I have this very ugly ODE system which I solve with "dsolve, numeric, complex=true". It works ok but I'd really like to be able to use events. The problem is that the solution of the system has very small (~10^(-Digits)) imaginary part and as we know "events" works only for real ODEs.
My question is does anyone know a way to force dsolve to solve the ODE as a real system? In Mathematica, there is the function "chop" which does the trick. In Maple, I tried with fnormal and also by forcing some terms to be real but that makes it hit a singularity at 0.01 which doesn't exist when it integrates it as a complex system. In Mathematica, it integrates ok with "chop" without any random singularities.
I'm currently trying separating the system into real and imaginary parts, but considering how ugly the system is, it may not be so simple (and so far, it doesn't work). So something to trick dsolve would come handy.
How can plot two  and bipolar figures as attached and extract their data.
Thank You.
I find many tools about differential
i had some differential ideal
how to use these tools to research what application can be applied with differential ideals I discovered?
If A is an m × n matrix and B is a p × q matrix, then the Kronecker product C = A ⊗ B is the mp × nq block matrix. Assume I have matrix C and want to find matrix A and B. This problem has known solution called "Nearest Kronecker Product". So I just need a function like this: A,B:=NearestKroneckerProduct(C)  which minimizes ||C - A ⊗ B||F  where denotes frobenius norm.
Here is an Image that shows a mathematica code:
I took it from the link below:
https://mathematica.stackexchange.com/questions/91651/nearest-kronecker-product
Also there is a matlab code:
https://gist.github.com/tholden/58dd9a8991daa750ae36a633fe7060a4/revisions
can you convert mathematica code to maple?
If I do:
df:=DataFrame(Matrix(3,4,[seq(1..12)]), rows=[a,b,c],columns=[A,B,C,D]);Tabulate(df, width=100)
The font that Maple uses for the Tablulate is much larger than the font used to display the Dataframe. How does one choose the font size that Tabluate() uses?
Peter
We put A = {1,2,3,4} and B is the set of lower cubes
to 100 of positive integers.Determine A ∪ B  A ∩ B , A ∩ {6,8} and A \ B
i am trying to solve a differential equation numercially but since it is second degree,I can not achieve the proper answer.What should I do?
thank you
diff1.mw
h := 1-.8*x+.5*(x^2-x)
1-1.3*x+.5*x^2
z := 3^(3/2)*(((2+k*De^2*(diff(p(x), x))^2*h^2)^3*h^2+108*k*De^2)/k)^(1/2)
3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2)
c := (1/6)*((-54*De+z)*k^2*h^2)^(1/3)/(k*De*h)-(1/2)*h*(2+k*De^2*(diff(p(x), x))^2*h^2)/(De*((-54*De+z)*k^2*h^2)^(1/3))-(1/2)*h*(diff(p(x), x))
(1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x))
ode1 := ((1/2)*c*(diff(p(x), x))^2*h^4+(diff(p(x), x))*c^2*h^3+(1/10)*(diff(p(x), x))*h^5+c^3*h^2)*k*De^2+(1/2)*c*h^2+(1/6)*(diff(p(x), x))*h^3+h = 0
((1/2)*((1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x)))*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^4+(diff(p(x), x))*((1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x)))^2*(1-1.3*x+.5*x^2)^3+(1/10)*(diff(p(x), x))*(1-1.3*x+.5*x^2)^5+((1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x)))^3*(1-1.3*x+.5*x^2)^2)*k*De^2+(1/2)*((1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x)))*(1-1.3*x+.5*x^2)^2+(1/6)*(diff(p(x), x))*(1-1.3*x+.5*x^2)^3+1-1.3*x+.5*x^2 = 0
ivp := {ode1, p(0) = 0}
{((1/2)*((1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x)))*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^4+(diff(p(x), x))*((1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x)))^2*(1-1.3*x+.5*x^2)^3+(1/10)*(diff(p(x), x))*(1-1.3*x+.5*x^2)^5+((1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x)))^3*(1-1.3*x+.5*x^2)^2)*k*De^2+(1/2)*((1/6)*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3)/(k*De*(1-1.3*x+.5*x^2))-(1/2)*(1-1.3*x+.5*x^2)*(2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)/(De*((-54*De+3*3^(1/2)*(((2+k*De^2*(diff(p(x), x))^2*(1-1.3*x+.5*x^2)^2)^3*(1-1.3*x+.5*x^2)^2+108*k*De^2)/k)^(1/2))*k^2*(1-1.3*x+.5*x^2)^2)^(1/3))-(1/2)*(1-1.3*x+.5*x^2)*(diff(p(x), x)))*(1-1.3*x+.5*x^2)^2+(1/6)*(diff(p(x), x))*(1-1.3*x+.5*x^2)^3+1-1.3*x+.5*x^2 = 0, p(0) = 0}
dsolve(ivp, p(x), numeric, parameters = [k, De])
Error, (in dsolve/numeric/make_proc) Could not convert to an explicit first order system due to 'RootOf'
Download diff1.mw
Download diff1.mw
Is it possible to expand vector calculus identities directly in Maple without taking them to basis form (i.e. their component partial derivatives).
For example:
with(Physics[Vectors]):
%Curl(u*%Gradient(v)) = u*%Curl(%Gradient(v)+`&x`(%Gradient(u), %Gradient(v)))
Given the Left Hand Side, can Maple come up with the RHS on its own?
Many Thanks.
Please, I need to use Maple to solve Euler-Bernoulli Beam on Pasternak Foundation using Homotopy Perturbation Method.
The governing equation is
initial conditions are
the boundary condition is
The governing equation represents Euler-Bernoulli beam on a generalized Pasternak viscoelastic foundation under an
arbitrary distributed dynamic load. in which E, I , ρ ,A are the parameters of the beam, representing Young’s modulus of elasticity, moment of inertia, density and area of cross section, respectively. K,C and Gp are spring stiffness, damping coefficient, and shear coefficient of the foundation. Moreover, y(x, t) and F(x, t) are defined as the vertical deflection of the beam and the generic arbitrary dynamic loads, respectively, where the loads distribute along the x-axis and t is time.
I will appreciate anyone who can help me with a Maple solution.
How should wirte a while loop for solve nonlinear equations by newton raphson method
Dear Maple friends~
Recently I am thinking a question about how to use Maple to prove an equation based on a known partial differential equationand its boundary conditions.
Although I can Prove it with hand computation ,it still has some difficulty and it will be really hard if its partial differential equation become more complex(As a matter of fact, it will happen).So I think of Maple and want to take advantage of computer.However,I get few ideas how to realize it .The details are as follows:
alias(u=u(x,t)):
pde:=diff(u,t)-diff(u,x$2,t)+4*u^2*diff(u,x)=3*u*diff(u,x)*diff(u,x$2)+u^2*diff(u,x$3);
N:=5;#actually N can be any positive integer!
bcs:=eval(u,x=-infinity)=0,seq(eval(diff(u,x$ha),x=-infinity)=0,ha=1..N),eval(u,x=infinity)=0,seq(eval(diff(u,x$ha),x=infinity)=0,ha=1..N);
E:=Int(u^4+2*u^2*diff(u,x)^2-diff(u,x)^4/3,x=-infinity..infinity);
#try to prove the following equation
diff(E,t)=0
The written proof is as follows:
Therfore,I submit such a problem and look forward your solutions and suggestions sincerely~
How I can write a code for the determination of Laplacian in a new form that is introduced in the maple code (First line).
FOR
Maple Worksheet - Error
Failed to load the worksheet //convert/FOR
Download FOR
How may I please use maple tools in communication engineering applications. May I please have any example model
I'm trying to use the ExpectedValue function to get the next close value of a stock.
restart; with(Finance)
W := WienerProcess()
T := 1.0
S := SamplePath(W(t), t = 0 .. T, timesteps = 100, replications = 10^4)
A := S[1 .. 10^4, 50]
TI := 1
AN := 100 (Start Value)
sigma := 3.5 (volatility)
r := 0.5e-1    (interest)
ANF := AN*exp((r-(1/2)*sigma^2)*TI+sigma*W(TI))       (ANF: is the forecasting Value)
ExpectedValue(ANF, timesteps = 100, replications = 10^3)
Is this approach right?
How i can generate Pr matrix when P= -x and x0=-1 , x1=-2/3 , x2=-1/3 , and x3=0 with the help loop?
First 129 130 131 132 133 134 135 Last Page 131 of 371
