Consider a taper steel plate of uniform thickness t := 25mm as shown in the Fig. In addition to its self weight, the plate is subjected to a point load P := 100N at its mid point. Find the global force vector [F] , global stiffness matrix [K] , displacement in each element (1 and 2) , stresses in each element  (1 and 2) and reaction force at the support.Take E := 2*10^5N/mm2; rho := 8.2*10^(-5)kg/m3;
t__1 := 150:
t__3 := 75:
w := 25:
l := 600:
t__2 := (t__1-t__3)/l*((1/2)*l)+t__3 = 225/2
A__1 := t__1*w = 3750``
A__2 := t__2*w = 5625/2``
A__3 := t__3*w = 1875``
Revised areas:
A__1e := (A__1+A__2)*(1/2) = 13125/4``
A__2e := (A__2+A__3)*(1/2) = 9375/4``
  E := 2*10^11:m2; F__1 := R__1:is support reaction N; F__2 := 100:N;``
rho__1 := 82*10^(-6) = 41/500000  N/mm2
rho__2 := 82*10^(-6) = 41/500000 N/mm2
l := 600:``
Number of elements,
n__e := 2:
l__e := 300 = 300````
q__0 := 100:N/m ; l := 1: m; n__e := 4:  elementsl  l__e := l/n__e: m;
We shall consider a two element system as shown in the Fig.
For element 1 Stiffness matrix K is
                                           Vector[row](2, {(1) = 1, (2) = 2})
K__1 := A__1e*E/l__e.(Matrix(2, 2, {(1, 1) = 1, (1, 2) = -1, (2, 1) = -1, (2, 2) = 1})) = Matrix([[2625000000000000, -2625000000000000], [-2625000000000000, 2625000000000000]])  Vector(2, {(1) = 1, (2) = 2})
For element 2 Stiffness matrix K is
                                         Vector[row](2, {(1) = 2, (2) = 3})
K__2 := A__2e*E/l__e.(Matrix(2, 2, {(1, 1) = 1, (1, 2) = -1, (2, 1) = -1, (2, 2) = 1})) = Matrix([[1875000000000000, -1875000000000000], [-1875000000000000, 1875000000000000]])  Vector(2, {(1) = 2, (2) = 3})
Global stiffness matrix obtained by adding all the elemental stiffness matrices and given b
           Vector[row](3, {(1) = 0, (2) = 0, (3) = 0})
K__g := Matrix(3, 3, {(1, 1) = K__1[1, 1], (1, 2) = K__1[1, 2], (1, 3) = 0, (2, 1) = K__1[2, 1], (2, 2) = K__1[1, 2]+K__2[1, 1], (2, 3) = K__2[1, 2], (3, 1) = 0, (3, 2) = K__2[2, 1], (3, 3) = K__2[2, 2]}) = Matrix([[K__1[1, 1], K__1[1, 2], 0], [K__1[2, 1], K__1[1, 2]+K__2[1, 1], K__2[1, 2]], [0, K__2[2, 1], K__2[2, 2]]])  Vector(3, {(1) = 0, (2) = 0, (3) = 0})
For element 1 Load matrix F is
  F__1e := (1/2)*`ρ__1`*A__1e*l__e*(Vector(2, {(1) = 1, (2) = 1})) = Vector[column]([[861/25600], [861/25600]]) Vector(2, {(1) = 1, (2) = 2})
For element 2 Load matrix F isNULL
F__2e := (1/2)*A__2e*l__e*`ρ__2`*(Vector(2, {(1) = 1, (2) = 1})) = Vector[column]([[123/5120], [123/5120]])
Download wrong_answers.mwwrong_answers.mwwrong_answers.mw
Ramakrishnan V
rukmini_ramki@hotmail.com
hello everyone
can any one tell me what is this anti reduction method. In the paper of serdal palmuk,the link is given bellow
http://www.hindawi.com/journals/mpe/2009/202307/
in this paper question #4 is first solved by anti reduction method for  exact solution.
but i dont understand this method,
if anybody know this then please also tell me how to solve this,
and in the next  (6 & 7 ) examples "in the pourus media equation" they first find its particular exact solution.i also dont understand this,so please tell me
actually i know how to solve ODE to find its exact solution but  i dont know how we find exact solutions of partial differtial equations,
so please help me to solve this problem
How to find the integral
assuming k and n  integer?
It is known (McCrea W. H., Whipple F. J. W.Random paths in two and three dimensions, Proc. Roy. Soc. Edinburgh. 1940. V. 60. P. 281–298) that
G(n,n)=2/Pi*sum(1/(2*k-1),k=1..n).
The general case is reduced to the case k=n.
This is not a creature of pure reason: the one appears in electric circuits
(see M. Skopenkov, A. Paharev, A. Ustinov, Through resistor net, Mat. pros. Issue 18 (2014), 33-65, in Russian, http://www.mccme.ru/free-books/matpros/pdf/mp-18.pdf).
I found G(8,8) = 182144/(45045*Pi) in 657.797 s and G(9,9) = 3186538/(765765*Pi) in 4157.687 s on my comp by
restart; s := time():(1/2)*VectorCalculus:-int((1-cos(9*Pi*x)*cos(9*Pi*y))/(sin((1/2)*Pi*x)^2+sin((1/2)*Pi*y)^2), [x, y] = Rectangle(0 .. 1, 0 .. 1)); time()-s;
Mathematica 10.3.0 does G(9,9) in 250.391 s on my comp.
I have a question about poincare sections. I have this piece of code i need to analyse and I want to use a poincare section in order to so. How could I do it? I am interested in theta and omega. Any help is greatly appreciated! Thank you in advance!
Kind regards,
Gambia Man
a := 1.501*10^9:
Th := sqrt(4*Pi^2*a^3/(G*(Mh+Msat)));
1876321.326
0.3348672330e-5
HyperionOrbit := proc (`θIC`, `ωIC`) local a, Mh, Msat, G, e, beta, M, Eqns, ICs; global `ωH`, Th, soln; a := 1.501*10^9; Mh := 5.5855*10^18; Msat := 5.6832*10^26; G := 6.67259/10^11; e := .232; beta := .89; M := Mh+Msat; Eqns := diff(theta(t), t) = omega(t), diff(omega(t), t) = -G*Msat*beta^2*(xH(t)*sin(theta(t))-yH(t)*cos(theta(t)))*(xH(t)*cos(theta(t))+yH(t)*sin(theta(t)))/(xH(t)^2+yH(t)^2)^2.5, diff(xH(t), t) = vxH(t), diff(vxH(t), t) = -G*M*xH(t)/(xH(t)^2+yH(t)^2)^(3/2), diff(yH(t), t) = vyH(t), diff(vyH(t), t) = -G*M*yH(t)/(xH(t)^2+yH(t)^2)^(3/2); ICs := xH(0) = a*(1+e), yH(0) = 0, vxH(0) = 0, vyH(0) = sqrt(G*M*(1-e)/(a*(1+e))), theta(0) = `θIC`, omega(0) = `ωIC`; soln := dsolve({Eqns, ICs}, numeric); odeplot(soln, [theta(t), omega(t)/`ωH`], 0 .. 5*Th, numpoints = 2000, labels = ["θ(t)","ω(t)/ωH"], axes = boxed, size = [.25, .75]) end proc
Download New_Poincare_section.mw
http://www.maplesoft.com/support/help/Maple/view.aspx?path=Physics/.
i see bra and ket expression are so beautiful,
however,
how do real valued eigenvectors involve in calculation of bra and ket style computation?
equ1 := -l*cos(xi)^2*(1-cos(`β__f`))/(alpha^2.sin(sigma))-`λ__2`*w*(v^2.sin(sigma))/(g*l*cos(xi)^2) = 0
equ2 := -l*cos(xi)^2*(1-cos(beta[f]))/(alpha*sin(sigma)*tan(sigma))+Typesetting:-delayDotProduct(l, cos(xi)^2)*z__0*sin(`β__f`)/(alpha*sin(sigma)*(2*l*cos(sigma)^2))-`λ__1`*`#mi("L")`*`#mi("sin",fontstyle = "normal")`(sigma)*cos(xi)+`λ__2`*L*cos(sigma)*cos(xi)-`λ__2`*w*alpha*v^2*sin(sigma)/(g*l*tan(sigma)*cos(xi)^2) = 0
-l*cos(xi)^2*(1-cos(beta[f]))/(alpha*sin(sigma)*tan(sigma))+(1/2)*(l.(cos(xi)^2))*z__0*sin(`β__f`)/(alpha*sin(sigma)*l*cos(sigma)^2)-`λ__1`*`#mi("L")`*`#mi("sin",fontstyle = "normal")`(sigma)*cos(xi)+`λ__2`*L*cos(sigma)*cos(xi)-`λ__2`*w*alpha*v^2*sin(sigma)/(g*l*tan(sigma)*cos(xi)^2) = 0
equ3 := l*cos(xi)^2*sin(`β__f`)*tan(sigma)/(alpha*sin(sigma)*(2*l)) = 0
(1/2)*cos(xi)^2*sin(`β__f`)*tan(sigma)/(alpha*sin(sigma)) = 0
equ4 := -`λ__1`*`#mi("L")`*`#mi("cos",fontstyle = "normal")`(sigma)*sin(xi)+`λ__2`*L*sin(sigma)*sin(xi)-2*`λ__2`*tan(xi)*w*alpha*v^2*sin(sigma)/(g*l*cos(xi)^2)-l*sin(2*xi)*(1-cos(beta[f]))/(alpha*sin(sigma)) = 0
equ5 := L*cos(sigma)*cos(xi)-w = 0
`#mi("equ6")` := `#mi("L")`*`#mi("sin",fontstyle = "normal")`(sigma)*cos(xi)-w*alpha*v^2*sin(sigma)/(g*l*cos(xi)^2)
answer := solve({equ1, equ2, equ3, equ4, equ5, equ6}, {alpha, sigma, xi, `λ__1`, `λ__2`, beta[f]})
Download Bryson_sesson1_p6.mw
Maple's isprime is not a definitive primality test. The input has to pass a "strong pseudo-primality test" and "one Lucas test". This is well documented. I thought I remembered that there is also a way to get Maple to perform a true primality test, but I don't remember how and don't see anything about this in the Maple help system.
Is my memory faulty, or is there no definitive primality test in Maple?
Thanks in advance,
Doug
Douglas B. Meade  <><
Math, USC, Columbia, SC 29208  E-mail: mailto:meade@math.sc.edu
Phone:  (803) 777-6183         URL:    http://www.math.sc.edu
How to change the length underline in latex ?
For example in this environment :
$\underline{\mathcal{G}}$
Thank you,
Gérard.
So I am trying to apply the Optimization function to a rather complicated problem I am currently working on, and having some trouble getting maple to cooporate. This is the part of the code that is giving me the error, with error included. All of the variables imputtet when calling OptimizeSpring are constants. If there is any other details I should add, please say so and I will add them promptly :) Thanks alot!
Maple problem
I suspect that it might be related to this suggestion, but I am not sure how to apply it http://www.mapleprimes.com/posts/95113-Optimization-Workaround-For-Operator-Form
I'm trying to solve a beam vibration problem. I am relatively new to Maple and trying to solve PDE's. I feel like I'm pretty close, but I don't understand what's wrong here.
This is my maple file.
Thesis_Pde2_attempt.mw
as a note, I made some simplifying assumptions. I am just using part of this equation since it is less complex. And my boundary conditions are simply supported on both ends so no displacement and no 2nd derivative at the ends.
Any help would be greatly appreciated!!
I have some problems with the "isolve" command on Maple. I am trying to solve for integer a very easy system of equations. When I type the commands
n := 2;
isolve({sum(a[k], k = 1 .. n)-1 = 1}, d)
I get the expected {a[1] = 2-d, a[2] = d}. However, if I add conditions a[1],a[2] >= 0, that is the commands
n := 2;
isolve({ge(a[1], 0), ge(a[2], 0), sum(a[k], k = 1 .. n)-1 = 1}, d)
I get the warning "Warning, solutions may have been lost". What am I doing wrong? Is there a way to get Maple to give me the possible values?
Thank you in advance,
David
I'm trying to solve a system of equations thats expressed as a summation (the original has the summation symbol as opposed to 'sum'):
d_actual := solve(W_actual = sum(W_guess(def-asp_rad_inverse[i], E, asp_rad[i]), i = 1 .. n), def);
When n<5, I get an answer after a few seconds, but when n is higher, the program sits and 'evaluates' forever...I've waited up to 30 min.
Background:
I have a plate with a number of hemispheres on the surface (# of impacted hemispheres given a force = n). Each has a unique radius and they're listed from largest to smallest in 'asp_rad[]'. I have an equation for the deflection of a single hemisphere as a function of Force and material properties that I have rearranged with respect to Force (W_guess(deflection, E, r)). There's an opposing plate that stays parallel to the original plate while pushing down on the asperities with Force W_actual. The total deflection of the opposing plate is the sum of: 1) the difference between the tallest radius and the impacted radius in question (asp_rad_inverse[]), and 2) the deflection of the impacted radius in question.
I'm attempting to solve for the total deflection of the opposing plate via solving for the 'def' in the summation above, but when I run it, the program is not able to compute a solution.
I'm a very new beginner, and I have a question about getting the data of a curve from a JPG, without using manual measures an too getting more accurate datas.
I wish to fit the curve with a model. The JPG joined, from EU 2015, is about human thermoregulation. I still try to found a model with Mathematica but am uncertain seeing the result as illogic.
Did anyone write something to read curves from a JPG and get coordinates from these curves ? In the JPG, the curve is above, as an 'U'.
Thanks for your advice,
Milos.
I have an error in my code. I don't know where it came from. Earlier today I loaded this and it worked fine and now an error comes up. Any help is greatly appreciated! Thank you in advance!
Kind regards,
Gambia Man
HyperionOrbit := proc (`&theta;IC`, `&omega;IC`) local a, Mh, Msat, G, e, beta, M, Eqns, Th, ICs, soln, `&omega;H`; a := 1.501*10^9; Mh := 5.5855*10^18; Msat := 5.6832*10^26; G := 6.67259/10^11; e := .232; beta := .89; M := Mh+Msat; Eqns := diff(theta(t), t) = omega(t), diff(omega(t), t) = -G*Msat*beta^2*(xH(t)*sin(theta(t))-yH(t)*cos(theta(t)))*(xH(t)*cos(theta(t))+yH(t)*sin(theta(t)))/(xH(t)^2+yH(t)^2)^2.5, diff(xH(t), t) = vxH(t), diff(vxH(t), t) = -G*M*xH(t)/(xH(t)^2+yH(t)^2)^(3/2), diff(yH(t), t) = vyH(t), diff(vyH(t), t) = -G*M*yH(t)/(xH(t)^2+yH(t)^2)^(3/2); Th := sqrt(4*Pi^2*a^3/(G*(Mh+Msat))); `&omega;H` := 2*Pi/Th; ICs := xH(0) = a*(1+e), yH(0) = 0, vxH(0) = 0, vyH(0) = sqrt(G*M*(1-e)/(a*(1+e))), theta(0) = `&theta;IC`, omega(0) = `&omega;IC`; soln := dsolve({Eqns, ICs}, numeric); odeplot(soln, [theta(t), omega(t)/`&omega;H`], 0 .. 5*Th, numpoints = 2000, labels = ["&theta;(t)","&omega;(t)/&omega;H"], axes = boxed) end proc
HyperionOrbit(.5, 1.8*`&omega;H`)
Warning, The use of global variables in numerical ODE problems is deprecated, and will be removed in a future release. Use the 'parameters' argument instead (see ?dsolve,numeric,parameters)
Error, (in dsolve/numeric/SC/IVPpoints) unable to store '11.3097335529232/Th' when datatype=float[8]
Download Poincare_section.mw
Consider this maple 18 doc: Euler18.mw
The code is regular code for Julia sets of the exponential.
To see how the Julia set behaves at infinity, I apply the transform mu(z)=1/z.
The plot3d command correctly plots the Julia set at an appropriate neighborhood of infinity, but:
1) Axes are not transformed
2) Saving as .eps produces an empty plot, sans the axes (plot is saved correctly, when not applying mu(z))
Is there any trick to force the axes to also show correctly with the transformed ranges?
Seems that this misalignment is bothering the .eps renderer, which probably plots the graph in twilight zone, given the false ranges of the untransformed axes.
Any ideas on how to force the saveas .eps to work in this case?
Many thanks,
Yiannis
First 216 217 218 219 220 221 222 Last Page 218 of 371
