I know that anames( 'user' ) recovers the contents of the workspace but I wonder whether it would be possible to recover only the contents of each m-file read within a worksheet.
Many thanks
Ed
My maplet
mpt := Maplet(Window("Точка выше или ниже прямой",
[[Plotter[f]()], ["1st vector"],
[TextField[v1](), TextField[v2](), TextField[v5]()],
["2nd vector"],
[TextField[v3](), TextField[v4](), TextField[v6]()], ["Скаляр"],
[TextField[scalar]()], [Button("Add", Evaluate(f = 'work(1)'))],
[[ToggleButton['d2']("2D", 'value' = true, 'group' = 'BG1')],
[ToggleButton['d3']("3D", 'value' = false, 'group' = 'BG1')]]]),
ButtonGroup['BG1']())
Now I choose via toogle button what to plot 2D or 3D addition but I need to plot it in two different plotter, is there a way to do it?
Procedure
with(Maplets);
with(Elements);
with(Tools);
[AddAttribute, AddContent, Get, ListBoxSplit, Parse, Print, Set,
  SetTimeout, StartEngine, StopEngine]
with(plots);
with(LinearAlgebra);
with(Student[LinearAlgebra]);
with(Maplets[Elements]);
work:=proc(g)
     local x1, y1, x2, y2, scalar;z1, z2,d2,d3,u,v,U,V,r1,r2,r3,R1,R2,R3,V1:
 x1 := Get(v1::algebraic);
 y1 := Get(v2::algebraic);
z1 := Get(v5::algebraic);
x2 := Get(v3::algebraic);
y2 := Get(v4::algebraic);
z2 := Get(v6::algebraic);
scalar := Get(scalar::algebraic);
 d2:= Get(d2);
d3:= Get(d3);
 if d2 = true then  u, v:=<x1, y1>, <x2, y2>;
elif d3 = true then   u, v:=<x1, y1,z1>, <x2, y2,z2>;
end if;  U:=arrow(u, color=red):
V:=arrow(u, v, color=black):
   r1:=u+v: r2:=u-v: r3:=ScalarMultiply(u,scalar):r4:=ScalarMultiply(v,scalar):
R1:=arrow(r1, color=red):
 R2:=arrow(v, r2, color=black):
R3:=arrow(r3, color=black):
 R4:=arrow(r4, color=black):
V1:=arrow(v, color=blue):
if g = 1 then return VectorSumPlot(u,v, show=1, caption="Треугольник", vectorcolors=[red,blue]);
Repeat once again what do I need: I want to plot addition of vectors in 2D and 3D in 2 different plotters at once
how to convert a function to transition matrix?
how to convert a differential system to transition matrix?
Does global optimization toolbox has randomization option it gives same value every time
In addition to defining a function in a standard way, a fast and convenient way to turn a formula (an expression) into a function is to use unapply command (check Maple help center for this command). The following items are about defining functions.
  1. Define a function midpoint, which returns the average of two arguments given on input. For example, midpoint(2,3) returns 2.5, midpoint(a,b) returns 𝑎+𝑏2.
  2. b) For two positive natural numbers 𝑎 and 𝑏 we can define the least common multiple lcm(𝑎,𝑏) via their greatest common divisor gcd (𝑎,𝑏), i.e.: lcm(𝑎,𝑏) = 𝑎𝑏gcd (𝑎,𝑏). When 𝑎 and/or 𝑏 are zero, lcm(𝑎; 𝑏)=0. Use the arrow operator and piecewise to define the function my_lcm which returns the least common multiple of two natural numbers.
  3. c) The quadratic formula allows to write the roots of 𝑝 = 𝑎𝑥2+𝑏𝑥+𝑐 explicitly in terms of 𝑎,𝑏, and 𝑐.
 Define a piecewise function of 𝑥 so that the value of the function is 0, if 𝑥<−(𝑟1+ 𝑟2+𝑟3) or 𝑥>𝑟1+ 𝑟2+𝑟3, and it is equal to the area of confined region if −(𝑟1+ 𝑟2+𝑟3)<𝑥<𝑟1+ 𝑟2+𝑟3.
a) Given real values 𝑟1,𝑟2,𝑟3>0, consider the curve of the positive part of the circle with radius 𝑟1+ 𝑟2+𝑟3 and center at the origin and three semi-circles below with radii 𝑟1,𝑟2,𝑟3 so that they are arranged from left to right like the following graph. Define proper functions and plot this graph in Maple for 𝑟1=10,𝑟2=2,𝑟3=8.
Hey everyone,
Got another Symbolic question here that I have no idea how to begin. Please help again.
Question:
Note that if i is an integer then convert(i,base, 2) will convert i to a binary list (the binary representation of i in reverse order). Then you may use list_to_set to convert  this list to a set. Note that if i runs from 0 to 2^n-1 then list_to_set(convert(i,base,2) )  will run through all subsets of {1, 2, . . ., n}.
(a) Use this idea to make your own procedure PowerSet which will given n,  produce the powerset of {1, 2, . . . , n}. Show by several examples that your procedure works. For your examples you should get nops(PowerSet(n)) = 2^(n). Check that this is the case.
(b) Use this idea to make a procedure RandSet which given n produces a random subset of {1, 2, . . . , n}. [Use rand to produce a random integer in the range 0..2^n-1 and then convert it to a subset of {1, 2, . . . , n}.]  Do NOT use PowerSet or powerset. Show by examples that it works for small n such as 5, 10, and 20 as well as for large n such as 100. It will even work for n = 1000, but the output will be rather large. On average a random subset of {1,2,...,n} will contain n/2 elements.
Again, please help me with this and thank you in advance. Your assistance is appreciated.
First-time poster here. Got a question for Symbolic Computations and don't know how to do it. Please help me out.
Here is the question:
There is a one-to-one correspondence between subsets of {1, 2, . . . , n} and binary lists of length n, that is, lists L = [x1, x2 , . . . , xn] where x1, x2, . . . , xn are elements of the set {0,1}.  The correspondence is given by associating to the set S the list L where xi = 1 if i is in S and 0 if not. For example, the set {1,3,5} corresponds to the list [1,0,1,0,1,0,0] if n = 7.
(a) Write a procedure list_to_set whose input is a binary list and whose output is the corresponding set. E. g., list_to_set([1,0,1,0,1]) will return the set {1,3,5}. Note that nops(L) is the length of a list.
(b) Write a procedure set_to_list whose input is a pair S,n where S is a subset of {1, 2, . . . , n} and n is a positive integer and whose output is the binary list of length n corresponding to the set S. E. g., if n = 5 then set_to_list({1,3,5},5) will return [1,0,1,0,1].
(c) Show by a few tests that each procedure works. Then apply set_to_list to each set in the powerset of {1, 2, 3, 4} to form all binary lists of length 4. Make a program to print out a table of the following form. (But the order need not be the same as that started below.)
   [0,0,0,0] <-->  {  }
   [1,0,0 0] <--> { 1 }
   [0,1,0,0] <--> { 2 }
    etc
Some extra commas in the output is okay. You may obtain the power set of the set {1,2,...,n} by the command powerset(n); but you must first load the package combinat.
Please let me know if there are any questions. Thank you in advance.
I want to do min max algebra in maple but dont know how to start. What package is required . Can anyone help me.
Does Maplesoft provide success percentage of this toolbox on benchmark functions?. I cannot see much options in the global solve command (from maple help page) other than population size etc.
Non-Linear overdetermined equations - which is best method? with less number of iterations
When I use Jacobi it takes 25 iterations.
Any other method which takes less iterations?
I would like to know whether a local optimizer is combined with the present global optimization toolbox?. I read that toolbox has differential evolution and surrogate optimization techniques etc. These methods guarantee near-optimal solutions and it is often recommended to use a local optimization technique in conjunction with global optimization techniques.
First 120 121 122 123 124 125 126 Last Page 122 of 371
