Dear Users!
Hoped everyone fine here. I have three main questions regarding the maple code given bellow:
restart; with(LinearAlgebra); with(plots);
alpha := 1; beta := 1; theta := 1/2;
UU := sinh(x)*sinh(y)*sinh(z)*exp(-1.*t);
NN := 3; L := 0; R := 1; T := 1; N := NN; Mx := NN; My := NN; Mz := NN; `Δx` := (R-L)/Mx; `Δy` := (R-L)/My; `Δz` := (R-L)/Mz; `Δt` := (R-L)/N;
kappa[1] := 1; kappa[2] := 2/x^2; kappa[3] := 1/x^2; kappa[X] := x^2+y^2+z^2+1; kappa[Y] := x^2+y^2+z^2+1; kappa[Z] := x^2+y^2+z^2+1; kappa[4] := 0; NL := 3;
ics := [seq(seq(seq([u[i, j, k, 0] = eval(UU, [x = i*`Δx`, y = j*`Δy`, z = k*`Δz`, t = 0]), u[i, j, k, -1] = eval(u[i, j, k, 1]-2*`Δt`*(eval(diff(UU, t), t = 0)), [x = i*`Δx`, y = j*`Δy`, z = k*`Δz`, t = 0])][], i = 0 .. Mx), j = 0 .. My), k = 0 .. Mz)];
bcs := [seq(seq(seq([u[0, j, k, n] = eval(UU, [x = 0, y = j*`Δy`, z = k*`Δz`, t = n*`Δt`]), u[Mx, j, k, n] = eval(UU, [x = L, y = j*`Δy`, z = k*`Δz`, t = n*`Δt`])][], j = 0 .. My), k = 0 .. Mz), n = 1 .. N), seq(seq(seq([u[i, 0, k, n] = eval(UU, [x = i*`Δx`, y = 0, z = k*`Δz`, t = n*`Δt`]), u[i, My, k, n] = eval(UU, [x = i*`Δx`, y = L, z = k*`Δz`, t = n*`Δt`])][], i = 1 .. Mx-1), k = 0 .. Mz), n = 1 .. N), seq(seq(seq([u[i, j, 0, n] = eval(UU, [x = i*`Δx`, y = j*`Δy`, z = 0, t = n*`Δt`]), u[i, j, Mz, n] = eval(UU, [x = i*`Δx`, y = j*`Δy`, z = L, t = n*`Δt`])][], i = 1 .. Mx-1), j = 1 .. My-1), n = 1 .. N)];
Sol := {u[1, 1, 1, 1] = 0.2366497936e-1, u[1, 1, 1, 2] = 0.7589975856e-2, u[1, 1, 1, 3] = 0.6029906475e-3, u[1, 1, 2, 1] = 0.3778786317e-1, u[1, 1, 2, 2] = 0.7126415819e-2, u[1, 1, 2, 3] = -0.1197885714e-2, u[1, 2, 1, 1] = 0.3778786315e-1, u[1, 2, 1, 2] = 0.7126415820e-2, u[1, 2, 1, 3] = -0.1197885718e-2, u[1, 2, 2, 1] = 0.6038763054e-1, u[1, 2, 2, 2] = 0.4264591907e-2, u[1, 2, 2, 3] = -0.3509477851e-2, u[2, 1, 1, 1] = 0.3171958616e-1, u[2, 1, 1, 2] = -0.1327161715e-1, u[2, 1, 1, 3] = -0.4628647419e-2, u[2, 1, 2, 1] = 0.4979852397e-1, u[2, 1, 2, 2] = -0.3060811899e-1, u[2, 1, 2, 3] = -0.344914876e-4, u[2, 2, 1, 1] = 0.4979852397e-1, u[2, 2, 1, 2] = -0.3060811898e-1, u[2, 2, 1, 3] = -0.3449150010e-4, u[2, 2, 2, 1] = 0.7882396741e-1, u[2, 2, 2, 2] = -0.6192340018e-1, u[2, 2, 2, 3] = 0.1156615222e-1}
Using set of points given in ics, bcs and Sol
1. I want to contruct a vector at any time level (by fixing fourth suffix like u[i,j,k,n]) for i = 0..Mx,j=0..My,k=0..Mz and then find its L2 and L[infinity] norms.
2. Next I want contruct a vector by fixing two suffixes like u[i,j,k,n]) for i = 0..Mx,j=0..My and plot a surface in 3D
3. Finally I want to construct a vector by fixing three suffixes like u[i,j,k,n]) for i = 0..Mx, and plot a curve in 2D.
I'm waiting for your positive respone. I shall be very thankfull to you in advance.
Special request to:
@acer @Carl Love @Kitonum @Preben Alsholm
Hi everyone, I have a mechanical problem, I solved it using hybrid method (differential transformation method for time and finite difference method for space) I need some help please.
How do i pipe maple output to the clipboard and vice versa (assigning clipboard content to a variable declared in a maple worksheet)?
  1. The member() function doesn't find the value in a table if that value is associated with the key (aka index)  '0'
  2. Doesn't seem to matter if the table is created explicitly (ie by calling table()) or implicitly (ie by simple indexed assignment)
  3. member() doesn't seem to have the same issue with a zero-based Array()
  4. I'm pretty sure that this is a bug, but I'd like some opinions before I report it
  5. This behaviour has been around for a while: same thing happens all the way back to Maple 18. (I can't check anything earlier)
Check the ouput of member(10,t1) in the attached
`Standard Worksheet Interface, Maple 2019.1, Windows 7, May 21 2019 Build ID 1399874`
# Explicit table creation: same thing
# happens if table is created "implicitly"
  t1:=table([0=10, 1=12]);
  member(10,t1);
  member(12,t1);
table( [( 0 ) = 10, ( 1 ) = 12 ] )
false
# Zero-based Array
  A:=Array(0..1, [10, 12]);
  member(10,A);
  member(12,A);
Array(%id = 18446744074528920750)
Download memberProp.mw
Recently I discovered you can get the wolfram language and Mathematica for free if you buy a Raspberry Pi.
Will there be something similar with Maple?
I'm guessing since Mathematica has secured a contract with Raspberry Pi, that would exclude competitors, ie Maple
Hi everybody
l I tried to install Maple 2018.2 on the golden master of Catalina and it didn't work : the installation process ended after the entering of the password to authorize the installation. In fact Maple 2018.2 still contains 32 bit elements. Is there a solution ? Thank you
David
Second terms coefficient = 2/3*x when (....)^2
9/16*x^2 when (...)^3
64/125*x^3 when (...)^4
625/1296*x^4
Which Bernstein has these result?
Which limit function of x^n = (n^(n-1))/((n+1)^(n-1))*x^(n-1)?
how to find and calculate?
    This is not an answer. I can't ask question, since I can't add any 'tags'! This problem appeared long time ago, but I hadn't solved it until now. So I ask here.
    I have a question about the function coeffs(). I don't know why it cann't get coefficients for me.
question.mw
Variable disappear after read file and then pass parameter to create thread
Hello people in mapleprimes,
I have a question.
I use maple2019 with mac os 10.14.6.
$ sw_vers
ProductName:	Mac OS X
ProductVersion:	10.14.6
BuildVersion:	18G95
With maple2019, errors appears.
> kernelopts(version);
        Maple 2019.1, APPLE UNIVERSAL OSX, Jun 6 2019, Build ID 1403154
> assume(a>-1,b>0);
> additionally(a<=1);
> about(a);
Originally a, renamed a~:
  is assumed to be: FAIL
> assume(tau<1,tau>0,s<1,s>0):
> a_e1:=tau*s*(1+tau)<tau*s+tau+s-1:
> b_e2:=expand(lhs(a_e1)-rhs(a_e1))<0:
>  b_e3:=collect(b_e2,s,factor):
> solve(b_e2,s) assuming tau<1;
Error, (in assuming) when calling 'property/ConvertProperty'. Received: 'FAIL
is an invalid property'
On the other hand, with maple2018, they do not.
       Maple 2018.2, APPLE UNIVERSAL OSX, Nov 16 2018, Build ID 1362973
> assume(a>-1,b>0);
> additionally(a<=1);
> about(a);
  is assumed to be: RealRange(Open(-1),1)
                               [{-------- < s~}]
                                 1 + tau~
Are errors due to some bugs in maple2019 when being used with mac os 10.14.6?
Take care.
taro
I'm working in MapleSim to model a mechanism called Schatz which has a six-Revolut, known whit TURBULA name.
I modeled the mechanism in CREO to have a CAD part to use in maplesim.
everything is okay when I run the simulation without a speed constant. as shown in the picture above.
when I add a speed source, MapleSim finds an error (Internal error occurred during the simulation).
Can someone help me please?
Hi everybody!
Quick question for you guys. I have access to Maple 2019 on my main computer and Maple 2018 on a remote Desktop (but I don't want to use because it's super slow and bad (normal rdp stuff)). The problem I have is for the same document, same line, same instruction, Maple 2019 on my computer is failling to do it correctly (unable to do the matrix correctly) and in the Remote Maple 2018 it's doing it just fine. I really don't understand. If someone can give me a little help it would be highly apreciated!
Maple 2018 (what it's supposed to do):
Maple 2019 (what it is not suppose to do):
How i convert the following mathematica code to Maple
f1[t^m_] := Gamma [m + 1] t^(m - a[t]) /Gamma[m + 1 + a[t]];
f1[t] := Gamma [2] t^(1 - a[t]) /Gamma[2 + a[t]];
f1[p_Plus] := Map[f1, p]
f1[c_*f_] := c*f1[f] /; FreeQ[c, t]
f1[c_] := 0 /; FreeQ[c, t]
f1[x^2*t^2 + t + x]
gives
t^(1 - a[t])/Gamma[2 + a[t]] + (2 t^(2 - a[t]) x^2)/Gamma[3 + a[t]]
Glyph2.maple
The above link is a maple workbook containing the package Glyph2 together with the install script and two worksheets illustrating the difficulty I am having with the code in the procedure assignaltbasis (near the end of the code in Glyph2.mpl).
The problematic code is shown standalone is basisdemo worksheet, but reproduced below for reference. Interestingly, even though the table should be evaluated in a seq command, outside the module it works without eval. Inside the module evaluation does not make any difference.
indxs := [1, 2, 3, 4];
altbasis := [seq(seq(e[i[]], i = combinat:-choose(indxs, 2*k)), k = 1 .. 2)];
gen := table([seq(op(gen[i]) = bivec[i], i = 1 .. nops(gen))]);
exprs := [seq(exteriorp(seq(gen[op(2*i - 1 .. 2*i, b)], i = 1 .. nops(b)/2)), b = altbasis)];
The worksheet Basischangedemo shows how the exported procedure “assignaltbasis” is used in the module and the error that results if a bivector basis is used. From experimentation I have found that the error results because “assignaltbasis” passes the table name to the procedure “exteriorp” instead of the bivectors that should have resulted from evaluation of the table. Including the eval command within the seq procedure does not make any difference to the result. I am unclear whether this is a problem with evaluation of the table or a problem that results from namespace conflict.
I have a further namespace problem with the local variables, AltRoot, AltToStd, and StdToAlt which store the results from assignaltbasis.  If I declare these variables as exports, I get an error message “attempt to assign to a protected variable”. Therefore I added an exported procedure “ShowAltBasis” to display the results.  As you can see, this procedure produces the fully-qualified names of each blade making the result difficult to read. I would prefer to get rid of the “Glyph2:-” qualification.
The waters are muddied even further because the other worksheet, “basisdemo”, contains the core code extracted from assignaltbasis showing that the code using the table actually works (outside the module). From this I conclude that a namespace conflict exists within the module, preventing the table from fully evaluating.
My understanding is that within the module local and exported names are more or less equivalent, so I am puzzled why local and exported names in assignaltbasis are so problematic.
I would appreciate any advice about these issues. Clearly my understanding of maple’s namespaces is incomplete.
First 122 123 124 125 126 127 128 Last Page 124 of 371
