I am currently facing an issue as regards stability analysis and I will be glad if anyone can offer me some suggestions.  My aim is to have a Theorem in my research stating that the Disease free equilibrium is locally asymptotically stable if R0 (Basic reproduction number) < 1 and unstable if R0 > 1. The same applies to the endemic equilibrium.  I am trying to carry out a stability analysis using Linearization. However, due to the nature of my model, not all my eigenvalues are negative. Below is my Jacobian Matrix:
ROW 1                           ROW 2                       ROW 3                         ROW 4
Column 1:=              -psi-gamma-mu                       varphi                              omega                                   betaS
Column 2:=                 -psi                 - varphi - varpi - mu                    0                                  epsilon * beta  M
Column 3:=                   gamma                         varphi                             - omega - mu                                  xi * beta * V
Column 4:=                 0                                0                                0                       betaS + epsilon * beta  M + xi * beta * V -tau - kappa - mu
By using the Routhz Hurwitz criterion, I reduced the matrix block from 4 by 4 to 3 by 3 by using column 4 as co-factor, however, after this matrix reduction, I was still unable to get all terms relating to my basic reproduction number for me to compare and see if the conditions in Routh Criterion is satisfied using the condition R0 < 1 holds.
My Basic Reproduction Number is as follows:
(varphi+mu+varpi)*(mu+omega-mu*rho)-(mu+varphi+omega)*mu*sigma+ epsilon ((omega+mu+gamma)*sigma*mu+(mu+omega-mu*rho)*psi) + xi*((varphi+varpi+mu+psi)*mu*rho+(mu*sigma+gamma+psi)*varphi+(mu-mu*sigma+varpi)*gamma)/((varphi+mu)*(psi+gamma+omega+mu)+(omega+mu+gamma)*varpi+psi*omega)
Are there any other methods to  carry out local stability analysis? and Can local stability analysis be done using maple?
Thank you in advance
I can calculate real number eigenvector with QR algorithm from rotation matrix
but this real number is just magnitude of complex number
what is the rotation matrix for calculating complex number?
what algorithm do maple use to calculate fraction eigenvector?
are complex decimal and complex fraction eigenvectors are two different algorithm?
Hello everyone!
how to solve system of 5 equations like as in attachment, but much more faster?
I tried to do this on my computer (CPU 8 Core 3,4 GHz, RAM DDR3 2x8 GB, SSD) but after 12 hour my computer doesn't respond.
What I can do if I don't have a supercomputer?
Forum.mw
`ode&lambda;` := diff(lambda(tau), tau, tau)+2*a*Ep(tau)*(diff(lambda(tau), tau))/(Xi(tau)*a+1) = 0:
th := algsubs((diff(lambda(tau), tau))^2 = (-1-(diff(xi(tau), tau))^2)/(-(xi(tau)*a+1)^2), `ode&xi;`):
a*(diff(xi(tau), tau))^2/(xi(tau)*a+1)+diff(diff(xi(tau), tau), tau)+a/(xi(tau)*a+1) = 0
a*(diff(xi(tau), tau))^2/(xi(tau)*a+1)+diff(diff(xi(tau), tau), tau)-a/(xi(tau)*a+1) = 0
ds2 := -(xi(tau)*a+1)^2*(diff(lambda(tau), tau))^2+(diff(xi(tau), tau))^2:
`&lambda;p1` := 1:
`ics&lambda;1` := lambda(0) = 0, (D(lambda))(0) = `&lambda;p1`:
xi(0) = (-1+2^(1/2))/a, (D(xi))(0) = 1
xi(0) = 1/a, (D(xi))(0) = 2
`lp&xi;1` := dsolve([`ode&xi;1`, `ics&xi;1`], numeric, output = listprocedure, range = teu .. te, events = event1); Xi := eval(xi(tau), `lp&xi;1`); `&Xi;p` := eval(diff(xi(tau), tau), `lp&xi;1`); `ode&lambda;`; `lp&lambda;1` := dsolve([`ode&lambda;`, `ics&lambda;1`], numeric, output = listprocedure, range = teu .. te, events = event1)
diff(diff(lambda(tau), tau), tau)+.6*Ep(tau)*(diff(lambda(tau), tau))/(.3*Xi(tau)+1) = 0
Error, (in dsolve/numeric/DAE/make_proc) number of unknown functions and equations must match, got 3 functions {Ep, Xi, lambda}, and 1 equations
`lp&xi;1`(1)
[tau(1) = 1., (xi(tau))(1) = 2.20293901854199481, (diff(xi(tau), tau))(1) = .670856526448510904]
`&lambda;ep1` := eval(diff(lambda(tau), tau), lp1); `&xi;ep1` := eval(diff(xi(tau), tau), lp1); `&lambda;e1` := eval(lambda(tau), lp1); `&xi;e1` := eval(xi(tau), lp1)
proc (tau) local _res, _dat, _solnproc, _xout, _ndsol, _pars, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](tau) else _xout := evalf(tau) end if; _dat := eval(`dsolve/numeric/data/modules`[1]); _solnproc := _dat:-Get("soln_procedure"); _pars := map(rhs, _dat:-Get("params")); if not type(_xout, 'numeric') then if member(tau, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(tau, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(tau, ["last", 'last', "initial", 'initial', NULL]) then _res := _solnproc(convert(tau, 'string')); if type(_res, 'list') then return _res[4] else return NULL end if elif member(tau, ["parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(tau, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[4], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(tau), 'string') = rhs(tau); if lhs(_xout) = "initial" then if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else _res := _solnproc("initial" = ["single", 4, rhs(_xout)]) end if elif not type(rhs(_xout), 'list') then error "initial and/or parameter values must be specified in a list" elif lhs(_xout) = "initial_and_parameters" and nops(rhs(_xout)) = nops(_pars)+1 then _res := _solnproc(lhs(_xout) = ["single", 4, op(rhs(_xout))]) else _res := _solnproc(_xout) end if; if lhs(_xout) = "initial" then return _res[4] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[4], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(tau), 'string') = rhs(tau)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _dat:-Get("sysvars") end if; if procname <> unknown then return ('procname')(tau) else _ndsol := `tools/gensym`("xi(tau)"); eval(FromInert(_Inert_FUNCTION(_Inert_NAME("assign"), _Inert_EXPSEQ(ToInert(_ndsol), _Inert_VERBATIM(pointto(_dat:-Get("soln_procedures")[4])))))); return FromInert(_Inert_FUNCTION(ToInert(_ndsol), _Inert_EXPSEQ(ToInert(tau)))) end if end if; try _res := _solnproc(_xout); _res[4] catch: error  end try end proc
`&lambda;ep2` := eval(diff(lambda(tau), tau), lp2); `&xi;ep2` := eval(diff(xi(tau), tau), lp2); `&lambda;e2` := eval(lambda(tau), lp2); `&xi;e2` := eval(xi(tau), lp2)
proc (tau) local _res, _dat, _solnproc, _xout, _ndsol, _pars, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](tau) else _xout := evalf(tau) end if; _dat := eval(`dsolve/numeric/data/modules`[2]); _solnproc := _dat:-Get("soln_procedure"); _pars := map(rhs, _dat:-Get("params")); if not type(_xout, 'numeric') then if member(tau, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(tau, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(tau, ["last", 'last', "initial", 'initial', NULL]) then _res := _solnproc(convert(tau, 'string')); if type(_res, 'list') then return _res[4] else return NULL end if elif member(tau, ["parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(tau, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[4], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(tau), 'string') = rhs(tau); if lhs(_xout) = "initial" then if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else _res := _solnproc("initial" = ["single", 4, rhs(_xout)]) end if elif not type(rhs(_xout), 'list') then error "initial and/or parameter values must be specified in a list" elif lhs(_xout) = "initial_and_parameters" and nops(rhs(_xout)) = nops(_pars)+1 then _res := _solnproc(lhs(_xout) = ["single", 4, op(rhs(_xout))]) else _res := _solnproc(_xout) end if; if lhs(_xout) = "initial" then return _res[4] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[4], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(tau), 'string') = rhs(tau)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _dat:-Get("sysvars") end if; if procname <> unknown then return ('procname')(tau) else _ndsol := `tools/gensym`("xi(tau)"); eval(FromInert(_Inert_FUNCTION(_Inert_NAME("assign"), _Inert_EXPSEQ(ToInert(_ndsol), _Inert_VERBATIM(pointto(_dat:-Get("soln_procedures")[4])))))); return FromInert(_Inert_FUNCTION(ToInert(_ndsol), _Inert_EXPSEQ(ToInert(tau)))) end if end if; try _res := _solnproc(_xout); _res[4] catch: error  end try end proc
ds2h1 := subs([lambda(tau) = `&lambda;e1`(tau), xi(tau) = `&xi;e1`(tau), diff(lambda(tau), tau) = `&lambda;ep1`(tau), diff(xi(tau), tau) = `&xi;ep1`(tau)], ds2); dse1 := unapply(ds2h1, tau); ds2h2 := subs([lambda(tau) = `&lambda;e2`(tau), xi(tau) = `&xi;e2`(tau), diff(lambda(tau), tau) = `&lambda;ep2`(tau), diff(xi(tau), tau) = `&xi;ep2`(tau)], ds2); dse2 := unapply(ds2h2, tau)
dse1(0); dse2(0)
-.999999999
1.000000000
t := proc (xi, lambda) options operator, arrow; (xi+1/a)*sinh(a*lambda) end proc; x := proc (xi, lambda) options operator, arrow; (xi+1/a)*cosh(a*lambda) end proc; xi0 := 1; teg := 7
p1 := plot([[x(xi0, `&lambda;e1`(tau)), t(xi0, `&lambda;e1`(tau)), tau = teu .. te]], legend = ['ds' = -1], color = ["red"]); p2 := plot([[t(xi0, `&lambda;e2`(tau)), x(xi0, `&lambda;e2`(tau)), tau = teu .. te]], legend = ['ds' = 1], color = ["blue"]); p3 := plot([[tau, tau, tau = -teg .. teg], [tau, -tau, tau = -teg .. teg]], color = ["black", "black"], legend = ['ds' = 0, 'ds' = 0])
with(plots); display([p1, p2, p3])
Download Rindler_simulation_v2.mw
Hello!
I'm a beginner in Maple. My question is: is it possible to trim the surface along the intersection line in Maple? There is a problem - inclined surfaces are constructed along the contour of the triangle, they intersect. Is it possible to get a pyramid along the intersection lines?
Thank you!trimming_surfaces.mwtrimming_surfaces.mw
restart; with(plots), with(plottools); with(linalg)
Q1p := 45; Q1po := 75
Q2p := 110; Q2po := 84
Q3p := 63; Q3po := 120
XP := KTX1+(KTX2-KTX1)*t1
YP := KTY1+(KTY2-KTY1)*t1
x1 := subs({KTX1 = Q1p, KTX2 = Q2p, t1 = t1}, XP)
y1 := subs({KTY1 = Q1po, KTY2 = Q2po, t1 = t1}, YP)
x2 := subs({KTX1 = Q2p, KTX2 = Q3p, t1 = t2}, XP)
y2 := subs({KTY1 = Q2po, KTY2 = Q3po, t1 = t2}, YP)
x3 := subs({KTX1 = Q3p, KTX2 = Q1p, t1 = t3}, XP)
y3 := subs({KTY1 = Q3po, KTY2 = Q1po, t1 = t3}, YP)
za := 0
Kriv1 := spacecurve([x1, y1, za, t1 = 0 .. 1], color = brown, scaling = constrained, thickness = 4)
Kriv2 := spacecurve([x2, y2, za, t2 = 0 .. 1], color = green, scaling = constrained, thickness = 4)
Kriv3 := spacecurve([x3, y3, za, t3 = 0 .. 1], color = blue, scaling = constrained, thickness = 4)
display(Kriv1, Kriv2, Kriv3)
xE1 := x1-30*(diff(y1, t1))/sqrt((diff(x1, t1))^2+(diff(y1, t1))^2)
yE1 := y1+30*(diff(x1, t1))/sqrt((diff(x1, t1))^2+(diff(y1, t1))^2)
zE1 := 30
KrivE1 := spacecurve([xE1, yE1, zE1, t1 = 0 .. 1], color = blue, scaling = constrained, thickness = 4)
xP1 := simplify(xE1+l1*(x1-xE1))
yP1 := simplify(yE1+l1*(y1-yE1))
zP1 := simplify(zE1*(1-l1))
P1 := plot3d([xP1, yP1, zP1], t1 = 0 .. 1, l1 = 0 .. 1, transparency = 0)
display(KrivE1, Kriv1, P1, Kriv2, Kriv3)
xE2 := x2-30*(diff(y2, t2))/sqrt((diff(x2, t2))^2+(diff(y2, t2))^2)
yE2 := y2+30*(diff(x2, t2))/sqrt((diff(x2, t2))^2+(diff(y2, t2))^2)
zE2 := 30
KrivE2 := spacecurve([xE2, yE2, zE2, t2 = 0 .. 1], color = blue, scaling = constrained, thickness = 4)
xP2 := simplify(xE2+l2*(x2-xE2))
yP2 := simplify(yE2+l2*(y2-yE2))
zP2 := simplify(zE2*(1-l2))
P2 := plot3d([xP2, yP2, zP2], t2 = 0 .. 1, l2 = 0 .. 1, transparency = 0)
display(KrivE2, Kriv2, P2)
xE3 := x3-30*(diff(y3, t3))/sqrt((diff(x3, t3))^2+(diff(y3, t3))^2)
yE3 := y3+30*(diff(x3, t3))/sqrt((diff(x3, t3))^2+(diff(y3, t3))^2)
zE3 := 30
KrivE3 := spacecurve([xE3, yE3, zE3, t3 = 0 .. 1], color = blue, scaling = constrained, thickness = 4)
xP3 := simplify(xE3+l3*(x3-xE3))
yP3 := simplify(yE3+l3*(y3-yE3))
zP3 := simplify(zE3*(1-l3))
P3 := plot3d([xP3, yP3, zP3], t3 = 0 .. 1, l3 = 0 .. 1, transparency = 0)
display(KrivE3, Kriv3, P3)
L22 := solve(zP2 = zP1, l2)
L111 := solve(subs(l2 = L22, yP2 = yP1), l1)
L222 := subs(l1 = L111, L22)
T11 := solve(subs(l2 = L222, l1 = L111, xP2 = xP1), t1)
L2T := subs(t1 = T11, L222)
L1T := subs(t1 = T11, L111)
LP12 := spacecurve([XT12, YT12, ZT12, t2 = 0 .. 1], color = red, scaling = constrained, thickness = 1)
PLOT3D(CURVES([[110., 84., 0.], [108.7339864, 84.33411040, .5045906412], [107.4679728, 84.66822079, 1.009181282], [106.2019593, 85.00233119, 1.513771924], [104.9359457, 85.33644158, 2.018362565], [103.6699321, 85.67055198, 2.522953207], [102.4039185, 86.00466237, 3.027543849], [101.1379050, 86.33877277, 3.532134491], [99.87189139, 86.67288316, 4.036725133], [98.60587781, 87.00699356, 4.541315775], [97.33986423, 87.34110395, 5.045906417], [96.07385066, 87.67521435, 5.550497059], [94.80783708, 88.00932474, 6.055087701], [93.54182350, 88.34343514, 6.559678343], [92.27580993, 88.67754554, 7.064268985], [91.00979635, 89.01165593, 7.568859626], [89.74378277, 89.34576633, 8.073450268], [88.47776919, 89.67987672, 8.578040910], [87.21175562, 90.01398712, 9.082631552], [85.94574204, 90.34809751, 9.587222194], [84.67972846, 90.68220791, 10.09181284], [83.41371488, 91.01631830, 10.59640348], [82.14770131, 91.35042870, 11.10099412], [80.88168773, 91.68453909, 11.60558476], [79.61567415, 92.01864949, 12.11017540], [78.34966058, 92.35275989, 12.61476605], [77.08364700, 92.68687028, 13.11935669], [75.81763342, 93.02098068, 13.62394733], [74.55161984, 93.35509107, 14.12853797], [73.28560627, 93.68920147, 14.63312861], [72.01959269, 94.02331186, 15.13771926], [70.75357911, 94.35742226, 15.64230990], [69.48756554, 94.69153265, 16.14690054], [68.22155196, 95.02564305, 16.65149118], [66.95553838, 95.35975345, 17.15608182], [65.68952480, 95.69386384, 17.66067247], [64.42351123, 96.02797424, 18.16526311], [63.15749765, 96.36208463, 18.66985375], [61.89148407, 96.69619503, 19.17444439], [60.62547050, 97.03030542, 19.67903503], [59.35945692, 97.36441582, 20.18362567], [58.09344334, 97.69852621, 20.68821632], [56.82742976, 98.03263661, 21.19280696], [55.56141619, 98.36674700, 21.69739760], [54.29540261, 98.70085740, 22.20198824], [53.02938903, 99.03496780, 22.70657888], [51.76337545, 99.36907819, 23.21116953], [50.49736188, 99.70318859, 23.71576017], [49.23134830, 100.0372990, 24.22035081], [47.96533470, 100.3714094, 24.72494146]], COLOUR(RGB, 1.00000000, 0., 0.)), THICKNESS(1), SCALING(CONSTRAINED))
NULL``
L22 := solve(zP2 = zP3, l2)
L333 := solve(subs(l2 = L22, yP2 = yP3), l3)
L222 := subs(l3 = L333, L22)
T33 := solve(subs(l2 = L222, l3 = L333, xP2 = xP3), t3)
L2T := subs(t3 = T33, L222)
L3T := subs(t3 = T33, L333)
LP32 := spacecurve([XT32, YT32, ZT32, t2 = 0 .. 1], color = red, scaling = constrained, thickness = 3)
PLOT3D(CURVES([[82.69885121, 48.35683352, 44.89752824], [82.29683384, 49.81893896, 43.98125215], [81.89481646, 51.28104440, 43.06497607], [81.49279909, 52.74314984, 42.14869998], [81.09078172, 54.20525528, 41.23242389], [80.68876435, 55.66736072, 40.31614780], [80.28674698, 57.12946616, 39.39987171], [79.88472960, 58.59157160, 38.48359563], [79.48271223, 60.05367704, 37.56731954], [79.08069486, 61.51578248, 36.65104345], [78.67867749, 62.97788792, 35.73476736], [78.27666012, 64.43999336, 34.81849127], [77.87464274, 65.90209880, 33.90221519], [77.47262537, 67.36420425, 32.98593910], [77.07060800, 68.82630969, 32.06966301], [76.66859063, 70.28841513, 31.15338692], [76.26657325, 71.75052057, 30.23711083], [75.86455588, 73.21262601, 29.32083475], [75.46253851, 74.67473145, 28.40455866], [75.06052114, 76.13683689, 27.48828257], [74.65850376, 77.59894233, 26.57200648], [74.25648639, 79.06104777, 25.65573039], [73.85446902, 80.52315321, 24.73945431], [73.45245165, 81.98525865, 23.82317822], [73.05043428, 83.44736409, 22.90690213], [72.64841690, 84.90946954, 21.99062604], [72.24639953, 86.37157498, 21.07434995], [71.84438216, 87.83368042, 20.15807387], [71.44236479, 89.29578586, 19.24179778], [71.04034741, 90.75789130, 18.32552169], [70.63833004, 92.21999674, 17.40924560], [70.23631267, 93.68210218, 16.49296951], [69.83429530, 95.14420762, 15.57669343], [69.43227792, 96.60631306, 14.66041734], [69.03026055, 98.06841850, 13.74414125], [68.62824318, 99.53052394, 12.82786516], [68.22622581, 100.9926294, 11.91158907], [67.82420844, 102.4547348, 10.99531298], [67.42219106, 103.9168403, 10.07903690], [67.02017369, 105.3789457, 9.162760809], [66.61815632, 106.8410511, 8.246484721], [66.21613895, 108.3031566, 7.330208633], [65.81412157, 109.7652620, 6.413932545], [65.41210420, 111.2273675, 5.497656457], [65.01008683, 112.6894729, 4.581380368], [64.60806946, 114.1515784, 3.665104280], [64.20605209, 115.6136838, 2.748828192], [63.80403471, 117.0757892, 1.832552104], [63.40201734, 118.5378947, .9162760162], [62.99999996, 120.0000001, -0.8979507982e-7]], COLOUR(RGB, 1.00000000, 0., 0.)), THICKNESS(3), SCALING(CONSTRAINED))
NULL``
L33 := solve(zP3 = zP1, l3)
L111 := solve(subs(l3 = L33, yP3 = yP1), l1)
L333 := subs(l1 = L111, L33)
T11 := solve(subs(l3 = L333, l1 = L111, xP3 = xP1), t1)
L3T := subs(t1 = T11, L333)
LP13 := spacecurve([XT13, YT13, ZT13, t3 = 0 .. 1], color = red, scaling = constrained, thickness = 1)
PLOT3D(CURVES([[89.14619532, 109.5415219, 28.16031418], [88.24525256, 108.8365929, 27.58561389], [87.34430980, 108.1316638, 27.01091360], [86.44336704, 107.4267348, 26.43621331], [85.54242428, 106.7218058, 25.86151302], [84.64148151, 106.0168768, 25.28681273], [83.74053875, 105.3119478, 24.71211244], [82.83959598, 104.6070187, 24.13741215], [81.93865322, 103.9020897, 23.56271186], [81.03771046, 103.1971607, 22.98801157], [80.13676769, 102.4922317, 22.41331128], [79.23582493, 101.7873027, 21.83861099], [78.33488217, 101.0823736, 21.26391070], [77.43393941, 100.3774446, 20.68921041], [76.53299664, 99.67251561, 20.11451012], [75.63205388, 98.96758659, 19.53980983], [74.73111112, 98.26265757, 18.96510954], [73.83016835, 97.55772855, 18.39040925], [72.92922559, 96.85279953, 17.81570896], [72.02828283, 96.14787051, 17.24100866], [71.12734006, 95.44294149, 16.66630837], [70.22639730, 94.73801248, 16.09160808], [69.32545454, 94.03308346, 15.51690779], [68.42451177, 93.32815444, 14.94220750], [67.52356901, 92.62322542, 14.36750721], [66.62262625, 91.91829640, 13.79280692], [65.72168348, 91.21336738, 13.21810663], [64.82074072, 90.50843836, 12.64340634], [63.91979796, 89.80350934, 12.06870605], [63.01885519, 89.09858032, 11.49400576], [62.11791243, 88.39365131, 10.91930547], [61.21696967, 87.68872229, 10.34460518], [60.31602690, 86.98379327, 9.769904891], [59.41508414, 86.27886425, 9.195204600], [58.51414138, 85.57393523, 8.620504310], [57.61319861, 84.86900621, 8.045804020], [56.71225585, 84.16407719, 7.471103729], [55.81131309, 83.45914817, 6.896403439], [54.91037032, 82.75421915, 6.321703149], [54.00942756, 82.04929013, 5.747002858], [53.10848480, 81.34436112, 5.172302568], [52.20754204, 80.63943210, 4.597602278], [51.30659927, 79.93450308, 4.022901987], [50.40565651, 79.22957406, 3.448201697], [49.50471375, 78.52464504, 2.873501407], [48.60377098, 77.81971602, 2.298801116], [47.70282822, 77.11478700, 1.724100826], [46.80188546, 76.40985798, 1.149400536], [45.90094269, 75.70492896, .5747002453], [44.99999991, 74.99999993, -0.5632062994e-7]], COLOUR(RGB, 1.00000000, 0., 0.)), THICKNESS(1), SCALING(CONSTRAINED))
display(LP12, LP13, LP32, P1, P2, P3, Kriv1, Kriv2, Kriv3)
Download trimming_surfaces.mw
I want to know about some algorithms used by Maple, if there is a way to dig through the code.
x1 := 0; -1; x2 := 0; -1; J2 := J1
J1
ec1 := (1/J3-1/J2)*M2*M3+m*g*(g2*x3-g3*x2) = 0;
(1/J3-1/J1)*M2*M3+m*g*x3*g2 = 0
ec2 := (1/J1-1/J3)*M1*M3+m*g*(-g1*x3+g3*x1) = 0;
(1/J1-1/J3)*M1*M3-m*g*x3*g1 = 0
ec3 := (1/J2-1/J1)*M1*M2+m*g*(g1*x2-g2*x1) = 0;
0 = 0
ec4 := g2*M3/J3-g3*M2/J2 = 0;
g2*M3/J3-g3*M2/J1 = 0
ec5 := g3*M1/J1-g1*M3/J3 = 0;
ec6 := g1*M2/J2-g2*M1/J1 = 0;
g1*M2/J1-g2*M1/J1 = 0
F1 := (1/J3-1/J2)*M2*M3+m*g*(g2*x3-g3*x2);
F2 := (1/J1-1/J3)*M1*M3+m*g*(-g1*x3+g3*x1);
F3 := (1/J2-1/J1)*M1*M2+m*g*(g1*x2-g2*x1);
F4 := g2*M3/J3-g3*M2/J2;
g2*M3/J3-g3*M2/J1
F5 := g3*M1/J1-g1*M3/J3;
g3*M1/J1-g1*M3/J3
F6 := g1*M2/J2-g2*M1/J1;
g1*M2/J1-g2*M1/J1
with(Groebner)
[Basis, FGLM, HilbertDimension, HilbertPolynomial, HilbertSeries, Homogenize, InitialForm, InterReduce, IsBasis, IsProper, IsZeroDimensional, LeadingCoefficient, LeadingMonomial, LeadingTerm, MatrixOrder, MaximalIndependentSet, MonomialOrder, MultiplicationMatrix, MultivariateCyclicVector, NormalForm, NormalSet, RationalUnivariateRepresentation, Reduce, RememberBasis, SPolynomial, Solve, SuggestVariableOrder, Support, TestOrder, ToricIdealBasis, TrailingTerm, UnivariatePolynomial, Walk, WeightedDegree]
G := {F1, F2, F3, F4, F5, F6};
{0, g1*M2/J1-g2*M1/J1, g2*M3/J3-g3*M2/J1, g3*M1/J1-g1*M3/J3, (1/J1-1/J3)*M1*M3-m*g*x3*g1, (1/J3-1/J1)*M2*M3+m*g*x3*g2}
(15)
B := Basis(G, tdeg(M1, M2, M3, g1, g2, g3))
Error, (in gcd/Freeze) arguments should be polynomials
IsBasis(B, tdeg(M1, M2, M3, g1, g2, g3))
Error, invalid input: Groebner:-IsBasis expects its 1st argument, G1, to be of type {list, set}, but received B
Download 418.mw
Can someone help with the simplification of the result of this code? I am sure the "qs" in the final result should not appear.
Thanking you in anticipation of your positive responses
#k=1
P:=sum(a[k]*x^k, k=0..2):
assume(alpha>0,alpha <= 1):
Q:=fracdiff(P,x,alpha);
e1:=simplify(eval(P, x=q))=y[n]:
e2:=simplify(eval(Q,x=q))=f[n]:
e3:=simplify(eval(Q,x=q+h^alpha))=f[n+1]:
var:=seq(a[i], i=0..2):
M:=e||(1..3):
Cc:=eval(<var>, solve(eval({M}),{var}) ):
for i from 1 to 3 do
	a[i-1]:=Cc[i]:
Cf:=P:
E:=collect(Cf, [y[n], f[n], f[n+1]], recursive):
print():
#y[n+1]=collect(simplify(simplify(expand(eval(Cf,x=q+h^alpha)),size)), [y[n],f[n],f[n+1]], factor);
y[n+1]=simplify(eval(Cf, x=q+h^alpha)):
collect(%, [y[n], f[n], f[n+1]], recursive);
Let be given tetrahedron ABCD, where AB = BC = AC = a, AD = d, AD = e, CD = f. I know that, If the measure of angle of AB and CD equal to Pi/3, then we have d^2 - e^2 - a*f = 0. I tried:
ListTools[Categorize];
L := [];
for a to 30 do for d to 30 do
for e to 30 do for f to 30 do
if abs(d-e) < a and a < d+e and abs(a-e) < d and d < a+e and abs(d-a) < e and e < d+a and abs(d-f) < a and a < d+f and abs(a-f) < d and d < a+f and abs(d-a) < f and f < d+a and abs(e-f) < a and a < e+f and abs(a-f) < e and e < a+f and abs(a-e) < a and a < a+e and -a*f+d^2-e^2 = 0 and igcd(a, d, e, f) = 1 and nops({a, d, e, f}) = 4
then L := [op(L), [a, d, e, f]] end if end do end do end do end do;
nops(L);
L;
Another way to find the length of edges of a tetrahedron knowing that the mesure angle of two opposite?
Hello Friends
I have a critical problem that I wish to solve it with maple
suppose we have a list like following: y_obs=(2,4,8,7,9,52,35,478,52) and corresponding variance σy=(.2,.3,.5,.87,.1.2,.22,.78,.99,1.5)
we know y as the function of x described such as y_theoric=x+p and minimizing X is
X=Sigma [(y_theoric-y_obs)^2]/σy which includes the sum of nine numbers...
the question is:
How we can find p from likelihood function and plot general behavior of y versus of x through two above series?
for example this solution used in article under the names Hubble parameter data constraints on dark energy by Yun Chen and Bhatra Ratra (Physics Letters B)
      I was trying to apply some assumptions to a pdsolve command and noticed a strange error. Here's a minimal working example.
restart():
pdsolve(diff(f(t,x),t) = 0, {f(t,x)}, ivars = {x, t}) assuming x::real:
returns
Error, (in simpl/relopsum) invalid terms in sum: diff(f(t,x),t) = 0
Is this indeed a bug, or is it expected behavior?
I have a problem with "Infinitesimals" for the system of equations.
"Infinitesimals" Counts the system for (x, t) but shows an empty string for (x, y, z, t).
When I add to the equation (img 2) u [y, y], u [z, z] or simply y ^ 2, z ^ 2, Maple shows an empty string in Infinitesimal.
Thank you in advance.
Hello everybody,
I am quiet new to Maple and just have to program a small tool.
I need to show a conculison in a pop-up Window which should contain a matrix and a plot.
I tried different ways but they didn't work.
I have a very simple problem. When Maple displays long outputs I can only see a part of them. Here there is an example
https://www.dropbox.com/s/ymp1vdsg80ewu1s/Untitled.jpeg?dl=0
On my previous versions of Maple I had a slider on the bottom of the page. How can I activate it in Maple 2016?
Thanks, Nicola
First 146 147 148 149 150 151 152 Last Page 148 of 371
