So, I am trying to write a method for array interpolation. I have a Matrix that is X by 3, where each column holds specific data (column 1 holds independent data 1, column 2 holds independent data 2, column 3 holds dependent data).
This data comes from a function with 2 independent variables, and I am creating a graph of this function, basically, with both independent variables going from 0 to 1 (approximately 300 values per variable, giving me a matrix with 90k values already). My goal is to use interpolation to get a lot of values in between the points I already calculated.
That being said, I don't know how to use the ArrayInterpolation command to achieve this. I will post my code below if anyone can help me out!
Code:
Interpolate := proc(M::Matrix)
  local i; local j;
  local M1 := Matrix(RowDimension(M),1);
  local M2 := Matrix(RowDimension(M),1);
  local M3 := Matrix(RowDimension(M),1);
  for i from 1 to RowDimension(M) do
    M1(i) := M(i,1);
    M2(i) := M(i,2);
    M3(i) := M(i,3);
  print(M1,M2,M3);
  local M4 := Matrix(1000,1);
  local M5 := Matrix(1000,1);
  for j from 1 to 1000 do
    M4(j,1) := 0.001*j;
    M5(j,1) := 0.001*j;
  ArrayInterpolation([M1,M2],M3,[M4,M5]);
How I can replace  u__0r, theta, t) with f1, 1(r, theta) in attached file.
I want in I have only f1,1] function.
"f[1, 1](r, theta):=`u__0`(r, theta,t)  "
proc (r, theta) options operator, arrow, function_assign; u__0(r, theta, t) end proc
"L[1, 1](r, theta):=-`A__0`*(∂)/(∂r) (F*(∂)/(∂r)`u__0`(r,theta))-1/(2)*`A__0`*(∂)/(∂r) (`K__1`*`u__0`(r,theta))+1/(2)*`A__0`*`K__1`*(∂)/(∂r)`u__0`(r,theta)-1/(2)*`A__0`*(∂)/(∂ r) (`H__1`*`u__0`(r,theta))+1/(2)*`A__0`*`H__1`*(∂)/(∂r)`u__0`(r,theta)+`K__3`*`A__0`*`u__0`(r,theta)-1/(2)*`A__0`*(∂)/(∂ r) (`K__4`*`u__0`(r,theta))+1/(2)*`A__0`*`K__4`*(∂)/(∂r)`u__0`(r,theta)+`A__0`*`K__5`*`u__0`(r,theta)-2*`A__0`*(∂)/(∂ theta) ((`H__2`)/(r)*(∂)/(∂theta)`u__0`(r,theta))+(1)/(4)*`A__0`*l^(2)*((∂)^(2))/(∂ r ∂ theta)(mu*((∂)^(2))/(∂r ∂theta)`u__0`(r,theta))+(1)/(4)*`A__0`*l^(2)*((∂)^(2))/(∂theta^(2))(mu*((∂)^(2))/(∂ theta^(2))`u__0`(r,theta))+rho*`A__0`*`K__16`*((∂)^(2))/(∂t^(2))`u__0`(r,theta);"
proc (r, theta) options operator, arrow, function_assign; -A__0*(diff(F*(diff(u__0(r, theta), r)), r))-(1/2)*A__0*(diff(K__1*u__0(r, theta), r))+(1/2)*A__0*K__1*(diff(u__0(r, theta), r))-(1/2)*A__0*(diff(H__1*u__0(r, theta), r))+(1/2)*A__0*H__1*(diff(u__0(r, theta), r))+K__3*A__0*u__0(r, theta)-(1/2)*A__0*(diff(K__4*u__0(r, theta), r))+(1/2)*A__0*K__4*(diff(u__0(r, theta), r))+A__0*K__5*u__0(r, theta)-2*A__0*(diff(H__2*(diff(u__0(r, theta), theta))/r, theta))+(1/4)*A__0*l^2*(diff(mu*(diff(u__0(r, theta), r, theta)), r, theta))+(1/4)*A__0*l^2*(diff(mu*(diff(u__0(r, theta), theta, theta)), theta, theta))+rho*A__0*K__16*(diff(u__0(r, theta), t, t)) end proc
Download replace
Hi, my codes ran smoothly well until I changed some assignment value. It reported invalid object error.
Error, Got internal error in Typesetting:-Parse:-Postprocess : "internal error: invalid object "
Part of the codes are as follows:
""sigma:=0.00002:    m:=5:   n:=4:
Could anyone give some hints on what goes wrong here? It seems to be a configuration issue but I completely have no clue..
Thanks a million in advance,
Best,
Jie
How 2 solve summation when M,  Z,  X are given with mixed conditions?
##########  omega and theta are variables,where J[3],F[2],H[2],etc are constants.
#### I tried with "evlf" and "evlc" command but maple was not ready to provide the solution,please help me to solve this
t1:=-1/(-16.*omega^2+exp(-4*omega)+exp(4*omega)-2.)*(-(0.5817764173e-1*I)*exp((2/9)*omega*cos(theta))*omega^5*cos(theta)*J[3]-(.6981317009*I)*exp((2/9)*omega*cos(theta))*omega^4*cos(theta)*H[3]-0.4524927691e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^3*G[3]-.6205615118*exp(.1111111111*omega*(2.*cos(theta)-9.))*cos(theta)*omega^3*H[2]+.6205615118*exp(.1111111111*omega*(2.*cos(theta)-9.))*cos(theta)*omega^3*F[2]+.9308422676*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^4*H[3]-.1034269187*exp(.1111111111*omega*(2.*cos(theta)-9.))*cos(theta)*omega^3*G[2]-0.7757018900e-1*exp(.1111111111*omega*(2.*cos(theta)-9.))*cos(theta)*omega^2*G[2]-0.7757018898e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^4*J[3]-0.9696273622e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^3*J[3]-0.4524927691e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^2*J[3]-.2714956613*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^2*H[3]-0.7757018898e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^4*G[3]+0.8726646261e-1*exp((2/9)*omega*cos(theta))*omega^3*J[3])*cos((2/9)*omega*sin(theta));
t2:=int(int(t1,omega=0..infinity),theta=0..2*Pi);
Problem copying a document to Maple Cloud (Public domain)
• Reset password
• Verified email is correct
• Chose File → Save to Cloud... (or clicked Send Document to Cloud on Maple Cloud palette) either way opend Login dialog
• Entered  Account = Maplesoft account, my Email and password then clicked Log in.  The following message appears: "The account type or email address or password is incorrect"
I've saved .mw files to Maple Cloud before with no problems.  Any help appreciated.
Thanks, Les
I have the equation (𝑑𝑥/𝑑𝑡)^2=𝑎𝑥^3+𝑏𝑥^2+𝑐𝑥+𝑑.
How do I plot 𝑑𝑥/𝑑𝑡 against x? (as the coefficients a, b, c and d vary)
I expect it looks like the following graph:
I'm confused about Maple's adjoint function (in the DEtools package). When I take the adjoint of the derivative operator:
DEtools:-adjoint(Dx, [Dx, x])
I get back simply "Dx". However, doing the calculation by hand and integrating by parts seems to indicate that this should return the negative of Dx. The inner product I'm using is int(f(x)*conjugate(g(x)), x=0..1). Is Maple perhaps using a different inner product? Or is this a generalization that I'm unaware of? Or is it perhaps just a bug?
Consider a wave y=f(x,t) with amplitude modulation such that it becomes
 y_new=(1+A)*f(x,t), where A=A(t) is a small perturbation.
How can I do the simulation to test the robustness of the system to see if the wave is stable / unstable under perturbation? As the time t goes to infinity, I want to see if the original wave is distorted or not under either random or prescribed perturbation.
P.S. For example,  f(x,t) = (sech(0.5*x-0.1*t))^2.
I have an expression like x:= C*exp(I*T[1]*e*eta) and want to define e*T[1] as T[2]. How can I do this with coding?
Bahar
Hi I have encounted this error:
Error, (in diffalg/DAparse_polynomial) unknown indeterminate or coefficient outside base field, -Cp+Cf/(1+Kw*(-sigma*`ΔPi`+`ΔP`)*(1-(1/2)*Fp/Ff)/Ks)
The text highlighted in bold is an equation that I typed in.
Can I know what it means?
1,1,2,2,2,3,3,2,2,1,2,2,2,3,3,1,1
i would like to research the ordering mechanism of this kind of series Before sorting.
How I can simplify result? For factor or using rule.
can maplesim simulate a robot arm and hand catch a throwing ball and picking objects?
can maplesim simulate a balancing a robot legs?
will these simulation require complex formula to draw the robots arm and hand and maintain the joints stick together during motions?
can maplesim output the specification to autodesk for 3D print parts?
how much of a maplesim?
i can not see the price in maple official site from Hong Kong area.
HI,
Yesterday I replied  denitsastaicova's question while providing an attached file.
Surprisingly, I wasn't able to save the worksheet after having executed it. The only way I found to save it was to copy-paste it's content in a new worksheet and save this latter without any execution.
Here is the file
events.mw
For info I'm working with  Standard Worksheet Interface, Maple 2015.2, Mac OS X, December 21 2015 Build ID 1097895
on Mac OS Mojave 10.14.3
If I open this file and execute it (and even if I execute only the commands from the initial restart to the three dsolve), I get this pop-up error message when trying to save it:
Does my worksheet contain some undesired character or is it a bug ?
First 128 129 130 131 132 133 134 Last Page 130 of 371
