Hello everybody,
While i was trying to work on a physical math problem, a system of 4 integral equations is obtained. The right hand sides of these equations are known functions of r. The left hand sides contain double integrals with respect to lambda and t. i believe that an analytical determination of the 4 unknown functions f_1(t), f_2(t), f_3(t), and f_4(t) is far from being trivial, thus recourse to a numerical technique is necessary and indispensable.
i tried to express the unknown functions as series expansions in t and solve the resulting linear system of equations for the expansion coefficients, but unfortunately the coefficients are very large and the solution is strongly dependent on the number of coefficients. i was wondering whether someone here has some experience with such integral problems and is willing to assist and help. Any hint is highly appreciated.
i attach a Maple script including the equations.
Thank you,
>>>>>> Question.mw
I am trying to use Maple to solve a set of 5 equations, but cannot get a solution. Or there is no solution??
Any help? (Yes, the L function is a likelihood function and I am doing MLE for 5 variables..)
h := 4
4
k := Matrix(3, 4, {(1, 1) = 11.0, (1, 2) = 7.0, (1, 3) = 7.0, (1, 4) = 11.0, (2, 1) = 5.0, (2, 2) = 7.0, (2, 3) = 12.0, (2, 4) = 12.0, (3, 1) = 1., (3, 2) = 9.0, (3, 3) = 7.0, (3, 4) = 19.0})
Matrix(%id = 18446746279852723246)
A := Vector[row](3, {(1) = 6.0, (2) = 13.0, (3) = 18.0})
Vector[row](%id = 18446746279852713854)
B := Vector[row](3, {(1) = 3.0, (2) = 4.0, (3) = 4.0})
Vector[row](%id = 18446746279852763126)
"l(N1,M1,lambda,phi,r):=product((phi*(N1-'B[i]'+r*'A[i]'))^('k[i][1]')*(1/(2)*lambda*(M1-'A[i]'))^('k[i][2]'+'k[i][3]')*(1-phi*(N1-'B[i]'+r*'A[i]')-lambda*(M1-'A[i]'))^('k[i][4]')   ,i=1..(h-1))"
proc (N1, M1, lambda, phi, r) options operator, arrow, function_assign; product((phi*(N1-'B[i]'+r*'A[i]'))^'k[i][1]'*((1/2)*lambda*(M1-'A[i]'))^('k[i][2]'+'k[i][3]')*(1-phi*(N1-'B[i]'+r*'A[i]')-lambda*(M1-'A[i]'))^'k[i][4]', i = 1 .. h-1) end proc
fsolve({diff(ln(l(N1, M1, lambda, phi, r)), M1) = 0, diff(ln(l(N1, M1, lambda, phi, r)), N1) = 0, diff(ln(l(N1, M1, lambda, phi, r)), lambda) = 0, diff(ln(l(N1, M1, lambda, phi, r)), phi) = 0, diff(ln(l(N1, M1, lambda, phi, r)), r) = 0}, {M1, N1, lambda, phi, r}, N1 = 0 .. infinity, M1 = 0 .. infinity, lambda = 0 .. 1, phi = 0 .. 1, r = 0 .. 1)
Download PlayGround.mw
I would like to find a fixed point of f^4 in tems of a and b. I define function as
I calculate f(f(f(f(x,y))))  and Iet f(f(f(f(x,y)))) = (x,y), then use the solve command as:
solve({b^4*(a*(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)-(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)^2-(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)*b^2*(a*x-x^2-x*y)*x*y)*(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)*(a*x-x^2-x*y)*x*y = y, a*(a*(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)-(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)^2-(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)*b^2*(a*x-x^2-x*y)*x*y)-(a*(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)-(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)^2-(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)*b^2*(a*x-x^2-x*y)*x*y)^2-(a*(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)-(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)^2-(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)*b^2*(a*x-x^2-x*y)*x*y)*b^3*(a*(a*x-x^2-x*y)-(a*x-x^2-x*y)^2-(a*x-x^2-x*y)*b*x*y)*(a*x-x^2-x*y)*x*y = x}, {x, y})
My computer was freezing. How can I get my result. Thank you
Hi guys,
I have tried to create a loop to solve a set of two equations, but can't seem to get it working. My initial equations are given by;
nstar := (F, L, sigma) -> ceil((ln(k*F) - ln(c(L, sigma)*B))/ln(Phi(L, sigma)))
i := (F, L, sigma) -> r*(1 - (G(L, sigma)*Phi(L, sigma))^nstar(F, L, sigma)*B/F)/(1 - G(L, sigma)^nstar(F, L, sigma))
in which both are based on further rather simple equations. To these I am trying to apply the proc function where I am trying to find which i makes borth the equations above work :
i := proc(F,L,sigma)
local k :=0.01 ;
local eps := 0.01 ;
do while(eps>0.001)
nstar:= (6)
i := (7)
eps:= i -k:
k=i:
k;
Error, Got internal error in Typesetting:-Parse : "'_Inert_DELAYLESSTHAN' is not a valid inert form"
But as you see I am here getting a error which I have not managed to fix. Can anyone see where I might have gone wrong? Could this be done by solve or fsolve? If yes, then how (have tried it as well without succeding)?
help me!
I have a problem with the system, looking forward to everyone's help!
Hello!
How can I make MAPLE to create the solution of the following system?
https://math.stackexchange.com/questions/301068/how-do-you-find-a-corresponding-recurrence-relation-for-some-random-algorithm/301709
according to this link, how to parse or walk through the algorithm in maple to generate recurrence relation formula?
I have a differential equation involving several functions of the following form:
diff(h,z) = iAf + iBg,
where h, f and g are functions of the Cartesian coordinates x, y and R and the third coordinate corresponds to z = R for some fixed constant value R.  The derivative is then with respect to the coordinate z and A and B are constants, with i the usual imaginary unit.  Is there some way this equation could be solved explicitly with Maple?
Basically it spits out the subset of values for which a division by zero error will occur for the function you specify on  range you specify for each of it's arguments, but I get an ambigous error when ever exponentiation features in the function I specify, which of course dramatically reduces the application of the calculator. Division,addition,substraction and multiplication are currently the only available arithmetic operators availble for the function window that I know the error will not occur.
If some one can help it is much appriciated
DIVISION_BY_ZERO_CALCULATOR.mw
hello everyone,
   INGT.mw
L__d := 100:
L__b := 200:
L__c := L__d+(1/2)*L__b;
200
X := .3;
.3
Error, (in plot) procedure expected, as range contains no plotting variable
`ΔE__g` := 1.155*X+.37*X^2;
.3798
V__0 := .6*`ΔE__g`;
.22788
m__D := 0.67e-1*m[e];
0.67e-1*m[e]
m__B := (0.67e-1+0.83e-1*X)*m[e];
0.919e-1*m[e]
Sol := solve(2*cos(L__d*sqrt(E__x))+(m__D*sqrt((V__0-E__x)/E__x)/m__B-m__B*sqrt(E__x/(V__0-E__x))/m__D)*sin(L__d*sqrt(E__x))-(m__D*sqrt((V__0-E__x)/E__x)/m__B+m__B*sqrt(E__x/(V__0-E__x))/m__D)*sin(L__d*sqrt(E__x))*exp(-sqrt(V__0-E__x)*L__b) = 0, E__x);
0.1110897170e-2, 0.3531161505e-2, -.2585338615+0.9991335677e-27*I
E__1 := 0.1110897170e-2:
K__1 := sqrt(E__1);
0.3333012406e-1
K__2 := sqrt(V__0-E__1);
.4762027959
C := cosh((1/2)*K__2*L__b);
0.2399908351e21
beta := m__D*K__2/(m__B*K__1);
10.41631973
B := -beta*sinh((1/2)*K__2*L__b);
-0.2499821271e22
A := -B*sin(K__1*L__d)+C*cos(K__1*L__d);
-0.7112056933e21
h := proc (x) options operator, arrow; piecewise(x <= -L__c, A*exp(K__2*(x+L__c)), -L__c < x and x < -(1/2)*L__b, -B*sin(K__1*(x+(1/2)*L__b))+C*cos(K__1*(x+(1/2)*L__b)), abs(x) <= (1/2)*L__b, (1/2)*exp(K__2*x)+(1/2)*exp(-K__2*x), (1/2)*L__b < x and x < L__c, -B*sin(K__1*(x-(1/2)*L__b))+C*cos(K__1*(x-(1/2)*L__b)), L__c <= x, A*exp(K__2*(x-L__c))) end proc:
'h(x)' = h(x);
h(x) = piecewise(x <= -200, -7.112056933*10^20*exp(95.24055918+.4762027959*x), -200 < x and x < -100, 2.499821271*10^21*sin(3.333012406+0.3333012406e-1*x)+2.399908351*10^20*cos(3.333012406+0.3333012406e-1*x), abs(x) <= 100, (1/2)*exp(.4762027959*x)+(1/2)*exp(-.4762027959*x), 100 < x and x < 200, 2.499821271*10^21*sin(0.3333012406e-1*x-3.333012406)+2.399908351*10^20*cos(0.3333012406e-1*x-3.333012406), 200 <= x, -7.112056933*10^20*exp(-95.24055918+.4762027959*x))
(15)
L__y := 200:
L__z := 200:
P := proc (x, y, z) options operator, arrow; h(x)*cos(Pi*y/L__y)*cos(Pi*z/L__z) end proc:
'Psi(x, y, z)' = P(x, y, z);
Psi(x, y, z) = piecewise(x <= -200, -7.112056933*10^20*exp(95.24055918+.4762027959*x), -200 < x and x < -100, 2.499821271*10^21*sin(3.333012406+0.3333012406e-1*x)+2.399908351*10^20*cos(3.333012406+0.3333012406e-1*x), abs(x) <= 100, (1/2)*exp(.4762027959*x)+(1/2)*exp(-.4762027959*x), 100 < x and x < 200, 2.499821271*10^21*sin(0.3333012406e-1*x-3.333012406)+2.399908351*10^20*cos(0.3333012406e-1*x-3.333012406), 200 <= x, -7.112056933*10^20*exp(-95.24055918+.4762027959*x))*cos((1/200)*Pi*y)*cos((1/200)*Pi*z)
(16)
INGT := proc (x__i) `assuming`([evalf(int(int(int(P(x, y, z)^2*exp(-lambda*sqrt((x-x__i)^2+y^2+z^2)), x = -infinity .. infinity), y = -L__y .. L__y), z = -L__z .. L__z))], [0 < lambda]) end proc
evalf(INGT(2))
Warning,  computation interrupted
Download INGT.mw
L__d := 100:
L__b := 200:
200
X := .3;
.3
`&Delta;E__g` := 1.155*X+.37*X^2;
.3798
V__0 := .6*`&Delta;E__g`;
.22788
0.67e-1*m[e]
0.919e-1*m[e]
K__1 := sqrt(E__1);
0.3333012406e-1
.4762027959
0.2399908351e21
10.41631973
-0.2499821271e22
-0.7112056933e21
'h(x)' = h(x);
(15)
L__y := 200:
L__z := 200:
(16)
evalf(INGT(2))
Download INGT.mw
I'm trying to calculate a triple integral complicated by a procedure that changes each time a variable xi, while the program takes a lot of time and it gives me the message "Warning, computation interrupted". If anyone can help me I will be very happy
Is there something I should be doing whenever I use simplify to avoid things like this, or should I stop using the "is" function all together?
interface(showassumed = 0):
sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1)
(n-k+1)*binomial(n+1, k)/(k+1) = binomial(n+1, k+1)
#And we have:
is(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1))
FAIL
#And since:
is(simplify(convert(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1), 'factorial')))
is(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1)) = is(simplify(convert(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1), 'factorial')))
Download main.mw
Hello people :)
As the captian says, im trying to remove an old task i've made.
But i get this:
Error in Get, invalid object [_XML_reply_data_get("reference" =
"_Maplets_reference_12","parameter" =
"value",_XML_content("Task,UserTasks,Nyops",&Entity "#xc3",&Enity
"#xa6","tning"))]
And i have no idea what it is, but it won't erase my task :'D
Thanks a bunch in advance!
Have a great weekend you all
Best regards Lucas :)
I was wondering someone could help me with something.
Basically I've got a function of f(x,z) that I have plotted which comes from an integration that was taken over a large number of small steps. I have been able to plot this function to determine a Potential Field as a function of x and z. (No Problems so far)
However the next step that I want to be able to do is compute a field form this potential. apologies for my lack of knowing how to input into here as I am fairly new to this. To do this I have:
Field = - Nabla * Potential
Again no problem, I can plot a gradient field from it which is great using the gradplot command. I beleive this comes as a result of the following:
gradplot = [diff(f,x), diff(f,z)]
HOWEVER I want to be able to plot a Field Strength plot (In essence a Gradient Field Strength) where it takes the magnitude of the vectors at each point. Firstly am I correct in saying that this should be:
Magnitude Field = |F| = sqrt( Fx^2+Fz^2)      where Fx is diff(f,x) and Fz is diff(f,z)
However when I try to compute this, it takes an age to evaluate and doesn't seem to make much progress. I think this may come as a result of computing square roots of large numbers/large decimal places? I was wondering whether there is any command that anyones knows of that would calculate Gradient Field Strength/Magnitude that may solve this issue? Or even who to just compute this Square root?
A few seconds after calling up Help starts zucking araound and the whole computer then freezes. Ctrl-Alt-Delete doesn't work, hard reset required. Very funny. Am I alone?
Hi good afternoon , im looking for maple code of HPM to solve time dependent diffusion reaction , can anybody help me . I didnt get how to solve it by maple .
First 119 120 121 122 123 124 125 Last Page 121 of 371
