I wondering if it is able to create a new symbol in maple, like it is possible to create a custom snippet in the pallets. Speceficly I am asking how to create a new symbol/charachter for 2D math. So if anyone knows please tell me :)
Hello everybody!
Please help me to solve the attached partial differential equation. I am getting an error. I do have its analytical solution and that works fine.
The error is as follows
Error, (in pdsolve/numeric/plot) unable to compute solution for t>HFloat(0.0):
solution becomes undefined, problem may be ill posed or method may be ill suited to solution
The worksheet is attached hereshortsngle.mw
Hi All,
When doing retart in a saved workbook get a no read access error link (see partial screen shot below). When the link is followed the message is there is no help for this error.
I am using Windows 10 64 bit and have full administrative prilvilages so I not sure what the problem is.
I have the same issue when I upload to the cloud.
In spite of message I can still do computations.
Any help in understanding this will be greatly appreciated.
Joe
In Maple V, Release 4 (1996):
T:=table():
i:=1:N:=5000;
for i from i to N
do
   T[i]:=T[i+1]:
   T[i+1]:=1;
   eval(T[1]);
print(i);
for i from i to N
do
   T[i]:=T[i+1]:
   T[i+1]:=1;
   eval(T[1]);
print(i);
I receive this output:
N := 5000
Error, too many levels of recursion
3607
5001
Can You explain this occurence, as well as the following one:
T:=table():
i:=1:N:=5000;
for i from i to N
do
  T[i]:=T[i+1]:
  eval(T[1]);
print(i);
for i from i to N
do
  T[i]:=T[i+1]:
  eval(T[1]);
print(i);;
gives:
N := 5000
3607
3607
How does one control allowance for recursion depth?
Hey,
I want to solve this equation and looking at the plot there are at least 3 solutions. I want the greatest/smallest negative solution. Unfortunately using solve with assumptions produces no results and solve without assumptions only finds two solutions.
Can you please help me?
#select greatest negative value from solution
expr:= ax*cos(lambda)+ay*sin(lambda)-(a+b*lambda)
ax*cos(lambda)+ay*sin(lambda)-b*lambda-a
ax:=1:ay:=2:a:=0.5:b:=0.25: #examplanatory values
plot(expr)
assume(-2*Pi<lambda,lambda<0): #does not work
sol_lambda:=[solve(expr=0,lambda, useassumptions)];# returns empty list even though without assumption one solution is found
sol_lambda:=[solve(expr=0,lambda)]; #returns only two solutions even though looking at the plot 3 are there
Warning, solve may be ignoring assumptions on the input variables.
[2.190357220, -.2688724573]
sol_l_v:=evalb~(sol_lambda<~0); #dirty workaraound
[false, true]
sol_l_add:=[ListTools:-SearchAll(true,sol_l_v)] ; #this seems overly complicated
[2]
lambda:=sol_lambda[sol_l_add[-1]];  #to select the last entry
-.2688724573
expr; #test
0.
Download select_solution.mw
Honigmelone
This is regarding numerical solution of a function and plot. I have a function in the form of f1(omega,arctan(f2(omega))), and i need to plot it with omega (as the expression is too long i cant insert it here). Now, if i am changing the range of omega in plot command then I am getting different plots for the small values of omega. Let's say if i change the range from 1..10 to 1..50 and look at the plot in the range of 1..3 then the plots looks different. Apart from this if i change the value of Digits  from 10 to 30 or 40 then every time i am getting an entire different  plot. As the expression if too long i cant convert it to Matlab expression and plot there. How to fix these issues. Please help me regarding this.
Regarding
Sunit
After using the Groebner and PolynomialIdeals packages, Maple goes into a long calculation when I make an entry of the form
name:=polynomial expression. This can take 10's of minutes for an expression of two lines. The only solution I have found is to save the sheet and restart it and enter the line name:= etc. before loading Groebner and PolynomialIdeals. This is most inconvenient. Is there a better workaround?
I would like compute the vertices of the convex hull of finitely many points in some \mathbb{R}^{n}, where the coordinates of these points could be rational numbers or irrational numbers like \sqrt{2}.
I know that PolyhedralSets[ConvexHull] is a direct command, however it does not support irrational numbers. But if I transform all coordinates into floating point numbers, for some rational numbers the rounding error would be large enough to affect the result. For example, after the transform some collinear points are no longer collinear.
USB and or RS232 porting from inside maple console. Title explains what i need, or how to port an externally built java app into the maple console, either which will engine my dispatch tonight
how to use Riemann matrix to output Riemann surface?
and plot this surface?
with(algcurves):
f:=y^3+2*x^7-x^3*y;
pm:=periodmatrix(f,x,y);
evalf(pm, 5);
rm:=evalf(periodmatrix(f,x,y,Riemann),10);
M := rm;
A := proc (x, y) options operator, arrow; RiemannTheta([x, y], M, [], 0.1e-1, output = list)[2] end proc;
plot3d(Re(A(x+I*y, 0)), x = 0 .. 1, y = 0 .. 4, grid = [40, 40]);
is this graph Riemann Surface?
if so, how to convert A into polynomials?
I'm displaying a series of point plots as an animation, and would like to update a displayed parameter as well.  I have a nested list L[t] where there's a set of points for each t, and for each t there's also a numerical value M that I'd like to display.  (In my real problem, L[t] is the number of particles in each of several states, and M is the rms deviation from am algebraic probability distribution.)
The closest I've gotten (for a simple L and M) is the following, but it displays all of the M values in the legend at once:
with(plots); with(Statistics);
L := [[1, 2, 3, 4, 5, 6], [2, 4, 6, 8, 10, 12]];
M := [1, 2];
display([seq(PointPlot(L[t], legend = M[t]), t = 1 .. 2)], insequence = true)
I don't need this to be in the legend.  Is there a way to display only the current value of M for each t?  Thanks very much.
Dear All
In following I tried to find symmetries of certain partial differential equation taken from paper "Group classification and exact solutions of generalized modified Boussinesq equation". But the determining equations are not matching with equations obtained in paper.
with(PDEtools)
DepVars := [f(u(x, t)), u(x, t)]; declare(f(u(x, t)), u(x, t))
f(u(x, t))*`will now be displayed as`*f
u(x, t)*`will now be displayed as`*u
PDE1 := diff(u(x, t), t, t)-delta*(diff(u(x, t), x, x, t, t))-(diff(f(u(x, t)), x, x))
diff(diff(u(x, t), t), t)-delta*(diff(diff(diff(diff(u(x, t), t), t), x), x))-((D@@2)(f))(u(x, t))*(diff(u(x, t), x))^2-(D(f))(u(x, t))*(diff(diff(u(x, t), x), x))
G := [seq(xi[j](x, t, u), j = [x, t]), seq(eta[j](x, t, u), j = [u])]
[xi[x](x, t, u), xi[t](x, t, u), eta[u](x, t, u)]
declare(G)
eta(x, t, u)*`will now be displayed as`*eta
xi(x, t, u)*`will now be displayed as`*xi
DetSys := DeterminingPDE(PDE1, G, integrabilityconditions = false)
{diff(diff(xi[t](x, t, u), u), u)-(diff(diff(diff(diff(xi[t](x, t, u), u), u), x), x))*delta, (diff(diff(eta[u](x, t, u), x), x))*(diff(f(u), u))+(diff(diff(diff(diff(eta[u](x, t, u), t), t), x), x))*delta-(diff(diff(eta[u](x, t, u), t), t)), -(diff(diff(xi[x](x, t, u), u), u))*(diff(f(u), u))-(diff(diff(diff(diff(xi[x](x, t, u), t), t), u), u))*delta+(diff(diff(f(u), u), u))*(diff(xi[x](x, t, u), u)), 2*(diff(diff(diff(diff(xi[x](x, t, u), u), u), u), x))+2*(diff(diff(diff(diff(xi[t](x, t, u), t), u), u), u))-(diff(diff(diff(diff(eta[u](x, t, u), u), u), u), u)), 2*(diff(diff(diff(xi[x](x, t, u), u), u), x))+2*(diff(diff(diff(xi[t](x, t, u), t), u), u))-(diff(diff(diff(eta[u](x, t, u), u), u), u)), 4*(diff(diff(xi[x](x, t, u), t), x))-2*(diff(diff(eta[u](x, t, u), t), u))+diff(diff(xi[t](x, t, u), t), t), 2*(diff(diff(xi[x](x, t, u), u), x))+2*(diff(diff(xi[t](x, t, u), t), u))-(diff(diff(eta[u](x, t, u), u), u)), diff(diff(xi[x](x, t, u), x), x)-2*(diff(diff(eta[u](x, t, u), u), x))+4*(diff(diff(xi[t](x, t, u), t), x)), -2*(diff(xi[x](x, t, u), x))+(diff(diff(diff(eta[u](x, t, u), u), x), x))*delta-2*(diff(diff(diff(xi[t](x, t, u), t), x), x))*delta, -(diff(diff(diff(xi[x](x, t, u), u), x), x))*delta-4*(diff(diff(diff(xi[t](x, t, u), t), u), x))*delta+2*(diff(diff(diff(eta[u](x, t, u), u), u), x))*delta-2*(diff(xi[x](x, t, u), u)), (diff(diff(f(u), u), u))*eta[u](x, t, u)+(diff(diff(diff(eta[u](x, t, u), t), t), u))*delta-2*(diff(diff(diff(xi[x](x, t, u), t), t), x))*delta+2*(diff(xi[t](x, t, u), t))*(diff(f(u), u)), -2*(diff(xi[t](x, t, u), u))*(diff(f(u), u))+4*delta*(diff(diff(diff(eta[u](x, t, u), t), u), u))-2*(diff(diff(diff(xi[t](x, t, u), t), t), u))*delta-8*(diff(diff(diff(xi[x](x, t, u), t), u), x))*delta, 2*(diff(xi[t](x, t, u), u))*(diff(f(u), u))+2*delta*(diff(diff(diff(eta[u](x, t, u), t), u), u))-(diff(diff(diff(xi[t](x, t, u), t), t), u))*delta-4*(diff(diff(diff(xi[x](x, t, u), t), u), x))*delta, 2*(diff(diff(xi[t](x, t, u), t), u))-(diff(diff(eta[u](x, t, u), u), u))+(diff(diff(diff(diff(eta[u](x, t, u), u), u), x), x))*delta-2*(diff(diff(diff(diff(xi[t](x, t, u), t), u), x), x))*delta, diff(diff(xi[x](x, t, u), u), u)-4*(diff(diff(diff(diff(xi[t](x, t, u), t), u), u), x))*delta+2*(diff(diff(diff(diff(eta[u](x, t, u), u), u), u), x))*delta-(diff(diff(diff(diff(xi[x](x, t, u), u), u), x), x))*delta, 2*(diff(xi[x](x, t, u), u))-8*(diff(diff(diff(xi[t](x, t, u), t), u), x))*delta+4*(diff(diff(diff(eta[u](x, t, u), u), u), x))*delta-2*(diff(diff(diff(xi[x](x, t, u), u), x), x))*delta, -(diff(diff(xi[t](x, t, u), u), u))*(diff(f(u), u))-4*(diff(diff(diff(diff(xi[x](x, t, u), t), u), u), x))*delta-(diff(diff(diff(diff(xi[t](x, t, u), t), t), u), u))*delta+(diff(diff(f(u), u), u))*(diff(xi[t](x, t, u), u))+2*(diff(diff(diff(diff(eta[u](x, t, u), t), u), u), u))*delta, -(diff(diff(xi[t](x, t, u), x), x))*(diff(f(u), u))+diff(diff(xi[t](x, t, u), t), t)-2*(diff(diff(eta[u](x, t, u), t), u))+2*(diff(diff(diff(diff(eta[u](x, t, u), t), u), x), x))*delta-(diff(diff(diff(diff(xi[t](x, t, u), t), t), x), x))*delta, -2*(diff(xi[t](x, t, u), x))*(diff(f(u), u))+2*(diff(xi[x](x, t, u), t))-2*(diff(diff(diff(xi[x](x, t, u), t), x), x))*delta+4*(diff(diff(diff(eta[u](x, t, u), t), u), x))*delta-2*(diff(diff(diff(xi[t](x, t, u), t), t), x))*delta, (diff(diff(diff(diff(eta[u](x, t, u), t), t), u), u))*delta-2*(diff(diff(diff(diff(xi[x](x, t, u), t), t), u), x))*delta+(diff(diff(diff(f(u), u), u), u))*eta[u](x, t, u)+(diff(diff(eta[u](x, t, u), u), u))*(diff(f(u), u))-2*(diff(diff(xi[x](x, t, u), u), x))*(diff(f(u), u))+2*(diff(diff(f(u), u), u))*(diff(xi[t](x, t, u), t)+(1/2)*(diff(eta[u](x, t, u), u))), -(diff(diff(xi[x](x, t, u), x), x))*(diff(f(u), u))+2*(diff(diff(eta[u](x, t, u), u), x))*(diff(f(u), u))+2*(diff(diff(f(u), u), u))*(diff(eta[u](x, t, u), x))+diff(diff(xi[x](x, t, u), t), t)-delta*(diff(diff(diff(diff(xi[x](x, t, u), t), t), x), x))+2*delta*(diff(diff(diff(diff(eta[u](x, t, u), t), t), u), x)), 2*(diff(diff(xi[x](x, t, u), t), u))-2*(diff(diff(xi[t](x, t, u), u), x))*(diff(f(u), u))-2*(diff(xi[t](x, t, u), x))*(diff(diff(f(u), u), u))+4*(diff(diff(diff(diff(eta[u](x, t, u), t), u), u), x))*delta-2*(diff(diff(diff(diff(xi[t](x, t, u), t), t), u), x))*delta-2*(diff(diff(diff(diff(xi[x](x, t, u), t), u), x), x))*delta, diff(diff(diff(diff(xi[t](x, t, u), u), u), u), u), diff(diff(diff(diff(xi[t](x, t, u), u), u), u), x), diff(diff(diff(diff(xi[x](x, t, u), t), u), u), u), diff(diff(diff(diff(xi[x](x, t, u), u), u), u), u), diff(diff(diff(xi[t](x, t, u), u), u), u), diff(diff(diff(xi[t](x, t, u), u), u), x), diff(diff(diff(xi[t](x, t, u), u), x), x), diff(diff(diff(xi[x](x, t, u), t), t), u), diff(diff(diff(xi[x](x, t, u), t), u), u), diff(diff(diff(xi[x](x, t, u), u), u), u), diff(diff(xi[t](x, t, u), u), u), diff(diff(xi[t](x, t, u), u), x), diff(diff(xi[t](x, t, u), x), x), diff(diff(xi[x](x, t, u), t), t), diff(diff(xi[x](x, t, u), t), u), diff(diff(xi[x](x, t, u), u), u), diff(xi[t](x, t, u), u), diff(xi[t](x, t, u), x), diff(xi[x](x, t, u), t), diff(xi[x](x, t, u), u)}
for EQ in sort([op(DetSys)], length) do EQ = 0 end do
diff(xi[t](x, t, u), u) = 0
diff(xi[t](x, t, u), x) = 0
diff(xi[x](x, t, u), t) = 0
diff(xi[x](x, t, u), u) = 0
diff(diff(xi[t](x, t, u), u), u) = 0
diff(diff(xi[t](x, t, u), u), x) = 0
diff(diff(xi[t](x, t, u), x), x) = 0
diff(diff(xi[x](x, t, u), t), t) = 0
diff(diff(xi[x](x, t, u), t), u) = 0
diff(diff(xi[x](x, t, u), u), u) = 0
diff(diff(diff(xi[t](x, t, u), u), u), u) = 0
diff(diff(diff(xi[t](x, t, u), u), u), x) = 0
diff(diff(diff(xi[t](x, t, u), u), x), x) = 0
diff(diff(diff(xi[x](x, t, u), t), t), u) = 0
diff(diff(diff(xi[x](x, t, u), t), u), u) = 0
diff(diff(diff(xi[x](x, t, u), u), u), u) = 0
diff(diff(diff(diff(xi[t](x, t, u), u), u), u), u) = 0
diff(diff(diff(diff(xi[t](x, t, u), u), u), u), x) = 0
diff(diff(diff(diff(xi[x](x, t, u), t), u), u), u) = 0
diff(diff(diff(diff(xi[x](x, t, u), u), u), u), u) = 0
diff(diff(xi[t](x, t, u), u), u)-(diff(diff(diff(diff(xi[t](x, t, u), u), u), x), x))*delta = 0
4*(diff(diff(xi[x](x, t, u), t), x))-2*(diff(diff(eta[u](x, t, u), t), u))+diff(diff(xi[t](x, t, u), t), t) = 0
2*(diff(diff(xi[x](x, t, u), u), x))+2*(diff(diff(xi[t](x, t, u), t), u))-(diff(diff(eta[u](x, t, u), u), u)) = 0
diff(diff(xi[x](x, t, u), x), x)-2*(diff(diff(eta[u](x, t, u), u), x))+4*(diff(diff(xi[t](x, t, u), t), x)) = 0
2*(diff(diff(diff(xi[x](x, t, u), u), u), x))+2*(diff(diff(diff(xi[t](x, t, u), t), u), u))-(diff(diff(diff(eta[u](x, t, u), u), u), u)) = 0
-2*(diff(xi[x](x, t, u), x))+(diff(diff(diff(eta[u](x, t, u), u), x), x))*delta-2*(diff(diff(diff(xi[t](x, t, u), t), x), x))*delta = 0
(diff(diff(eta[u](x, t, u), x), x))*(diff(f(u), u))+(diff(diff(diff(diff(eta[u](x, t, u), t), t), x), x))*delta-(diff(diff(eta[u](x, t, u), t), t)) = 0
2*(diff(diff(diff(diff(xi[x](x, t, u), u), u), u), x))+2*(diff(diff(diff(diff(xi[t](x, t, u), t), u), u), u))-(diff(diff(diff(diff(eta[u](x, t, u), u), u), u), u)) = 0
-(diff(diff(xi[x](x, t, u), u), u))*(diff(f(u), u))-(diff(diff(diff(diff(xi[x](x, t, u), t), t), u), u))*delta+(diff(diff(f(u), u), u))*(diff(xi[x](x, t, u), u)) = 0
-(diff(diff(diff(xi[x](x, t, u), u), x), x))*delta-4*(diff(diff(diff(xi[t](x, t, u), t), u), x))*delta+2*(diff(diff(diff(eta[u](x, t, u), u), u), x))*delta-2*(diff(xi[x](x, t, u), u)) = 0
2*(diff(xi[x](x, t, u), u))-8*(diff(diff(diff(xi[t](x, t, u), t), u), x))*delta+4*(diff(diff(diff(eta[u](x, t, u), u), u), x))*delta-2*(diff(diff(diff(xi[x](x, t, u), u), x), x))*delta = 0
2*(diff(diff(xi[t](x, t, u), t), u))-(diff(diff(eta[u](x, t, u), u), u))+(diff(diff(diff(diff(eta[u](x, t, u), u), u), x), x))*delta-2*(diff(diff(diff(diff(xi[t](x, t, u), t), u), x), x))*delta = 0
(diff(diff(f(u), u), u))*eta[u](x, t, u)+(diff(diff(diff(eta[u](x, t, u), t), t), u))*delta-2*(diff(diff(diff(xi[x](x, t, u), t), t), x))*delta+2*(diff(xi[t](x, t, u), t))*(diff(f(u), u)) = 0
-2*(diff(xi[t](x, t, u), u))*(diff(f(u), u))+4*delta*(diff(diff(diff(eta[u](x, t, u), t), u), u))-2*(diff(diff(diff(xi[t](x, t, u), t), t), u))*delta-8*(diff(diff(diff(xi[x](x, t, u), t), u), x))*delta = 0
2*(diff(xi[t](x, t, u), u))*(diff(f(u), u))+2*delta*(diff(diff(diff(eta[u](x, t, u), t), u), u))-(diff(diff(diff(xi[t](x, t, u), t), t), u))*delta-4*(diff(diff(diff(xi[x](x, t, u), t), u), x))*delta = 0
diff(diff(xi[x](x, t, u), u), u)-4*(diff(diff(diff(diff(xi[t](x, t, u), t), u), u), x))*delta+2*(diff(diff(diff(diff(eta[u](x, t, u), u), u), u), x))*delta-(diff(diff(diff(diff(xi[x](x, t, u), u), u), x), x))*delta = 0
-2*(diff(xi[t](x, t, u), x))*(diff(f(u), u))+2*(diff(xi[x](x, t, u), t))-2*(diff(diff(diff(xi[x](x, t, u), t), x), x))*delta+4*(diff(diff(diff(eta[u](x, t, u), t), u), x))*delta-2*(diff(diff(diff(xi[t](x, t, u), t), t), x))*delta = 0
-(diff(diff(xi[t](x, t, u), x), x))*(diff(f(u), u))+diff(diff(xi[t](x, t, u), t), t)-2*(diff(diff(eta[u](x, t, u), t), u))+2*(diff(diff(diff(diff(eta[u](x, t, u), t), u), x), x))*delta-(diff(diff(diff(diff(xi[t](x, t, u), t), t), x), x))*delta = 0
-(diff(diff(xi[t](x, t, u), u), u))*(diff(f(u), u))-4*(diff(diff(diff(diff(xi[x](x, t, u), t), u), u), x))*delta-(diff(diff(diff(diff(xi[t](x, t, u), t), t), u), u))*delta+(diff(diff(f(u), u), u))*(diff(xi[t](x, t, u), u))+2*(diff(diff(diff(diff(eta[u](x, t, u), t), u), u), u))*delta = 0
-(diff(diff(xi[x](x, t, u), x), x))*(diff(f(u), u))+2*(diff(diff(eta[u](x, t, u), u), x))*(diff(f(u), u))+2*(diff(diff(f(u), u), u))*(diff(eta[u](x, t, u), x))+diff(diff(xi[x](x, t, u), t), t)-delta*(diff(diff(diff(diff(xi[x](x, t, u), t), t), x), x))+2*delta*(diff(diff(diff(diff(eta[u](x, t, u), t), t), u), x)) = 0
2*(diff(diff(xi[x](x, t, u), t), u))-2*(diff(diff(xi[t](x, t, u), u), x))*(diff(f(u), u))-2*(diff(xi[t](x, t, u), x))*(diff(diff(f(u), u), u))+4*(diff(diff(diff(diff(eta[u](x, t, u), t), u), u), x))*delta-2*(diff(diff(diff(diff(xi[t](x, t, u), t), t), u), x))*delta-2*(diff(diff(diff(diff(xi[x](x, t, u), t), u), x), x))*delta = 0
(diff(diff(diff(diff(eta[u](x, t, u), t), t), u), u))*delta-2*(diff(diff(diff(diff(xi[x](x, t, u), t), t), u), x))*delta+(diff(diff(diff(f(u), u), u), u))*eta[u](x, t, u)+(diff(diff(eta[u](x, t, u), u), u))*(diff(f(u), u))-2*(diff(diff(xi[x](x, t, u), u), x))*(diff(f(u), u))+2*(diff(diff(f(u), u), u))*(diff(xi[t](x, t, u), t)+(1/2)*(diff(eta[u](x, t, u), u))) = 0
DetSys1 := dsubs(diff(xi[t](x, t, u), u) = 0, diff(xi[t](x, t, u), x) = 0, diff(xi[x](x, t, u), t) = 0, diff(xi[x](x, t, u), u) = 0, diff(eta[u](x, t, u), u, u) = 0, diff(eta[u](x, t, u), x, u, t) = 0, DetSys)
{0, diff(diff(xi[t](x, t, u), t), t)-2*(diff(diff(eta[u](x, t, u), t), u)), diff(diff(xi[x](x, t, u), x), x)-2*(diff(diff(eta[u](x, t, u), u), x)), -2*(diff(xi[x](x, t, u), x))+(diff(diff(diff(eta[u](x, t, u), u), x), x))*delta, (diff(diff(diff(f(u), u), u), u))*eta[u](x, t, u)+2*(diff(diff(f(u), u), u))*(diff(xi[t](x, t, u), t))+(diff(diff(f(u), u), u))*(diff(eta[u](x, t, u), u)), (diff(diff(f(u), u), u))*eta[u](x, t, u)+(diff(diff(diff(eta[u](x, t, u), t), t), u))*delta+2*(diff(xi[t](x, t, u), t))*(diff(f(u), u)), (diff(diff(eta[u](x, t, u), x), x))*(diff(f(u), u))+(diff(diff(diff(diff(eta[u](x, t, u), t), t), x), x))*delta-(diff(diff(eta[u](x, t, u), t), t)), -(diff(diff(xi[x](x, t, u), x), x))*(diff(f(u), u))+2*(diff(diff(eta[u](x, t, u), u), x))*(diff(f(u), u))+2*(diff(diff(f(u), u), u))*(diff(eta[u](x, t, u), x))}
for EQ in sort([op(DetSys1)], length) do EQ = 0 end do
0 = 0
diff(diff(xi[t](x, t, u), t), t)-2*(diff(diff(eta[u](x, t, u), t), u)) = 0
diff(diff(xi[x](x, t, u), x), x)-2*(diff(diff(eta[u](x, t, u), u), x)) = 0
-2*(diff(xi[x](x, t, u), x))+(diff(diff(diff(eta[u](x, t, u), u), x), x))*delta = 0
(diff(diff(f(u), u), u))*eta[u](x, t, u)+(diff(diff(diff(eta[u](x, t, u), t), t), u))*delta+2*(diff(xi[t](x, t, u), t))*(diff(f(u), u)) = 0
(diff(diff(diff(f(u), u), u), u))*eta[u](x, t, u)+2*(diff(diff(f(u), u), u))*(diff(xi[t](x, t, u), t))+(diff(diff(f(u), u), u))*(diff(eta[u](x, t, u), u)) = 0
-(diff(diff(xi[x](x, t, u), x), x))*(diff(f(u), u))+2*(diff(diff(eta[u](x, t, u), u), x))*(diff(f(u), u))+2*(diff(diff(f(u), u), u))*(diff(eta[u](x, t, u), x)) = 0
The third equation in (8) can simplify last equation. This will give us eta[u][x] = 0as f[u, u] is non zero.
Download [1116]_Symmetries_Determination.mw[1116]_Group_classification_and_exact_solutions_of_generalized_modified_Boussinesq_equation.pdf
Still a little unclear what this error means tho
-f(X)/(X*(ln(X)-Psi(1-f(X))-Psi(f(X)))*GAMMA(1-m))+X*(ln(X)-Psi(1-f(X))-Psi(f(X)))/(f(X)*GAMMA(1-m)) = 0
Download dispatchTOshillCORE.mw
updated:
with(CurveFitting);
f := PolynomialInterpolation([[0, x0],[1, x1],[2, x2],[3, x3],[4, x4]], x);
f2 := solve(f=y,x);
area1 := int(f, x=0..1);
with(student):
area2 := trapezoid(f2[1], x = 0..1);
with(CurveFitting);
f := PolynomialInterpolation([[0, x0],[1, x1],[2, x2],[3, x3]], x);
f2 := solve(f=y,x);
with(student):
i use 5 points trapezoid got RootOf  in result,
only 4 points is acceptable
when i try 5 points, there is no problem, but when more points such as
30 points, got RootOf for c sharp code
moreover, i got a problem when i copy the area1 result into
visual studio c# code, it has error Integral Constant is too large
with(CurveFitting);
f := PolynomialInterpolation([[0, x0],[1, x1],[2, x2],[3, x3],[4, x4],[5, x5],[6, x6],[7, x7],[8, x8],[9, x9],[10, x10],[11, x11],[12, x12],[13, x13],[14, x14],[15, x15],[16, x16],[17, x17],[18, x18],[19, x19],[20, x20],[21, x21],[22, x22],[23, x23],[24, x24],[25, x25],[26, x26],[27, x27],[28, x28],[29, x29]], x);
f2 := solve(f=y,x);
area1 := int(f, y=0..1);
with(student):
with(CodeGeneration):
CSharp(area1, resultname = "area1");
CSharp(area2, resultname = "area2");
i find area2 has
Warning, the function names {RootOf, Sum} are not recognized in the target language
Warning, precedence for Range unspecified
Warning, cannot translate range
area2 = RootOf((System.Double) (19276689540529530246975515949293568 * x3 - 2626509155780373903082144116707328 * x2 + 239680950855919251544490932629504 * x1 -
I am trying to solve a set of homogeneous equations for the non-trivial solutions. Mathematically it is possible to get it. But is there any way to get it in Maple. Please find the attached maple sheet for the question. Please help me regarding this.
Sunit
eq[1] := diff(x[1](t), t)-x[2](t)
eq[2] := diff(x[2](t), t)+2*zeta*beta*x[2](t)+beta^2*x[1](t)+n*psi*(-v*(phi[1](t)-phi[1](t-2*Pi/(n*omega0)))+x[1](t)-x[1](t-2*Pi/(n*omega0)))
eq[3] := diff(phi[1](t), t)-phi[2](t)
eq[4] := diff(phi[2](t), t)+2*kappa*phi[2](t)+phi[1](t)+n*(-v*(phi[1](t)-phi[1](t-2*Pi/(n*omega0)))+x[1](t)-x[1](t-2*Pi/(n*omega0)))
for k to 4 do eqn[k] := simplify(coeff(map(expand, eval(eq[k], [x[1] = (proc (t) options operator, arrow; x[1]*exp(lambda*t) end proc), x[2] = (proc (t) options operator, arrow; x[2]*exp(lambda*t) end proc), phi[1] = (proc (t) options operator, arrow; phi[1]*exp(lambda*t) end proc), phi[2] = (proc (t) options operator, arrow; phi[2]*exp(lambda*t) end proc)])), exp(lambda*t))) end do
x[1]*lambda-x[2]
x[2]*lambda+2*zeta*beta*x[2]+beta^2*x[1]-n*psi*v*phi[1]+n*psi*v*phi[1]*exp(-2*lambda*Pi/(n*omega0))+n*psi*x[1]-n*psi*x[1]*exp(-2*lambda*Pi/(n*omega0))
phi[1]*lambda-phi[2]
phi[2]*lambda+2*kappa*phi[2]+phi[1]-n*v*phi[1]+n*v*phi[1]*exp(-2*lambda*Pi/(n*omega0))+n*x[1]-n*x[1]*exp(-2*lambda*Pi/(n*omega0))
A, b := GenerateMatrix([seq(eqn[k], k = 1 .. 4)], [x[1], x[2], phi[1], phi[2]])
A, b := Matrix(4, 4, {(1, 1) = lambda, (1, 2) = -1, (1, 3) = 0, (1, 4) = 0, (2, 1) = beta^2+n*psi-n*psi*exp(-2*lambda*Pi/(n*omega0)), (2, 2) = 2*Zeta*beta+lambda, (2, 3) = n*psi*v*exp(-2*lambda*Pi/(n*omega0))-n*psi*v, (2, 4) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = lambda, (3, 4) = -1, (4, 1) = n-n*exp(-2*lambda*Pi/(n*omega0)), (4, 2) = 0, (4, 3) = -n*v+1+n*v*exp(-2*lambda*Pi/(n*omega0)), (4, 4) = 2*kappa+lambda}), Vector(4, {(1) = 0, (2) = 0, (3) = 0, (4) = 0})
right_vector := Matrix(4, 1, [r[1], r[2], r[3], r[4]])
right_vector := Matrix(4, 1, {(1, 1) = r[1], (2, 1) = r[2], (3, 1) = r[3], (4, 1) = r[4]})
junk := MatrixVectorMultiply(subs(lambda = I*omega, A), right_vector)
junk := Matrix(4, 1, {(1, 1) = I*omega*r[1]-r[2], (2, 1) = (beta^2+n*psi-n*psi*exp(-(2*I)*omega*Pi/(n*omega0)))*r[1]+(2*Zeta*beta+I*omega)*r[2]+(n*psi*v*exp(-(2*I)*omega*Pi/(n*omega0))-n*psi*v)*r[3], (3, 1) = I*omega*r[3]-r[4], (4, 1) = (n-n*exp(-(2*I)*omega*Pi/(n*omega0)))*r[1]+(-n*v+1+n*v*exp(-(2*I)*omega*Pi/(n*omega0)))*r[3]+(2*kappa+I*omega)*r[4]})
junk(1)
I*omega*r[1]-r[2]
for k to 4 do eqnn[k] := junk(k) end do
I*omega*r[1]-r[2]
(beta^2+n*psi-n*psi*exp(-(2*I)*omega*Pi/(n*omega0)))*r[1]+(2*zeta*beta+I*omega)*r[2]+(n*psi*v*exp(-(2*I)*omega*Pi/(n*omega0))-n*psi*v)*r[3]
I*omega*r[3]-r[4]
(n-n*exp(-(2*I)*omega*Pi/(n*omega0)))*r[1]+(1-n*v+n*v*exp(-(2*I)*omega*Pi/(n*omega0)))*r[3]+(2*kappa+I*omega)*r[4]
solve({seq(eqnn[k], k = 1 .. 4)}, {seq(r[k], k = 1 .. 4)})
{r[1] = 0, r[2] = 0, r[3] = 0, r[4] = 0}
Download question4.mw
First 188 189 190 191 192 193 194 Last Page 190 of 371
