For years I used to use 2 accounts when I am home
  • one under Firefox corresponds to my profesionnal account, which I can access to from my office oror home (and which is the one I use here),
  • the other one under Safari is my "personal" account; (login mmcdara)  which I cannot access to from my office because of security rules.
To separate the managing of professional and personal accounts I always used the former under Firefox and the latter under Safari.
Since the outage my personal account is no longer accessible, neither from Safari nor Firefox.
I created this account about eight years ago using the adress michael.mcdara@gmail.com and during all these years the connexion to Mapleprimes from Safari was  "automatic" in the sense that I was always logged in as mmcdara. Even after having quit Safari or shut down my computer, I was logged in as mmcdara as soon as I reopened Mapleprimes (a curiosity, for quitting Firefox being logged in as sand15 and openening it again required my relogging as sand15).
This still was the case early this morning (I sent replied to andiguy) but not one hour after.
Indeed Mapleprimes asked me my mail adress, that I knew, and my password, that I have forgot, of course.
Eight years ago the double authentification was not mandatory and so Gmail has purely and simply made the adress michael.mcdara@gmail.com inaccesible in between (I used it only with Mapleprimes, thus no real need to look at it regularly nor to bother with this double authentification stuff... at least I thought).
So any attempt to ask for a reinitialization of my password is a dead end for I cannot access the address michael.mcdara@gmail.com
My main activity on Mapleprimes is realized using my mmcdara account.
What bothers me the most  (loosing my mmcdara account would be unplesant but I can survive this) is that I was working since several months on two or three posts and that I can't anymore access the corresponding drafts (not a deadly situation I cannot survive to neither).
Do you have any idea about how to solve these issues?
I would satisfy myself recovering the two or three post drafts I was working on.
what is problem in here
with(DEtools):
diff(u(x), x) = f(u(x), v(x)), diff(v(x), x) = g(u(x), v(x)) for the two differential equations.
f := (u,v) -> u+cos(v);
g := (u,v) -> u*v-v+sin(v);
proc (u, v) options operator, arrow; u+cos(v) end proc
proc (u, v) options operator, arrow; v*u-v+sin(v) end proc
The equilibria:
equilibria := solve({f(u,v)=0, g(u,v)=0}, {u,v},explicit);
{u = 1, v = Pi}, {u = -cos(RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z)), v = RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z)}
allvalues(RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z))
RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z, 1.306542374), RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z, -1.306542374), RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z, -2.331122370), RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z, 2.331122370), 0
Download remove.mw
i want plot a system of differential equation and do phaseportrait i did but when i want make it a little bit more clear and colorfull like rainbow when i find the C.Q i don't know how set the option for ploting?
e1.mw
In a recent MaplePrimes question: https://mapleprimes.com/questions/240543-Maple-20251-On-Windows-11-How-To-Resize
a discussion of interrupting a computation also came up.
I gave some comments. In one of these I wanted to include a link to a screenshot.
I tried several times. It seemed that I only had the choice between the full image or a thumb nail.
So I chose the latter. That appeared to me as worthless. I tried a couple of times more, but decided to delete all 3.
Then I wrote a comment without a screenshot.
It looks silly to have these empty (and anonymous) "comments" still around.
Is there any way to remove these?
Someone should please help me compute the left and right eigenvectors of the system below. The purpose is to compute values for 'a' and 'b' in the bifurcation formula.
with(VectorCalculus)
interface(imaginaryunit = I)
I
I
I
diff(S(t), t) := `Λ__p`-(`#mrow(mi("ϕ",fontstyle = "normal"),mo("⋅"),msub(mi("θ",fontstyle = "normal"),mi("B")),mo("⋅"),msub(mi("I"),mi("B")))`/N[p]+µ__C)*S+`ω__B`*I__B
Lambda__p-(`#mrow(mi("ϕ",fontstyle = "normal"),mo("⋅"),msub(mi("θ",fontstyle = "normal"),mi("B")),mo("⋅"),msub(mi("I"),mi("B")))`/N[p]+µ__C)*S+omega__B*I__B
diff(I__B(t), t) := `#mrow(mi("ϕ",fontstyle = "normal"),mo("⋅"),msub(mi("θ",fontstyle = "normal"),mi("B")),mo("⋅"),msub(mi("I"),mi("B")))`*S/N[p]-`ω__B`*I__B-(`σ__B`+µ__C)*I__B
`#mrow(mi("ϕ",fontstyle = "normal"),mo("⋅"),msub(mi("θ",fontstyle = "normal"),mi("B")),mo("⋅"),msub(mi("I"),mi("B")))`*S/N[p]-omega__B*I__B-(sigma__B+µ__C)*I__B
diff(S__A(t), t) := `Λ__A`-(µ__A+`#mrow(mi("ϕ",fontstyle = "normal"),mo("⋅"),msub(mi("α",fontstyle = "normal"),mi("B")),mo("⋅"),msub(mi("I"),mi("B")))`/N[p])*S__A+`δ__A`*I__A
Lambda__A-(µ__A+`#mrow(mi("ϕ",fontstyle = "normal"),mo("⋅"),msub(mi("α",fontstyle = "normal"),mi("B")),mo("⋅"),msub(mi("I"),mi("B")))`/N[p])*S__A+delta__A*I__A
diff(I__A(t), t) := `#mrow(mi("ϕ",fontstyle = "normal"),mo("⋅"),msub(mi("α",fontstyle = "normal"),mi("B")),mo("⋅"),msub(mi("I"),mi("B")))`*S__A/N[p]-(µ__A+`δ__A`)*I__A
`#mrow(mi("ϕ",fontstyle = "normal"),mo("⋅"),msub(mi("α",fontstyle = "normal"),mi("B")),mo("⋅"),msub(mi("I"),mi("B")))`*S__A/N[p]-(µ__A+delta__A)*I__A
Download CBD2.mw
Same question for googletagmanager.
The NoScript extension for Firefox lists the following java scripts
I do not see a degradation in performance when these scripts are disabled. So why are these scripts running?
What do they do?
It is not difficult to manually check the validity of the identity  sqrt(x+2*sqrt(x-1)) = sqrt(x-1)+1 , which is true at least for all  x>=1 . I don't know of any Maple command that directly makes this simplification:
expr:=sqrt(x+2*sqrt(x-1));
simplify(expr);
simplify(expr) assuming x>=1;
It was possible to simplify it only by making a variable substitution  x=y+1 (and then a reverse substitution  y=x-1 ) :
expr1:=subs(x=y+1,expr);
simplify(expr1);
subs(y=x-1, %);
By the way,  the CAS Mathematica also cannot cope with simplifying the expression  expr .
Wondering what the experts here think of this. Should not simplify have worked on this automatically? By trial and error, found that combine command is what simplified it the best.
But I think simplify should also have done the same.
Interested to hear what others think, and why simplify (even using trig option) did not do it.
The issue is that this is done in code, without lookin at the screen and deciding what to do based on what the expression "looks like".
`Standard Worksheet Interface, Maple 2025.0, Linux, March 24 2025 Build ID 1909157`
A:=(((sin(sqrt(3)/2)*sqrt(3) - 3*cos(sqrt(3)/2))*cos(sqrt(3)*x/2) - sin(sqrt(3)*x/2)*(sqrt(3)*cos(sqrt(3)/2) + 3*sin(sqrt(3)/2)))*exp(-1/2 + x/2))/3 ;
(1/3)*((sin((1/2)*3^(1/2))*3^(1/2)-3*cos((1/2)*3^(1/2)))*cos((1/2)*3^(1/2)*x)-sin((1/2)*3^(1/2)*x)*(3^(1/2)*cos((1/2)*3^(1/2))+3*sin((1/2)*3^(1/2))))*exp(-1/2+(1/2)*x)
B:=- exp(-1/2 + x/2)*(sqrt(3)*sin(sqrt(3)*(x - 1)/2) + 3*cos(sqrt(3)*(x - 1)/2))/3;
-(1/3)*exp(-1/2+(1/2)*x)*(3^(1/2)*sin((1/2)*3^(1/2)*(x-1))+3*cos((1/2)*3^(1/2)*(x-1)))
simplify(A-B); #show these are same
simplify(A,trig)
-(1/3)*((-sin((1/2)*3^(1/2))*3^(1/2)+3*cos((1/2)*3^(1/2)))*cos((1/2)*3^(1/2)*x)+sin((1/2)*3^(1/2)*x)*(3^(1/2)*cos((1/2)*3^(1/2))+3*sin((1/2)*3^(1/2))))*exp(-1/2+(1/2)*x)
simplify(A)
simplify(A,size)
simplify(normal(A))
combine(A); #finally
(-(1/3)*3^(1/2)*sin((1/2)*3^(1/2)*(x-1))-cos((1/2)*3^(1/2)*(x-1)))*exp(-1/2+(1/2)*x)
Download simplify_vs_combine_june_4_2025.mw
I'm working on a Maple package that manages external processes via TCP connections. I'm using ModuleUnload for cleanup, but I need to better understand how it behaves during Maple termination.
The issue:
- I have a module that manages external processes (via TCP connections)
- I implemented ModuleUnload to kill these processes when the module is unloaded
- ModuleUnload works perfectly when using 'restart'
- However, when closing the Maple window, the external processes remain active
Investigation:
Using 'lsof', I observed that:
   - When Maple closes, it properly closes its TCP connection (goes to CLOSE_WAIT state)
   - But the external processes remain active
Questions:
1. Is this the expected behavior of ModuleUnload during session termination?
2. Are there alternative approaches to ensure cleanup when Maple is closed?
Any insights or suggestions would be greatly appreciated!
I used Maple’s odetest to check the validity of 36 exact solutions.
About half of them return zero, meaning they satisfy the ODE correctly. But the other half don’t — odetest gives nonzero expressions.
My question is:
Could there be a mistake in my assumptions, or are some of these solutions only valid under specific conditions?
I’d appreciate any clarification or suggestions.
ode-test-36.mw
Respected sir,
I sincerly apologize to take your valuable time.
kind help with construction of function for the question in the word file attached.
Kind help please it may be simple too.
Kind_help.pdf
I've been debugging this for 20 hrs and finally able to make an example.
I noticed that solve() suddenly no longer works and times out.
First time calling solve() works. Second time it I see message
               Warning, solve may be ignoring assumptions on the input variables.
And it hangs.  Same exact code.   It has to do with calling odetest before and using Physics:-Setup('assumingusesAssume' = false):
i.e. this works
     odetest(...) assuming integer
     solve(....) #no hang
     odetest(....) assuming positive
But this does not work
     Physics:-Setup('assumingusesAssume' = true):
     solve(...)   #HANGS
Here is worksheet showing the problem. If I remove first call to odetest, solve do not hang.
Also removing Physics:-Setup('assumingusesAssume' = false):, solve also works OK. (ie. does not hang)
So it has to do with some internal caching which causes solve to stop working.
Can others reproduce this and can cause it and how to fix it so solve do not hang second time?
The input used below is not important. It is just what I found to cause this. One would expect solve() to work same way for same input all the time.
Also, same problem happens when using PDEtools:-Solve instead of solve. It hangs second time.
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1873 and is the same as the version installed in this computer, created 2025, May 18, 21:44 hours Pacific Time.`
SupportTools:-Version();
`The Customer Support Updates version in the MapleCloud is 20 and is the same as the version installed in this computer, created May 23, 2025, 23:34 hours Eastern Time.`
DEFINE input
ode:=y(x)*sqrt(1 + diff(y(x), x)^2) - a*y(x)*diff(y(x), x) - a*x = 0:
sol:=-_C4^2 + (-y(x)*sqrt(_C4^2/y(x)^2) + a*x)^2/a^2 + y(x)^2 = 0:
ode_to_test:=y(x)*(1+diff(y(x),x)^2)^(1/2)-a*y(x)*diff(y(x),x)-a*x = 0:
FIRST TIME solve works
    try
        timelimit(30,(odetest(sol,ode,y(x)) assuming integer));
    catch:
        NULL;
    end try:
    try
        timelimit(30,[solve(ode_to_test,diff(y(x),x))]);
        print("SOLVE worked");
    catch:
        print("WHY TIMED OUT??");
    end try:
    try
        timelimit(30, (odetest(sol,ode,y(x)) assuming positive) );
    catch:
        NULL;
    end try:
"SOLVE worked"
RUN SAME CODE AS ABOVE again, now it does not work
    try
    catch:
        NULL;
    end try:
    try
    catch:
    end try:
    try
    catch:
        NULL;
    end try:
"WHY TIMED OUT??"
Download why_solve_stops_working_maple_2025_may_28_2025.mw
This worksheet below shows that by removing Physics:-Setup('assumingusesAssume' = false): now solve works OK second time. (I turn on/off Physics:-Setup('assumingusesAssume' since I found sometimes it can help with odetest to turn it off in some other cases. But now I am scared of touching this setting as it seems to have side effects internally)
Physics:-Version();
DEFINE input
    try
    catch:
        NULL;
    end try:
    try
    catch:
    end try:
    try
    catch:
        NULL;
    end try:
"SOLVE worked"
    try
    catch:
        NULL;
    end try:
    try
    catch:
    end try:
    try
    catch:
        NULL;
    end try:
"SOLVE worked"
Download why_solve_stops_working_maple_2025_may_28_2025_V2.mw
with(Physics);
with(Vectors);
Given
Ket(i) = alpha*Ket(u) + beta*Ket(d);
Ket(o) = gamma*Ket(u) + delta*Ket(d);
and using
<o|u><u|o> =1/(2)
<o|d><d|o> =1/(2)
 <i|d><d|i> =1/(2);
 <i|u><i|o> =1/(2);
Prove that
                     "alpha^*alpha = 1/2"
and the same for the rest of the unknowns
If you could help me start using them because later I will have a lot to check.
Thank you in advance for your help.
Mario
I have just started to use Maple workbook (*.maple). In the workbook, there are 4 worksheets: "main.mw","calc1.mw","calc2.mw","calc3.mw". In "main.mw", I plot variables saved from "calc?.mw". This works. However, when I make changes in one of the worksheet "calc?.mw" and get the new expressions for the variables, they are not updated in "main.mw". I deleted the variables being changed but "main.mw" still run and show the old expressions of these variables.
How do I refresh so that "main.mw" will show the updated variables from "calc?.mw"?
I get error when solving Riccati equation. I want to get six different solution.
ricatti_equation.mw
thank you for your help
First 10 11 12 13 14 15 16 Last Page 12 of 371
