pls help review this code, its doesnt return a solution
Digits := 16;
M := .5; lambda := .5; Pr := .72; beta := 1; L[w] := 0; m := 1; R := 1; Ec := 1;
N := 7;
for j from 0 to N do J[j] := sum(f[k](t)*(diff(f[j-k](t), `$`(t, 2))), k = 0 .. j) end do;
for i from 0 to N do K[i] := sum((diff(f[k](t), t))*(diff(f[i-k](t), t)), k = 0 .. i) end do;
for j from 0 to N do G[j] := sum(f[k](t)*(diff(theta[j-k](t), t)), k = 0 .. j) end do;
for j from 0 to N do H[j] := sum((diff(f[k](t), t))*theta[j-k](t), k = 0 .. j) end do;
for i from 0 to N do P[i] := sum((diff(f[k](t), t, t))*(diff(f[i-k](t), t)), k = 0 .. i) end do;
epsilon := 1; delta := 0;
f[0] := proc (t) options operator, arrow; L[w]+epsilon+delta*A*t+(1/2)*A*t^2 end proc;
1 2
t -> L[w] + epsilon + delta A t + - A t
theta[0] := proc (t) options operator, arrow; 1+B*t end proc;
t -> 1 + B t
NULL;
NULL;
NULL;
NULL;
NULL;
for i to N do f[i] := simplify(-((m+1)*(1/2))*(int(int(int(J[i-1], t = 0 .. eta), t = 0 .. eta), t = 0 .. eta))+m*(int(int(int(1-K[i-1], t = 0 .. eta), t = 0 .. eta), t = 0 .. eta))-M*(int(int(int(diff(f[i-1](t), t)-1, t = 0 .. eta), t = 0 .. eta), t = 0 .. eta))-lambda*(int(int(int(theta[i-1](t), t = 0 .. eta), t = 0 .. eta), t = 0 .. eta))); f[i] := unapply(f[i], eta); theta[i] := simplify(-3*Pr*R*(((m+1)*(1/2))*(int(int(G[i-1], t = 0 .. eta), t = 0 .. eta))-(2*m-1)*(int(int(H[i-1], t = 0 .. eta), t = 0 .. eta))+Ec*(int(int(P[i-1], t = 0 .. eta), t = 0 .. eta)))/(4+3*R)); theta[i] := unapply(theta[i], eta) end do;
NULL;
F(eta):=collect((∑)f[z](eta),eta):
Theta(eta):=collect((∑)theta[z](eta),eta):
with(numapprox);
for k from 2 to 5 do W[k] := pade(diff(F(eta), eta), eta, [k, k]); Q[k] := pade(Theta(eta), eta, [k, k]); SOLL1[k] := expand(coeff(numer(W[k]), eta^k)) = 1; SOLL2[k] := expand(coeff(numer(Q[k]), eta^k)) = 0; SOL[k] := solve({SOLL1[k], SOLL2[k]}, {A, B}); print([k] = SOL[k]) end do;
Warning, computation interrupted
im just getting a generic recursive assignment plus first unused arg error
thats what the maple engine says im doing wrong ill get the number of recursives counted but i guess it just makes me the most angry because its like the same type of error for me every ******* time
I was wondering how to go about validating some airfoil designs for my Formula SAE team's CFD results.  I know this is more common with simplier calculations but I'm hoping using Maple and maybe the new algebraic manipulation of non-comunitive differential operators, I could achive what I am after.   The two calculations of interest are the drag force and downforce.  Can someone shed some light? Thanks
Dear Maple users
I have done some experiments with the new Workbook feature in Maple 2016. It is a very welcome addition, indeed. Earlier I have created Maple files in which data from an external Excel file was imported and being used for certain calculations. In order to make recalculations work properly, one need to let the Excel file follow the Maple file. That's where a Workbook come in handy! I tried placing those two files in a Workbook. It didn't work completely as advertised, I think. I moved the Workbook to another location on the harddrive to make sure it wouldn't interfere with the original files outside the Workbook. Then I recalculated the Maple document inside the Workbook. The good thing: The data from the Excel file was still present. The bad thing: If I changed some data in the Excel file inside the Workbook, it didn't register in the Maple file when updating it!
Maybe I should explain that I did import data from the Excel file into Maple via the menu: Tools > Assistants > Import Data... The data was retrieved as a matrix within the Maple file and assigned to a variable and used for plots ...
Why doesn't the above procedure work properly? I hope one don't need to use the Workbook URI to reference files within the workbook. It is not that userfriendly!
Erik
Hello people in mapleprimes,
I think that I found a bug.
Using the screen opened with command + f, I tried to find a v__1211 in the file I appended here.
But, when the cursor is trapped on an output part, which is a blue part, maple wouldn't continue to find the next
v__1211 anymore even if I clicked the Find Next on the screen.
If I move the cursol one line below with a hand, the Find Next butttons works again, but it is intricate.
Isn't there any good way to avoid this trouble other than not using double _, that is __.?
I hope you will give me some hint.
taro
v_1211.mw
P.S. I clicked the above link and opened that file with maple. Then, the notification telling that this is read-only file and
you cannot save this file after some modification, appeared. I don't know whether there is any problem.
Does appending a maple file on a post on this mapleprimes always done in such a way?
The keyboard shortcut sequence for executing an entire worksheet is Alt+e+e+w. Occasionally, I hit Alt+e+w+w by accidence. In that case, Maple sometimes, not always!?, gets completely stuck and can only be shut down through the job list window (Windows Ctrl+Alt+Del). Can anybody else replicate that? And if so, has this erratically odd behaviour been fixed in later versions of Maple?
hi....how i can extract Coefficients  (i.e. {f1[2],f2[2],f2[3],f3[2],.....f3[6]}) from every algebric equations and create matrix A ,in form AX=0, (X are f1[2],f2[2],f2[3],f3[2],.....f3[6] ) then the determinant of the matrix of coefficients (A) set to zero for obtaining unknown parameter omega.?
Note that  if m=3 then 6 equations is appeare and if m=4 then 9 equations is appeare.thus i need a procedure that works for every arbitary value of ''m''.
in attached file below m=4 thus we have 9 equations, i.e. 3 for eq1[k_] and 3 for eq2[k_] and so on...
also we should use boundary conditions for some amount of fi[j] (i=1,2,3 and j=2,3,...,7)
be extacting above Coefficients for example from first equation ,
''**:= (1/128)*f1[2]*omega^2-(1/4)*f2[2]-(1/2)*f2[3]+(1/4)*f2[4]+(1/4)*f3[2]-(1/2)*f3[3]+(1/4)*f3[4]+140*f1[2]-80*f1[3]+20*f1[4]'''
must compute
coeff(**, f1[2]); coeff(**, f2[2]) and so on...
fdm-maple.mw
 ############################Define some parameters
restart; Digits := 15; A1 := 10; A2 := 10; A3 := 10; A4 := 1; A5 := 1; A6 := 1; A7 := 1; A8 := 1; A9 := 1; A10 := 1; A11 := 1; B1 := 10; B2 := 10; B3 := 10; B4 := 1; B5 := 1; B6 := 1; B7 := 1; B8 := 1; B9 := 1; B10 := 1; B11 := 1; C1 := 10; C2 := 10; C3 := 10; C4 := 1; C5 := 1; C6 := 1; C7 := 1; C8 := 1; C9 := 1; C10 := 1; C11 := 1; C12 := 1; C13 := 1; C14 := 1; C15 := 1; C16 := 1; A12 := 1; B12 := 1; C18 := 1; C17 := 1; C19 := 1; n := 1; U := proc (x, theta) options operator, arrow; f1(x)*cos(n*theta) end proc; V := proc (x, theta) options operator, arrow; f2(x)*sin(n*theta) end proc; W := proc (x, theta) options operator, arrow; f3(x)*cos(n*theta) end proc; n := 1; m := 4; len := 1; h := len/m; nn := m+1
 ############################Define some equation
eq1[k_] := -2*f1[k]*(-A11*n^4+A10*n^2+A12*omega^2)*h^4+(A6*(f2[k-1]-f2[k+1])*n^3+A9*(f3[k-1]-f3[k+1])*n^2-A5*(f2[k-1]-f2[k+1])*n-A8*(f3[k-1]-f3[k+1]))*h^3+(4*(f1[k]-(1/2)*f1[k-1]-(1/2)*f1[k+1]))*(A3*n^2-A2)*h^2+(-A4*(f2[k-2]-2*f2[k-1]+2*f2[k+1]-f2[k+2])*n-A7*(f3[k-2]-2*f3[k-1]+2*f3[k+1]-f3[k+2]))*h+12*A1*(f1[k]+(1/6)*f1[k-2]-(2/3)*f1[k-1]-(2/3)*f1[k+1]+(1/6)*f1[k+2]):
                                     ######################################  APPLY BOUNDARY CONDITIONS
f1[nn+1] := f1[m]:
for k from 2 to m do eq1[k_]; eq2[k_]; eq3[k_] end do
-(1/64)*f2[4]+(1/128)*f2[3]+(1/64)*(f3[4]-(1/2)*f3[3])*(omega^2-1)-(1/64)*f1[2]+(1/32)*f1[3]+(1/64)*f1[4]-280*f3[4]-120*f3[2]+300*f3[3]+20*f3[7]
Download fdm-maple.mw
Good morning, I'm a student and I installed Maple 18 on my PC, as a "Single User Profile". Unfortunately, I had to buy another computer, so now I'm trying to install the program on my new one. Even if I enter my Purchase Code and my details, Maple says that no more activations are left in my account, even if the expiration date is on March 2020. Is it possible to activate again the program?
Thank you,
Laura
Please help me.I don't know how to achieve the following iteration relation by maple code.iterative relationship
In a Maple Primes reply by Joel Riel on Sept. 14, 2011 he included the following command referring to warnings issued from a dsolve, numeric command having events containing a halt action:
_Env_in_maplet := true:  # incantation to suppress integrator warnings
Where can if find explanatory help for his command and any others of a similar nature?
m that i guess is genus,
but if i do not know genus number, how can i calculate with genus function
genus(y^m-(x...., x, y);
when i change m only the genus number is also changing
is my function wrong?
can i use this as a verification?
if m i set is 3 and then genus(...) result is 3
if result is equal to input 3, then it is correct function?
is hilbert series only for genus 0 only?
i got error
Error, (in Groebner:-Basis) the generators are not polynomials with respect to, {a, b, c, d}
how can i do this GIFs with maple ?
I am getting the error that maple was unable to allocate enough memmory for the computation. I have seen that some of the values could have been stored in a remember table so that they are accessed whenever needed. I am however using arrays and maple cannot tell when the entries in an array change, how about option cache? can that be useful? if not, how can I optimize my storage space?
in internet or maple, is there a neural network package in maple?
i find example link after googled, however, still feeling not easy to apply to data.
is there the most simplest version for two columns of data ?
First 189 190 191 192 193 194 195 Last Page 191 of 371
