which algorithm can be used to mining data set in maple after feature extraction
hope systematic and automatic doing this instead of using eyes
i feel derived attributes are unlimited, how to know sufficient?
in real practice,
what is application of the cycles in algcurves[homology] ?
is there any book teaching about the use of this function in maple?
> restart:with(plots):blt:=7:
> lambda:=2:m:=3:s:=1:
> Eq1:=(diff(f(eta),eta,eta,eta))+(f(eta)*(diff(f(eta),eta,eta)))-((diff(f(eta),eta))^2)+lambda*(((f(eta)*(diff(f(eta),eta,eta,eta))))-2*(diff(f(eta),eta))*(diff(f(eta),eta,eta,eta))^2)-(M/(1+m^2))*((diff(f(eta),eta)+ms))=0;
> Eq2:=(diff(h(eta),eta,eta))+(f(eta)*(diff(h(eta),eta)))-((diff(f(eta),eta))*(h(eta)))+lambda*(((f(eta)*(diff(h(eta),eta,eta,eta))))+(h(eta)*(diff(f(eta),eta,eta,eta)))+(diff(f(eta),eta,eta))*(diff(h(eta),eta))-2*(diff(f(eta),eta))*(diff(h(eta),eta,eta))+(M/(1+m^2)))*(m*(diff(f(eta),eta)-h))=0;
> Eq3:=((f(eta))*(diff(theta(eta),eta)))+Pr*((diff(theta(eta),eta,eta)))=0;
> bcs1 := f(0) = 0, (D(f))(0) = 1, (h)(0) = 0, (theta)(0) = 1, (D(f))(blt) = 0,  h(blt) = 0, theta(blt) = 0, D(D(f))(blt) = 0, (D(h))(blt)=0;
> L := [1,2,3];
> for k to 3 do R := dsolve(eval({Eq1, Eq2, Eq3, bcs1}, M = L[k]), [f(eta),h(eta),theta(eta)], numeric, maxmesh=10000, output = listprocedure);;Y || k := rhs(R[3]); YA || k := rhs(R[6]);YB || k := rhs(R[5]);YC || k := rhs(R[4]);YD || k := rhs(R[7]);end do:
Error, (in dsolve/numeric/bvp/convertsys) unable to convert to an explicit first-order system
i want a scheme of fractional differential equation so that i solve my questions and make a code of it.
please provide me the scheme
I was learning about Maple, but I do not understand this code below. This does not look correct.
http://www.maplesoft.com/support/help/Maple/view.aspx?path=Task/ConvertExpressionToFunction
When I type it on my worksheet, I get these errors
Sometimes I wonder if any one at Maplesoft actually looks at their own help web pages and try to use them, or is just the poor users who do that.
digit := 15;
F[0] := fw;
F[1] := delta*F[2]+epsilon;
F[2] := A;
T[0] := B;
T[1] := -1;
a := 0.01;
m := 1;
M := 1;
lambda := 1;
b := 1;
fw := 1;
epsilon := 1;
delta := 1;
Pr := 6;
Ec := 1;
R := 1;
for k from 0 to 7 do F[k+3] := (a*(sum((i+1)*(i+2)*F[i+2]*(k-i+1)*T[k-i+1], i = 0 .. k))-m(1+a*T[k]-(sum((i+1)*F[i+1]*(k-i+1)*F[k-i+1], i = 0 .. k))+a*(sum(sum(T[i]*(r-i+1)*F[r-i+1]*(k-r+1)*F[k-r+1], i = 0 .. r), r = 0 .. k)))-M*(1-(k+1)*F[k+1]+a*T[k]-a*(sum(T[i]*(k-i+1)*F[k-i+1], i = 0 .. k)))-((m+1)*(1/2))*(sum((i+1)*(i+2)*F[i+2]*F[k-i], i = 0 .. k)+a*(sum(sum(T[i]*F[k-r]*(r-i+1)*(r-i+2)*F[r-i+2], i = 0 .. r), r = 0 .. k)))-lambda*(T[k]+a*(sum(T[i]*T[k-i], i = 0 .. k))))/((k+1)*(k+2)*(k+3)); T[k+2] := (-(1+b/Pr)*(k+1)*T[k+1]-b*(sum(T[i]*(k-i+1)*T[k-i+1], i = 0 .. k))-M*Ec*(1-(2*(k+1))*(k+2)*F[k+2])-Ec*(1+M)*(sum((i+1)*(i+2)*F[i+2]*(k-i+1)*(k-i+2)*F[k-i+2], i = 0 .. k))-(1-2*m)*(sum(T[i]*(k-i+1)*F[k-i+1], i = 0 .. k))-((m+1)*(1/2))*(sum(F[i]*(k-i+1)*T[k-i+1], i = 0 .. k)))/((4/3)*R*(k+1)*(k+2)) end do;
FF := sum(F[j]*y^j, j = 0 .. 5);
TT := sum(T[j]*y^j, j = 0 .. 5);
with(numapprox); pade(FF, y, [4, 4]);
pade(diff(FF, y), y, [4, 4]);
pade(TT, y, [4, 4]);
solve({limit(pade(TT, y, [4, 4]), y = infinity) = 0, limit(pade(diff(FF, y), y, [4, 4]), y = infinity) = 1}, [A, B]);
If an expression is of the form x^3 + x^2 + x + z + y^3 + y^2 + y + xy=0 ,
How to represent it in the following form,
           x^3 + y^3 + x^2 + y^2 + xy + x + y + z=0 ?
I have exported a maple document to latex, but it only shows the output of the commands used. Rather than the commands, and the procedures.
How do I get both to export together? and show up together?
Is there a way to automatically convert and paste my clipboard contents as 2D math?
hi..when i use rule [for] in maple code i encounter error'''''
Error, (in dsolve/numeric/process_input) input system must be an ODE system, found {f1(x), f2(x), f3(x), ApproximateInt(-4*cos(theta)^2, theta = 0. .. 1, method = simpson), ApproximateInt(4*cos(theta)^2, theta = 0. .. 1, method = simpson), ApproximateInt(8*cos(theta)^2, theta = 0. .. 1, method = simpson)}''''''''
please help me for remove it
99999999999999.mw
i want for different beta for example beta=0, 40 and 80 this lines will computed three times
 ''with(Student[Calculus1]); a1 := ApproximateInt(g1*g1, theta = a .. 1, method = simpson); a2 := ApproximateInt(2*(g1*g1)+3*g1*(diff(g1, theta, theta)), theta = a .. 1, method = simpson).......................''
 by {for i from 1 by 1 to 3 do } and final gain ''ITRA_1_W[m] := eval(fy33*g3, fixedparameter)'' that have 3 amount.
when i use  rule {for i from 1 by 1 to 3 do ...  }   integral not computed and showed for example:::
a1=ApproximateInt(4*cos(theta)^2, theta = 0. .. 1, method = simpson)!!!!!!!!
thanks..
I read a posting by Mr. Stephen Forrest on Thingiverse about using the exportplot command to export a 3D plot as a .stl file. I have a 3D printer and need the convert the plot from the Maple file into an .stl file.
Here is the posting I am referencing:
Thingiverse/3dmodelimportexport.pdf
I was able to follow the commands successfully in the referenced paper for a hyperboloid or revolution that I plotted in Maple - it was very helpful. However, I could not figure out how to access the temporary .stl file that was created so that I could open it using my 3D printer's software.
My question is: Once I execute the "exportplot(stl, hyprev)" command that I inputted, how can I find the file in the Temporary Directory in order to open it from the software I use for my 3D printer?
I would appreciate any further details you can provide for accessing the temporary .stl file I created in order to be able to print the object.
Thank you!
I use Maple on a Surface Pro 4 tablet and the math input panel does not work with Maple.  This would be a great feature to have.  Or does anybody know how to get it working?
Hello Dr/Prof?sir?madam
i have problem on running the ode bcs
there is cos n sine in ther ode
any idea to solve this ?
i have attched it
thnks
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Sc.mw .
Download Sc.mw
For my first question, I am looking for some help about the following. I have the opportunity to run a worksheet in parallel on a cluster of sixteen workstations, each one endowed with twelve CPUs, through the GRID Computing Toolbox. However, I have troubles concerning how to do that.
I join the worksheet at issue: abmm_ma_1.mw The aim is to run large-scale numerical simulations of a dynamic system, depending on the values given to the initial conditions and to the parameters. The worksheet is organized in four execution groups:
  1. The required packages (combinat and LinearAlgebra).
  2. Calibration of the parameters and initial conditions.
  3. The system, which is embedded into a procedure called SIM.
  4. The activation of SIM, whose outputs are nine .mla files, each one being made of a real-number matrix.
The truth is, I do not clearly see how to modify the worksheet with some elements of the GRID package. Besides, the cluster operates under HTCondor so that running the worksheet requires beforehand the creation of a .sub file. This should be done in consistency with the aforesaid modification.
Any help is welcome, thanks a lot.
First 190 191 192 193 194 195 196 Last Page 192 of 371
