How to increase the size of toolbar icons in Maple 2015 32-bit Classic on Windows?
How do you put labels on individual columns in ColumnGraph?
a1:= f(x) :
> T1 :=simplify((taylor(a1,x=alpha,N+3))):
> E1:=subs([seq(((D@@i)(f))(alpha) = 0,i=1..m-1),f(alpha)=0,x=e[n]+alpha],T1):
> g1 :=(convert(simplify(series((E1,e[n]=0,N))),polynom));
thanks. I played around, and had problems implementing your ideas for one of the systems I'm interested in.I don't see a difference between this and what you had advised me on, but it gets an error.
any idea why?
or how to fix it?
thing1 := diff(B[1](t), t) = piecewise(t <= 500, 0.3e-2-(63/10000)*B[1](t)-(3/500)*B[2](t), -(3/10000)*B[1](t)):
thing2 := diff(B[1](t), t) = piecewise(t <= 500, 0.1e-1-(1/50)*B[1](t)-(13/625)*B[2](t), -(1/1250)*B[2](t)):
sol := dsolve({thing1, thing2, B[1](0) = 0, B[2](0) = 0}, {B[1](t), B[2](t)}, numeric, output = listprocedure); plots:-odeplot(sol, [B[1](t), B[2](t)], t = 450 .. 550);
Error, (in dsolve/numeric/DAE/explicit) unable to obtain the standard form of the DAE system due to the presence of leading dependent variables/derivatives in the piecewise: piecewise(t <= 500, 1/100-(1/50)*B[1](t)-(13/625)*B[2](t), -(1/1250)*B[2](t))-piecewise(t <= 500, 3/1000-(63/10000)*B[1](t)-(3/500)*B[2](t), -(3/10000)*B[1](t))
Error, (in plots/odeplot) curve is not fully specified in terms of the ODE solution, found additional unknowns {B[1](t), B[2](t)}
how to do differentiation of an ideal in maple?
availables variables : a,b,c
case 1 : all are independent variebles, a,b,c
case 2 : only one independent variable, a
case 3: only one dependent variable a
i find this, but i do not know respect to which variable when differentiate an ideal which has 3 variables and 3 equations
http://www.maplesoft.com/support/help/maple/view.aspx?path=DifferentialAlgebra%2fTools%2fDifferentiate
I try to repeat lines (25)-(28) at
http://www.maplesoft.com/support/help/maple/view.aspx?path=Physics%2fTrace#commentform
I use Maple 14. However, instead of (28) I get the following result:
It means that Maple 14 does not perceive p_\mu, k_\nu and m as scalar quantities. I would like to ask how to define these variables correctly.
Thank you in advance!
hi.please help me for solve this equations
thanks...
Tur.mw
Non dimensionalisation is a vary common task, and I was suprised that I couldn't find a maple tool to automate it . Has anyone developed their own package for it?
I want to automatically do it to the system equations for some Dynamical systems to make some of the other processing I do with them easier.
I was hoping to start with somehting in the form of
Diff(x[1],t)=f[1](p[1]....p[n],x[1]...x[m])
Diff(x[m],t)=f[m](p[1]....p[n],x[1]...x[m])
where each f[i] is some kind of quotient of multivariate polynomials in the variables and parameters:
and end up with something like
Diff(y[1],s)=f[1](q[1]....q[p],y[1]...y[m])
Diff(y[m],s)=f[m](q[1]....q[p],y[1]...y[m])
where p<n
Hi everyone...!
Can somebody tell me how to express this equation in Maple?
xij <= zkl ; ∀ i ∈ I: S(i)=k, ∀ j ∈ B: R(j)=l;
Currently I'm dealing with containerization problem and have 4 indexes in the constraints (namely: i for item, j for container, k for shipment, l for route, S for Set of Shipment, and R for Set of Route) while x and z are binary variables. What I want to express is: (for example), item 1,2,3 are in shipment 1, item 4,5 are in shipment 2, etc etc. SO, if i = 1,2,3 then the value of k will be 1. If i = 4,5 then the value of k will be 2, etc. Same thing goes to j and l, (for example) if j = 1,2 then the value of l will be 1, etc etc. Further depcition is more or less like this:
S(i) = k
S(1) = 1
S(2) = 1
S(3) = 1
S(4) = 2
S(5) = 2
Thank you very much for the help.
I faced a very large eigenproblem during my research. The square matrix under consideration is of size more than 2^30 times 2^30. I have tried to deal with this problem by the QR algorithm with double implicit shift (more precisely, the Francis double step QR algorithm). I'm a very beginner of programming, but I tried as follows:
A := Matrix([[7, 3, 4, -11, -9, -2], [-6, 4, -5, 7, 1, 12], [-1, -9, 2, 2, 9, 1], [-8, 0, -1, 5, 0, 8], [-4, 3, -5, 7, 2, 10], [6, 1, 4, -11, -7, -1]]):
H := HessenbergForm(A):
p:=6:
for p while p>2 do:
q:=p-1:
s:=H(q,q)+H(p,p):
t:=H(q,q)*H(p,p)-H(q,p)*H(p,q):
x:=(H(1,1))^(2)+H(1,2)*H(2,1)-s*H(1,1)+t:
y:=H(2,1)*(H(1,1)+H(2,2)-s):
z:=H(2,1)*H(3,2):
for k from 0 to p-3 do:
V:=Vector([x,y,z]):
P:=Transpose(HouseholderMatrix(1/(Norm(V+exp(argument(V(1))*I)*Norm(V,2)*Vector(3,shape=unit[1]),2))*(V+exp(argument(V(1))*I)*Norm(V,2)*Vector(3,shape=unit[1])))):
r:=max(1,k):
H[k+1..k+3,r..6]:=MatrixMatrixMultiply(Transpose(P),SubMatrix(H,[k+1..k+3],[r..6])):
r:=min(k+4,6):
H[1..r,k+1..k+3]:=MatrixMatrixMultiply(SubMatrix(H,[1..r],[k+1..k+3]),P):
x:=H(k+2,k+1):
y:=H(k+3,k+1):
if k<3 then z:=H(k+4,k+1):
P:=GivensRotationMatrix(Vector([x,y]),1,2):
H[q..p,p-2..6]:=MatrixMatrixMultiply(Transpose(P),SubMatrix(H,[q..p],[p-2..6])):
H[1..p,p-1,p]:=MatrixMatrixMultiply(SubMatrix(H,[1..p],[p-1,p]),P):
if abs(H(p,q))<10^(-20)*(abs(H(q,q))+abs(H(p,p))) then    H(p,q):=0: p:=p-1:q=p-1:
elif abs(H(p-1,q-1))<10^(-20)*(abs(H(q-1,q-1))+abs(H(q,q))) then    H(p-1,q-1):=0: p:=p-2:q:=p-1:
end if:  od:
It seemed that replacing 0 in a Hessenberg matrix by a non-zero element is not allowed. How can I remedy this?
Plus, can anyone tell me the problem of the above thing(it's not really a programming...;( ), please?
I would also appreciate it if someone let me know a better idea for a huge eigenproblem.
es posible obtener la función del contorno de un dominio convexhull ?
Sorry for the uninformative title. I've never used Maple, but I'm willing to buy a student license and learn it. But before spending too much effort and money I need to know if it suits my needs.
Basically what I need to do is:
1) I have a positive definite symmetric matrix of size nxn, where n can range from 2 to inf. I don't know the elements, except the fact that the diagonal has ones everywhere. All I know is that the elements out of the diagonal are in the range [0,1)
2) I have to compute the lower triangular cholesky decomposition of this matrix, lets call it L.
3) I need to subtract from each element of L the mean of the elements in the respective column. Lets call this matrix L*
4) Then I need to evaluate another nxn matrix computed from the elements of L* following a simple pattern.
5) Finally I need to find the eigenvalues of this last matrix.
What I would ideally want is to get a symbolic representation of the n eigenvalues as symbolic functions of the (unknown) elements of the matrix at point 1.
I can drop the assumption of n being unknown, i.e. fix n=3 and get the 3 functions that, after replacing the right values, give me the eigenvalues, then fix n=4 and get 4 functions, etc.
Is this possible to do in maple?
I try to use a Catmull-Rom spline which has to match on several points.
I use a code extracted from the book "Geometry and curves with maple".
Here you can find an extract which is visible from google book :
I have slightly modified the initial procedure crom_2d. I didn't find the error in my procedure. May you help me to find the blocking point of my procedure ?
Here I attached my code:
CalculSplineMatmull-Rom.mw
I never expected that the reflected light direction of sun from moon in the sky would be so dificult to imagine ...
at the following article mentioned :
we derive an equation for the magnitude of the moon tilt illusion that can be applied to all con gurations of sun and moon in the sky.
THE MOON TILT ILLUSION
since the calculations contains many steps and high level mathematical formula , there is no way rather to recourse to maple (powerful math assistant )
I hope there was adaptations between a lots of functions and predefined schema of maple and this problem so that the calculations and visualization facilitated several times ?
your effort will be a graet present for all the people of the world that look to the moon crescent everytime !
I have some preferences for viewing. Specially, I prefer atomic variables to be showed with a different color. So I check mark the related option for this in the view menu. But every time I close and reopen the Maple, it just restore my setting for atomic variables. Suprisingly, this does not happen for other viewing options in the view menu! What should I do? Why is it like this?
First 211 212 213 214 215 216 217 Last Page 213 of 371
