Hi everybody,
I have some experimental data from an oscillating system (time domaine) and I would like to get an approximation of the damping ratio (zeta). I have already try to use the half-power band width method with the vibrationdata Matlab package designed by Tom Irvine. But I would like to double-check the result with another method.
I found several methods in this paper and I would like to try to do the curve fitting method with the Curve Fitting Toolbox of Maple or Matlab (R2014b) (2.2.2 Curve fitting in the paper). data.txt
It's the first I use this Toolbox with a custom equation, so, I do not really know how to do it with my sample data.
Can anybody help me with this ? I have attached the .txt file sample data to this post.
Cheers
I was wondering how to go about plotting a Fourier Tranform in Maple.
My assignment is to plot a simple harmonic equation as a Fourier transform, depicting amplitude against fequency.
I've been given: x'' + w^2 x = 0
And want to obtain both the f(x) = a0 sin(wt) + b0cos(wt) form, and a graph of the the amplitude (c^2 =a0^2 + b0^2) against frequency.
I know how to do this on paper but not in Maple, so any help with line commands and layout would be very much appreciated.
PrimesQuestion.mw
Please let me know if this link correctly accesses my worksheet. If not, I will copy its contents into this question.
Which ODE in the worksheet, if any, provides the correct answer?
f := proc (x) local t; if not type(evalf(x), 'numeric') then ('procname')(x) else evalf(Int(exp(-(1/10)*t^2), t = 0 .. x)) end if end proc
solA := dsolve({diff(y(x), x) = y(x)+f(x), y(0) = 0}, numeric, known = f)
solA(1)
[x = 1., y(x) = HFloat(0.7081492947996167)]
f2 := evalf(Int(exp(-(1/10)*t^2), t = 0 .. 1)); f(1)
.9676433126
.9676433126
solB := dsolve({diff(y(x), x) = y(x)+f2, y(0) = 0}, numeric, output = listprocedure)
solB(1)
[x(1) = 1., (y(x))(1) = HFloat(1.6626837619970016)]
YinSolB := subs(solB, y(x))
YinSolBeval := solve(YinSolB(a) = .7081, a); solB(YinSolBeval)
.5491485953
[x(.5491485953) = .5491485953, (y(x))(.5491485953) = HFloat(0.7081000000284681)]
I'm trying to work out whether or not Maple will be able to help me out with some algebra involving lots of indices, but I can't seem to work out how the gauge indices features work in the Physics package. For example I would like to define a gauge field carrying an SU(3) index and a spacetime index. The SU(3) index should run from 1 to 8 and the spacetime index from 1 to 5. I think I have worked out how it works with spacetime indices but I can't seem to find any documentation on the gauge indices.
Is there are a way to set the "dimension" of the gauge index, like we can set the space time dimension?
Cheers
  I would need to get access to the values of euler angles defining the orientation of a 3D plot.
I generate the 3D plot with a given orientation, then the user is allowed to rotate it with mouse orbit. How can I get the values of the new euler angles to use them in further computations?
In the plot/structure I cannot find any data concerned with orientation...
Marco
I have the following equation:
Diff(W(t), t) = -q*V*(sin(Phi)-sin(Psi[s]))/(2*h*Pi);
I solve it for rhs() = 0:
soln := solve([rhs((2)) = 0, Phi < 2*Pi], [Phi], allsolutions = true,explicit);
This works and I get this result:
Now I want to get the first zeros, which occur for _Z1 and _Z2 equal to 0. So I substitute:
subs(_Z2=0,(3));
and get
In other words, the substitution did not work.
The original problem is embedded in a larger sheet created with Maple 15 and there it does work. It fails on Maple 2015.2. I then pulled out the relevant pieces to make this example demonstrating the problem (see the attached sheet, which has some of my other (unsuccessful) attempts to diagnose what is going on). It seems like the created variables _Z1 and _Z2 are somehow not recognized at all.
The only way I can get the _Z2 terms out is to substitute 2=0. This is really too icky to seriously consider, though.
Anyone has seen this before?
FWIW: Maple 2015.2 on Mac OS X 10.10.5.
Mac Dude
Assumptions_test.mw
I have an issue calculating an electronics circuit with Maple, using units. I have a current source that I know, and I want to determin the voltage in a capacitor by solving an ODE (except that the current source is defined piecewise). And to make sure I have all the units and scales right, I use the standard unit package. All my variables have their units defined.
Except that Maple doesn't want to solve the equation. It seems to me that it assumes that the function I am trying to solve is unitless, and therefore refuses to solve.
V__out := 3*Unit('kV');
C__out := 2*Unit('nF');
R__blead := 520*Unit('`k&Omega;`');
I__fly := proc (t) options operator, arrow; Unit('A')*piecewise(t < 3.25*Unit('us'), (1+(-1)*t/(3.25*Unit('us')))*.2, 0) end proc;
dsolve({I__fly(t*Unit('s'))-V__C(t*Unit('s'))/R__blead = C__out*(diff(V__C(t*Unit('s')), t)), V__C(0*Unit('s')) = V__out}, V__C(t*Unit('s')));
Error, (in Units:-Standard:-+) the units `A` and `S` have incompatible dimensions
Is there a way to make Maple assume the unit of what it's trying to solve ? I need it to understands that V__C is in Unit('V') ...
hi .by changing amount of variable such as '' f '' or 'D5 ' in input data, not changing  in final result!!!!please chek attached file
thanksX4.mw
I have Maple package "DESOLVE" having two different types of files namely in format .mpl and .mws, where code is written in .mpl file and .mws is just a example worksheet, this package is available at following link;
http://cpc.cs.qub.ac.uk/summaries/ADYZ_v1_0.html
My problem is how to work with package?
One thing that I able to do is that I have opened the file type .mpl  in Maple worksheet and after executing whole whorsheet I able to to start working with package using with(desolv).
But when I type with(desolv) in new worksheet an error shows up.
How I can store this .mpl file in Maple library so as to use this package using "with(desolv)" in new worksheets
Desolv_worksheet_paper.mws?
Remark by Markiyan Hirnyk:
The part of the body of this question disappears after my edit of its title only.
Crosslinking surfaces by a spiral.
My fantasy is a source.
I am making a mpl file which looks like below:
font_size := thickness = 4, font = [bold, "TimesNewRoman", 30], labelfont = [bold, "TimesNewRoman", 30], axis[1] = [thickness = 3], axis[2] = [thickness = 3], captionfont = [bold, "TimesNewRoman", 30], legendstyle = [font = [bold, "TimesNewRoman", 30]];
I  export it as mpl, but when I want to read it in a worksheet, I get the error below:
Error, on line 1, syntax error, character `?` unexpected:
<?xml version="1.0" encoding="UTF-8"?>
Error, while reading ``/Users/..../font_size.mpl``
This is just a simple mpl, I get this error for all mpl s that I want to read!
Can somebody help me with this please? It is really annoying :(
I am able to get unlimeted numbers of equations describing my system. These equations are generally relate quotients of multivariate polynomials. Each additional equation I get is generally less than twice the length of the last, and it is not always the case that an equation is independant of the previous equations. Although I can get unlimited numbers of equations describing the system, it is not overdetermined.
I am interested in solving these equations for their variables. There are about 30 cases I am working on, the smallest number of evariables is six, the largest would be twenty.
I want to be able to solve these equations in the minimal time possible. But I don't understand the function solve well enough to do so.
How do I choose the equations to minimise the time taken for the command solve to proccess them?
How does the command solve work?
particularly:
  1. if I process the command solve([Eq1,Eq2,Eq3...Eqn],variables) would the command solve([Eq[1],Eq[2],Eq[3]...Eq[n],Eq[n+1]],variables) take longer if Eq[n+1] is not indipendant of the previous equations?
  2. Is there a way of checking whether Eq[n+1] is independant of the previous vequations, fast enough for it to be useful to check the equations before they are processed?
  3. Does the ordering of the equations affect the speed of solve?
  4. Is there a way of pre processing the equations before they are put into solve that will save it time? (for example factorising them, simplifying them etc...)
Dear all, I have obtained some figures in Maple code. But they looks not very good. Iwant to export the plot data to matlab. Then try to plot in matlab. I think it should't be very hard. Does anyone can help me? Thanks
I have a maple code, which some expressions have more that 80000 terms and I need to double integrate them. The terms have sine, cossine trigonometric functions.
I tried to used de MAP command, it works for the first expressions but, after a while, Maple displays an error message related to too large expression.
Do you know how to handle large expressions ?
First 212 213 214 215 216 217 218 Last Page 214 of 371
