Which sorting related with famous sequence
for example
sorting differential equation in a list
then access the list with famous sequence as index such as using https://oeis.org/
after access with sequence as index, use choose function to get combinations then most result are isomorphism differential ideals?
is there methods about this sorting in Richard Stanley Combinatiric book? which page of it?
Last month I still can read file
by
read “c://Users//hello//Documents//h.m”
but
now it return error
no read access c://Users//hello//Documents/
in security I add the m file into readable
I saw open file at c drive has many shell folders
i just add m file
but still the same error
i unencrypted m file by window properties
i save file into maple roaming directory under 12 folder , still the same error
i save into maple installation directory maple 12 , still the same error
possible to solve following equation with unknown parameter omega.
parameter constant.
I see before for one dimension ode this type equation was solved.
Now for 2d equation is possible?
can consider or I can send again.
Best
2d-2
Why am I not able to use my MaplePrimes login credentials to login into MapleCloud?
A few months ago i completely lost one of my linux operating systems in a single line of commands I entered into the terminal, and at some point I want to utilize the StringTools package with commands like  RegSubs and RegMatch to output the matching strings that match for the current command line content in a linux terminal, so I will know before I hit the enter key how stupid it was of me to do so *prior* to hitting the enter key.
The part I have no idea about is the piping of the keyboard input  for a terminal window to the maple session that will output the strings matching as previously described. I'm sorry if this question is not very clear I will try clarify more this afternoon.
I have the following PDE
                         ...(1)
My Question: I have done manually following calculations. I want to verify the following operations are right, or not by MAPLE. Could you help me, please?
The METHOD:
Suppose that
                         ...(2)
In here,  is an Nx1 matrix, P, C are NxN matrices. (N is an integer and superscript T   denotes the transpose of the matrix.)  and P are given matrices. But the matrix C is ungiven I will find it in the final step. But my question doesn' t include all steps. I just wonder how to calculate the first two steps by Maple.
( If Maple doesn' t do matrix algebra, we can treat them as if , P, C were not matrix. I think the result won' t be changed. We will get again equation 9 by Maple.)
First Step
We will find the followings
 in terms of the matrices  ,  P and C.
So, if we integrate Equation (2) with respect to x (from 0 to x), and  by using the following two assumptions
we have
   ...(3)
substituting x=1  in Equation (3)
 ...(4)
if rewrite Eqn. (4), we have
...(5)
substituting Eqn. (5) to Eqn. (3), we have
...(6)
integrating Equation (3) with respect to t,
we have
...(7)
If we integrate Equation (2) from 0 to x with respect to t, we have
...(8)
Second Step We will substitute the terms to the pde ( Equation 1)
Substituting Eqn. (6), (7), (8) to Eqn. (1), we have finally
...(9)
I want to do the above calculations by Maple.
Because I have more complex questions than above, I want to write a Maple code in order to avoid calculation errors.
Final Step for curious: it's hard to explain the whole method here. Briefly, we will discretize equation 9 for some collocation points t and x. And after doing it, we will have a system of an algebraic equation. (N equation and N unknown ( C is Nx1 unknown vector to be find) )
And then we will substitute vector C to Eqn. 7
Code for Matrices , P^1, P^2,etc.
code.mw
Best Regards...
maple does not work at all
it displays this error
Error, (in StringTools:-FormatMessage) unknown option MAPLE
Generally when I respond to questions on this site, I make sure that I tick the checkbox requesting that I get an email when updates are made to the thread.
I've just realised that I have been receiving no such updates for a week or so. Two possibilities
  1. Problem with Mapleprimes website, meaning that email updates aren't being generated/sent
  2. Problem with my ISP
Before I try investigating (2) above, I'd just like to know if anyone else has seen any issue which might be explained by (1) above
How to calculate potential function of Maxwell equations?
is there calculation examples of strong and weak force examples too?
which library can calculate intersection numbers of familes of potential function of Maxwell equations?
is there any examples?
Hi everybody:
I have the code in Maple that when run it I see this error, how can I solve this error?
tnx...
hello everyone,
please I need our help to find the eigenvalues (m) of this equation (eq)
thank you
eq.mw
Digits := 5:
eq := exp(-m*xi)*(exp((1/4)*sqrt(-m)*r*(r-1))*(1+(7/20)*sqrt(m)*r+((49/800)*m-(1/4)*sqrt(m))*r^2)*r^I+exp((1/4)*sqrt(-m)*r*(r-1))*(1+(7/20)*sqrt(m)*r+((49/800)*m-(1/4)*sqrt(m))*r^2)*r^I*cos(theta)+r^I*sin(5*theta))
exp(-m*xi)*(exp((1/4)*(-m)^(1/2)*r*(r-1))*(1+(7/20)*m^(1/2)*r+((49/800)*m-(1/4)*m^(1/2))*r^2)*r^I+exp((1/4)*(-m)^(1/2)*r*(r-1))*(1+(7/20)*m^(1/2)*r+((49/800)*m-(1/4)*m^(1/2))*r^2)*r^I*cos(theta)+r^I*sin(5*theta))
Download eq.mw
Hi all
trying to find analytically sin(erf(t)) and cos(erf (t)) rather than numerically
1/0;
Error, numeric exception: division by zero
lastexception;
            0, "numeric exception: division by zero"
lastexception; # ???
            Typesetting:-Typeset, "invalid input: %1 expects %2 arguments, but received %3", type, 2, 3
So, printing lastexception produces a new error!
When typesetting=standard, it's OK.
Hi, I have a procedure named f1. In it, it calls another procedure f couple of times. procedure f does not have recursive calls implemented.
I have no idea what caused the error. Could anyone give a hint?
Thanks a million in advance,
Best,
Jie
I like Maple the most for calculation of difficult parts. But when it comes to display, I am ignorant and do not know how to command the maple for showing me what is visible in the document.
I attach herewith my document which shows in print view only top half of the sketch. What should I do to show all three figures in the portrait page.
(Here below, after uploading it is shown alright, but in the print preview it is not showing!!).
I want to convert the doc to pdf. Therefore, in the doc preview itself it should be complete.
Thanks for help.
Ramakrishnan V
Download sketchesNotComing_in_full.mw
First 127 128 129 130 131 132 133 Last Page 129 of 371
