using FDM or FEM rather than dsolve?
ode.docxode.docx
Occasionally I have need to import 1D Maple expressions into Mathematica, because I believe mma has superior simplify functionality (sorry Maple). Mathematica has its own syntax which (of course) differs to maple.  eg sin(x) in maple is Sin[x] in mma ; ln(x)=Log[x] ;....... I'm aware of the package MmaTranslator, but I think it only converts mma to maple.
so i need some code pls.
(i have bolded the functions which need to be converted)
eg: i/p:
(1/365)*(365*B21*EP*ln(1+i)*(1+i)^B21*hr*kw*p-365*EP*hr*kw*p*(1+i)^(-1+B21)*i-365*EP*hr*kw*p*(1+i)^(-1+B21)+365*EP*hr*kw*p+SC*i)/(hr*kw*(EP*ln(1+i)*(1+i)^B21*p-FIT*i*p+cos(omega)))
o/p:
(1/365)*(365*B21*EP*Log[1+i]*(1+i)^B21*hr*kw*p-365*EP*hr*kw*p*(1+i)^(-1+B21)*i-365*EP*hr*kw*p*(1+i)^(-1+B21)+365*EP*hr*kw*p+SC*i)/(hr*kw*(EP*Log[1+i]*(1+i)^B21*p-FIT*i*p+Cos[omega]))
I'm null in statistic. I'm doing a calculation to calculate a set of parameter. By example:
I have to calculate 5 parameters x1,x2,x3,x4,x5 from 7 equations f1,f2,f3,f4,f5,f6,f7. Because it is difficult to calculate directly 5 parameters, I used chisquare to minimize the difference between experimental and theorical data. Then, I can get the results. After that, I used these 5 parameters to back-calculate the data using 7 equations above. My question is about how to calculate the error bar (or standard error) of the back-calculate datato add to the plot.
Thank you  for helping me,
Best regards.
Hi, Im now trying to run my code. But it took like years to even getting the results. may I know any solutions on how to get faster results? Because I have run this code for almost 4 hours yet there is still 'Evaluating...' at the corner left. And when I tried to stop the program, it will stop at 'R1...'.
Digits := 18;
with(plots):n:=1.4: mu(eta):=(diff(U(eta),eta)^(2)+diff(V(eta),eta)^(2))^((n-1)/(2)):
Eqn1 := 2*U(eta)+(1-n)*eta*(diff(U(eta), eta))/(n+1)+diff(W(eta), eta) = 0;
Eqn2 := U(eta)^2-(V(eta)+1)^2+(W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(U(eta), eta))-mu(eta)*(diff(U(eta), eta, eta))-(diff(U(eta), eta))*(diff(mu(eta), eta)) = 0;
Eqn3 := 2*U(eta)*(V(eta)+1)+(W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(V(eta), eta))-mu(eta)*(diff(V(eta), eta, eta))-(diff(V(eta), eta))*(diff(mu(eta), eta)) = 0;
bcs1 := U(0) = 0, V(0) = 0, W(0) = 0;
bcs2 := U(4) = 0, V(4) = -1;
R1 := dsolve({Eqn1, Eqn2, Eqn3, bcs1, bcs2}, {U(eta), V(eta), W(eta)}, initmesh = 30000, output = listprocedure, numeric);
Warning, computation interrupted
for l from 0 by 2 to 4 do R1(l) end do;
plot1 := odeplot(R1, [eta, U(eta)], 0 .. 4, numpoints = 2000, color = red);
Thankyou in advance :)
i have attchassignment.mwsassignment.pdf
Hi everyone
I've come across a RAM-issue.
My program creates a lot of plots using millions of variables-values and it eats up my computers memory since I use the plots to make an animation.
The plots are simple 3d plots created using the surfdata function.
How do I save plots into a single file as the program creates them concurrently such that after the program has terminated I can use the plots to create an animation?
and how do I efficiently delete variables I dont not need anymore?
Dear Friends
            Hope everything going fine with you. I want the numerical solution of nonlinear system of ordinary differential equations using RK method. The system of ODEs and their required results are present in attached file. I am waiting your quick response.
Help.docx
With my best regards and sincerely.
Mob #: 0086-13001903838
I want to separate strings into substrings for example
input is "6,3,A,n,k,L,+,-" then the procedure breaks this string into substrings like
if a member numeric b:="6,3",or if lowercase c:="n", if uppercase l:="A,L" else m:="+,-"
In the running of an example I faced to computation of radical ideal of the following ideal:
<-c*m*u+d*c*n+m*b*v+m*c*t>
I used from Radical command in PolynomialIdeals package. But I dno't now why it's computation is very hard and Time-consuming?
What I have to do? I think there is a bug, since this ideal is simple, apparently.
It took me a while to figure out what was causing this unusual sort result;
I loaded the MTM package because I want to convert numbers to integers for indexing. This sort result seem like it could be a bug.
Sort a List of Floats
with(MTM):
x := [1/3, 0, 4] = [1/3, 0, 4]``
sort(x) = [0, 1/3, 4]``
f_x_MTM := [seq(convert([x[n], n], float), n = 1 .. 3)] = [[.3333333333, 1.], [0., 2.], [4., 3.]]NULL
sort(f_x_MTM) = [[.3333333333, 1.], [0., 2.], [4., 3.]]NULL
unwith(MTM):
f_x := [seq(convert([x[n], n], float), n = 1 .. 3)] = [[.3333333333, 1.], [0., 2.], [4., 3.]]
sort(f_x) = [[0., 2.], [.3333333333, 1.], [4., 3.]]
Download MTMsort.mw
Hello Everybody,
I was trying to apply the Newton-Raphon method("Newton" in maple) for the following problem to obtain the constants (c1...cM) without success.
eq[1] := -0.0139687 c[2] - 0.0132951 c[1] = 0
eq[2] := 24806.4 c[2] - 0.0139687 c[1] = 0
If anybody has experience with it or knows how to use it I would really appreciate your help.
Just to introduce the previous steps of calculations leading to the problem:To calculate the critical buckling force N and the shape of a rectangular uniformly loaded plate the governing diff. equation is the following
D11*w''''(x)+(2*D12+4*D66)*w''(x)''(y)+D22*w''''(y)+N*w''(x)=0
For the follwing solution of a boundary value problem(Boundary conditions:clamped-clamped: w(x=0,x=a)=0 & w'(x=0,x=a)=0) I applied the Ritz method:
w:=sum(c[i]*(cos(2*i*Pi*x/a)-1)),i=1..M)
Thus the Potential Energy P is:
P:=16537.6*c[2]^2-0.0139687*c[2]*c[1]+1033,60*c[1]^2-9.86960*N*c[2]^2-2.46740*N*c[1]^2
 deriving P to each constant c and setting them =0 leads to:
eq[1] := -0.0139687 c[2] + 2067.20 c[1] - 4.93480 N c[1] = 0
eq[2] := 33075.2 c[2] - 0.0139687 c[1] - 19.7392 N c[2] = 0
After calculating N=418,902  and feeding eq1 and eq 2,the follwing equations if two terms are considered:
Everything I tried resulted in any c1 = c2 = 0 which is not  realistic. Maybe I made a mistake earlier.
Thanks a lot in advance.
Sam
 Plate_Buckling.mw
Hi guys,
I can not execute any command in worksheet. I even can't set a variable to a number. When I write some lines and hit enter, it does not respond in anyway. Basicly I can't enter anything it doesn't do anything. How cold I solve this?
I've this equation ,what is displacement,
U := sum(C[i]*lambda[i]*h^2*M*(C[13]+C[55])*exp(Z*lambda[i]*M)*cos(M*x)/C[11], i = 1 .. 4);
 But when I used the data ,I do not get the right result
the datas are
h := .25;
M := Pi/L; L := 1;
E[3] := 1; E[1] := 40; E[2] := 1;
V[13] := .25; V[31] := .25; V[12] := .25; V[23] := .25; V[32] := .25; V[21] := .25;
G[44] := .2; G[55] := .2; G[66] := .2;
G[13] := .5;
C[55] := G[13];
Omega := -2*V[13]*V[21]*V[32]-V[12]*V[21]-V[13]*V[31]-V[23]*V[32]+1;
C[11] := (-V[23]*V[32]+1)*E[1]/Omega;
C[12] := (V[13]*V[32]+V[12])*E[2]/Omega;
C[33] := (1-V[12]*V[12])*E[3]/Omega;
C[1] := -.2596702449; C[2] := -2.411545729; C[3] := -0.6051254981e-1; C[4] := .4085627399;
lambda[1] := .6891428810; lambda[2] := -.6891428810; lambda[3] := 9.177422410; lambda[4] := -9.177422410;
could you help me plase
Limitation of Maple spreadsheet is only 100 x 52
I don't know why there's a limitation on the size but there's no way of increasing it either.  Is there?
Just to be sure that some outside operation wouldn't nudge the spreadsheet size I tried
with(Spread):
a:=CreateSpreadsheet():
b:=Matrix(100,100):
SetMatrix(a,b)
                           Error, (in Spread:-SetMatrix) spreadsheets cannot exceed 52 columns
So unfortunately until the feature gets built into Maple I don't believe there is a workaround.
I read research paper about elasticity, and I don't not how can get the results for displacment ant shaer stress,, could you help me please.
please help me
Kind Regards
First 214 215 216 217 218 219 220 Last Page 216 of 371
