I want to change the datatype of a column of a Dataframe imported from Excel.
The import succeeds, and I can change the data type of numeric columns (from the default 'anything' to, say, float).
But conversion fails for all string columns. For example:
DataNew := SubsDatatype(Data, "UN Region", string);
throws the following error:
Error, (in DataSeries:-SubsDatatype) in datatype conversion; try using the 'conversion' option for data type string
The column in question has values such as "Southern Asia", which I would have thought would convert.
What am I doing wrong?
Did you intend on doing the diffetentiation elememtwise, ie. on each of the Matrix entriez?
Did you try,
   diff~(V, x)
or,
  map(diff, V, x)
I want to convert an XYZ file into a hydrogen-depleted heavy-atom molecule in Maple. Since XYZ has only coordinates, I’ll infer bonds by comparing inter-atomic distances to the sum of covalent radii ± tolerance, then remove hydrogens and output a heavy-atom molecule with only these bonds. What tolerances are sensible, and is there any built-in way in Maple to do this? Kind help with a maple code to do this.
Maple 2025.1 unable to solve this ode. Sympy gives the following two solutions which Maples verifies are correct.
Any trick or option that can help dsolve find these solutions?
`Standard Worksheet Interface, Maple 2025.1, Linux, June 12 2025 Build ID 1932578`
ode:=diff(y(x),x) = (1+cos(x)*sin(y(x)))*tan(y(x));
diff(y(x), x) = (1+cos(x)*sin(y(x)))*tan(y(x))
sol:=dsolve(ode);
sol_1:=y(x)=arcsin( 2*exp(x) / ( c__1 + sqrt(2)*exp(x) * sin(x+Pi/4) ) ) + Pi
y(x) = arcsin(2*exp(x)/(c__1+2^(1/2)*exp(x)*sin(x+(1/4)*Pi)))+Pi
odetest(sol_1,ode)
sol_2:=y(x)=arcsin( 2*exp(x) / ( c__1 - sqrt(2)*exp(x) * sin(x+Pi/4) ) ) ;
y(x) = arcsin(2*exp(x)/(c__1-2^(1/2)*exp(x)*sin(x+(1/4)*Pi)))
odetest(sol_2,ode)
Download How_to_find_solution_sept_20_2025.mw
update:
OK, found out how. Needed transformation u(x)=sin(y(x)). Maple probably did not have this in one of the things to try.
sol:=dsolve(ode);
tr:=y(x)=arcsin(u(x));
PDEtools:-dchange(tr,ode,[u(x)]):
dsolve(%);
sol:=y(x)=arcsin(rhs(%));
odetest(sol,ode)
y(x) = arcsin(u(x))
u(x) = -2/(-2*exp(-x)*c__1+sin(x)+cos(x))
y(x) = -arcsin(2/(-2*exp(-x)*c__1+sin(x)+cos(x)))
Download How_to_find_solution_sept_20_2025_V2.mw
Hello, is there a way to generate a warning or to flag instances in Maple Flow where a duplicate variable assignement is made? In the example below, I would like to know that I have re-defined x:
Maple documents appear to be an excellent way of documenting problems and procedures, and notetaking in general, but I have always found them laborious and frequently encountered problems with formatting. One may as well use Tex. This is the reason that I was struck by the ability of the GenerateDocument() procedure in the NaturalLanguage package to create Maple documents.
Is there any practical way to use NaturalLanguage for notetaking and documentation of procedures. By this I mean, the ability to input math and or explanatory text and request(direct) the AI to produce a maple document.
In this kind of contour plot i have two line but when i change time variable t just contour of one line wil move the other is not do any movement and is stop how i can  make the second plot one second line move too? also there is any way for ploting this kind any other option?
line-2-done.mw
How do I enter a number as an actual percentage?  I know that I can enter a number as a fraction, and then redisplay the number formatted as a percentage, but I would like to be able to type in that a variable is 10%, not have to type in that it is 0.1, then convert it to percent.  I would like Maple Flow to figure out what it is, because I typed in, in effect, it's units.
It is possible to perform the simplest QFT calculations with second quantization, in Maple? Bosons in a box. See attached example. bosons_in_a_box.mw
Sure any general purpose programming language is capable of performing this task with enough effort. What I am interested in is if the physics tools has a standard way of dealing with these calculations. The general impedement when attempting the calculation is that integrations are perfomed by replacements with delta functions or kronecker delta functions, and its not clear how to force the Maple Physics package to recognize this or if that's possible. Part of the problem is that integrations in maple are defined in one dimension at a time where as in QFT the integration element is almost always atleast three dimensional, d^3x or dxdydzy, the later of which can get extremely cumbersome with even a small number of fields under consideration. I don't find much of what I am refering to mentioned in the help pages and I doubt these types of QFT calculations are possible to perform in Maple without addressing these issues.
bosons_in_a_box.mw
Hello everyone!
I have had an issue for the past weeks, where it seems like Maple has a problem identifying the correct units and also sometimes having an issue with defining a variable.
In the picture below you can see I have defined rho, m and tried to Solve V. I get m^3, which is fine but I cannot change the unit in the right bar (see picture).
I even tried to just take square root of my V to see if I could then change units. It seems like it thinks I'm playing with weight.
I even had 2 teachers trying to help me find a solution, without luck.
I have tried executing the whole document and also only bits of the document without luck.
Does anyone know this problem and has a solution?
Thanks in advance!
- Jacob
i don't  know  why my graph make a problem and what is issue i did plot  but this time make issue for me which i don't know where is problem there is anyone which can help and even modified the plot?
explore-chaotic.mw
Hello All
I have the system of 4 differential equations with retarted delay (t-tau) and advanced argument (t+tau). The problem is also considered as a two-value boundary problem since some variables have initial conditions and some have terminal ones.
Here is a model:
Data:
A := 10;
B := 5;
C := 2;
tau = 0.5;
T := 10;
 z := 5;
 N := 20;
System:
sys := diff(K(t), t) = A*Q(t - tau) + K(t), diff(Q(t), t) = l_Q(t)*z - N, diff(l_K(t), t) = B*Q(t - tau) + l_K(t), diff(l_Q(t), t) = l_K(t + tau)*K(t + tau) + C;
Initial and terminal conditions:
inc := K(0) = 50, Q(0) = 200, l_K(T) = -20, l_Q(T) = 0;
I will appreciate any direction/suggestion on how this system can be solved.
Dmitry
THis is problem from textbook. Maple do not give solution.
But when asked for implicit solution, it gives one.  Should it not have done this automatically?
ode:=y(x)*diff(y(x),x) = a;
ic:=y(0) = b;
sol:=dsolve([ode,ic]);
y(x)*(diff(y(x), x)) = a
y(0) = b
sol:=dsolve([ode,ic],'implicit')
-2*a*x+y(x)^2-b^2 = 0
Download why_no_solution_maple_2025_1.mw
We see now there are two solutions for y(x), since quadratic.
So why dsolve do not solve this and at least give implicit solution automatically? Should this be reported as defect?
Greetings
I trust that everyone is well here. I have an inquiry regarding the partitioning of a matrix BA, defined on both regular and irregular domains, into three matrices: Ad, Ab, and Ae, such that NewBA = Ad + Ab + Ae. Here, Ad comprises the entries of BA that reside within the domain, Ab includes the elements of BA located on the boundary, and Ae is derived as BA - Ad - Ab for any values of Mx and My. The specifics of matrix BA are contained in the attached document where NewBA constructed manually for different values of Mx and My for better understanding.
Splitting_a_matrix.mw
The attached file contains the matrix BA constructed in a square format. How may the BA matrix be adapted to create an irregular shape, such as a quarter circle?
The red dots indicate the mesh within the domain Ad, while the meshing along the blue line should occur in Ab.
I await your kind reply. Kindly ensure your well-being
I was wondering why there is no longer a separate section for Maple Flow under the tab "Products". As syntax is not always the same between Maple and Maple Flow it would be nice to ask specific questions. Also why is there no suggestion tag for maple flow?
Thank you for any information
First 9 10 11 12 13 14 15 Last Page 11 of 371
