Hello, I try this integral, but Maple not solutions, the answer is the same integral.
int(N*exp((2*(-(1/2)*x^2-2*a^2*ln(x)*x/(-2*x^2+2)))/sigma^2)/(-2*x^2+2), x = -1 .. 1)
N,a, sigma are constants.
I created a user library and added a component that I had created from a shared subsystem and this worked fine.
I edited the component in the library to add some additional functionality and saved it.  I then had to reload the library in Maplesim but now I get this error everytime I try to run the simulation:
Cannot resolve `ControlLogix.PIDE` in model `Main`; there is no `ControlLogix` visible
Yet I dragged and dropped the component PIDE from the ControlLogix library.
Can anyone help me to resolve this?
I'm having trouble connecting from Maple on Windows 10 to MSQL Server. I tried Microsoft recommended drivers such as sqljdbc_6.4.0.0, did (as I thought) all required steps. The only invariable result I get is "Cannot load driver". I was wandering if anyone had implemented such a construction. Driver name & version , connection string and Java version would be greatly appreciated. Another option is to have any driver, which connects to any of standard databases (Oracle, MySQL).  The only limitation is- it must be from Windows 7 or 10.
           A.B.
I remember there was a command that used to start an independent java session each time. I thought it's "xmaple -singlemode" but it's not. So could anybody please remind me what was the command. I just killed a second java session after losing kernel connection and java running wild. I'd be very happy to do my calculation in another java session so that if anything goes bad II won't have to open all my 5 tabs again.
Integrating a positive definite function (normal distribution) and a >= 0 function (Heaviside) should not return a negative value.
with(Statistics);
X := RandomVariable(Normal(1, sqrt(2.25)));
int(PDF(X, x)*Heaviside(x^7-5*x^4-3*x+1), x = -infinity .. infinity);
                         -0.08507120131
Bug.mw
I'm using dsolve command to solve a differential equation. Using infolevel to 3 will tell me the classification of said DE. However, how can I see the step by step solution? I'm using Maple as a study tool so I do solve manually a DE then I'd like to compare my answer with Maple's. How can I acomplish this? Thanks in advance.
Please may I know if you can offer ma student's discount ob the seleted version.
Fred.
I open a completely new document, type in a few simple expressions and get this weird complex number out. Can someone pleas help me fix this?
Is there any way we can get maple to tell us which variable we are recursively assigning?
solve({-infinity < a , a < -1, -1 < b ,  b < 0});
f(x) := piecewise(0 < x, x^(3/2)*sin(1/x), x = 0, 0, undefined);
plot(f(x));
gives me the following error:
Error, (in plot) incorrect first argument piecewise(0 < x, (HFloat(2.739493386336394e-116)+HFloat(2.739493386336394e-116)*I)*x^(3/2), x = 0, 0, undefined)
I just want to see the function plot. With Wolfram Alpha this is no deal at all!
Maple doesn't completely check the condition on the number of trials "n" for Binomial and NegativeBinomial distributions (package Statistics).
The attribute "Conditions" explicitely says that n must be a strictly positive integer but no strictly positive real valuereturna an error (ok, it would be stupid to set n to a non integer value !!!).
I think it is a default that ought to be corrected in future releases (this default still exists in Maple 2018)
kernelopts(version)
`Maple 2015.2, APPLE UNIVERSAL OSX, Dec 20 2015, Build ID 1097895`
with(Statistics):
BINOMIAL DISTRIBUTION
X := RandomVariable(Binomial(n, p)):
L := [attributes(X)][3]:
A := exports(L)
Conditions, ParentName, Parameters, CDF, CharacteristicFunction, Kurtosis, Mean, Median, Mode, MGF, ProbabilityFunction, Skewness, Support, Variance, VariationCoefficient, CDFNumeric, QuantileNumeric, RandomSample, RandomSampleSetup, RandomVariate
L:-Conditions
[0 <= p, p <= 1, n::posint]
# Maple should return an error for N is not of type posint
# It seems that Sample uses floor(N)
N := 10.49; type(N::posint);
P := 1/2:
X := RandomVariable(Binomial(N, P)):
Mean(X), N*P;
ProbabilityFunction(X, k);
S := Sample(X, 10^6):
Mean(S);
# A non consistent result (only non negative values of k should be accepted)
eval(ProbabilityFunction(X, k), k=evalf(Pi));
N := 10.49
false
5.245000000, 5.245000000
piecewise(k < 0, 0, binomial(10.49, k)*(1/2)^k*(1/2)^(10.49-k))
HFloat(4.998903)
.1096019539
NEGATIVE BINOMIAL DISTRIBUTION
X := RandomVariable(NegativeBinomial(n, p)):
A := exports(L):
L:-Conditions
[0 < n, 0 < p, p <= 1]
N := 10.49:
P := 1/2:
X := RandomVariable(NegativeBinomial(N, P)):
Mean(X)
Download BinomialLaw.mw
Yeah, i have tried evalf[10](sqrt(25)).
How can i get a simple number as answer? I'm loving the software but i just wished i could type in:
int(sin(x), x = 0 .. pi)
and get 2 instead of (2.739493386*10^(-116) + (2.739493386*10^(-116))*I)*pi.
Also, when i type evalf[50](pi), i wish to get all the 50 digits, but i just get \pi :/.
Please help me.
I want to solve an ODE system numerically, but maple show not converge for iteration, can you give a solution
with(VectorCalculus);
with(linalg);
pi := 4; eta := 6; mh := .1; mv := .3; bh := .15; Nh := 400; Nv := 200; bv := .25; b := .8; d := .1; p := .5; B := 10; A := 1; alpha := .25; beta := .7; K := 400; r := .5; c := .9; q := .8; Sh0 := 225; Sv0 := 100; Ih0 := 175; Iv0 := 600; P0 := 50; T := 35; B := 10;
eq1 := diff(L1(t), t) = -L1(t)*(-bh*b*Iv(t)/Nh-mh)-L2(t)*bh*b*Iv(t)/Nh; eq2 := diff(L2(t), t) = -L2(t)*(-mh-d)+L3(t)*bv*b*Sv(t)/Nv-L4(t)*bv*b*Sv(t)/Nv; eq3 := diff(L3(t), t) = -(L4(t)*Iv(t)+L3(t)*Sv(t))*L3(t)/(2*B^2)-L3(t)*(-bv*b*Ih(t)/Nv-mv-L3(t)*Sv(t)/(2*B^2)-(L4(t)*Iv(t)+L3(t)*Sv(t))/(2*B^2)-P(t)*alpha)-L4(t)*(bv*b*Ih(t)/Nv-L3(t)*Iv(t)/(2*B^2))-L5(t)*P(t)*alpha; eq4 := diff(L4(t), t) = -A-(L4(t)*Iv(t)+L3(t)*Sv(t))*L4(t)/(2*B^2)+L1(t)*bh*b*Sh(t)/Nh-L2(t)*bh*b*Sh(t)/Nh+L3(t)*L4(t)*Sv(t)/(2*B^2)-L4(t)*(-mv-L4(t)*Iv(t)/(2*B^2)-(L4(t)*Iv(t)+L3(t)*Sv(t))/(2*B^2)-P(t)*alpha)-L5(t)*P(t)*alpha; eq5 := diff(L5(t), t) = L3(t)*Sv(t)*alpha+L4(t)*Iv(t)*alpha-L5(t)*(r*(1-P(t)/Nv)-P(t)*r/Nv+alpha*(Sv(t)+Iv(t))-q*c); eq6 := diff(Sh(t), t) = pi-bh*b*Sh(t)*Iv(t)/Nh-mh*Sh(t); eq7 := diff(Ih(t), t) = bh*b*Sh(t)*Iv(t)/Nh-mh*Ih(t)-d*Ih(t); eq8 := diff(Sv(t), t) = eta-bv*b*Sv(t)*Ih(t)/Nv-mv*Sv(t)-P(t)*Sv(t)*alpha-L3(t)*Sv(t)^2/(2*B^2)-L4(t)*Sv(t)*Iv(t)/(2*B^2); eq9 := diff(Iv(t), t) = -L3(t)*Sv(t)*Iv(t)/(2*B^2)+bv*b*Sv(t)*Ih(t)/Nv-mv*Iv(t)-P(t)*Iv(t)*alpha-L4(t)*Iv(t)^2/(2*B^2); eq10 := diff(P(t), t) = P(t)*r*(1-P(t)/Nh)+P(t)*alpha*(Sv(t)+Iv(t))-q*P(t)*c
fcns := {Ih(t), Iv(t), L1(t), L2(t), L3(t), L4(t), L5(t), P(t), Sh(t), Sv(t)}; a := dsolve({eq1, eq10, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9, Ih(0) = Ih0, Iv(0) = Iv0, L1(T) = 0, L2(T) = 0, L3(T) = 0, L4(T) = 0, L5(T) = 0, P(0) = P0, Sh(0) = Sh0, Sv(0) = Sv0}, fcns, type = numeric);
  Sh(t), Sv(t)}
Error, (in dsolve/numeric/bvp) initial Newton iteration is not converging
First 124 125 126 127 128 129 130 Last Page 126 of 371
