Can you please explain which optimization package is better from your experience
1 maple
2 matlab
3. mathematica
4. gams studio
5. gurobi
or any other
I am reading a paper which has some useful two-dimensional Fourier transforms in the appendix: for example,
Fourier transform of 1/r = (1/k)*e^(-kz),
where r = sqrt(x^2 + y^2 + z^2) and k =  sqrt(k_1^2 + k_2^2).
My guess is that the author has computed these by taking contour integrals in the upper half-plane and I would like to compute some of these myself but I have many of them to compute and was wondering if it could be done with Maple instead.
For example, could I use Maple to verify that the above 2D Fourier transform is correct and that the inverse 2D Fourier transform takes you back to the original (or almost takes you back).  After that I would then like to feed in the functions which I have to get Fourer and inverse Fourier transforms.
combine(2^n*4, icombine);
2^(2+n)
combine(2^n*4);
4*2^n
combine(2^n/4, icombine); # BUG
Error, (in compat) invalid input: igcd received undefined, which is not valid for its 2nd argument
combine(2^n/4);
(1/4)*2^n
combine(2^n/2^m, icombine); # BUG
combine(2^n*2^(-m), icombine);
2^(n-m)
combine(2^n/2^m);
2^(n-m)
is(2^n/4 = 2^(n-2)); # ???
false
Download bug-icombine-is.mw
Hi everyone, I'm having issues using Maple through the command line (I have reasons to be avoiding the GUI, namely I am trying to use Maple in a development environment that integrates other programs, e.g. Mathematica into the mix. This forces me to only be able to access Maple via the command line).
Here is my issue: for some functions, like diff(), which differentiates functions, Maple evaluates the function on the input:
> f:=x+2;
                    f := x + 2
> g := diff(f, x);
                      g := 1
For other functions though, such as SPolynomial() (from the Ore_algebra library), command-line Maple is lazy and just spits back the input:
> with(Ore_algebra)
> A:=diff_algebra([D1, x1], [D2, x2]);
A := diff_algebra([D1, x1], [D2, x2])
> T:=MonomialOrder(A, grlex(D1, D2));
T := MonomialOrder(diff_algebra([D1, x1], [D2, x2]), grlex(D1, D2))
> L1:=D1;
                     L1 := D1
> L2:=D2;
                     L2 := D2
> L:=SPolynomial(L1, L2, T);
L := SPolynomial(D1, D2, MonomialOrder(diff_algebra([D1, x1], [D2, x2]), grlex(D1, D2)))
Let me know if you get the same error as well! The correct output (outputted by the worksheet version of Maple) should be:
L := 0
This is a question more or less related to this one Is it possible to define variables with unusual na... but I think it's better to open a new thread. If some think otherwise, please feel free to displace it to the link above.
I want to relabel the vertices of a graph by using special characters.
It happens that this works perfectly if I do not impose the style of the drawing but that it doesn't if I set, for instance, spring=style.
In the attached file you will see that the subsitution of the old vertex names by the new ones doesn't work if apply it directly on the many operators of the PLOT command contains.
Is this behaviour fixed in more recent versions of Maple or it's still present?
Strange-Behaviour-with-SpringStyle.mw
Hi! I have been trying to calculate the value of theClenshaw derivative. I can get the regular clenshaw to work but not the derivative. I'm going off of the thread (https://scicomp.stackexchange.com/questions/27865/clenshaw-type-recurrence-for-derivative-of-chebyshev-series). (P.s notice I have halfed the A[z+1] term. I have tried both ways but the overall result is wrong so I am guessing something more important is wrong).
This is my code so far
Clenshaw_Dx_1D:=proc(z,C,Nm,s)
local i,k,A,B: global Clen1D_Dx:
A := Vector(z..Nm+1+z);
B := Vector(z..Nm+1+z);
for k from Nm-1+z by -1 to 1+z do
A[k] := C[k] + 2*s*A[k+1] - A[k+2]:
B[k] := 2*A[k+1] + 2*s*B[k+1] - B[k+2]:
Clen1D_Dx :=  A[z+1]/2 + s*B[1+z] - B[2+z]:
end:
Where z could be 0 or 1 depending on what index your C array starts at. C is the array of chebyshev coefficients of a Chebyshev series appromating u(x) for example. The Chebycoeff1D procedure calculates the Chebyshev coefficients  and the code below calls the procedure for a specific function. Try it with some values of xM, for example 4-10.
Chebycoeff1D:=proc(express,Nn,C2,A,B)
local Cfac,fac1x,fac2x,k,K;
fac1x:=Pi/Nn;
  for k from 1 to Nn do
  Cfac(k):=eval(subs(x=evalf(cos(fac1x*(k-0.5)))*A+B,evalf(express)));
  od; unassign('k'):
  for K from 1 to Nn do
    fac2x:=Pi*(K-1)/Nn;
    C2[K-1]:=(2/Nn)*add(Cfac(k)*evalf(cos(fac2x*(k-0.5))),k=1..Nn);
end:
nn := 1.0:
Lc := 0.0: Rc := 1.0:
func:=nn*sin(2*Pi*x)+0.5*nn*sin(Pi*x):
Chebycoeff1D(func,xM+1,C,0.5*(Rc-Lc),0.5*(Rc+Lc)):
Once you have the C array call Clenshaw_Dx_1D. For example
Clenshaw_Dx_1D(0,C,xM+1,0.0);  # Evalutes f'(x) in the middle of the domain.
Check with
subs(x=0.5, diff(func,x));
The overall "pattern/shape" of the derivative values is correct, just not the amplitude/values. Any help here? Where is the Clenshaw derivative procedure going wrong.
The Library:-RedefineTensorComponent in the physics package has got some serious problems, I guess in the update. It is not assigning the components at the right location for a tensor of rank 4 and above. It is working for tensors of rank 1, 2 and 3. Can someone please look into the issue and help out?
I am attaching the code with an example to indiacate the problem. Redefine.mw
Hi there!
Sorry to ask, but I don't know how I can solve it in a smart way. I want to take the covariant derivative of a specific vector, whose components are specifically defined, which can be constant or some functions of the coordinates. But, as soon as I define that specific vector, the covariant derivative fails to compute, saying there are "too many levels of recursion". Let me show what I mean.
I have these two attempts to get this:
First attempt
with(Physics)
Setup(mathematicalnotation = true)
Coordinates(X = spherical)
{X}
(1.1)
Parameters(k)
{k}
(1.2)
Setup(metric = {(1, 1) = a(t)^2/(-k*r^2+1), (2, 2) = (a(t)*r)^2, (3, 3) = (a(t)*r*sin(theta))^2, (4, 4) = -1})
[metric = {(1, 1) = a(t)^2/(-k*r^2+1), (2, 2) = a(t)^2*r^2, (3, 3) = a(t)^2*r^2*sin(theta)^2, (4, 4) = -1}]
(1.3)
Define(b[mu])
{Physics:-D_[mu], Physics:-Dgamma[mu], Physics:-Psigma[mu], Physics:-Ricci[mu, nu], Physics:-Riemann[mu, nu, alpha, beta], Physics:-Weyl[mu, nu, alpha, beta], b[mu], Physics:-d_[mu], Physics:-g_[mu, nu], Physics:-Christoffel[mu, nu, alpha], Physics:-Einstein[mu, nu], Physics:-LeviCivita[alpha, beta, mu, nu], Physics:-SpaceTimeVector[mu](X)}
(1.4)
Define(Db[nu, mu] = D_[nu](b[mu](X)))NULL
{Physics:-D_[mu], Db[nu, mu], Physics:-Dgamma[mu], Physics:-Psigma[mu], Physics:-Ricci[mu, nu], Physics:-Riemann[mu, nu, alpha, beta], Physics:-Weyl[mu, nu, alpha, beta], b[mu], Physics:-d_[mu], Physics:-g_[mu, nu], Physics:-Christoffel[mu, nu, alpha], Physics:-Einstein[mu, nu], Physics:-LeviCivita[alpha, beta, mu, nu], Physics:-SpaceTimeVector[mu](X)}
(1.5)
Define(b[mu] = [0, 0, 0, beta], redo)
(1.6)
Db[]
Db[mu, nu] = Matrix(%id = 18446746372997772822)
(1.7)
beta := proc (X) options operator, arrow; b0 end proc``
(1.8)
(1.9)
Db[]
Error, (in index/PhysicsTensor) too many levels of recursion
Second attempt
with(Physics)
{X}
(2.1)
Parameters(beta, k)
{beta, k}
(2.2)
(2.3)
Define(b[mu])
(2.4)
Define(Db[nu, mu] = D_[nu](b[mu](X)))``
(2.5)
(2.6)
Db[]
On my first attempt, expression (1.7) is almost fine, but β is supposed to be constant (and a function of "t" in the future), so I set it as a constant function. But then it causes that problem. Therefore, on my second attempt, I tried to set β as a parameter since the beginning, but it was no good either.
If I were to take the covariant derivative as "D_[nu](b[mu])" (without the "(X)"), it would not have that specific problem, but would not be a good solution, since the covariant derivative would discard the partial derivative of b[mu] and, if it would have some dependence on the coordinates, it would give a wrong result.
The only way it seems to work is by defining the tensor "Db[mu,nu]" explicitly as "d_[mu](b[nu](X)) - Christoffel[~alpha, mu, nu]*b[alpha]". (It seems that the problem comes from that "(X)" next to "b[alpha]" in the connection term.) But that would be an awful way to circumvent the problem. Isn't there any better way to get this?
Can someone help me with this, please?
Thanks for any help!
Download Cov._derivative_of_a_specific_vector.mw
How can add a PNG within a text section of a Maple Worksheet without having the image appear with a black background?
Does Maple have an alpha channel or transparency setting that must be toggled for this to work?
Maple 2019
macOS 10.14.6
I am added pictures from the clipboard via drag+drop.
(Yes, I know that I can use JPEG without this problem and that is NOT my question).
JJW
Hello Everyone,
I am new to Maple and I have designed an algorithm to compute multivariate differential dimension Grobner bases. Now I want to add this Maple as a package but I do not how to do that.
Can someone please help with this.
Thank you so much for your help.
My code can be found at https://github.com/Gsparsh/Grobner-bases
Hi everyone, I have a problem in the code solving coupled partial differential equations. I could not find out the solution. Please help me out with this. Find the code in the attachment.
Dear maple users,
Greetings.
I am solving an ode problem with an analytical solution.
programming running properly, but my plot not exact with the already existing article plot.
how to get the exact plot.
Thanking you.
Code:JVB.mw
N := 3;
dsolve(diff(f(x), `$`(x, 3)));
f(x) = (1/2)*_C1*x^2+_C2*x+_C3
Rf := 2*(diff(f[m-1](x), x, x, x))-(2*mh*mh)*(diff(f[m-1](x), x))+sum(f[m-1-n](x)*(diff(f[n](x), x)), n = 0 .. m-1)-bet*(sum(sum(2*f[m-1-n](x)*(diff(f[n-t](x), x))*(diff(f[t](x), x, x))+f[m-1-n](x)*f[n-t](x)*(diff(f[t](x), x, x, x))+x*(diff(f[m-1-n](x), x))*(diff(f[n-t](x), x))*(diff(f[t](x), x, x)), t = 0 .. n), n = 0 .. m-1));
2*(diff(diff(diff(f[m-1](x), x), x), x))-2*(diff(f[m-1](x), x))+sum(f[m-1-n](x)*(diff(f[n](x), x)), n = 0 .. m-1)-.2*(sum(sum(2*f[m-1-n](x)*(diff(f[n-t](x), x))*(diff(diff(f[t](x), x), x))+f[m-1-n](x)*f[n-t](x)*(diff(diff(diff(f[t](x), x), x), x))+x*(diff(f[m-1-n](x), x))*(diff(f[n-t](x), x))*(diff(diff(f[t](x), x), x)), t = 0 .. n), n = 0 .. m-1))
dsolve(diff(f[m](x), x, x, x)-CHI[m]*(diff(f[m-1](x), x, x, x)) = h*H*Rf, f[m](x));
f[m](x) = Int(Int(Int(CHI[m]*(diff(diff(diff(f[m-1](x), x), x), x))+2*h*(diff(diff(diff(f[m-1](x), x), x), x))-2*h*(diff(f[m-1](x), x))+h*(sum(f[m-1-n](x)*(diff(f[n](x), x)), n = 0 .. m-1))-(1/5)*h*(sum(sum(2*f[m-1-n](x)*(diff(f[n-t](x), x))*(diff(diff(f[t](x), x), x))+f[m-1-n](x)*f[n-t](x)*(diff(diff(diff(f[t](x), x), x), x))+x*(diff(f[m-1-n](x), x))*(diff(f[n-t](x), x))*(diff(diff(f[t](x), x), x)), t = 0 .. n), n = 0 .. m-1)), x), x)+_C1*x, x)+_C2*x+_C3
f[0](x) := 1-exp(x);
1-exp(x)
for m to N do CHI[m] := `if`(m > 1, 1, 0); f[m](x) := int(int(int(2*CHI[m]*(diff(f[m-1](x), x, x, x))-(2*h*H*mh*mh)*(diff(f[m-1](x), x))+h*H*(sum(f[m-1-n](x)*(diff(f[n](x), x)), n = 0 .. m-1)), x)-h*H*(sum(sum(2*f[m-1-n](x)*(diff(f[n-t](x), x))*(diff(f[t](x), x, x))+f[m-1-n](x)*f[n-t](x)*(diff(f[t](x), x, x, x))+x*(diff(f[m-1-n](x), x))*(diff(f[n-t](x), x))*(diff(f[t](x), x, x)), t = 0 .. n), n = 0 .. m-1))*bet, x)+_C1*x, x)+_C2*x+_C3; s1 := evalf(subs(x = 0, f[m](x))) = 0; s2 := evalf(subs(x = 0, diff(f[m](x), x))) = 0; s3 := evalf(subs(x = 1, f[m](x))) = 0; s := {s1, s2, s3}; f[m](x) := simplify(subs(solve(s, {_C1, _C2, _C3}), f[m](x))) end do:
f(x) := sum(f[l](x), l = 0 .. N);
1-0.7644444444e-1*exp(5.*x)*h^2*x-0.1333333333e-1*x^2*exp(5.*x)*h^2-2.675700596*exp(2.*x)*h^2*x-0.5876096022e-1*exp(6.*x)*h^3*x-0.9282030175e-2*x^2*exp(6.*x)*h^3+.9962792493*exp(3.*x)*h^3*x+.1647896790*exp(5.*x)*h^3*x+0.2066962962e-1*x^2*exp(5.*x)*h^3+3.357118680*exp(2.*x)*h^3*x-.3264340965*exp(4.*x)*h^3*x+0.3999999998e-1*exp(2.*x)*ln(exp(x))*h^2+58.61348006*h^3+1.023148148*h^2*x^3+0.1364197531e-1*ln(exp(x))*h^3*x^3-0.8954734530e-1*exp(2.*x)*h^3*x^4-.1353159884*x^3*exp(4.*x)*h^3+.7542645986*exp(3.*x)*h^3*x^2-0.2830138323e-1*x^3*h^3*exp(3.*x)-0.6455420536e-1*exp(x)*h^3*ln(exp(x))*x+0.4775858416e-1*exp(x)*h^3*ln(exp(x))*x^2+0.8888888887e-3*exp(x)*h^3*ln(exp(x))^2+8.400000000*h*exp(x)-exp(x)-0.6666666666e-1*h*ln(exp(x))+.1416666666*exp(4.*x)*h^2*x-.4790123458*exp(3.*x)*h^2*x+.1333333333*exp(3.*x)*h*x+.3791666665*exp(4.*x)*h^2-1.340020575*exp(3.*x)*h^2+.3111111109*exp(3.*x)*h+5.570191338*h^2*exp(2.*x)-.4500000000*h*exp(2.*x)-0.9874869443e-1*exp(6.*x)*h^3+.4125877323*exp(3.*x)*h^3-4.984787877*h^3*exp(2.*x)-.8010958741*exp(4.*x)*h^3+.3215641638*exp(5.*x)*h^3-5.930474628*h^2*x+36.04284024*exp(x)*h^3*x+8.324321524*x^2*h^2-.5362260993*h^3*x^3-6.207072379*exp(x)*x^2*h^3+1.664189246*exp(x)*h^3*x^3-8.237962963*h+.1200000000*exp(x)*h^2*ln(exp(x))+0.2222222222e-1*exp(3*x)*h*x+24.00299428*h^3*x-2.098561083*x^2*h^3-53.48457977*h^3*exp(x)+0.9949705035e-2*ln(exp(x))*h^3*x^4-0.7308641971e-2*ln(exp(x))*exp(4.*x)*h^3+0.8984910834e-2*ln(exp(x))*exp(3.*x)*h^3-0.3741666666e-1*ln(exp(x))*h^3*exp(2.*x)-.1188740741*exp(5.*x)*h^2-12.53662834*x^2*h+25.90916526*h^2*exp(x)-30.39962862*h^2-0.7499999999e-1*h*exp(2*x)+0.5185185185e-1*exp(3*x)*h+5.372840718*exp(x)*x^2*h^2-25.09181716*exp(x)*h^2*x+0.8976305409e-1*h^3*x^5+0.2158026099e-1*exp(7.*x)*h^3+0.8606919260e-1*h^3*x^4+0.5079365079e-3*x^3*exp(7.*x)*h^3-.3215468487*x^2*exp(4.*x)*h^3+0.1762236380e-1*exp(7.*x)*h^3*x+0.5048727639e-2*exp(7.*x)*x^2*h^3-3.116709690*exp(2.*x)*x^2*h^3+.1066289908*exp(2.*x)*h^3*x^3-8.527777777*h*x-0.2814814814e-2*ln(exp(x))*exp(4.*x)*h^3*x-0.1053497943e-2*ln(exp(x))*exp(3.*x)*h^3*x+0.4848332783e-1*h^3*x^6+.7462278773*h^2*x^4+.5519508187*exp(x)*h^3*x^4+0.9367631194e-1*exp(x)*h^3*ln(exp(x))+3.581893812*exp(2.*x)*x^2*h^2
Download JVB.mw
Analytical solution approach:
Explore the values of km_digit(n,m) using km_ for all m,0 < or equal to m and less than or equal to 8.
Look at the output until you can make a conjecture that concerns the pattern obtained.
Hint use km_list(m,6,20) when m is not a multiple of 4 and km_list(m,6,50) when m is a multiple of 4
I am studying the motion of a beam coupled to piezoelectric strips. This continuous system is modelled by two DE:
YI*diff(w(x,t), x$4)-N[0]*cos(2*omega*t)*diff(w(x,t), x$2)+c*diff(w(x,t), t)+`&rho;A`*diff(w(x,t), t$2)+C[em,m]*v(t) = 0;
And:
C[p]*diff(v(t), t)+1/R[l]*v(t) = C[em,e]*(D[1,2](w)(0,t)-D[1,2](w)(ell,t));
where "w(x,t)" stands for the beam's vibration and "v(t)" means the electric voltage, which is constant throught the beam. I would like to numerically solve both DE simultaneosly, but maple will not let me do it. I would like to know why. I am getting the following error:
Error, (in pdsolve/numeric/process_PDEs) number of dependent variables and number of PDE must be the same
I suppose it is because "w(x,t)" depends on "x" and "t", while "v(t)" depends solely on time, but I am not sure. Could someone help me out? Here is my current code:
with(PDEtools):
declare(w(x,t), v(t)):
pde1:= subs([YI = 1e4, N[0] = 5e3, c = 300, omega = 3.2233993, C[em,m] = 1], %):
ibc1:= w(0,t) = 0, D[1,1](w)(0,t) = 0, w(ell,t) = 0, D[1,1](w)(ell,t) = 0, D[2](w)(x,0) = 0, w(x,0) = sin(Pi*x/ell):
pde2:= subs([C[p] = 10, R[l] = 1000, C[em,e] = 1, ell = 5], %):
ibc2:= v(0) = 0:
pdsolve({pde1, pde2}, {ibc1, ibc2}, numeric);
Hello everyone!
I'm interesting in "zcoloring" funciton in colorscheme option.
I wrote simple programm which compares two results: spectrogram of signal drawn with "colormap" list and spectrogram which was plotted with zcoloring function. I use red, green, blue functions to construct JET-colormap: list and expressions in "zcoloring".
My result:
As I understand, when I use:
colorscheme = ["zcoloring", [z-> Red color function(z), z-> Green color function(z), z-> Blue color function(z)], colorspace = "RGB"]
Maple plots z-value with color RGB color coordinates defined from "zcoloring". For example, if "zcoloring" is
colorscheme = ["zcoloring", [z-> 5*z, z-> 3*z, z-> 2*z], colorspace = "RGB"]
and z value is 10, then 10 value will correspond [50,30,20]-RGB color.
My test program:
Spectrogram_zcoloring.mw
Spectrogram of my test signal:
list_test.txt
First 117 118 119 120 121 122 123 Last Page 119 of 371
