In the Maple 2025 release, the "old/former" user interface was provided under a menu entry called "Maple 2025 for Screen Readers". I used this version because of shortcommings of the new ribbon interface. Some of the shortcommings have been fixed in the 2026 release but it is still slow to use (I am missing functions in the quick access toolbar that I frequently use and no customization of the bar seems possible).
I could not find a similar menu entry in the 2026 release under Windows 11. Is the old unser interface still available?
I am solving a hybrid nanofluid flow problem in a bifurcated artery using Maple. The governing equations for velocity and temperature are solved using dsolve(..., numeric, method=bvp[midrich]).
My Maple code successfully produces for both the artery  parentartery_and_daughter_artery_error.mw.
The velocity profiles are obtained correctly using odeplot.
However, I want to compute additional physical quantities and generate plots similar to the velocity profiles.
Specifically I want to plot:
  1. Flow rate Q versus axial distance z
  2. Impedance (flow resistance) λ versus z
  3. Wall shear stress τ versus z
for different values of Hartmann number Ha.
The formulas I am using are
Flow rate:
Q=2π(R∫01ηw(η) dη+R2∫01w(η) dη)Q = 2\pi \left( R \int_0^1 \eta w(\eta)\,d\eta + R_2 \int_0^1 w(\eta)\,d\eta \right)Q=2π(R∫01​ηw(η)dη+R2​∫01​w(η)dη)
Wall shear stress:
τ=μ∣dwdr∣\tau = \mu \left|\frac{dw}{dr}\right|τ=μ​drdw​​
Impedance:
λ=∣dp/dz∣Q\lambda = \frac{|dp/dz|}{Q}λ=Q∣dp/dz∣​
Please help me to solve this question.
I have attached a MapleFlow file that shows a result I don't quite understand.  For some reason the FinalValue result that I get using the DynamicSystems:-StepProperties is different than the steady state value from a DynamicSystems:-ResponsePlot to a unit step using a DifferentialEquation object.
You will notice that I played around a bit, including transforming the DiffEquation object to a TransferFunction object, to see if I could make sense of it.  All of the results are the same as the StepProperties result, it appears that only the ResponsePlot for the DifferentialEquation object is different.
Am I doing something wrong?  Does anyone have any ideas?
Dynamic_Systems_Final_Value.flow
I am not sure whether this should be in "create a post" or "ask a question." Let me know if this is more appropriate in "ask a question"
The standing wave equation is given by:
PDE:=diff(u(x,t),t,t)=c^2*diff(u(x,t),x,x)
IBC := {u(x, 0) = A0*cos(Pi*x/L), D[1](u)(0, t) = 0, D[1](u)(L, t) = 0, D[2](u)(x, 0) = 0}
pdsolve(PDE,IBC,numeric)
In my problem, the material is a magneto-elastic material where c, the speed of the acoustic wave, is a function of a magnetic field H.  The material is nonlinear and saturable.  I define it by a 3 segment piecewise nonlinear function of H.  The material response is a result of a sinusoidal H field.  I am interested in solving u(x,t).
With that, c in the PDE has to be rewritten as c(H(t)), pdsolve gives an error as PDE has to be expressed as a function of u,t, or x.  So I redefine c(H(t)) as c(t).  I ran into another error in pdsolve as the piecewise has to be based on t or x and not H.
The problem is that depending on H I can go through all 3 segments and back in one cycle and I have to find the corresponding t's for the piecewise.  Now I am driving the material with 100 cycles, I have to find and list all those piecewise transition points which is hardly practical.
Is there any other ways to approach and solve this problem?
once i founded but  i lost the technique and i can't remember how i can reach the point how to find thus parameter and find the solution of pde
t1.mw
I just found a rather incredible error in versions 2025.1 and 2025.2.
The function works fine in version 2022.
The drag function in solve does not work, even for solving a very simple problem.
For example, in the equation 1 + 5x = 3x - 1, if I try to do 3x from right to left, a box opens with a good suggestion (subtract   1+2x = -1)
# subtract 3*x from both sides
((1)) + ~(3 * x)
we can see that the correct expression should be ((1)) - ~(3 * x)
I finally get:
1 + 8x = 6x -1 (it added and did not subtract 3x from both sides)
Please correct this...
Mapleprimes issue
Trying to upload a mw file throws this error message
Dear sir,
i want to draw velocity and temperature plots for fluid and dust phases. but getting error in that showing 12 BC need only 8
i have tried with 8 Bc also but showing different error how to rectify it
dust_phase_work_error.mw
I have tried to create a function "modelica style" that acts as a custom component.
The Modelica code editor recognizes it.  It correctly sees the language constructs "function, parameter, etc." and then the block has the {} symbology showing it is a function.  Also, the Syntax Template doesn't seem to work per chapter 07.  i.e., the reference of "function" plus CTL-SHIFT-SPACE does nothing.
However, trying to call this does not work and errors that the function is being called from main as a public declaration and gving the named function "myfunction_1" instantiation within main which errors out.
    Modelica coide in Main:   public MyFunction myfunction_1 annotation(Placement(transformation(origin={120.0,160.0},extent={{-20.0,-20.0},{20.0,20.0}},rotation=0)));
MyFunction is declared below Main along with another custom component model class "UseMyFunction" that calls this function with the variables being used in the simulation.
Where can I find the modelica language references that MapleSim accepts in the modelica coding region?
This mini-attempt is to find the usage syntax and method to reach higher custom functions that act similar to "Math" code blocks in the library.
Bill
is been a while i work on it but i can't figure out where is problem and even my solution is so far from it when numerically i tested , i got same outcome as the paper did maybe is  long but it is same and maybe have some typical different but they are same , the problem in here is that which when i substitue is not my answer i don't know where is my mistake ?
pde-te.mw
f18.mw
f19.mw
I am currently encountering an issue while solving my boundary value problem in Maple. The following error message appears:
"Error, (in dsolve/numeric/bvp) cannot determine a suitable initial profile; please specify an approximate initial solution."
This problem arises when I attempt to generate plots by varying the parameters λl, λu, βl, βu, etc.
Lamda_l_new.mw
I recently got access to a 12-core Intel MacPro with 64 GB main memory. This motivated me to try parallel programming again, even though in prior years I have never been successfull. The project I am trying to do is particle tracking through a circular accelerator, an embarassingly parallel problem in the sense that you can track n particles in parallel through your machine for many turns and then gather up the results for analysis. The function describing the tracking is a 6-component polynomial function acting on 6-vectors and yielding a 6-Vector as a result. Each accelerator component (magnet, drift section, rf, ...) is described by such a function. I am simplifying this a bit here, but in the problem at hand this is what I am doing. The point is that each particle gets treated independently from the others, hence parallelization should be trivial.
Using an existing package (Lattice, which I published with Maple) as framework I set this up such that the tracking proc for n turns of one particle in the accelerator is a member of a module. This module is in the body of a proc and gets returned when the proc is called, essentially instantiating the tracking object and assigning it to a Vector with as many elements as I have particles to track. The tracking function returns a 6-Vector with the coordinates after all turns are complete.
A separate proc does the instantiation of all tracking objects, gives each one its particle number (from a Beam object it is being given) and sends it off using Threads:-Create. It then waits until every task is done (using Threads:-Wait) and assembles the result in another Beam object which it returns. Please refer to the enclosed Maple worksheet for how it is done.
This actually all appears to work. MacOS is 15.7.2 (Sequoia); Maple is 2023.2. The results are identical both parallel and serial.
The "interesting" result however, is that usage of the available CPU cores saturates at about 4. In the graph shown below, the green line shows the CPU usage of the mserver process, and it saturates between 400 & 500%, actually going down to 360% as more particles get added. 100% is one core, so I am never getting more than about 4 cores to work for me. Correspondingly, the no. of seconds per particle goes up from about 3 s (particle 1 to 4) up to about 15 s/particle, settling at about 10 s/particle as 12 particles are approached. Below is a graph against no. of particles (n) of running time (red), CPU time (dark blue), CPU usage (yellow) and # or mkernel threads (green).
Bottom line: I am only getting 4 cores out of the 12. Process limits of MacOS (ulimit -a) do not indicate any limit that would cause this (and I have had build jobs that would merrily use all 12 cores).
Is there a limit in Maple that prevents using all available cores? Am I doing something inefficient that could cause this?? This is the first time I actually got parallel operations in Maple to work, so I am happy about that, but my happiness is tempered by not getting it to work at the level I was aiming for. I did google around a bit and found some prior conversations on MP (mostly involving @acer and @Carl Love) about parallel threads which indicated that (a) environment variable OMP_NUM_THREADS should be set and (b) that numcpus can only be set at the very beginning of a Maple session (which I interpret as "right after firing up Maple"). Did both (and verified the settings were in) but no change in behaviour of this code; I only get four cpu cores to work.
Mac Dude
Parallel_tracking_attempt.mw
Edit: Added graph, fixed up graph.
I do not think I've ever seen this before.
I have Maple set up to use one engine per one worksheet.
Today, when I tried to open new worksheet (after Maple had an internal error running some code in another worksheet), I was not able to execute anything in the new worksheet. I get this message
Looking at task manager, I see the front end running at high CPU
Stange thing, there was nothing else running at the time.
Had to kill all of Maple.
Just wondering if any one saw this message before and what could cause it?
I'll try to see if I can reproduce it again by running same code which caused that initial Maple error in the first worksheet. But as I said, this is the first I see such a problem in Maple.
I was connected to the network at the time, if this makes any difference.
Does anyone have any exoerience playing with this topic?
Hello everyone
Dear experienced and expert friends
As a beginner, I would like to ask if any of my friends can guide me.
The following commands are related to Mathematica:
plots = Table[n = sValues[[i]];
   ParametricPlot[{1 - 2/n - 1.5/n^2 + (1.33 - 2/n) \[Gamma] -
      0.0740741 (15 + 4*n) \[Gamma]^2,
     12/n^2 + (16 \[Gamma])/n + (80 \[Gamma]^2)/9}, {\[Gamma], 0,
     0.06}, PlotStyle -> colors[[i]],
    PlotRange -> {{-10, 10}, {-10, 10}}], {i, Length[sValues]}];
Show[plots, Frame -> True, FrameLabel -> {"\!\(\*
StyleBox[SubscriptBox[\"n\", \"s\"],\nFontSize->16,\n\
FontColor->GrayLevel[0]]\)", "\!\(\*
StyleBox[\"r\",\nFontSize->16,\nFontColor->GrayLevel[0]]\)"},
 GridLinesStyle -> Black, PlotRange -> {{0.94, 1}, {0, 0.06}},
 PlotLegends ->
  Placed[LineLegend[sValues, LegendLabel -> "s,w"], {0.5, 0.5}],
 ImageSize -> 400]
I want to rewrite this process in Maple for my own functions.
I would be grateful if it is possible or if these commands are rewritten in a complete and executable form in Maple for me so that I can understand the working pattern. Or at least an equivalent command that can do this in Maple is introduced
Thank you all
3 4 5 6 7 8 9 Last Page 5 of 371
