Plot([x^2, subs(x=0, 2*x)], axis[1]=[color=white]);
can not find the y=0 this red line
how to plot y=x^2 and x = 0 on the same graph to show the slope at x=0 ?
How to derive from n*x^(n-1) to limit definition ?
I am trying to solve a simple two-equation linear system with solve, but I keep getting this weird result where the magnitude order of the numerator and denominator don't cancel out. Whenever I have a linear system with floating-point numbers, more unknowns than equations and try to solve it for a specific set of variables, this happens.
Any suggestions on how to get around this? Or do I need to solve it manually?
How to proof exp(x) is transcendental function without using calculus?
How to write this equation in maple?
g(k-r-1);
conditions:=
1.r from 0 to k,
2.g(0)=1;
3.g(n)=0, where n not equal to 0.
How to convert diff(f(t),t) + diff(g(t),t)
to diff(t(f,g), f)+ diff(t(f,g), g)
How to cmaple or mw file maple dualaxisplot output to jpeg file after press and run?
How to cmaple print int(f(x),x) after append to text command instead of /
How can I make Maple preserve old outcomes?
I can display an animated plot of the Normal distribution pdf and was wondering if anybody has a routine to animate the Normal cdf. If this is so - is it possible to generalise for any continuous statistical distribution?
Thanks for reading!
Dear Community!
I'm struggleing with a problem long since. I highly appreciate any help with this theme.
The problem is the following:
- I have a set of points, what comes from a numerical solution of a complex, but periodical function. Therefore I have a set of points (X;Y). The points are doesn't matter, but in my case, it look like this:
I want to use the Fourier-method to approximate this points with a function.
The best result I could get is this:
But it is not acceptable due to the high inaccuracy at the starting, and finishing points (there is a diagram inaccuracy %):
I'm feel like, I'm doing something wrong. Unfortunately, I had no time to look deep into the math here. Can somebody tell me, that how can I get a better result, using this method?
Thank you very much for the help in advance.
Best regards
Dávid
Hi guys,
I'm trying to apply boundary condition on the seris i generated using Adomian decomposition. Could some one please check it for me?
u[0] := a1+a2*y:
w[0] := a3+a4*y:
theta[0] := a6*y+a5
phi[0] := a8*y+a7
A[1] := R*(diff(u[0], y))+A-Gr*(B*phi[0]+theta[0])/Ree+Ha^2*(alpha*u[0]+beta*w[0])/(alpha^2+beta^2)
R*a2+A-Gr*(a5+a6*y+B*(a7+a8*y))/Ree+Ha^2*(alpha*(a1+a2*y)+beta*(a3+a4*y))/(alpha^2+beta^2)
u[1] := int(A[1], y = 0 .. y)
(1/2)*(-Gr*(a6+B*a8)/Ree+Ha^2*(alpha*a2+beta*a4)/(alpha^2+beta^2))*y^2+R*a2*y+A*y-Gr*(a5+B*a7)*y/Ree+Ha^2*(alpha*a1+beta*a3)*y/(alpha^2+beta^2)
u[11] := int(u[1], y = 0 .. y)
(1/3)*(-(1/2)*Gr*(a6+B*a8)/Ree+(1/2)*Ha^2*(alpha*a2+beta*a4)/(alpha^2+beta^2))*y^3+(1/2)*(R*a2+A-Gr*(a5+B*a7)/Ree+Ha^2*(alpha*a1+beta*a3)/(alpha^2+beta^2))*y^2
u = u[0]+u[11]
u = a1+a2*y+(1/3)*(-(1/2)*Gr*(a6+B*a8)/Ree+(1/2)*Ha^2*(alpha*a2+beta*a4)/(alpha^2+beta^2))*y^3+(1/2)*(R*a2+A-Gr*(a5+B*a7)/Ree+Ha^2*(alpha*a1+beta*a3)/(alpha^2+beta^2))*y^2
A[2] := R*(diff(w[0], y))-Ha^2*(beta*u[0]-alpha*w[0])/(alpha^2+beta^2)
R*a4-Ha^2*(beta*(a1+a2*y)-alpha*(a3+a4*y))/(alpha^2+beta^2)
w[1] := int(A[2], y = 0 .. y)
-(1/2)*Ha^2*(beta*a2-alpha*a4)*y^2/(alpha^2+beta^2)+R*a4*y-Ha^2*(beta*a1-alpha*a3)*y/(alpha^2+beta^2)
w[11] := int(w[1], y = 0 .. y)
-(1/6)*Ha^2*(beta*a2-alpha*a4)*y^3/(alpha^2+beta^2)+(1/2)*(R*a4-Ha^2*(beta*a1-alpha*a3)/(alpha^2+beta^2))*y^2
w = w[0]+w[11]
w = a3+a4*y-(1/6)*Ha^2*(beta*a2-alpha*a4)*y^3/(alpha^2+beta^2)+(1/2)*(R*a4-Ha^2*(beta*a1-alpha*a3)/(alpha^2+beta^2))*y^2
A[3] := R*Pr*(diff(theta[0], y))-2*Br*((diff(u[0], y))^2+(diff(w[0], y))^2+M^2*C*(u[0]^2+w[0]^2))-gamma*R*Pr*theta[0]
R*Pr*a6-2*Br*(a2^2+a4^2+M^2*C*((a1+a2*y)^2+(a3+a4*y)^2))-gamma*R*Pr*(a5+a6*y)
theta[1] := int(A[3], y = 0 .. y)
-(2/3)*Br*M^2*C*(a2^2+a4^2)*y^3+(1/2)*(-2*Br*M^2*C*(2*a1*a2+2*a3*a4)-gamma*R*Pr*a6)*y^2+R*Pr*a6*y-2*Br*(a2^2+a4^2+M^2*C*(a1^2+a3^2))*y-gamma*R*Pr*a5*y
theta[11] := int(theta[1], y = 0 .. y)
-(1/6)*Br*M^2*C*(a2^2+a4^2)*y^4+(1/3)*(-Br*M^2*C*(2*a1*a2+2*a3*a4)-(1/2)*gamma*R*Pr*a6)*y^3+(1/2)*(R*Pr*a6-2*Br*(a2^2+a4^2+M^2*C*(a1^2+a3^2))-gamma*R*Pr*a5)*y^2
theta = theta[0]+theta[11]
theta = a5+a6*y-(1/6)*Br*M^2*C*(a2^2+a4^2)*y^4+(1/3)*(-Br*M^2*C*(2*a1*a2+2*a3*a4)-(1/2)*gamma*R*Pr*a6)*y^3+(1/2)*(R*Pr*a6-2*Br*(a2^2+a4^2+M^2*C*(a1^2+a3^2))-gamma*R*Pr*a5)*y^2
A[4] := R*Sc*(diff(phi[0], y))-K*Sc*phi[0]
R*Sc*a8-K*Sc*(a7+a8*y)
phi[1] := int(A[4], y = 0 .. y)
-(1/2)*K*Sc*a8*y^2+R*Sc*a8*y-K*Sc*a7*y
phi[11] := int(phi[1], y = 0 .. y)
-(1/6)*K*Sc*a8*y^3+(1/2)*(R*Sc*a8-K*Sc*a7)*y^2
(15)
phi = phi[0]+phi[11]
phi = a7+a8*y-(1/6)*K*Sc*a8*y^3+(1/2)*(R*Sc*a8-K*Sc*a7)*y^2
(16)
Download second_problem.mw
Please, I really need your expertise advice(s) on what i am not doing right in the code attached below. I was actually writing the code on Multi-step DTM, but, instead of continuing from the last point, it starting all over again. Please, your expertise will save a soul here. Regard
MsDTM3.mw
I'm pretty annoyed with maple because when I try to create proc's it dooes not use tabbing or smart tabbing. This makes writing readable code a chore. Basically it's always screwing up alignment. (it wants to left justify things a lot)...
What's worse is that using the tab key takes one outside the proc rather than adding a tab, making one having to use spaces.
Any way to fix this?
How to find PARETO FRONT WITH fminsearch Command for weighted sum method In Matlab R2015a
First 123 124 125 126 127 128 129 Last Page 125 of 371
