When I finished the following code, I can not export the .eps file for the densityplot
restart; t := 1; a[1] := 0; a[2] := 2; a[4] := 0; a[5] := 1; a[6] := -1; a[8] := 0; g := t*a[3]+x*a[1]+y*a[2]+a[4]; h := t*a[7]+x*a[5]+y*a[6]+a[8]; f := g^2+h^2+a[9]; a[3] := -(3*a[1]^3+a[1]*a[2]^2+3*a[1]*a[5]^2-a[1]*a[6]^2+2*a[2]*a[5]*a[6])/(3*(a[1]^2+a[5]^2)); a[7] := -(3*a[1]^2*a[5]+2*a[1]*a[2]*a[6]-a[2]^2*a[5]+3*a[5]^3+a[5]*a[6]^2)/(3*(a[1]^2+a[5]^2)); a[9] := (3*(a[1]^6+3*a[1]^4*a[5]^2+3*a[1]^2*a[5]^4+a[5]^6))/(a[1]*a[6]-a[2]*a[5])^2; u := (4*(2*a[1]^2+a[5]^2))/f-8*(g*a[1]+h*a[5])^2/f^2; with(plots); plot3d(u, x = -20 .. 20, y = -20 .. 20, axes = frame, labels = ["x", "y", "z"], labeldirections = ["horizontal", "horizontal", "horizontal"], labelfont = ["TIMES", 16], style = patchnogrid); densityplot(u, x = -10 .. 10, y = -10 .. 10, axes = frame, labels = ["x", "y"], labeldirections = ["horizontal", "horizontal"], labelfont = ["TIMES", 16], colorstyle = HUE, style = patchnogrid); contourplot(u, x = -5 .. 5, y = -5 .. 5, labels = ["x", "y"], labeldirections = ["horizontal", "horizontal"], labelfont = ["TIMES", 16])
Why does
MultiSeries:-series(LegendreQ(-1/2,x),x=-1))
not work?
seems to work, but does it give the correct result?
I actually thought there was a pole at -1.
Thx
PS: or is the cut between -1 and 1 with both logarithmic singularities?
I'm still wondering about the behaviour of MultiSeries
Hi I was hoping if someone could mark this proof for a lemma regarding the Euler totient functin for me.
totient_lemma_proof.mw
I am working on problems in identifiability and I am interested in how many Lie derivatives of two kinds are required to get a full result for a simple system, and more interestingly a way of visualising what comes out when too few Lie derivatives are used.
The method is simple, I use Lie derivatives my own program GTS2 to get relationships that must be conserved for the output for two parameter vectors to give the same output (you can find it along with everything else for this question here.
An example of a list of parameter relationships is:
[{R = R, Rh = Rh, alpha = alpha, C[T] = C[T], Ch[T] = Ch[T], k[a1] = -(k[a2]*C[T]*R-kh[a1]*Ch[T]*Rh-kh[a2]*Ch[T]*Rh)/(R*C[T]), k[a2] = k[a2], k[d1] = k[d1], k[d2] = k[d2], kh[a1] = kh[a1], kh[a2] = kh[a2], kh[d1] = -(k[d1]*x[2]-k[d1]*xh[1]-k[d1]*xh[2]-k[d2]*x[2]+kh[d2]*xh[2])/xh[1], kh[d2] = kh[d2], x[1] = -x[2]+xh[1]+xh[2], x[2] = x[2], xh[1] = xh[1], xh[2] = xh[2]},{...},{...}]
i.e. they will show that there are multiple relationships that satisfy the Lie derivative conditions (each relationship is in a seperate set within the list) and within each set some parameters can vary freely (like R and Rh in the above) and others are determined by the ones that vary freely (like k[a1] and kh[a2]).
I want to count the numbers of parameters that have their relationships determined in three different ways so i can plot these numbers as the numbers of both types of Lie-Derivatives vary. These numbers are:
  1. N_i number of identifiabile parameters; parameters that in all solutions are of the form {p=ph or ph=p}
  2. N_l number of locally identifiable parameters; parameters that in all solutions take either the form {p=ph or ph=p} or {p=some function of the parameters with hs at the end of their names or ph=some function of exclusively the parameters without hs at the end of their names}
  3. N_u number of unidentifiable parameters; parameters that are neither identifiable or n locally-identifiable.
    I think its nice to have a link to a worksheet at the end of a question, so here_it_is_again.
Acknowledgement: most of the code in the above was based on snippets written by @Carl Love in response to my previous questions.
EDIT: I had some teaching to do, so uploaded the question early as i was writing in a computer room- as a result the maple worksheet I originally included was confusing, the worksheet I've included in this edit is much easier to understand.
TLDR: i am looking a way to count the numbers of outputs of various types from a program that is built around maples solve feature, and stuck
I have training video that shows the visualization window "docked" below the main window.   Can this work space arrangement be done in sim2017 ??
Also I push the anchor button and nothing seems to happen
Hi all, does anyone know why i can't export maple as a pdf file? I have tried saving as other type of files which works, but when pressing save as pdf nothing happens.
I've used this guide, https://www.maplesoft.com/support/help/maple/view.aspx?path=worksheet/managing/exportPDF#bkmrk1
hi
by passing all steps to install Maplesim 2017.3 i confort the error "The system cannot find the file specidied" when i want to open it. what shoud i do?
Update: rebooting the PC fixed this error for me. Now help comes up OK.
original question:
I am on windows 7, home editon, running Maple 2018.
For some reason, now each time I tried to get help, I get the message that it lost connection with server. I closed Maple, started it up again, and same error happens. Movie below.
This also happend from new worksheet also Each time I type ?anything I get the above.
Any idea what can cause it? and where I should look for errors?
I did not nothing before this to anything on system. Was just editing some worksheet which opens fine. It is only help that seems to be having hard time.
Fivebyfive_crossword.mwsFivebyfive_crossword.txt
  I am trying to solve a 5x5 crossword  puzzle, where one must find 5 across clues, and 5 down clues - all in a 5x5 square grid.  I have done a dictionary search for all the possibilities of the ten clues.  (For brevity this is not in the attached program.)  These possible solutions have been put as lists.  The attached Maple 7 program attempts to solve the crossword by a series of nested for loops, checking if the intersection of across and down clue letters match.  In this the use of nops is made, as the number of possible words for each clue varies.  I appreciate why the program fails, but am at a loss for a "work around", and fear a complete restart may be needed.
   I attach two files of the program.  The Fivebyfive_crossword.mws Maple 7 file includes a graphic grid of the crossword, with asterisks (*)  for unknown letters.  The corresponding .txt file probably will not have that.  Sadly, Maple doesn't allow the upload of .rtf files.  Further documentation is in the program.
   Any comments, help would be most appreciated.
I want to solve a set of parametric inequalities with constraints but it takes too much time to processing. do you know any faster solution?
thanks in advance
Hi, i want to solve the Ax=b with jacobi method and 4 Iteration, A=Matrix(3, 3, [1, 2, 1, 2, 1, 3, -1, -3, 4]) and b=[8, 13, 5].
i want to write a code with for or if or while. tnx
Dear sir / madam
I'm a student of mechanical engineering and looking for some HPM ( homotopy perturbation method) maple codes with the related article to practice more in this field.
can I ask you for help?
unfortunately, I couldn't find any articles with maple solution about HPM.
sincerely
Aidin
When running this code in Maple 13 and 16 this works just fine,
GenMs:= (k::posint)-> assign(m||(1..2*k) =~ seq([dx||i, dy||i][], i= 1..k)):
GenMs(k), m || (1 .. 2*k);
gln := evalDG(l1 &s n1+`&s`(l2, n2)+sum('epsilon || i'*(cat(m, 2*i-1) &s cat(m, 2*i-1)+cat(m, 2*i) &s cat(m, 2*i)), i = 1 .. k));
But running the same code in Maple 2018 I get the following error:
Error, (in DifferentialGeometry:-Tensor:-SymmetrizeIndices) expected 1st argument to be a tensor. Received: `m2*i-1`^2
I don't know if it's related to Maple 2018 screwing with my tensor formatting:
https://gyazo.com/88eaeceda2e36cf411df44dbc4aa3ab6
(compare https://gyazo.com/b33396131165d66bbcf16e45d20cc579)
For whatever reason I just noticed that my inline &t's have been turned into `&t` but that's a separate issue.
For the most part, when I have come across bugs (or what appears to be bugs from my naive view, maybe it is left unevaluated for some means of diplomacy that I am not privy to) they are very difficult or impossible for me to find a way to get around.
But I have found alot recently that I was able to fix very quickly using functions that are already inbuilt in maple. Most have to do  with evaluating functions of trancendental arguements or composites of trancendental functions, but still, it leaves me feeling a little disturbed just how readily it was resolved.
I don't know exactly what to say, perhaps a 'dispatch' needed to be included in an inbuilt procedure to inform the 'engine' that a user has come across a bug of some kind at that address, so that maplesoft can keep the process of applying patches in house, avoiding having to enable the evolution/personal development the inept user that clearly stumbled upon the bug by sheer coincidence whist entering formula and observing output in a relatively sub human cognitive state?
I only just noticed the Start.mw file being always number 1 in my Recent document list.  I don't recall it being there, ever, and I don't think it should.  Why is it there now?  Anyone else have this?
First 147 148 149 150 151 152 153 Last Page 149 of 371
