(c23+Q))+(J0+2*c23-2*c21)/Q; # the potential drop across the system
c2:=solve(y-c21+Q*I0/2/J0*ln((Q*I0-Q*J0-2*J0*y)/(Q*I0-Q*J0-2*J0*c21))=-J0/2*x,y):
phi1:=I0/J0*ln(c1)+V:
phi3:=I0/J0*ln(c3):
dphi1:=diff(phi1,x);
dphi3:=diff(phi3,x);
phi21:=I0/J0*ln(c12)+V-0.5*ln((c21+Q)/c21);
phi2:=(2*c21-2*c2+Q*phi21-J0*x)/Q:
dphi2:=diff(phi2,x);
dphi12 := eval(dphi1, x=1);
dphi21 := eval(dphi2, x=0);
dphi23 := eval(dphi2, x=1);
dphi32 := eval(dphi3, x=0);
INT1 := int(1/(2*c1), x = 0 .. 1);
INT2 := int(1/(2*c2 + Q), x = 0 .. 1);
INT3 := int(1/(2*c3), x = 0 .. 1);
INT := INT1 + INT2 + INT3;
                      c12 := 0.9950000000
                       c32 := 1.005000000
                      c21 := 0.09804129000
                      c23 := 0.1000024500
                      I0 := 0.01419804328
                       V := 0.02539628566
                              0.007099021640
                dphi1 := - --------------------
                           1 - 0.005000000000 x
                              0.007099021640
           dphi3 := - ------------------------------
                      1.005000000 - 0.005000000000 x
                     phi21 := -2.299074561
dphi2 := (0.001000000000 LambertW(-0.2818670588 exp(-0.2818670588
   - 0.0007043224058 x)))/(1
   + LambertW(-0.2818670588 exp(-0.2818670588 - 0.0007043224058 x)
  )) - 0.001000000000
                   dphi12 := -0.007134695118
                   dphi21 := -0.001392499832
                   dphi23 := -0.001391964358
                   dphi32 := -0.007063703124
                      INT1 := 0.5012541824
                     INT2 := 0.09805801917
                      INT3 := 0.4987541511
                       INT := 1.098066353
sys1 := {
-omega*C11(x)+diff(diff(C12(x), x), x)=0,
omega*C12(x)+diff(diff(C11(x), x), x) = 0,
-omega*C21(x)+diff(diff(C22(x), x)+(c2*sigma2-C22(x)*dphi2*Q)/(2*c2+Q), x) =0,
 omega*C22(x)+diff(diff(C21(x), x)+(c2*sigma1-C21(x)*dphi2*Q)/(2*c2+Q), x) = 0,
-omega*C31(x)+diff(diff(C32(x), x), x)=0,
omega*C32(x)+diff(diff(C31(x), x), x) = 0
sys2 := {
diff(FA1(x), x) = C11(x)*dphi1/c1,
diff(FA2(x), x) = C21(x)*dphi2/(c2+Q/2),
diff(FA3(x), x) = C31(x)*dphi3/c3,
diff(FB1(x), x) = C12(x)*dphi1/c1,
diff(FB2(x), x) = C22(x)*dphi2/(c2+Q/2),
diff(FB3(x), x) = C32(x)*dphi3/c3
Bc := {
C11(0) = 0, C12(0) = 0,  C31(1) = 0, C32(1) = 0,
FA1(0) = 0, FB1(0) = 0,  FA3(1) = 0, FB3(1) = 0,
2*C11(1)/c12 = C21(0)/(c21+Q)+C21(0)/c21,
2*C12(1)/c12 = C22(0)/(c21+Q)+C22(0)/c21,
C21(1)/(c23+Q)+C21(1)/c23 = 2*C31(0)/c32,
C22(1)/(c23+Q)+C22(1)/c23 = 2*C32(0)/c32,
D(C11)(1)+dphi12*C11(1)-sigma1/2-c12*D(FA1)(1) = D(C21)(0)+dphi21*C21(0)-(c21+Q)*sigma1/(2*c21+Q)-(c21+Q)*D(FA2)(0),
D(C12)(1)+dphi12*C12(1)-sigma2/2-c12*D(FB1)(1) = D(C22)(0)+dphi21*C22(0)-(c21+Q)*sigma2/(2*c21+Q)-(c21+Q)*D(FB2)(0),
D(C11)(1)-dphi12*C11(1)+sigma1/2+c12*D(FA1)(1) = D(C21)(0)-dphi21*C21(0)+c21*sigma1/(2*c21+Q)+c21*D(FA2)(0),
D(C12)(1)-dphi12*C12(1)+sigma2/2+c12*D(FB1)(1) = D(C22)(0)-dphi21*C22(0)+c21*sigma2/(2*c21+Q)+c21*D(FB2)(0),
D(C31)(0)+dphi32*C31(0)-sigma1/2-c32*D(FA3)(0) = D(C21)(1)+dphi23*C21(1)-(c23+Q)*sigma1/(2*c23+Q)-(c23+Q)*D(FA2)(1),
D(C32)(0)+dphi32*C32(0)-sigma2/2-c32*D(FB3)(0) = D(C22)(1)+dphi23*C22(1)-(c23+Q)*sigma2/(2*c23+Q)-(c23+Q)*D(FB2)(1),
D(C31)(0)-dphi32*C31(0)+sigma1/2+c32*D(FA3)(0) = D(C21)(1)-dphi23*C21(1)+c23*sigma1/(2*c23+Q)+c23*D(FA2)(1),
D(C32)(0)-dphi32*C32(0)+sigma2/2+c32*D(FB3)(0) = D(C22)(1)-dphi23*C22(1)+c23*sigma2/(2*c23+Q)+c23*D(FB2)(1)
all_sys := sys1 union sys2 union Bc:
sol1 := dsolve(all_sys, initmesh = 100, maxmesh = 15000, numeric, method = bvp[midrich], output = listprocedure):
#(all_sys, numeric, method = bvp[midrich]);
I am looking for ways to clear remember tables in a Maple session to ensure that a Maple command/procedure is executed as if it were being called for the first time. I currently use
map(forget, [anames()])
but I am not sure if that statement clears all existing remeber tables (i.e. including system remember tables)?
Are there other ways to do this? Restart is not an option since it clears almost everything.
Edit: This question is not about disabling remember tables.
I'm looking for the general solution to the attached differential equation. Maple doesn't provide it. What am I doing wrong?
ode5 := diff(y(x), x) = (8*y(x)*b-32*b^2*x/y(x)-64*b^2*x^2*y(x))/(3*y(x)^2+8*b*x-16*b^2*x^2/y(x)^2)
simplify(ode5)
diff(y(x), x) = ((64*b^2*x^2-8*b)*y(x)^3+32*b^2*x*y(x))/(-3*y(x)^4-8*b*x*y(x)^2+16*b^2*x^2)
dsolve(ode5, y(x))
NULLNULL
Download testdgl5.mw
I was wondering which theorem the following result is based on, and what the name of the sequence used is.
restart; with(LinearAlgebra)
K := proc (i::integer, j::integer) local M; M := Matrix(5, 5); M[i, i] := 1; M[j, j] := 1; return M end proc
F := proc (r, c, g, h) options operator, arrow; Adjoint(A.K(r, c).B.K(g, h).C) end proc
d1 := 3; d2 := 5; A := Matrix(d1, d2, symbol = a); B := Matrix(d2, d2, symbol = b); C := Matrix(d2, d1, symbol = c)
d1 := 3
d2 := 5
Matrix(3, 5, {(1, 1) = a[1, 1], (1, 2) = a[1, 2], (1, 3) = a[1, 3], (1, 4) = a[1, 4], (1, 5) = a[1, 5], (2, 1) = a[2, 1], (2, 2) = a[2, 2], (2, 3) = a[2, 3], (2, 4) = a[2, 4], (2, 5) = a[2, 5], (3, 1) = a[3, 1], (3, 2) = a[3, 2], (3, 3) = a[3, 3], (3, 4) = a[3, 4], (3, 5) = a[3, 5]})
Matrix(5, 5, {(1, 1) = b[1, 1], (1, 2) = b[1, 2], (1, 3) = b[1, 3], (1, 4) = b[1, 4], (1, 5) = b[1, 5], (2, 1) = b[2, 1], (2, 2) = b[2, 2], (2, 3) = b[2, 3], (2, 4) = b[2, 4], (2, 5) = b[2, 5], (3, 1) = b[3, 1], (3, 2) = b[3, 2], (3, 3) = b[3, 3], (3, 4) = b[3, 4], (3, 5) = b[3, 5], (4, 1) = b[4, 1], (4, 2) = b[4, 2], (4, 3) = b[4, 3], (4, 4) = b[4, 4], (4, 5) = b[4, 5], (5, 1) = b[5, 1], (5, 2) = b[5, 2], (5, 3) = b[5, 3], (5, 4) = b[5, 4], (5, 5) = b[5, 5]})
Matrix(%id = 36893489807004764868)
simplify(Adjoint(A.B.C)-add([F(1, 2, 1, 2), F(1, 2, 1, 3), F(1, 2, 1, 4), F(1, 2, 1, 5), F(1, 2, 2, 3), F(1, 2, 2, 4), F(1, 2, 2, 5), F(1, 2, 3, 4), F(1, 2, 3, 5), F(1, 2, 4, 5), F(1, 3, 1, 2), F(1, 3, 1, 3), F(1, 3, 1, 4), F(1, 3, 1, 5), F(1, 3, 2, 3), F(1, 3, 2, 4), F(1, 3, 2, 5), F(1, 3, 3, 4), F(1, 3, 3, 5), F(1, 3, 4, 5), F(1, 4, 1, 2), F(1, 4, 1, 3), F(1, 4, 1, 4), F(1, 4, 1, 5), F(1, 4, 2, 3), F(1, 4, 2, 4), F(1, 4, 2, 5), F(1, 4, 3, 4), F(1, 4, 3, 5), F(1, 4, 4, 5), F(1, 5, 1, 2), F(1, 5, 1, 3), F(1, 5, 1, 4), F(1, 5, 1, 5), F(1, 5, 2, 3), F(1, 5, 2, 4), F(1, 5, 2, 5), F(1, 5, 3, 4), F(1, 5, 3, 5), F(1, 5, 4, 5), F(2, 3, 1, 2), F(2, 3, 1, 3), F(2, 3, 1, 4), F(2, 3, 1, 5), F(2, 3, 2, 3), F(2, 3, 2, 4), F(2, 3, 2, 5), F(2, 3, 3, 4), F(2, 3, 3, 5), F(2, 3, 4, 5), F(2, 4, 1, 2), F(2, 4, 1, 3), F(2, 4, 1, 4), F(2, 4, 1, 5), F(2, 4, 2, 3), F(2, 4, 2, 4), F(2, 4, 2, 5), F(2, 4, 3, 4), F(2, 4, 3, 5), F(2, 4, 4, 5), F(2, 5, 1, 2), F(2, 5, 1, 3), F(2, 5, 1, 4), F(2, 5, 1, 5), F(2, 5, 2, 3), F(2, 5, 2, 4), F(2, 5, 2, 5), F(2, 5, 3, 4), F(2, 5, 3, 5), F(2, 5, 4, 5), F(3, 4, 1, 2), F(3, 4, 1, 3), F(3, 4, 1, 4), F(3, 4, 1, 5), F(3, 4, 2, 3), F(3, 4, 2, 4), F(3, 4, 2, 5), F(3, 4, 3, 4), F(3, 4, 3, 5), F(3, 4, 4, 5), F(3, 5, 1, 2), F(3, 5, 1, 3), F(3, 5, 1, 4), F(3, 5, 1, 5), F(3, 5, 2, 3), F(3, 5, 2, 4), F(3, 5, 2, 5), F(3, 5, 3, 4), F(3, 5, 3, 5), F(3, 5, 4, 5), F(4, 5, 1, 2), F(4, 5, 1, 3), F(4, 5, 1, 4), F(4, 5, 1, 5), F(4, 5, 2, 3), F(4, 5, 2, 4), F(4, 5, 2, 5), F(4, 5, 3, 4), F(4, 5, 3, 5), F(4, 5, 4, 5)]))
Matrix(%id = 36893489807027993164)
nops([F(1, 2, 1, 2), F(1, 2, 1, 3), F(1, 2, 1, 4), F(1, 2, 1, 5), F(1, 2, 2, 3), F(1, 2, 2, 4), F(1, 2, 2, 5), F(1, 2, 3, 4), F(1, 2, 3, 5), F(1, 2, 4, 5), F(1, 3, 1, 2), F(1, 3, 1, 3), F(1, 3, 1, 4), F(1, 3, 1, 5), F(1, 3, 2, 3), F(1, 3, 2, 4), F(1, 3, 2, 5), F(1, 3, 3, 4), F(1, 3, 3, 5), F(1, 3, 4, 5), F(1, 4, 1, 2), F(1, 4, 1, 3), F(1, 4, 1, 4), F(1, 4, 1, 5), F(1, 4, 2, 3), F(1, 4, 2, 4), F(1, 4, 2, 5), F(1, 4, 3, 4), F(1, 4, 3, 5), F(1, 4, 4, 5), F(1, 5, 1, 2), F(1, 5, 1, 3), F(1, 5, 1, 4), F(1, 5, 1, 5), F(1, 5, 2, 3), F(1, 5, 2, 4), F(1, 5, 2, 5), F(1, 5, 3, 4), F(1, 5, 3, 5), F(1, 5, 4, 5), F(2, 3, 1, 2), F(2, 3, 1, 3), F(2, 3, 1, 4), F(2, 3, 1, 5), F(2, 3, 2, 3), F(2, 3, 2, 4), F(2, 3, 2, 5), F(2, 3, 3, 4), F(2, 3, 3, 5), F(2, 3, 4, 5), F(2, 4, 1, 2), F(2, 4, 1, 3), F(2, 4, 1, 4), F(2, 4, 1, 5), F(2, 4, 2, 3), F(2, 4, 2, 4), F(2, 4, 2, 5), F(2, 4, 3, 4), F(2, 4, 3, 5), F(2, 4, 4, 5), F(2, 5, 1, 2), F(2, 5, 1, 3), F(2, 5, 1, 4), F(2, 5, 1, 5), F(2, 5, 2, 3), F(2, 5, 2, 4), F(2, 5, 2, 5), F(2, 5, 3, 4), F(2, 5, 3, 5), F(2, 5, 4, 5), F(3, 4, 1, 2), F(3, 4, 1, 3), F(3, 4, 1, 4), F(3, 4, 1, 5), F(3, 4, 2, 3), F(3, 4, 2, 4), F(3, 4, 2, 5), F(3, 4, 3, 4), F(3, 4, 3, 5), F(3, 4, 4, 5), F(3, 5, 1, 2), F(3, 5, 1, 3), F(3, 5, 1, 4), F(3, 5, 1, 5), F(3, 5, 2, 3), F(3, 5, 2, 4), F(3, 5, 2, 5), F(3, 5, 3, 4), F(3, 5, 3, 5), F(3, 5, 4, 5), F(4, 5, 1, 2), F(4, 5, 1, 3), F(4, 5, 1, 4), F(4, 5, 1, 5), F(4, 5, 2, 3), F(4, 5, 2, 4), F(4, 5, 2, 5), F(4, 5, 3, 4), F(4, 5, 3, 5), F(4, 5, 4, 5)])
100
Download Adjoint353.mw
Is this account worth keeping? I only made it to try to download Maple. I am having technical problems downloading the app using a code, and was hoping that having a MapleSoft account would stop the firewall from blocking me somehow?... not my best idea, I will admit.
So is this account worth keeping? I can't delete it for some reason anyway
Just want to know if it will help me in any way with using Maple
Given first order nonlinear ode which is hard to solve using standard methods, the smart dsolve sometimes uses a method where it linearizes the first order ode to a linear second order ode and solves that.
Then with that solution to the linear second order ode, it is able to find the solution of the first order ode (need to resolve the constants of integration to merge them into one, but this part is easy to do).
My question is, how and what method it uses to "linearizes by differentation"? I could not find this in any textbook I have, and not able to see how it does.
Here is an example where it uses this method to solving this first order ode
Typesetting:-Unsuppress('all'); #always do this.
Typesetting:-Settings(prime=x,'typesetprime'=true); #this says to use y'(x) instead of dy/dx
Typesetting:-Suppress(y(x)); # this says to use y' and not y'(x)
ode:=diff(y(x),x) = (-y(x)^2+4*a*x)^2/y(x);
infolevel[dsolve]:=5;
dsolve(ode,y(x), singsol=all);
Tracing says
So it says, if I understand, that it differentiated the original given first order ode and then linearized the resulting second order ode to the above, which is    y''=-64 a^2 x^2 y - 16 a x y' which is certainly linear second order ode and now can be solved using kovacic algorithm. Now the solution to the first order ode can be obtained.
But when differentiating the first order ode, this is the result
expand(diff(ode,x))
So the question is, did Maple mean it "linearized" the above to y''=-64 a^2 x^2 y - 16 a x y'
If so, then how? Did it use Taylor series? but if so, where it expanded about? Or did it use some other method?  One thing I noticed is that by multiplying the RHS above by y^2 it becomes
And "removing" the nonlinear terms (say expansion is around y=0, so higher order y terms are very small and can be removed) the RHS above becomes
    y'' y^2 = -16 y' a^2 x^2 + 32 a^2 x y
Which is close to Maple shows, but 32 instead of 64, and what about the y^2 on the left side?  Is this method even valid mathematically to do? Since solution that result will be correct only near y=0?
So far, trying to step in the debugger to find how, I was not able to find where it does that but will keep trying.
Any idea what Maple means by linearization to 2nd order and how it does it?
ps. only case I know about, where nonlinear first order ode can be transformed to linear second order ode is the Riccati ode using transformation y=u'/u. But this  first order ode is not Riccati.
I just installed Maple 2023 on a MacPro running macOS Sequoia 15.7.2. Update to latest .version and activation worked without a hitch.
When I try to run it from the Finder it immediately puts up a dialog saying something like "Java not found". There is a webpage by Maplesoft addressing this, but it is completely uninformative and unhelpful.
I can get Maple to run using the cli (in Terminal) opening the Maple 2023 .app file, at which point Maple (running the standard GUI) works just as one would expect. So it is not a crisis but I'd like to be able to open it through the Finder as well. The Maple .app folder appears to have all the Java stuff in it, and clearly it is somewhere.
Anyone seen and solved this before?
Mac Dude
Solving this ode, Maple says
But notice, the xi and eta tangent vectors order is reversed. Maple says pattern is [0,F*G], but shows [F*G,0].
Also, when later using DEtools:-symgen with HINT option, it does not return the above result. Tried both patterns with 0 on left and 0 on right. In both cases symgen does not return what shows above.
Why is that? Am I doing something wrong? Notice also it says   "way=HINT"  but I am not using way option. Only HINT option, Why is it saying way=HINT? it seems argument passing I  am using is wrong, but do not see why it could be wrong.  This is what help says
Worksheet below
`Standard Worksheet Interface, Maple 2025.2, Windows 10, November 11 2025 Build ID 1971053`
ode:=diff(y(x),x)*cos(y(x))-cos(x)*sin(y(x))^2-sin(y(x)) = 0;
infolevel[symgen]:=5;
(diff(y(x), x))*cos(y(x))-cos(x)*sin(y(x))^2-sin(y(x)) = 0
dsolve(ode);
Methods for first order ODEs:
--- Trying classification methods ---
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying Chini
differential order: 1; looking for linear symmetries
trying exact
Looking for potential symmetries
trying inverse_Riccati
trying an equivalence to an Abel ODE
differential order: 1; trying a linearization to 2nd order
--- trying a change of variables {x -> y(x), y(x) -> x}
trying 1st order ODE linearizable_by_differentiation
--- Trying Lie symmetry methods, 1st order ---
 -> Computing symmetries using: way = 3
 -> Computing symmetries using: way = 4
 -> Computing symmetries using: way = 5
trying symmetry patterns for 1st order ODEs
 -> Computing symmetries using: way = patterns
-> trying a symmetry pattern of the form [F(x)*G(y), 0]
-> trying a symmetry pattern of the form [0, F(x)*G(y)]
-> The symmetry found is [0 exp(-x)*(2*sin(y)^2+cos(y)^2-1)/cos(y)]
<- symmetry pattern of the form [0, F(x)*G(y)] successful
[exp(-x)*(2*sin(y)^2+cos(y)^2-1)/cos(y), 0]
 <- successful computation of symmetries.
y(x) = arctan(-2*exp(x)/(exp(x)*cos(x)+exp(x)*sin(x)+2*c__1), ((2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)+4*c__1^2+(exp(x))^2)*(2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)-3*(exp(x))^2+4*c__1^2))^(1/2)/(2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)+4*c__1^2+(exp(x))^2)), y(x) = arctan(-2*exp(x)/(exp(x)*cos(x)+exp(x)*sin(x)+2*c__1), -((2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)+4*c__1^2+(exp(x))^2)*(2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)-3*(exp(x))^2+4*c__1^2))^(1/2)/(2*cos(x)*sin(x)*(exp(x))^2+4*c__1*sin(x)*exp(x)+4*cos(x)*c__1*exp(x)+4*c__1^2+(exp(x))^2))
infolevel[dsolve]:=0;
DEtools:-symgen(ode,y(x),HINT = [ 0,F(x)*G(y)]); #why this does not return the symmetries found by dsolve above?
 -> Computing symmetries using: way = HINT
DEtools:-symgen(ode,y(x),HINT = [ F(x)*G(y),0]); #why this does not return the symmetries found by dsolve above?
DEtools:-symgen(ode)
 -> Computing symmetries using: way = 2
 -> Computing symmetries using: way = abaco1
[0, exp(-x)*(-1+cos(2*y))/cos(y)]
[_xi = 0, _eta = exp(-x)*(-1+cos(2*y))/cos(y)]
Download symgen_confusion_jan_9_2026.mw
Has anybody seen the unit palette beeing empty?
This is new to me. I normally use the unit entry in the favourites but this time wanted to try Maple presets.
I'm doing some experimenting with the Optimization:-Maximize and Minimize functions, and I'm having difficulties getting them to find the actual extrema within a set of bounds.  I have found that the extrema they identify depend on the bounds, even when the same extrema lie within those bounds. I've also tried the initialpoint option to start the solution near the extrema and I've found three things: sometimes it works to get the correct solution, sometimes it doesn't and sometimes I get a message saying the initial point was ignored by the solver.
The problems I'm using are all taken from the Maple help or tutorials.
I haven't included a bunch of test cases but I've attached the Maple Flow file.  I have a suspicion it has to do with the second derivatives of the functions near the boundaries, but I'm not sure.
Can anyone point me to more information, or am I doing something wrong?
Thanks for your help.
Optimization_Local_Max_and_Min.flow
I was searching release notes for some old Maple versions. I found so many broken links on Maple web pages. The first page is https://www.maplesoft.com/products/maple/history/
Scrolling down, and starting from Maple 2016 (about half way down the page), all links to the "product press release" are broken. This is the link to the right of each product.  All these links on the right, from 2016 to the end of the page are broken,
Clicking on any of these, sends the user to new broken web page, called https://www.maplesoft.com/company/publications/  titled "Maplesoft media coverage".
This page does not even work. Clicking on "Jump to year" does not open. Clicking in "first page" does nothing. Tried Edge browser on windows 10, also the page does nothing.
Then I clicked on Maplesoft Media Releases link at top, and now it works.
But jumping to any year before  2016, all the links that show on those pages are broken. Try and see,
For example. jumping to 2015, and clicking on release called "
November 25, 2015"
Gives
This applies to each press release for each year from 2015 to 1997.
Hundreds of links are broken.
There is software which checks broken links, and it is free for windows, called Xenu's Link Sleuth. May be someone at Maplesoft can use it to find all broken links at Maplesoft web site and fix them?
It is not acceptable in this day and age to have a Major software company with a web site full of broken links.
4 5 6 7 8 9 10 Last Page 6 of 371
