> restart;
with(plots);
pr := .72; p := 0; n := [.5, 1, 1.5]; s := 0; a := .2; b := 0; L := [red, blue, green]; l := 0; k := 1;
for j to nops(n) do R1 := 2*n[j]/(1+n[j]); R2 := 2*p/(1+n);
sol1 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))+R1*(1-(diff(f(eta), eta))^2) = 0, diff(diff(theta(eta), eta), eta)+pr*k*f(eta)*(diff(theta(eta), eta))+R2*pr*k*(diff(f(eta), eta))*theta(eta)+(2*(a*(diff(f(eta), eta))+b*theta(eta)))/(1+n[j]) = 0, f(0) = 1, (D(f))(0) = b*((D@@2)(f))(0), (D(f))(1.8) = 0, theta(0) = 1+s*(D(theta))(0), theta(1.8) = 1], numeric, method = bvp);
fplt[j] := plots[odeplot](sol1, [eta, diff(diff(f(eta), eta), eta)], color = L[j], axes = boxed); tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = L[j], axes = normal) end do; plots:-display([seq(fplt[j], j = 1 .. nops(n))]);
plots:-display([seq(tplt[j], j = 1 .. nops(n))]);
staganation_point1.mw
can we chage the axis sir ?? like  f'' vs eta to f'' vs lambda.
l := 1:
.5
[blue, green, red, yellow]
for j to nops(p) do R1 := 2*n/(n+1); R2 := 2*p[j]/(n+1); R3 := 2/(n+1); sol1 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))+R1*(1-(diff(f(eta), eta))^2)-M*(diff(f(eta), eta)) = 0, diff(diff(theta(eta), eta), eta)+pr*f(eta)*(diff(theta(eta), eta))-R2*pr*(diff(f(eta), eta))*theta(eta)+R3*(A*(diff(f(eta), eta))+B*theta(eta)) = 0, f(0) = 1, (D(f))(0) = L+b*((D@@2)(f))(0), (D(f))(7) = 1, theta(0) = 1+s*(D(theta))(0), theta(7) = 0], numeric, method = bvp); plots[odeplot](sol1, [eta, ((D@@2)(f))(eta)], color = red); fplt[j] := plots[odeplot](sol1, [eta, f(eta)], color = K[j], axes = boxed); tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = K[j], axes = normal); fplt[j] := plots[odeplot](sol1, [eta, diff(f(eta), eta)], color = K[j], axes = boxed) end do:
sol1(0)
sol1(0)
sol1(.1)
[eta = .1, f(eta) = 1.05958091104306206, diff(f(eta), eta) = .643210624614908300, diff(diff(f(eta), eta), eta) = .881482678165403044, theta(eta) = .623284688471349546, diff(theta(eta), eta) = -.578039450700496560]
sol1(.2)
[eta = .2, f(eta) = 1.12800452943200891, diff(f(eta), eta) = .722346769554029544, diff(diff(f(eta), eta), eta) = .706526135439307756, theta(eta) = .568123251856343492, diff(theta(eta), eta) = -.525530979400813946]
sol1(.3)
[eta = .3, f(eta) = 1.20351830506746449, diff(f(eta), eta) = .785511903074783246, diff(diff(f(eta), eta), eta) = .561442941644520022, theta(eta) = .518103974464032668, diff(theta(eta), eta) = -.475257424178228970]
sol1(.4)
[eta = .4, f(eta) = 1.28466826824405134, diff(f(eta), eta) = .835505660630676662, diff(diff(f(eta), eta), eta) = .442470716586289281, theta(eta) = .472985640642506311, diff(theta(eta), eta) = -.427567049032814172]
sol1(.5)
[eta = .5, f(eta) = 1.37026161183094430, diff(f(eta), eta) = .874752886901313142, diff(diff(f(eta), eta), eta) = .345911467377074400, theta(eta) = .432494259338694842, diff(theta(eta), eta) = -.382764248064397461]
sol1(.6)
[eta = .6, f(eta) = 1.36678221814533528, diff(f(eta), eta) = .771028661281065508, diff(diff(f(eta), eta), eta) = .407805382194403932, theta(eta) = .876413930517023876, diff(theta(eta), eta) = -.197648778495384870]
sol1(2)
[eta = 2., f(eta) = 2.66120522956795602, diff(f(eta), eta) = .991532161353848585, diff(diff(f(eta), eta), eta) = 0.251405465681268682e-1, theta(eta) = .635967939441598018, diff(theta(eta), eta) = -.144641270049362308]
Download staganation_point1.mw
Hello every one,
I'm using Maple to create a compiled program of my model Maplesim. I had a error with "getcompiledProc" command, which is :
Error, (in GetCompiledProc) non-numeric initial condition for `Main.RAB.value`(t): Float(undefined)
the "Main.RAB.value(t)" represent a probe used to visualize an output of my system.
Does anybody had a such error ?
Thank you for your responses.
Larbi ANIBA
I am writing a package to define a few Records and collect some quantities and formulae to do some arithmetic with.
At some point I started running into a severe problem: Each time I want to use one of the exports form the module, the Maple kernel dies with a "Stack limit exceeded" message. The issue is: This seems to happen only on Maple 2016. I had some issues in Maple 2015 but that got sorted by rewriting some stuff. I never had any issue like that with Maple 15. I went as far as commenting out most of my .mapleinit code to make sure that did not cause issues. The code works as intended in Maple 15 and in Maple 2015.
I am posting this here and am asking others to see if they can reproduce this. Needless to say I will SCR this. But I actually need to get this to work.
The error can be triggered by simply entering
Booster;
after loading the package. Needless to say, it should just echo the name "Booster", to get more one would need to enter eval(Booster) (due to the last-name evaluation rules).
M.D.
BooMBA.mw
Hello everybody,
I want to solve this pde.the desire solution is V(r,z). three boundar conditions are written that two of them are related to rhe radial and one is related to the longitudinal coordinate.
I attached the solution for you. but this solution is derived by Matlab. Now, I just want to resolve it by Maple, but I couldn't reach it. Please let me know the correct way asap.
Thanks a lot.PDE.mw
Q := diff(V(r, z), r, r)+(diff(V(r, z), r))/r-V(r, z)/r^2+diff(V(r, z), z, z)+C/r = 0
diff(diff(V(r, z), r), r)+(diff(V(r, z), r))/r-V(r, z)/r^2+diff(diff(V(r, z), z), z)+C/r = 0
pdsolve(Q)
PDESolStruc(V(r, z) = _F1(r)*_F2(z)-(1/2)*(_C1/r+_C2*r+_C3*r*ln(r))*C/_C3, [{diff(diff(_F1(r), r), r) = _F1(r)*_c[1]+(-(diff(_F1(r), r))*r+_F1(r))/r^2, diff(diff(_F2(z), z), z) = -_F2(z)*_c[1]}])
Download PDE.mwPDE.mw
Howdy!!
Just thought I'd put a quick one in. I'm trying to solve the Schrodinger equation given as:
schro := {diff(psi(x), x, x)-((b^2-a*(2*p+3))*x^2+2*ab*x^4+a^2*x^6-energy)*psi(x) = 0};
under the constraint
energy=(2p+1)b
I'm trying to plot this for a range of values of the parameters a,b and fixed p=0,1.
I'm aiming to get a solution of the form
psi(x)=(x^p) exp((-a(x^4))/4)-(b(x^2)/2)
and plotting it.
Recently I have used a FilterForge filter to generate hyperbolic tiles from images (Lua code with Möbius transform etc. available). If an input image (1 see below) is selected a tile (2) is generated if the hyperbolic parameters (5,3,2) were chosen.  How could this be made with Maple?
> restart; for j to nops(n) do sys := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))+1-(diff(f(eta), eta))^2 = 0, (diff(diff(theta(eta), eta), eta))/pr+f(eta)*(diff(theta(eta), eta))-(diff(f(eta), eta))*theta(eta) = 0; bcs := f(0) = 0, (D(f))(0) = l+b*((D@@2)(f))(0), (D(f))(-.5) = 1, theta(0) = 1+s*(D(theta))(-.5), theta(2) = 0; n := [1, 2, 3, 4, 5, 6]; pr := .71; p := 0; q := 0; b := 0; l := 0; s := 0; L := [red, blue, orange]; R1 := 2*n[j]/(1+n[j]); R2 := 2*p/(1+n); p := proc (f1, th1, { output::name := 'number' }) local res1, fvals, thvals, res2; option remember; res1 := dsolve({sys, f(1) = 0, theta(0) = 1+th1, (D(f))(0) = f1, (D(theta))(0) = th1, ((D@@2)(f))(0) = f1-1}, numeric, :-output = listprocedure); fvals := (subs(res1, [seq(diff(f(eta), [`$`(eta, i)]), i = 0 .. 2)]))(0); thvals := (subs(res1, [seq(diff(theta(eta), [`$`(eta, i)]), i = 0 .. 1)]))(0); res2 := dsolve({sys, f(0) = fvals[1], theta(0) = thvals[1], theta(5) = 0, (D(f))(0) = fvals[2], (D(f))(5) = 1}, numeric, :-output = listprocedure); if output = 'number' then [fvals[3]-(subs(res2, diff(f(eta), `$`(eta, 2))))(0), thvals[2]-(subs(res2, diff(theta(eta), eta)))(0)] else res1, res2 end if end proc; p1 := proc (f1, th1) p(args)[1] end proc; p2 := proc (f1, th1) p(args)[2] end proc; p(.3, -.2); par := fsolve([p1, p2], [.3, -.2]); res1, res2 := p(op(par), output = xxx); plots:-display(plots:-odeplot(res1, [[eta, f(eta)], [eta, theta(eta)]]), plots:-odeplot(res2, [[eta, f(eta)], [eta, theta(eta)]])); plots:-display(plots:-odeplot(res1, [[eta, diff(f(eta), eta)], [eta, diff(theta(eta), eta)]]), plots:-odeplot(res2, [[eta, diff(f(eta), eta)], [eta, diff(theta(eta), eta)]])); plots:-display(plots:-odeplot(res1, [[eta, diff(f(eta), eta, eta)]]), plots:-odeplot(res2, [[eta, diff(f(eta), eta, eta)]])); plots:-display(plots:-odeplot(res1, [[eta, diff(f(eta), eta)]])); fplt[j] := plots[odeplot](res1, [eta, diff(diff(f(eta), eta), eta)], color = L[j], axes = boxed); tplt[j] := plots[odeplot](res1, [[eta, theta(eta)]], color = L[j], axes = boxed) end do;
Dear Sir
In my above problem i trying to plot for set of values of n but in plot command it not executing , can you do this why it is not executing ??
ha := (diff(c(t), t))/(c(t)*(diff(c(t), t))-c(t));
solve(subs(m=ha,f(m))*subs(m=subs(c(t)=a(t),ha)), f(m)) = subs(m=ha+subs(c(t)=a(t),ha), f(m), f);
just expect to find a function ?
1. How to generate times series data that have some logic law
but do not include distributive law?
Hi guys!
I have a PDE system. The mayority of the equations are equal to zero, but two of them are:
where a, b, c, d are CONSTANT parameters. I know that if a=b=d=c=1 the system is inconsistent. But I also know that if a=-1, b=d=0 and c=1 the system is consistent and exist the solution. I wanna know if there's a way to ask maple to find another selections of my parameter that make my PDE consistent and what it's the solution for that selection of a,b,c,d.
Here's my PDE system (sys2).
test.mw
thank you so much for your time!
Help me, please!
If i have boundary conditions with D(psi), i have no problem. But if i have condition with psi(infinity) (which i need), Maple says "too few boundary conditions". Maybe i make stupid mistakes, but i don't see.
assume(r, nonnegative);
ic_Re := `ψRe`(0) = 0, (D(`ψRe`))(0) = 0;
ic_Im := `ψIm`(0) = 0, (D(`ψIm`))(0) = 0;
V0 := 2.5; ERe := 1.5; EIm := 1.2; `ℏ` := 6.582; mu := 938.27*(1/2); Q0 := 1.5; Rq := 4.5; Rv := 2.5;
Q := proc (r) options operator, arrow; -Q0*exp(-r/Rq) end proc;
V := proc (r) options operator, arrow; -V0*exp(-r/Rv) end proc;
`Eqn_ψRe` := -`ℏ`^2*(diff(`ψRe`(r), r, r)+2*(diff(`ψRe`(r), r))/r)/(2*mu)-ERe*`ψRe`(r)+V(r)+EIm*`ψRe`(r) = Q(r);
`Eqn_ψIm` := -`ℏ`^2*(diff(`ψIm`(r), r, r)+2*(diff(`ψIm`(r), r))/r)/(2*mu)-EIm*`ψRe`(r)-ERe*`ψIm`(r) = 0;
F := dsolve({ic_Im, ic_Re, `Eqn_ψIm`, `Eqn_ψRe`}, numeric);
plots[odeplot](F, [r, `ψRe`(r)], r = 0 .. 20, numpoints = 500);
ic_Re := `ψRe`(0) = 0, `ψRe`(infinity) = 0;
ic_Im := `ψIm`(0) = 0, `ψIm`(infinity) = 0;
Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 5, got 4
Hi, I need help with this little university assignment.
See the thumbnail below.
I have been away from the class because of a staph infection and missed the notes about vectors and Euler's formula.
It would be helpful if someone could give a rundown about how to solve the problems or give a general solution.
-Thanks
Dear All
I calculate something with gr tensor, for example Ricciscalar. How can I save it in maple memory? As you know, in this situation you can not use your calculation directly and it seems that it saved in grtensor memory not maple memory. For example, if you want to plot Ricciscalar, you should save it as a new definition in maple and then plot it.
I have tried to solve the following ode equation, but I have got error. What is the potencial problem?
http://i65.tinypic.com/xdcl8p.jpg
 error
hy
i have to develop a code i which i have system of nonlinear equation
i have to generate the matrix of that nonlinear equation then i want to do or apply any method say newton method and make a loop which help us to find a solution using some tolerance
at the end i get a result in form of a table which give nth matrix then value of function matrix at nth value then error i-e xn-x(n-1)
thanx in advance
First 185 186 187 188 189 190 191 Last Page 187 of 371
